[Sammelthread] Crysis Performance & Tweaking
Na gut dann machen wir es mal einfach, so sieht die autoexec.cfg aus :coolblue:
; |Helder [HP] Pinto - Very High Quality Costum Config 1.3 FINAL |
; |This config has been tweaked to run Crysis withtin it's maximum beauty, |
; |while still getting minimaly smooth/playable FPS! |
; |Minimum System recomended is a Nvidia 8800, 2GB RAM and a fairly good dual core CPU. |
; |C&C: http://crymod.com/thread.php?threadid=13790 |
; User Options commands
con_restricted = 0
r_displayinfo = 0
r_VSync=0
d3d9_TripleBuffering=0
e_screenshot_width = 4096
e_screenshot_height = 3072
e_screenshot_quality = 100
e_screenshot_file_format = jpg
; Post Processing
r_ColorGrading = 1
r_DepthOfField = 2
r_MotionBlur = 1
; Shaders and Lighting
r_EyeAdaptationBase=0.25
r_SSAO=1
r_ssao_amount=0.4
r_SSAO_darkening=1.25
r_SSAO_quality=2
r_SSAO_radius=2
r_SSAO_blur 4
r_SSAO_blurriness 1
r_HDRlevel=0.75
r_Usepom = 1
r_sunshafts = 1
r_Beams=3
r_BeamsDistFactor = 0.1
r_BeamsMaxSlices=250
; Shadows
e_shadows = 1
r_ShadowsMaskResolution=0
e_shadows_on_alpha_blended=1
e_shadows_from_terrain_in_all_lods = 0
e_shadows_cast_view_dist_ratio = 0.6
r_ShadowBlur=3.0
e_shadows_max_texture_size=768
r_ShadowJittering=1.5
; Object Detail
e_obj_quality=4
ca_useDecals=1
e_decals_allow_game_decals=1
e_decals_life_time_scale=2
i_rejecteffects=1
sys_flash_curve_tess_error=2
e_view_dist_ratio=60
e_max_view_dst_spec_lerp=1
es_DebrisLifetimeScale=1
e_cbuffer_resolution=256
e_dissolve=1
ca_DrawFaceAttachments=1
ca_AttachmentCullingRation=60
e_terrain_occlusion_culling = 1
e_terrain_occlusion_culling_max_dist=200
; Vegetation
e_foliage_wind_activation_dist = 30
es_DebrisLifetimeScale = 1
r_DetailNumLayers = 2
r_VegetationSpritesTexRes = 128
r_DynTexAtlasSpritesMaxSize = 32
r_TexAtlasSize = 2048
e_vegetation_bending = 2
e_vegetation_min_size=0
e_proc_vegetation=1
e_vegetation_use_terrain_color=1
; Particles
e_particles_quality=4
e_water_ocean_soft_particles= 1
e_particles_max_emitter_draw_screen = 16
e_particles_object_collisions=1
r_UseSoftParticles = 1
e_particles_thread=1
; Water
r_WaterReflectionsQuality = 3
r_WaterUpdateDistance = 0.2
r_WaterCaustics=1
r_WaterRefractions=1
r_WaterReflections=1
r_WaterGodRays = 1
e_water_ocean_fft=1
e_water_tesselation_amount = 10
e_water_tesselation_swath_width=10
q_ShaderWater=3
e_phys_ocean_cell = 0.3
; Misc
e_max_entity_lights = 16
g_battleDust_enable = 1
g_breakage_particles_limit = 250
g_ragdollDistance = 35
g_ragdollMinTime = 15
e_terrain_ao=1
e_terrain_normal_map=1
; LODs
e_vegetation_sprites_distance_custom_ratio_min = 1
e_vegetation_sprites_distance_ratio=1.5
e_cull_veg_activation = 60
e_view_dist_ratio_vegetation = 50
e_particles_lod=0.6
es_MaxPhysDist=60
es_MaxPhysDistInvisible=25
e_terrain_lod_ratio=0.8
e_view_dist_ratio_detail=30
e_lod_ratio=6
e_lod_min=0
e_lods=1
e_detail_materials_view_dist_xy=4096
e_detail_materials_view_dist_z=256
r_DetailDistance=12
; FPS Gain commands
r_UseEdgeAA=2
r_TerrainAO_FadeDist=1
r_GeomInstancing=1
e_vegetation_static_instancing=0
e_gsm_lods_num = 5
e_gsm_range = 3
e_gsm_cache = 0
e_ram_maps = 1
e_dissolve = 1
r_TexturesStreaming=0
; Successfully loaded - Helder [HP] Pinto - Ultra High Quality Custom Config
Ich meinte MEINEN TFT und MEINE Graka, wieso sollte ich seinen TFT meinen oO?? Sinn ??
Hatte deine Aussage so verstanden, dass du der meinung seihst, ein guter TFT würde Screenshots schöner machen. :fresse:
Und ich habe immer noch nicht gerafft, warum Helder [HP] Pinto die autoexec in Crysis/Game und alle anderen diese in Crysis haben wollen ... :motz:
Hi, diese "Very Ultra High Config Final Version1.3" die man derzeit überall reunterladen kann ist doch für dx10 unter vista, oder?
Oder ist das nur son Teil, was für xp/dx9 alles auf "wanna be" dx10 pimpt?
