[Sammelthread] Asus Sabertooth 990fx
Inhalt:
  • Spezifikationen
  • Bilder
  • Bios
  • Review´s / Test´s
  • Downloads
  • Kompatibilität
  • Preis
  • FAQ
Spezifikationen:
CPU
AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
Supports AM3+ 32 nm CPU
Supports CPU up to 8 cores
Supports CPU up to 140 W
AMD Cool 'n' Quiet™ Technology​
Chipset
AMD 990FX/SB950​
AMD 990FX/SB950
Memory
4 x DIMM, Max. 32GB, DDR3 1866/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture​
Expansion Slots
3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8) *1
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
1 x PCI​
Storage
AMD SB950 controller :
6 x SATA 6Gb/s port(s), brown
Support Raid 0, 1, 5, 10
JMicron® JMB362 controller :
2 x SATA 3Gb/s port(s), black
1 x Power eSATA 3Gb/s port(s), green
1 x eSATA 3Gb/s port(s), red​
LAN
Realtek® 8111E , 1 x Gigabit LAN Controller(s)​
Audio
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- Blu-ray audio layer Content Protection
- ASUS Noise Filter
- Optical S/PDIF out port(s) at back panel
IEEE 1394
VIA® 6308P controller
2 x IEEE 1394a port(s)
(1 at mid-board, 1 at back panel)​
USB Ports
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
14 x USB 2.0 port(s) (10 at back panel, black+red, 4 at mid-board)​
Special Features
ASUS Dual Intelligent Processors 2 with DIGI+ VRM
TUF ENGINE! Power Design :
- 8 +2 Digital Phase Power Design
- TUF Components (Alloy choke, Cap. & MOSFET; certified by military-standard)
- ASUS DIGI+ VRM Utility
- E.S.P. : Efficient Switching Power Design
Ultimate COOL! Thermal Solution :
- TUF CeraM!X Heatsink Coating Tech.
- TUF Thermal Radar​
ASUS Exclusive Features
- MemOK!
- AI Suite II
- Anti-Surge
- ESD Guards
- Front Panel USB 3.0 Support
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector​
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
1 x LAN (RJ45) port(s)
2 x USB 3.0
10 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)​
Internal I/O Ports
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x COM port(s) connector(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
4 x Chassis Fan connector(s) (3 x 4 -pin, 1 x 3 -pin)
1 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x Clear CMOS jumper(s)​
Accessories
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x TUF Certification card(s)
1 x TUF 5 Year Warranty manual(s) (by region)​
BIOS
32 Mb Flash ROM, UEFI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2,​
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities​
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )​
Bilder:
Bilder von Huddel (nochmals danke)
Bilder von JACK RABBITz
(Quelle: User Huddel, Asus, JACK RABBITz)
Bios:
(0402)
Review´s/Test´s
Deutsch
HWLUXX
hartware.net
pcgameshardware
Tom´s Hardware
Englisch
guru3d.com
hardwarecanucks.com
legitreviews.com
Downloads
ASUS Sabertooth Downloadbereich
Asus FTP-Server derzeit wieder mal offline :-(
Betabios 0607 -Fan ignore Bug gefixed, CPU-Lüfter Monitor lies sich nicht abschalten, dadurch kam eine Fehlermeldung beim Booten
Bios 0705
1. Enhance RAID expansion card compatibility.
2. Enable support for Spanish and Russian Language.
3. Enhance RAID0 performance with SB950 native SATA ports.
4. Enable support for UEFI RAID Driver to support RAID partition above 2.2TB
Bios 0810
Bios 0813
1. Improve memory compatibility
2. Improve system stability
Bios 0901
Probleme mit X6 CPU´s, Board startet nicht mehr!
Bios 1102
1.Improve system stability.
2.Enhance compatibility with some USB devices.
3.Patch system hanged when use AM3 1090T or 1100T CPU.
Bios 1208
Bios 1304
Bios 1503
Kompatibilität
Arbeitsspeicher
-Kingston HyperX 2133Mhz 4x 2GB
-G.Skill Ripjaws-X 8GB Kit
-G.SKILL 8GB Kit DDR3-1600 F3-12800CL8D-8GBECO / 1,35V
inkompatibler Arbeitsspeicher
-2x2GB G.Skill F3-10666CL8D-4GBRM 8-8-8-24 1,5v (kein Boot möglich)
Luftkühlung
-Prolimatech Megahalems (mit Retentionmodul)
Wasserkühlung für Chipsatz
Preis
HWLUXX
FAQ
Asus Supportforum
Ich hoffe das geht erstmal soweit (Ist mein erster Sammelthread :)), ich versuche alles aktuell zu halten, nun her mit den Erfahrungen und Informationen...
