Wie kommen die jetzt auf die 128 Shader? Das ist genau daß was die 8800GTX hatt, der R600 sollte 64 Vec4 Shader bekommen.
Cebit ist definitiv der Launch oder?
aha qool das du ja schon weisst das der vermeintliche g81 morgen im regal steht![]()
ABER
Ich hoffe der R600 haut alles weg, dann hab ich ja auch was davon.
Grüße
Sascha
VR-Zone has learned that the official marketing name for R600 will be Radeon X2900 series and we will start using the name from now on. We can expect AMD to launch Radeon X2900XTX and XT first while X2900XL will follow later. The recent leaked R6xx series chart with pricing contains lots of false information is all we can say. RV610 and RV630 are 65nm and RV610 has 64-bit memory interface.
Among other things we can confirm right now; R600 is 80nm, contains 700M transistors and has 512-bit memory interface. X2900 requires 2 supplemental power connector from the PSU, one 8-pin and one 6-pin but you are able to plug in the 6-pin power cable into the 8-pin connector. The targeted driver release version for X2900 series is Catalyst 8.35.1. Systems with X2900XTX cards and tech demos will be at CeBIT but inside a private room for the privileged only.
http://www.vr-zone.com/?i=4672
X2600 XT
64
650
1600 MHz
128 Bit
8600 GT
650MHz
1800MHz
64
128bit
8800 GTS
500MHz
1600MHz
96
320bit
X2800 XL
96
600/900 MHz
512 Bit
512 MB
GDDR3
Ich glaube ATI schlägt aber derbst zurück.
NQ reported that R600 architecture will utilize PCI Express x16 connection to the fullest by delivering both video and audio content using HDMI. R600 board will be shipped with at least one DVI-to-HDMI dongle, with DVI serving as the bandwidth provider for video and audio. R600 chip has the bandwidth to drive not one, but two HDMI ports at the same time with resolution at 1920x1080 (1080p or 2560x1440 (1440p).
Kannst du ja auch so schon. DVI auf HDMI ist sowieso kein Problem und HDCP Support gibt es auch in diesem Fall. Ein Adapter -besser: Ein Kabel von DVI auf HDMI- kostet ja nun auch nicht die Welt. Eine Voraussetzung für gute Qualität ist, dass der LCD- oder Plasma TV nativ digital angesteuert werden kann. Ich fände den R600 schon interessant, aber ich befürchte, ATI wird es auch diesesmal nicht schaffen, Scalingfunktionen über die Grafikkarte bereitzustellen. Warum Sie das seit Jahren (!) nicht machen, wird mir ewig ein Rätsel bleiben. Es gibt leider genügend Computer LCDs ohne vernünftigen Scaler.Dann könnte man den R600 locker am TV mit guter Qualität anschließen.
Wollte damit nur sagen, dass eine vernünftige Ansteuerung schon mit eigentlich jeder halbwegs aktuellen Grafikkarte möglich ist (kann man auf HDCP verzichten, ist die Auswahl dann fast grenzenlos). Statt des Adapters hätten sich die Ingenieure bei ATI lieber mal um die Scalinggeschichte kümmern sollen.Ja eben.
1080p60 braucht sowieso nur SingleLink DVI. Interessante Modi, wie 1080p24/48, sind vom Limit noch weiter entfernt.R600 chip has the bandwidth to drive not one, but two HDMI ports at the same time with resolution at 1920x1080
Irgendwie wird das nichts bei AMD/ATI.
Release jetzt anscheinend noch nichtmal zur Cebit.
, also du brauchst dir kein neues holen.
...........mfg C-P
