ATI Radeon HD4000 (R700) - [Speku-, News- & Sammelthread] (Part2)
Alles rund um die ATI Radeon HD4000 Grafikkartenserie
Vorraussichtliche technische Daten:
HD 4870 (RV770XT), 55 nm, 850 MHz Chiptakt, 1050 MHz Shaderdomain, 1935 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 1008 GFlops, 27.200 MT/s, 256 Bit Speicherinterface, 1024 MiB GDDR5, 123,8 GB/s Speicherbandbreite, 150 W TDP, $349 MSPR, Release Mai 2008
HD 4850 (RV770PRO), 55 nm, 650 MHz Chiptakt, 850 MHz Shaderdomain, 1728 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 816 GFlops, 20.800 MT/s, 256 Bit Speicherinterface, 512 MiB GDDR5, 110,5 GB/s Speicherbandbreite, 110 W TDP, $269 MSPR, Release Mai 2008
HD 4850 GDDR3 (RV770PRO), 55 nm, 650 MHz Chiptakt, 850 MHz Shaderdomain, 1143 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 816 GFlops, 20.800 MT/s, 256 Bit Speicherinterface, 256/512 MiB GDDR3, 73,2 GB/s Speicherbandbreite, 110 W TDP
Quelle: Hartware.de
NEWS:
More RV770 and RV770X2 details
Die shrink with minor changes
ATI said a few things about its new upcoming RV770 chips, and as we've said before you can expect [...]
weiterlesen
RV770 will do GDDR 5 and GDDR3
Two flavours
We’ve learned that single chip RV770 card comes in two flavours. The first one [...]
weiterlesen
RV770XT supports 512-bit memory
Despite the claims
A German Website posted an interesting article with a lot of RV770XT and PRO specs, but [...]
weiterlesen
R700 to launch close to Computex
Or around, at leastRV770 chips are looking good and the highest end R700 based product might launch around Computex (starts at June 3 2008). We believe [...]
weiterlesen
RV770 is already in production
Test one
We learned
that the RV770 GPU already went to production and there is a big chance to see R700 generation much earlier than anyone [...]
weiterlesen
Bilder
X2 Kühler
770XT Kühler
770 Pro Kühler
Wer noch interessante Links hat, bitte per PN an mich weiterleiten!
habe auch in irgendeiner news so etwas gelesen glaube es handelte sich aber um eine 3890 und 4830
moin!
gigabyte soll irgendwelche schachteln von ner 3890 und ner 4850 am stand bei der computex gehabt haben. auf der 3890 packung stand soweit ich weis das gleiche an daten drauf wie bei der 4850, außer halt 3890.
Also kein großer Unterschied, der gleiche Chip dann sozusagen?! ;)
mal guggen, ich denke mal ein ziemlich abgespeckter, der dann gegen 8800(gts 320, also die performancetechnisch unter der 98GTX) oder so geht, ich find die news grad nimmer. aber ich denke es wird auch noch 46x0 karten geben für die untere mittelklasse oder so
€: - ja gut äh sicherlich äh es ist völlig klar äh ich will nen Arctic Accelero Extreme 4870X2 haben!!!! http://de.youtube.com/watch?v=2Y88iSiI5ME -​
was mich auch interessiert, ob ich ne 512er Ram Karte und ne 1gb Speicherkarte zusammenlaufen lassen kann.
Ich dachte mir zum Release eine mit 512 zu kaufen und sobald eine mit 1gb verfügbar ist die dann im CF laufen zu lassen. Macht dann ja summasumarum 1,5 GB Speicher, oder teilen die sich den Speicher dann nicht?
Ich dachte mir zum Release eine mit 512 zu kaufen und sobald eine mit 1gb verfügbar ist die dann im CF laufen zu lassen. Macht dann ja summasumarum 1,g GB Speicher, oder teilen die sich nicht den Speicher dann?