Ah, ok. Danke. Also richte ich mich nach der Haupttemperatur.
In dem Fall (habe die CPU am Wochenende feineingestellt) erreiche ich bei 1,4V (BIOS) (max 1,442V über CPU LLC) primestable über 6 Stunden 4,1GHz (241x17) und 61 Grad (CPU Temp CPUID Hardwaremonitor) max.
Ich könnte auch 4,2GHz (247x17) fahren, müßte allerdings im Bios auf 1,4375V gehen, was über LLC dann in 1,488V und 64 Grad endet. Hielt auch 6 Stunden durch, ist mir aber zu viel Spannung auf Dauer und auch zu warm. Geteste Werte bei 26 Grad Zimmertemperatur :fresse:
Nach diesen Festsellungen habe ich Maya rendern lassen. 3 Stunden ohne Fehler und danach noch 6 Instanzen Linx an einzelne Kerne gebunden und eine Instanz Prime 1 Stunde parallel werkeln lassen. Lief auch soweit. Ich gehe davon aus das das System zu 99% stabil mit diesem CPU Setting ist.
Maximaler Takt für einen Windowsboot liegt bei Bios-VCore 1,45V und 4,4GHz.
Heute kommt dann endlich der RAM mit der Feineinstellung dran. Genauer gesagt die Timings. Der Takt liegt nach endgültigem Test (wenn alle Settings außer Spannung erstmal auf AUTO bleiben) bei einem Maximum von 2050MHz. Ab 2100MHz gibts Prime- und Linxfehler. Die Spannung liegt dabei bei 1,62V. Die werksmäßig angegebene max von 1.65 lege ich auf keinen Fall an. Das ist mir zu heiß.
Da ich ohnehin den RAM-Takt dem CPU-Takt unterstelle, werde ich wahrscheinlich mit dem FSB von 241 bei ca. 1950MHz landen, was angesichts der 100MHz wohl nicht so tragisch ist und möglicherweise eine weitere Absenkung der RAM-SPannung zuläßt. Die Autosettings lagen mit CPUZ ausgelesen bei 11,11,11,28 und 1T. Und das sehe ich mir heute dann noch genauer an.
Wenn das dann steht, werde ich mir noch die Brücken-Taktraten zur Brust nehmen und dann alle Komponenten gleichzeitig einstellen und im Finaltest braten. Es kann ja sein, dass die Maximalwerte im Zusammenspiel dann nochmal einer kleinen Korrektur nach unten bedürfen aber das wird die Praxis zeigen.
Wenn ich mit allem durch bin gibts noch die UEFI Settings und Screenshots dazu.
*Ins Mainboard-Sammelthread Unterforum verschoben*
Kompatible DDRRAMs
@KeBeNe
Das G.Skill 8GB Kit [2 x 4GB]
DDR3-1600 Kit G.Skill F3-12800CL8D-8GBECO / 1,35V
kannst du auch in die Kompatibilitätsliste aufnehmen.
Ob Vollbestückung, also 2 Kits [4 x 4GB] möglich sind, bzw. problemlos laufen kann ich nicht sagen (mangels Ware ;)). Lt. QVL soll's aber möglich sein.
fuzzy
aktuallisiert...
Das Board scheint G.Skills zu lieben.
8GB G.Skill SNIPER Series F3-14900CL9D-8GBSR (2x4 GB) laufen bei mir total problemlos mit 1600 MHz-Taktung. Jetzt kann Bulli kommen :cool:
wollte die G:SKILL eintragen, aber nun laufen sie wohl doch nicht -> KLICK
Was gab es noch für Probleme?
Was hast du dir nun geholt?
Ja, stimmt, man soll den Tag nicht vor dem Abend loben. G-Skills sollen laut Handbuch kompatibel sein, von einem Tag zum anderen traten dann doch die benannten Probleme auf.
Weitere Probleme, die ich mit dem Board hatte: CPU wurde schlecht heruntergekühlt, hatte meist im Idle 50 Grad. USB-Probleme mit der Razer Lachesis, die an einigen USB-Boards nur sporadisch erkannt wurden.
Das Asrock, das ich jetzt habe ist da um Längen besser. Temperaturen liegen im Idle bei 30-35 Grad (gleicher Lüfter) und die Maus funzt problemlos.
Geholt habe ich mir das Asrock 970 Extreme4, ist seit gestern eingebaut, läuft bisher problemlos (aber wie schon gesagt, man soll den Tag nicht vor dem Abend loben).
ja, danke für die Erklärung, das mit der Lüftersteuerung kann ich nicht beurteilen, da Wakü, mit dem USB, naja, da kann man halt pech haben, wie mit den RAM´s.