Brief explanation on what the "CVarGroups" folder does:
Basically, in Crysis there is 4 levels of detail. But the 4th one, is locked on WindowsXP,
this "CVarGroups" folder unlocks it, making the 3th level (HIGH) looking just like the
4th (Very High), so what you need to do it set everything to High in the Graphics Options menu,
and in fact, you'll be running the game in very high!
Works on both Windows XP and Windows Vista (x86 and x64).
so siehst aus. :)
Keine ahung ob die nun nur für Vista ist, ich spiele diese Config unter XP 32-bit mit 1280x1024
Ja genau wegen dieser "VUHCV1.3"...
was braucht man das wirklich für eine hardware?
Ich habe jetzt einen E4300 @ 3GHz, 2GB Ram, 8800 GTS (g92) @ 750/1'875/1'010MHz und Vista 64Bit
gruss
Ich frage mich wozu ich nun eigentlich die Config Daten hier gepostet habe :fire:
@ HollY_D: Hast du Crysis schon? Wenn ja, teste es doch einfach. ;)
Wenn nicht, würde ich mal sagen, könnte eng werden, gerade im späteren Verlauf des Spiels, sehe ich da Probleme.
EDIT: Das ganze aber eher bei 20-30FPS, keine 40
Ja, ich hab Crysis schon das ein oder andere Mal schon durchgespielt.
Es geht bei dem oben genannten System um das eines Freundes.
Also 40fps wird er mit Sicherheit nicht haben.
Hey
zu den "rauschen" von den Screens
Ich vermute stark das das daran liegt das das gif's sind
als bmp wäre da glaube ich kein rauschen zu sehen ;)
Und ich bin der Meinung das die Textur auf Very High um einiges besser aussieht als in der Ultra High conf.
Kann das jetzt zwar nicht (mehr) nachprüfen da ich xp habe aber was man auf den Screenshots sieht sieht eigentlich nicht so überzeugent aus...
Was die Textur angehgt
Der rest sieht schon gut aus :bigok:
MFG
So ich habe jetzt die ultimative Config gefunden, die Grafik ist gut wenn nicht sogar Klasse.
Hier ein paar Bilder von mir :banana:
Pinto - Ultra High Quality Custom Config V1.3 FINAL
Increase the quality of Crysis with this Ultra High Quality Autoexec.
This autoexec includes all the features and graphics improvements available on Very High (Dx10),
and much more.
This config has been tweaked to run Crysis within it's maximum beauty,
while still getting minimaly smooth/playable FPS, although the
minimum system recomended is a Nvidia 8800, 2GB RAM and a fairly good dual core CPU.
- Better shadows
- Improved HDR
- Parallax Mapping
- Very high quality textures, terrain and vegetation
- Lightning improved
- High Quality particles
- Tweaked Lods for best FPS/Quality relation.
Ihr könnt entweder die Datei/Verzeichnis von mir gleich Laden die ich als Anhang beigefügt habe oder ihr nehmt den Link zur Original Seite : Ultra High Quality Custom Config - Update to v1.3 Release
Is die denn wirklich noch besser wie die Mask Fav.?
Fettes Respect an Mask., finde mit seiner cfg siehts verdammt geil aus und is jedenfalls in der 1. Hälfte des Spiels mmit meinem Sys geradeso spielbar.
Edit: bei dem ultrahighqualitycfg_1.3final Paket is ja auch n CVARGroups Ordner dabei. Brauch man den auch bei Vista64?
Weil ich die nfo so verstanden habe das der ordner dafür da is das die ultra Einstellungen unter XP freigeschaltet werden.
Oder habe ich das falsch verstanden und man brauch den auch für Vista?
In Post 1451 stehen ja nun die einelnen Optionen, wenn ihr die ahnung habt dann sagt doch mal was oder wo man etwas ändern sollte um es schöner zu bekommen anstatt immer nur zu nörgeln :fresse:
Niemand schaut meine an, dabei ist die doch schöner und schneller als die Pinto. :( :D
Ich glaube deine hatte ich schon mal versucht aber ich fand die von der Leistung her schlechter.
Ich kann jetzt aber nicht mehr genau sagen ob ich deine hatte :confused:
Das liegt dann aber wohl an deiner 8600 GT :coolblue:
Na am Prozessor wirds nicht liegen...
oder am ram...
oder dem mobo....
und an der hdd wohl auch nich..
Könntest mir ja gerne deine 88er geben wenn du willsd :rolleyes:
MFG
Tja ich bin da nicht so der Profi drin, das Prob ist aiuch das die Configs völlig verschieden sind und ich nicht wüsste was man jetzt wo ändern muß um es zu Optimieren.
mkaymkay?, werd deine config heut abend auch mal testen! schaut schon nice aus; wird wohl erst so ab 23.00 uhr rum... :(
mal nen direktvergleich zwischen ultra high config 1.3 und deiner anstellen dann :D
Ich habe Grade raus gefunden warum meine Pic's wohl nicht so gut ausgesehen hatten da ich nicht alles auf High hatte sondern eigene.
Ich hoffe diese kleine Galerie gefällt euch besser :asthanos:
Gelöschter Beitrag
Dieser Beitrag wurde auf Wunsch des Nutzers gelöscht.
