muhmaster
- Ort
- BRD - Hamberge
- Desktop System
- WhiteShadow
- AMD Ryzen 7800X3D
- Asrock B650E Steel Legend
- Thermalright Peerless Assasin 120
- Corsair Vengeance 6000 30CL
- Nvidia Geforce 4060Ti 16GB
- Gigabyte M32UC 4K + Dell 2716DG 2K + BenQ XL 2411 1080P
- 1TB WD_Black SN850X + 2x 2 TB WD_Black SN850X
- Soundkarte
- Soundblaster G6
- Fractal Meshify 2 RGB
- Bequiet Straight Power 12 850W
- Windows 11 Pro
- Webbrowser
- Thorium Browser
- Internet
- ▼250Mbit SV ▲40 Mbit
When I click "Play Civilization V", I cannot select the DX10/11 option
If you have a system that can play the DX10/11 version (Vista and Win 7), but the launcher will not let you select it (the DX10/11 button looks messed up, like text is overlapping other text), you need to switch the compatibility mode of Steam.
1. Quit out of Steam.
2. Right-click on the Steam.exe application (found in the Steam installation folder) and select "Properties", then select the "Compatibility" tab.
3. At the bottom of this tab is a button called "Change Settings for All Users". Click it.
4. Change the compatibility mode to AT LEAST "Windows Vista Service Pack 2".
5. Relaunch Steam.
This should correct this particular problem for you. When you install steam on 64-bit system, or on a different drive than "C", Steam will sometimes relegate itself to "Compatibility Mode" which can cause bad things to happen.
Thanks, and let me know if you have any problems.
1. Steam starten
2. Bibi anklicken
3. Civ 5 mit rechtsklick anwählen -> Einstellungen klicken
4. Sprache Deutsch wählen
5. Rechner neu starten
6. Wieder Steam starten
7. Download wird automatisch gestartet sobald beendet Civ 5 starten
tada.... Menüführung Deutsch
ist aus dem civ 5 forum vllt. hilft dir das, Ich spiele auf deutsch mit dx 10