Aber das AR ist bestimmt recht gut, habe/hatte auch diverse AR Boards und war/bin höchst zufrieden damit.
Hallo Leute,
vieleicht hat hier jemand eine idee. ich hab ein problem. und zwar hab ich auch das uefi bios drauf. der rechner lässt sich ins bios starten und dort lassen sich die laufwerke erkennen und im bios flash prog sogar ansprechen. wenn ich jetzt einen boot vorgang starten will fährt der rechner durchs bios und bleibt dann stehen, mit dem blinkenden cursor oben links in der ecke. die laufwerke werden nich angesprochen ( weder hdd noch dvd-rom ).
vielleicht hat einer von euch eine lösung parat oder so ein phänomen schon mal gehabt.
als hardware kommt zum einsatz:
asus sabertooth 990fx
phenom II X6 1090T
Corsair DIMM 4 GB DDR3-1333 Kit cmz8gx3m2a1600c9
geforce 465 gtx
und dann noch das übliche eine hdd s-ata und ein dvd-rom s-ata
wassergekühlt
inklusive aktuellem bios vom 11.06.2011
ich häng da mittlerweile seit einer woch drüber und komm nicht weiter !!!!!
gruss Blade1976
hast du nur einen Riegel drin?
Finde unter der Bezeichnung nur 2x4gb, also 8gb Kit.
Sind alle Einstellungen Manuell vorgenommen worden, also RAM timings etc.
Nur mal einen Riegel drin gelassen?
Leuchtet die DRAM LED?
RAM Bänke durch probiert?
Mal einen CMOS Reset machen, im Bios auf Settings-default stellen und mal Starten, dann die Speichersettings neu manuell durchführen.
mfg René
@kebene ja hab ich auch schon ausprobiert. mit einem, mit zwei oder mit vier riegeln keinen effekt. das bios hab ich schon zigmal zurück gesezt und auch upgedatet. die effekte waren null immer noch das selbe problem
gruss mark
mal andere RAM´s probiert? (mit Corsair hatte ich auch schon massiv Probleme, die brauchen recht hohe Spannungen, bei meinen Stand 1,6V drauf, unter 1,7V startet der Rechner nicht, die gingen ganz schnell wieder zurück und dann paar "ordentliche" gekauft)
Ich gehe mal davon aus das der 8Pol Stecker am Board angeschlossen ist.
Wenn alles nicht geht, Board zurück, dann wird das einen Defekt haben.
ja hab ich auch schon alles probiert. ich hab anscheinend wirklich eins von den defekten boards erwischt. mein dealer wird sich freuen wenn ich morgen meinem frust luft mache. in dieser preiklasse darf sowas nicht passieren.
Ist wohl ein NEUES!! -->>> Übrigens auch schon auf der Hompage herunterladbar!!
http://www.asus.com/Motherboards/AMD_AM3Plus/SABERTOOTH_990FX/#download
SABERTOOTH 990FX 0705 BIOS
4. Enable support for UEFI RAID Driver to support RAID partition above 2.2TB.
:bigok:
oki doki
fuzzy
@KeBeNe
Bitte in post #1 verlinken! BIOS 0705
danke,
soeben passiert...:wink:
Hallo zusammen
Frage wie sieht es denn so mit den NB Temp's aus???
Eine fullcover Wakü gibt es ja noch nicht soviel ich weiß Oder?
Danke vorab
MfG
Hi Jungs,
so hab meins nun auch in Betrieb genommen.
Als Speicher hab ich Corsair Vengeance drin 2 x 4 GB
CMZ8GX3M2A1866C9
Reingestöpselt und rennt.
Feintuning kommt später dann kann ich auch mal Pic's machen.
CPU ist eine BE 965 die läuft gerade mit 3500 MHZ bei 234 Busspeed und 1.368 Volt. Ist aber Zufall, ich muss mich erst mal durch das BIOS wühlen.
Als Kühlung ist da im Moment ein Katana III drauf, der passte auch knapp über den RAM. Da muss ich tätig werden.
Was ich im Moment nicht ganz verstehe sind die Lüfteranschlüsse das Boards.
Da sind ja 2 verschiedene Versionen drauf. Die PWR
( CHA_Fan3 / CPU_Fan / CPU_Opt ) sind klar, aber den anderen versteh ich nun nicht so recht.
CHA_Fan4 ist dann doch ein ungeregelter. ???
Leider hab ich nun feststellen müssen das der EATX Stecker da oben schlecht platziert ist. Dadurch das der so hoch ist, werde ich wohl keine WaKü in mein Corsair 400 R rein bekommen.
Weiß jemand von Euch ob es da abgewinkelte Stecker gibt ??
