[Sammelthread] DFI LANparty DK 790FXB-M2RS / -M2RSH / -M3H5 / 790GX-M2RS (AMD 790FX / 790GX) [2]
Sammelthread
Inhaltsverzeichniss:
top
AM2+
AM3
Anhang:
AM2+
AM3
Vorwort:
Da die Boards nahezu identisch ausgestattet sind habe ich nur die Details zusammengefasst, die sich von den anderen unterscheiden. Die Features die fehlen, kann man vom M2RSH übernehmen.
Nun gehts also los mit dem Sammelthread der DFI Lanparty DK series:
AM2+:
790FXB
DFI Lanparty DK 790FXB-M2RS
I. Technische Details zum Board:
CPU:
  • AMD Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
  • Socket 940 AM2 65nm
Chipset:
  • Northbridge: AMD 790FX
  • Southbridge: AMD SB750
System Memory:
  • Four 240-pin DDR2 DIMM sockets
  • Supports DDR2 667 and DDR2 800 DIMMs
  • Supports dual channel (128-bit wide) memory interface
  • Supports up to 8GB system memory
  • Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots
    - 2-way or 4-way CrossFire at x16/x16/NC bandwidth
    - 3-way CrossFire at x16/x8/x8 bandwidth
    - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
  • 3 PCI slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM overclocking
  • CPU/DRAM/Chipset overvoltage
  • 8Mbit flash memory
  • AM3 support ab BIOS-Version R7SD327 (beta), bzw. R7SD421 (final)
Audio:
  • Realtek ALC885 8-channel HD Audio Codec
  • High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN:
  • Marvell 88E8053 PCIE Gigabit LAN controller
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Power Management:
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 Keyboard/Mouse
  • Wake-On-USB Keyboard/Mouse
  • Wake-On-Ring
  • Wake-On-LAN
  • RTC timer to power-on the system
  • AC power failure recovery
Hardware Monitor:
  • Monitors CPU/system/chipset temperature
  • Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature during system boot-up
IDE:
  • One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Serial ATA with RAID:
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O:
  • 1 mini-DIN-6 PS/2 mouse port
  • 1 mini-DIN-6 PS/2 keyboard port
  • 1 optical S/PDIF-out port
  • 1 coaxial RCA S/PDIF-out port
  • 6 USB 2.0/1.1 ports
  • 1 RJ45 LAN port
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
Internal I/O:
  • 2 connectors for 4 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 front audio connector
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 4 Serial ATA connectors
  • 1 40-pin IDE connector
  • 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 6 fan connectors
  • EZ touch switches (power switch and reset switch)
PCB:
  • ATX form factor
  • 24.5cm (9.64") x 30.5cm (12")
II. Layout:
III. Reviews:
http://www.ur-hardware.com/mainboard/40-review-dfi-lanparty-dk-790fx
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...ormal&mode=view&downloadFlag=false&itemId=539
Treiber: http://www.dfi.com.tw:8080/portal/C...normal&mode=view&downloadFlag=true&itemId=539
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383889.html
M2RSH
DFI Lanparty DK 790FX-M2RSH
CPU:
  • AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron
  • HyperTransport 3.0 (5200MT/s for AM2+)
  • AMD OverDrive provides tuning options using the new“Advanced Clock Calibration” overclocking feature.
  • Socket 940 AM2+ 65nm
Chipset:
System Memory:
  • Supports DDR2 667/800/1066 MHz DIMMs
Expansion Slots:
  • 3 PCI slots
II. Layout:
III. Reviews:
http://www.modreactor.com/english/R...XB-M2RSH-AMD-LanParty-Motherboard-Review.html
http://www.overclock.net/amd-motherboards/399854-smt-review-dfi-lanparty-790fxb-m2rsh.html
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Treiber: http://www.dfi.com.tw:8080/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=driverTab&windowstate=normal&mode=view&downloadFlag=true&itemId=547
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383891.html
790GX
DFI Lanparty DK 790GX-M2RS
CPU:
Chipset:
  • Northbridge: AMD 790GX (RS780)
Expansion Slots:
  • 2 PCI Express (Gen 2) x16 slots
    - Hybrid CrossFireX - combination of the integrated graphics and a discretegraphics card in a PCIE slot (8-lane port).
    - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports)bandwidth
  • 1 PCI Express x1 slot
  • 3 PCI slots
Graphics:
  • Integrated ATI Radeon HD 3300 graphics core
  • One DVI-I connector for digital LCD display (ACHTUNG!! DVI Anschluss nur als Pin-Connector ausgeführt)
  • Microsoft® DirectX 10
  • Hybrid CrossFireX technology combines the onboard GPU and adiscrete PCIE graphics card
  • Onboard Performance cache for added performance
II. Layout:
III. Reviews:
http://www.madshrimps.be/?action=getarticle&articID=894
IV. Links:
Link zum "DVI-Problem": http://www.csd.dficlub.org/forum/showthread.php?t=8221
Treiber: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a356442.html
Lanparty JR Sammelthread: http://www.hardwareluxx.de/community/showthread.php?t=590779
hex
Anhang:
Für erweiterte Optionen im BIOS F9 drücken!
Achtung an alle Extrem-OC´er: das Board zeigt nur maximal -83°C an !
Hexcode Tabellen Für CPU-NB-VID und NB-Multi(790FXBM2RS/H):
tabelle
Vergleich zwischen den Boards:
kühler
Kompatible Kühler:
790FXB-M2RS(H):
passt:
Cooler Master Hyper TX (bläst nach hinten)
EKL Alenföhn Groß Clock'ner Blue Edition (bläst nach hinten)
EKL Alpenföhn Brocken (bläßt nach oben)
Scythe Infinity/Mugen (bläst nach oben)
Thermalright IFX-14 (bläst nach hinten), (ACHTUNG: bei verwendung der Thermalright Backplate auf Isolierung achten!)
Thermaltake GunMetal Orb (bläst nach unten)
OCZ Vanquisher (bläst nach oben)
Xigmatek HDT-S1283 (bläst nach oben)
Zalman CNPS 9500AM2 (nach hinten)
passt mit Modifikationen:
passt nicht:
790GX-M2RS:
passt:
passt nicht:
passende Wasserkühler für NB/SB und Spawa´s gibt es bei Anfi-tec oder Watercool
Lochabstände vom NB-kühler, Danke an Andreoid von Anfi-tec :bigok:
ram
RAM Kompatibilitätsliste:
790FX-M2RS/H:
läuft:
Cellshock 2x 1GB DDR2-667 (CS2110650)
GeIL DIMM 4 GB kit DDR2-800 (GX24GB6400C4UDC)
G.Skill Pi Series 4GB DDR2 1100 (F2-8800CL5D-4GBPI)
G.Skill 4GB kit DDR-1000 (F2-8000CL5D-4GBPQ)
Kingston HyperX 4GB kit DDR-1066 (KHX8500D2K2/4G)
Mushkin 4GB kit DDR-1066 (996599)
OCZ Platinum XTC 4GB kit DDR-800 (OCZ2P10004GK)
OCZ Titanium 4GB kit DDR-1150 (OCZ2T11504GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800C32GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800EB2GK)
OCZ Reaper HPC 2x2GB kit DDR2-1066 (OCZ2RPR10662G), (Tony´s SPD)
OCZ XTC Platinum 2 GB kit DDR2-1066 (OCZ2N10662GK)
macht Probleme:
läuft nicht:
Vollbestückung:
4GB
2x1GB OCZ Reaper (OCZ2RPR800C32GK) + 2x1GB OCZ Reaper (OCZ2RPR800EB2GK)
DDR800 | CL4-4-4-12 | Vdimm 2,0V
4x1GB Aenon Xtune DDR1066 | CL5-5-5-15 | Vdimm 1,85V
6GB
2x2GB Geil Ultra Plus (GX24GB6400C4UDC) + 2x1GB Cellshock
DDR800 | CL4-4-4-10 | Vdimm 1,85V
8GB
4x2GB G.Skill Pi Series (F2-8800CL5D-4GBPI) | DDR800 | CL5-5-5-18 | Vdimm 1,9V
2x4GB kit Mushkin XP2-8000 (996591) | DDR1000 | CL5-5-5-15 | Vdimm 2,1V
2x4GB kit
Mushkin DDR-1066 (996599) | DDR1066 | CL5-5-5-15 | Vdimm 2,05V
790GX-M2RS:
läuft:
Aeneon Xtune DIMM 2 GB DDR2-1066 Kit (AXT760UD00-19DM97-K-2G)
macht Probleme:
OCZ Reaper HPC 2 GB DDR2-1066 Kit (OCZ2RPR10662GK); (abstürtze mit 1066Mhz)
läuft nicht:
Vollbestückung:
4GB
6GB
8GB
Tipps für 8GB RAM bei 1066Mhz *klick*
FAQ
FAQ:
Q: Ab welcher BIOS-Version bietet das Board Deneb-Support?
A: Ab FinalVersion R7SDC26
Q: Ab welcher BIOS-Version bietet das Board AM3-Support?
