The_Unexpected
Is zwar in Englisch aber leicht verständlich:
"How to flash BIOS under DOS Mode? 2004/05/07
Answer :
1. Prepare one piece of clean bootable floppy disk with only booting program installed.
2. Download the appropriate BIOS update from the Download section according to the motherboard model and PCB (Printed Circuit Board) revision. The revision of motherboard can be checked from the lower right corner of label affixed on printer port. For aged motherboards, please find the label on the last ISA slot. You can take the first digit after "R." as PCB Revision. For example, the PCB revision is "A" if the revision of motherboard is marked as "R.AG0".
3. Extract the BIOS binary file and the flash utility program from the zipped file using applications as WinZip.
4. There should be two files being extracted from the zipped file. They are: *.EXE and *.BIN files. You can find another ".TXT" file sometimes which is the description of history of the BIOS updating and you don't have to use it upon flashing the BIOS.
5. Copy the *.BIN and *.EXE file on to a floppy disk and reboot your system from the floppy drive.
6. Type in the following command under DOS prompt (NOT under windows!):
A:\>[executable] [file name].bin /F
OR A:\> [Executable] [file name].bin /F/QI
OR, A:\>[executable] /?
for detailed instructions.
Warning: For NFII chipset based motherboard, please do not give "/F" instruction. Otherwise, LAN MAG IP will be lost that might cause your LAN feature failed.
7. Reset your computer AFTER the completion of BIOS flash process.
8. To check whether your BIOS has been updated successfully please refer to the BIOS date code shown on the bottom left hand corner of the boot up screen.
9. Please LOAD OPTIMAL SETTINGS or LOAD BIOS SETUP DEFAULTS in the BIOS setup menu during the first system boot up after the flashing the BIOS.
Warning:
WARNING: Please be very cautious during the BIOS flash process, your system may fail to boot if the BIOS was not programmed correctly."
Is die Anleitung von der DFI-Homepage.
Answer :
Warning:
, hat solch keine?