4850 oder 4870? ich denke den speicher teilen sich die NUR auf der 48x0X2, aber ich denke schon das du die beiden zamlaufen lassen kannst, bei 3870 und 3850 geht das ja auch, cf-x sei dank^^
@Grinsemann
denk mal das jede ihren eigenen speicher verwendet .... bei der X2 sollen beide gpus auf einen speicher zugreifen können
HD3890 800SP´s 775Mhz/1250Mhz 512MB GDDR4 256Bit
oder
HD3890 320SP´s 775Mhz/1900Mhz 512MB GDDR5 256Bit?
Oder was soll das werden mit der Karte.
@grinsemann
die Karte wird mit sicherheit im Cf laufen,wird aber mit sicherheit den zusätzlichen speicher nicht benutzen,gleicht sich also an
ja eben - mein x38 Board soll sich ja lohnen mit 2x 4870ern...sehe gerade wir haben das Gleiche.
....nur mein Bedenken ist, dass dann evtl die 1gb Karte von der mit 512 ausgebremst wird^^Die Leistung richtet sich ja immer nach dem schwächsten Glied in der Kette...sollte das nicht funzen kaufe ich mir gleich zwei mit 512.
oder
??? wie meinst du das?
naja, das sollte schon gehen, ham beide die selben daten nur die speichergröße ist halt anders. Asus Maximus Formula X38 meinste das?^^
@grinsemann
ahja, siehste - genau das meinte ich THX :(:kotz::heul:
Na eine HD3890 ist doch im gespräch und Gigabyte hat eine verpackung gezeigt wo angeblich die selben daten drauf standen wie bei der HD4850.
Daher mein gedanke man nehme das ALT PCB und schnalle dort eine Neue GPU drauf damit die Restbestände auch noch wegkommen.
es wird eher restbestände der gpus geben, die ati schnell weghaben möchte, kann ja sein, das es nur ne aufgemotzte 3870er is sonst würde das ja ne 46xx sein müssen für die untere mittelklasse
es wird keine 1gb oder 512 versionen geben - jedenfalls nicht offiziell.
Aktuell wird es 750 gddr5 speicher sein.
:bigok: ja , dann wäre ich ja da wo ich hin wollte,
aber wo steht das?
Crysis benches sind dazu gekommen von jimmyz
1680 x 1050 no aa high settings card stock
http://www.xtremesystems.org/forums/showpost.php?p=3059795&postcount=3
leider nur in DX9 da : I had immense problems with crysis benchmark utilities on 64 bit ultimate. the bench app would start the game at the july 7 screen and proceed to be the game not the beach flyover that it should be. I re-installed twice, both the game and applications as well as the patch. also tried without the patch. any advice is welcome. On XP it runs fine though so lets see how it fares.
ob das ergebnis jetzt allerdings gut ist darüber lässt sich streiten :fresse:
na dann testet mal jemand die 3870 unter den selben voraussetzungen wie die 4850 im test, dann kann man (besser) vergleichen. hat jemand nen QX9650 yorki auf 4ghz mit 3870 auf XP grad da zum vergleich?^^
denke schon und wenn nicht dann eben ein sehr weit fortgeschrittener beta treiber
mitte/ende juni sollte ati schon die 8.6 final draussen haben
Na ja ganz so einfach ist das auch nicht. Meist sind dann doch die Anbindungen der GPU sehr unterschiedlich auch von den mappings her.
Nur so zur Info : ein BGA-Tausch (GPU sind BGA Prozessoren) kostet ca. 15-20 Euro in 1er Stückzahlen, wenn du zu einem Professionelen fertiger gehst. D.h. man könnte ja sonst ne 3650 kaufen und für 20 Euro den 3870 GPU (von ner defekten Karte) aufbringen lassen.... na ja sehr sinnloses unterfangen :)
Aber was ich sagen wollte... in den meisten Fällen, ist das nicht so einfach also nur ne andere GPU zu bestücken und dann haste ne andere Karte. Die Layouts und Schematics haben meist doch größerer Unterschiede als nur die GPU :P
Soll das A12 Stepping sein vom RV670
