ATI Radeon HD4000 (R700) - [Speku-, News- & Sammelthread] (Part2)
Alles rund um die ATI Radeon HD4000 Grafikkartenserie
Vorraussichtliche technische Daten:
HD 4870 (RV770XT), 55 nm, 850 MHz Chiptakt, 1050 MHz Shaderdomain, 1935 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 1008 GFlops, 27.200 MT/s, 256 Bit Speicherinterface, 1024 MiB GDDR5, 123,8 GB/s Speicherbandbreite, 150 W TDP, $349 MSPR, Release Mai 2008
HD 4850 (RV770PRO), 55 nm, 650 MHz Chiptakt, 850 MHz Shaderdomain, 1728 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 816 GFlops, 20.800 MT/s, 256 Bit Speicherinterface, 512 MiB GDDR5, 110,5 GB/s Speicherbandbreite, 110 W TDP, $269 MSPR, Release Mai 2008
HD 4850 GDDR3 (RV770PRO), 55 nm, 650 MHz Chiptakt, 850 MHz Shaderdomain, 1143 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 816 GFlops, 20.800 MT/s, 256 Bit Speicherinterface, 256/512 MiB GDDR3, 73,2 GB/s Speicherbandbreite, 110 W TDP
Quelle: Hartware.de
NEWS:
More RV770 and RV770X2 details
Die shrink with minor changes
ATI said a few things about its new upcoming RV770 chips, and as we've said before you can expect [...]
weiterlesen
RV770 will do GDDR 5 and GDDR3
Two flavours
We’ve learned that single chip RV770 card comes in two flavours. The first one [...]
weiterlesen
RV770XT supports 512-bit memory
Despite the claims
A German Website posted an interesting article with a lot of RV770XT and PRO specs, but [...]
weiterlesen
R700 to launch close to Computex
Or around, at leastRV770 chips are looking good and the highest end R700 based product might launch around Computex (starts at June 3 2008). We believe [...]
weiterlesen
RV770 is already in production
Test one
We learned
that the RV770 GPU already went to production and there is a big chance to see R700 generation much earlier than anyone [...]
weiterlesen
Bilder
X2 Kühler
770XT Kühler
770 Pro Kühler
Wer noch interessante Links hat, bitte per PN an mich weiterleiten!
ja, denke aber auch dass es bereits einige gesicherte AMD-ATI Infos
am 16.ten Juni sehr spät abends/ 17-ten früh vormittags geben wird um
NV Startschuss zur GTX ein wenig zu stören.
Dann der offizielle Release der 4850 GDDR3 und 4870 GDDR5 wird am 25.06. sein, mit reichhaltiger Verfügbarkeit aller Karten!!
Will noch einmal fragen wierd es noch eine 4850 mit ddr5 geben oder nur die ddr3 version
Ich würde ja am besten die 4850 am 15. veröffentlichen da die sicher ausreichend(!) verfügbar ist um so ordentlich Geld zu scheffeln.
Und am 25. dann die 4870 mit 1GB GDDR5 veröffentlichen die dann für 230 Eur und keiner würde mehr eine Nvidia wollen^^
4870 mit 1GB GDDR5 für 230, ... das glaubst auch nur du, ... da kostet allein der Speicher so viel *gg*
So mit ca. 300€ wird man schon rechnen müssen.
Die 4870 Gddr5 kommt bestimmt erst in 2 Monaten.Ati hatte schon immer mit neuen sachen schwierigkeiten wort zu halten....
Ne, auch mit GDDR3.
Hinzugefügter Post:
Die HD4850 wirds auch mit GDDR3 und 5 geben.
Sicher? Ich dachte, dass ich es auf einer Folie so gesehen hätte. Das mit den 1GB und 512MB wusste ich schon.
Es kann aber auch sein, dass ich mich irre, bei all den vielen Spekulationen. Ich finds zum :kotz:, dass es noch immer nix Offizielles gibt. :grrr:
ja davon kann man ausgehen,sonst wäre der performance abstand viel zu klein zwischen den beiden karten.
Die Computex ist ja auch schon zu Ende und man hat nix erfahren, weder von ATI noch von NV.
Hab ich das nun richtig verstanden, dass es die 4870er als 512MB Version sowie als 1024MB Version geben wird? Und beide dann am 25.?
Aha....und ist nun schon bekannt in welchem Zeitraum sich "später" bewegen soll? :)
Wenns stimmt das der R700 von dem System als Single Gpu erkannt wird, könnte man dann auch 4GPUs (2xR700) unter Xp zum laufen bringen?
Man kann auch jetzt schon 2xR680 unter XP zum laufen bringen, da DX9 aber ein Prerenderlimit vom 3fps hat hilft das nichts.
Schon klar aber würden die 4Gpus arbeiten wie zwei wäre das ja kein problem.
Oder ist das nicht möglich bzw könnte es mit den "angenommenen" Änderungen die im Raum stehen möglich sein?
Die Karten berechnen ja immer noch gleichzeitig, und nicht wie eine GPU. Es wird wahrscheinlich nur die Ausgabe synchronisiert und nicht die Chips zusammengeschlossen. Das wäre ein wenig umständlich.
die mikroruckler haben andere ursachen als der VRAM.
Ja, fehkende Kommunikation ist die Ursache! Und um dies zu ermöglichen, wird der Speicher "missbraucht"... Wenn das auch mit einem anderen PLX-Chip gehen würde, wäre es dasselbe! Der VRam wird nicht als Ursache dargestellt, sondern als Lösung;)
