M
MöCkY
Guest
PT-BR: Add missing translation (android_packages_apps_Settings)
PT-BR: Add missing translations (android_packages_apps_Email)
PT-BR: Add missing translations (android_packages_apps_CMParts)
Added Czech translation. (android_packages_apps_ADWLauncher)
Added Czech translation. (android_packages_apps_AndroidTerm)
Czech translation - added missing strings and corrected exists string to be consistent. (android_packages_apps_Camera)
qsd8k:final fix for kernel panic (android_external_v8)
Traditional Chinese: Update translations for account color (android_packages_apps_Email)
res: strings: Set default account color translatable=false (android_packages_apps_Email)
Traditional Chinese: Update translations for application storage (android_packages_apps_CMParts)
Update Russian translation. Email - Account color (android_packages_apps_Email)
extend translation (cmparts/de) (android_packages_apps_CMParts)
Update Russian translation. CMParts (android_packages_apps_CMParts)
bashrc: set alias ls="busybox ls --color=auto" (android_external_bash)
Log Wifi NativeCommand exceptions (android_frameworks_base)
Fix: Do not change music volume if screen off and no music playing (android_frameworks_base)
extend translation (settings/de) (android_packages_apps_Settings)
extend translation (camera/de) (android_packages_apps_Camera)
Added Czech translation. (android_packages_apps_CMStats)
Add 'Mark All Read' Option to the Menu in Messaging App (android_packages_apps_Mms)
settings: Updated Italian translations (android_packages_apps_Settings)
camera: Updated Italian translations (android_packages_apps_Camera)
Fix exception in legacy USB support (android_frameworks_base)
Allow lower end devices to enable animated GIF support (android_external_webkit)
SystemUI: Show mic-less headphone icon in status bar (2/2) (android_vendor_cyanogen)
SystemUI: Show mic-less headphone icon in status bar (1/2) (android_frameworks_base)
Updated Ukrainian translation (android_packages_apps_Camera)
Updated Ukrainian translation (android_packages_apps_Settings)
Fix build error in init when building with bootchart (android_system_core)
Update Russian translation. Matrix metering (android_packages_apps_Camera)
Notification PowerWidget: Additional SoundMode: Vibrate/Silent (android_frameworks_base)
Traditional Chinese: Update translations (android_packages_apps_Camera)
Allow editing of contact birthdays also for Exchange contacts. (android_packages_apps_Contacts)
Update Russian translation. Settings - Additional storage (android_packages_apps_Settings)
Revert "Change Finnish time format to use ':' instead of '.'" (android_frameworks_base)
Camera Timer (android_packages_apps_Camera)
Update Russian translation. Contacts (android_packages_apps_Contacts)
Updated Dutch translations (android_packages_apps_Settings)
Don't inherit FM app, as it doesn't work properly with the Defy audio stack. (android_vendor_cyanogen)
libaudio-qdsp5v2: use new gb method for verify call state (android_hardware_msm7k)
libaudio-qsd8k: use new gb method for verify call state (android_hardware_msm7k)
allow TARGET_SKIA_USE_MORE_MEMORY set to false to override vfp condition (android_external_skia)
Restore pre-openvpn results of needKeyStoreToSave for L2TP_IPSEC_PSK and L2TP (android_packages_apps_Settings)
PT-BR: Add missing translations (android_packages_apps_DSPManager)
Updated Swedish translations (android_packages_apps_Camera)
ide: eclipse: Add theme classes to classpath (android_development)
Set translatable=false (android_packages_apps_DeskClock)
Updated Swedish translations (android_packages_apps_CMParts)
Music: Bluetooth AVRCP 1.3 feature changes (android_packages_apps_Music)
frameworks/base: bluetooth: AVRCP 1.3 feature changes (android_frameworks_base)
Bluez: Changing AVRCP connect timeout to four seconds. (android_external_bluetooth_bluez)
Bluetooth: Ignore the Genre attribute length for AVRCP 1.3 Metadata request (android_external_bluetooth_bluez)
Bluetooth: AVRCP 1.3 feature changes (android_external_bluetooth_bluez)
LGEStarRIL: Modify p999 exclusion logic (android_frameworks_base)
LGEStarRIL: Ignore SCREEN_ON/SCREEN_OFF events on star (android_frameworks_base)
libaudio-msm7x30: CAF Compatibility (android_hardware_msm7k)
libaudio-msm7x30: aic3254: slight performance improvment (android_hardware_msm7k)
libaudio-msm7x30: use the correct acdb for known bt devices (android_hardware_msm7k)
libauido-msm7x30: AIC3254: Updated dsp profile switch (android_hardware_msm7k)
libaudio-msm7x30: fix wrong LPA ifdef (android_hardware_msm7k)
libaudio-msm7x30: Add Desire HD and Inspire 4G DSP Profile support (android_hardware_msm7k)
libaudio-msm7x30: fix for notification with no mic headset (android_hardware_msm7k)
libaudio-msm7x30: code cleanup (android_hardware_msm7k)
Set to properly update the calendar app when display name or account color is changed in Email (Exchange) (android_packages_apps_Email)
Add customizable account 'color' chip - (credit to copolii) (android_packages_apps_Email)
add droid2we (droid2 global) support (1/2) (android_vendor_cyanogen)
Mal wieder ein ordentliches Changelog
