ATI Radeon HD4000 (R700) - [Speku-, News- & Sammelthread] (Part2)
Alles rund um die ATI Radeon HD4000 Grafikkartenserie
Vorraussichtliche technische Daten:
HD 4870 (RV770XT), 55 nm, 850 MHz Chiptakt, 1050 MHz Shaderdomain, 1935 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 1008 GFlops, 27.200 MT/s, 256 Bit Speicherinterface, 1024 MiB GDDR5, 123,8 GB/s Speicherbandbreite, 150 W TDP, $349 MSPR, Release Mai 2008
HD 4850 (RV770PRO), 55 nm, 650 MHz Chiptakt, 850 MHz Shaderdomain, 1728 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 816 GFlops, 20.800 MT/s, 256 Bit Speicherinterface, 512 MiB GDDR5, 110,5 GB/s Speicherbandbreite, 110 W TDP, $269 MSPR, Release Mai 2008
HD 4850 GDDR3 (RV770PRO), 55 nm, 650 MHz Chiptakt, 850 MHz Shaderdomain, 1143 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 816 GFlops, 20.800 MT/s, 256 Bit Speicherinterface, 256/512 MiB GDDR3, 73,2 GB/s Speicherbandbreite, 110 W TDP
Quelle: Hartware.de
NEWS:
More RV770 and RV770X2 details
Die shrink with minor changes
ATI said a few things about its new upcoming RV770 chips, and as we've said before you can expect [...]
weiterlesen
RV770 will do GDDR 5 and GDDR3
Two flavours
We’ve learned that single chip RV770 card comes in two flavours. The first one [...]
weiterlesen
RV770XT supports 512-bit memory
Despite the claims
A German Website posted an interesting article with a lot of RV770XT and PRO specs, but [...]
weiterlesen
R700 to launch close to Computex
Or around, at leastRV770 chips are looking good and the highest end R700 based product might launch around Computex (starts at June 3 2008). We believe [...]
weiterlesen
RV770 is already in production
Test one
We learned
that the RV770 GPU already went to production and there is a big chance to see R700 generation much earlier than anyone [...]
weiterlesen
Bilder
X2 Kühler
770XT Kühler
770 Pro Kühler
Wer noch interessante Links hat, bitte per PN an mich weiterleiten!
Hmmm....
Wenn ich mir das alles hier so anschaue dann werde ich mir wohl nächsten Monat ein X48 Board mit einer 4870er holen. :d
Hatte schon lange keien ATI mehr, freue mich drauf !
Crysis benches sind dazu gekommen von jimmyz
1680 x 1050 no aa high settings card stock
http://www.xtremesystems.org/forums/showpost.php?p=3059795&postcount=3
leider nur in DX9 da : I had immense problems with crysis benchmark utilities on 64 bit ultimate. the bench app would start the game at the july 7 screen and proceed to be the game not the beach flyover that it should be. I re-installed twice, both the game and applications as well as the patch. also tried without the patch. any advice is welcome. On XP it runs fine though so lets see how it fares.
ob das ergebnis jetzt allerdings gut ist darüber lässt sich streiten :fresse:
Eine normale 3870er macht da ca. 26FPS damit ist die 4850er 35% schneller als die 3870er in dem Test.
mach mal bitte mit aa und af. :bigok: und mal ne frage weiß jemand wieso ich diesen benchtool starten kann,bei mir startet der wenn ich run drücke einfach das game.
Hat jetzt auch das ganze mit AA und bin beeindruckt die Werte gehen nicht unter 10FPS, meine damit die MinFPS selbst bei 1900 x 1200 @4xAA:
Stimmt, .. aber was willste mit 19 avg ;( ..... das ist mager für "nur" DX9 und "High"
Treiber reißen da hoffentlich noch was!
Also, die 4850 ist auf 88ULTRA Niveau @stock und wird es ab 160 Eur geben die 4870 wird wahrscheinlich schneller als "nur" 30% gegenüber der 4850 !
Also ich vermute das die 4870 nahe kommt an die GX2, hoffen wirs es ;)
Hinzugefügter Post:
Wo bleibt "Derguru", juckt es dir schon in den Fingern ?!
Also ich vermute das die 4850 nahe kommt an die GX2, hoffen wirs es ;)
Hinzugefügter Post:
du meinst die 4870, nehm ich an, oder?^^
PS: scrollt mal bei dem ebay link (hier klicken) runter, da stehen 800 shaderprozessoren!!!
ich sag ja nur^^
jop, ich hoffe das ja auch^^
und die 800 shaderprozis hat se womöglich auch noch, BAMM^^ (ich kanns net oft genug sagen xD)
800s war doch im endeffekt klar, gabs ja schon etliche folie dazu.
aber das die 4850 in crysis ultra werte hat ist doch sehr gut,weiß gar nicht was die nörgler wieder wollen. hier haben einige echt ein rad ab.
ach ja die 4850 macht ja nur 19fps:p
Jake Dunn:
GENAU, die 4850 ist auf ULTRA Niveau und das mit dem 8.5 Treiber, dazu @stock mit OCen dürfte schon mehr drinn sein. Passt auch, zwei 4850 sind ja auf 280GTX Niveau ^^
Das wird nen kracher. Aber ich hoffe ATI liefert gleich die 4870 mit 1GB GDDR5 aus in genügender Stückzahl. Weil bisher wurde noch keine gesichtet das macht mir bissl angst. CIh sag nur 8800 GT @release, das war nen desaster.
Genau richtig guru was regen sich manche hier auf euch ist schon klar wenn sie in crysis 8800Ultra werte hat das sie etwa noch 15%-20% schneller als diese ist denn CRYSIS ist ja von nvidia mit optimiert worden :wink:Soulja
@Derguru:
Juckt es dich in den Fingern, hast sicher bemerkt das man die 4850 kaufen kann ^^
Zumindest sieht man das die KArten @stock potenzial haben, die min FPS sidn sehr gut und wie schon gesagt wurde zieht sie gleich mit einer 8800 Ultra..
Wenn man sich jetzt noch einen Accelero raufschnallt und das "Kärtchen" über ~900mhz clockt hat man für 160€ ne Hammer Leistung :d
Am besten gleich zwei von der Sorte für 320€, dann kann NV gute Nacht sagen in sachen P/L und Lautstärke (falls der S1 passen sollte).
Jep, und eine GTX280 scheffel ca. 60FPS bei 1680x1050@High und kostet.....
€:...eine gute 4870er DDR5 sollte bei knapp 45FPS liegen :d