Grüße
Dummbatz
Kann mir jemand sagen, ob das Board die Lanes für die beiden erdfarbenen PCIe-Ports reduziert, wenn man eine Soundkarte in einen der beiden anderen PCIe-x16-Slots steckt?
Habe eine Auzentech Forte und kann den PCIe-x1 ja so nicht nutzen...
Ich meine gelesen zu haben dass beide Slots x16 haben und auch behalten.
Schau doch vorsichtshalber nochmal im Handbuch nach.
grEEtz
fuzzy
Da stehts ja eben nicht drin, zumindest habe ich das dort nicht gefunden.
Da ist nichtmal PCie-16_2 betitelt, und CF nur max auf Tripple ausgeführt (Tabelle).
Wie gesagt, max. Tripple ausgeführt und nicht betitelt, welche Slots beteiligt sind. Die Tabelle ein paar seiten später führt für den PCIx16_2 immer N/A aus ;-)
Edit: Des weiteren wird das Board überall als 16/16/8/8 gelistet (z.B. Geizhals).
Nö, hab das Board ja nicht :fresse:
Will aber noch in den nächsten Wochen, sobald Bulldozer raus ist und die "Regierung" abgenickt hat, ein neues System aufbauen. Nur fehlt mir bisher das Board. Und von den aktuell verfügbaren bin ich letztlich bei 4 Boards hängen geblieben: das Sabertooth, das MSI GD80 und das Gigabyte UD5/UD7. Beim MSI könnte ich 2 Grakas und die Soundkarte ohne Einbußen einsetzen, habe aber etwas weniger Anschlussmöglichkeiten am Backpanel.
Beim Gigabyte UD7 hätte ich das "Problem", dass das Board durch einen starken V-Drop besticht.
Beim UD5 könnte ich den PCIe-x4 nicht nutzen, da der Chipsatzkühler zu hoch ist. Zudem würde PCIe 16_2 auf x8 reduziert, wenn in den x8-Slot was eingesteckt wird. Fällt also auch raus.
Demzufolge bin ich derzeit zwischen dem Sabertooth und dem MSI GD80 hin und hergerissen ;-)
Wenn also das Board den PCIe x16_2 normal nutzt und die Bandbreite des/der anderen Slots nicht beeinflusst wird, wäre es meine erste Wahl.
Edit: Laut der hartware.net-Review ist nur der dritte x16 mit dem x16@x8 darunter verknüpft, während der zweite x16 dauerhaft auf 4 Lanes beschränk ist. Das wäre doch garnicht mal schlecht...
Edit2: Die Hardwareluxx-Review sagt ebenfalls, dass der zweite x16 dauerhaft auf x4 läuft. Also wird es wohl nach Jahren wieder ein Asus-Board.
Sehr gute Entscheidung!
Bin auch sehr zufrieden mit dem Board, obwohl es momentan nicht im Einsatz ist da ich das Case (BigTower) in dem es verbaut war verkauft habe und morgen das neue (MidiTower) Lian Li PC-V1020A kommt. :banana: :banana:
oki doki
fuzzy
Das soll mein neues System werden
CPU AMD Phenom II X6 1090T
Arbeitsspeicher Corsair DIMM 8 GB DDR3-1600 Kit
CPU-Kühler Scythe Mugen 3 PC Games Hardware Edition CPU-Kühler
ASUS SABERTOOTH 990FX
Grafikkarte ZOTAC GTX560 Ti
Netzteil OCZ ModXStream Pro 500W
Kosten Ca 700 Euro
Irgendwelche Verbesserungsvorschläge.
Ich muss zugeben war jetzt zwei Jahre weg vom Hardware-Markt
Gruss Marco
Ist das Board gut? Bin eigentlich echt von Asus überzeugt
Thx an marjo für den Link.
Mal paar Fragen von mir zu einigen Sachen.
Welche Temperaturen habt Ihr für Vcore1 und Vcore 2
ebenso für die USB Chips ??
Ich betreibe das Board gerade mit 3 Lüftern und hab da etwas seltsame Ergebnisse, was aber auch an meinen Einstellungen liegen kann.
Dann zur der Lüfterreglung, sehe ich das richtig das ich zwar ein Haufen PWM zur Verfügung habe, aber regeln kann ich nur CPU einzeln und alle Gehäuselüfter zusammen ??
Was ausgesprochen schade wäre wenn man schon so viele Sensoren zur Verfügung hat.
Und bevor ich mir nun weitere Gehäuselüfter einbaue, würde ich das gerne wissen, das macht ja schon im Preis was aus ob PWM oder einfache.
@KeBeNe,
Wie kühlst Du den den Bereich um die CPU ?? Hast du trotz Wakü noch Lüfter dran ??
Thx
Dummbatz
