Zikonov
Die Tatsache, dass nur 4 Zeilen für Stats vorhanden sind, nervt tierisch...
---------- Beitrag hinzugefügt um 01:05 ---------- Vorheriger Beitrag war um 00:51 ----------
Es ist gefixt
weitere Infos zum Patch:
Es ist gefixt
The update is out now on Xbox 360, “soon” for PS3 and “in progress in and in testing” for PC. Read on for the full fix list.
Characters that have lost skill points will have them returned the next time they are loaded
Most instances involving character data loss when playing online should no longer occur
Item cards now display the intended five lines of text
Achievements should now unlock properly. Players should automatically receive achievements that did not unlock correctly
Fixed a progression issue in the Find Steele mission – characters affected by this issue should now be able to continue progressing
Some issues involving external data manipulation of the backpack and character level have been addressed
The auto-aim option should now fully disable auto-aim properly
Fixed a bug that kept challenges and achievements from unlocking for the rest of a session after visiting arenas
Fixed some formatting issues with the server list screen.
Fixed an issue causing servers to report the incorrect plot mission.
Proficiency progress to the next level should no longer be lost when leaving a multiplayer game as a client
Lilith’s “Silent Resolve” skill now works as intended
Fixed a bug that allowed Mordecai to spawn multiple Bloodwings
Mordecai’s “Loaded” skill now increases mag capacity by 20%
Roland’s “Scattershot” skill has had its spread adjustment corrected, and damage now increases at +5 per level