A: Ab Final Bios R7SD421 bzw. ab Beta R7SD327
Q: Mit welcher BIOS-Version lassen sich die X3´s freischalten?
A: Beta Version R7SD310A
Q: Wie flashe ich mein BIOS mit einem USB-Stick?
A: Tutorial auf der DFI-Club-Seite *klick*
Eine deutsche Übersetzung der POST Codes aus dem Handbuch findet ihr HIER
under construction...
AM3:
m3h5
DFI Lanparty DK 790FXB-M3H5
CPU:
  • AMD Phenom II processor
  • HyperTransport 3.0 (5200MT/s), HyperTransport 1.0 (2000/1600MT/s)
  • AMD OverDrive provides tuning options using the new "Advanced Clock Calibration" overclocking feature.
  • Socket 938 AM3 45nm
Chipset:
System Memory:
  • Four 240-pin DDR3 DIMM sockets
  • Supports DDR3 1600 (O.C.)/1333/1066Mhz
  • Supports non-ECC unbuffered DIMMs
  • Supports up to 16GB system memory
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots - 2-way crossfire at x16/x16 or x16/x4 bandwith - 3-way crossfire at x16/x16/x4 bandwith
  • 3 PCI-Slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM Overclocking
  • CPU/DRAM/Chipset Overvolting
  • 8Mbit SPI Flash Memory
Audio:
Lan:
  • Marvell 88E8056 PCIE Gigabit LAN controller
  • SATA speed up to 3GB/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
IDE:
  • One IDE connector allows up to two UltraDMA 133Mbps hard drives
Rear Panel I/O Ports:
  • 1 RJ45 LAN port
  • line-in, line-out (front R/L) and mic-in jacks
I/O Connectors:
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 6 Serial-ATA connectors
  • 6 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power and reset switch)
Power Management:
  • ACPI STR (Suspend to RAM) funktion
  • Wake-On-Ring
  • Wake-On-LAN
Hardware Monitor:
  • Monitors 12V/5V/3,3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • CPU Over Heat Protection function monitors CPU temperature during system boot-up
PCB:
  • ATX form factor
  • 24,5cm (9,64") x 30,5cm (12")
II. Layout:
III. Reviews:
User-Review von Öse:
http://www.hardwareluxx.de/community/showpost.php?p=11771090&postcount=1
http://www.ninjalane.com/reviews/motherboards/lanpartydk-790fxb-m3h5
IV: Links:
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a417781.html
kühler
Anhang:
Kompatible Kühler:
Die Sockelhalterung entspricht exakt der AM2(+) version, daher passen alle Kühler die auch mit dem M2RS(H) kompatibel sind.
Passende Wasserkühler:
Das Boardlayout entspricht ebenfalls dem des M2RSH, daher passen alle Wasserkühler die auch mit dem 790FXB-M2RS(H) verwendet werden können.
Hi ExAMDfAN
schau mal ob du ein neueres Bios drauf machen kannst, zumeist liegt es ein diesem leider.
lg
HI ,
Ich habe heute bei Aquacomputer angerufen. Sie sagten das es eine Inkompatibilität zum USB Controller vom Mainboard ist. Der Aquaero sei nach dem USB Standard hergestellt.
Lösungen gibt es nur Ansatzweis.
Neues Bios Mainboard
PCI USB Karte
USB Hub
Aber es sind zum glück nicht nur DFi Boards betroffen! Schlimmer ist es mit Asus Boards. Hier soll der Aquaero zum teil nicht mal erkannt werden!
Mit dem neuen Board schnurrt die Kiste wieder wie ein Kätzchen:d
Ich hab jetzt das 790FXB-M2RSH. Vorher hatte ich das 790GX-M2RS.
Musste aber direkt mal ein Bios-Update machen weil das Board die CPU nicht richtig erkannt hatte. Sie lief zwar aber er zeigte beim Bootvorgang "unknown CPU" an. Nach nem Update stand dann Phenom X2 550 da, und mit eingeschaltetem ACC steht da Phenom X4 B50:shot:
Mit dem neuen Retention Kit von Thermalright lässt sich nun auch der Ultra 120 Extreme auf dem Brett in alle Richtungen drehen. Und wenn man Everest Ultimate glauben schenken darf läuft die CPU bei 23° im Idle:d Und nach na Stunde Modern Warfare 2 waren es um die 40° bei 4x 3,0GHz @ 1,27v. Und ich habe nur ein Lüfter auf der Rückseite vom Kühler montiert der die Luft rauszieht weil mein RAM zu hoch ist.:d
23° scheint zwar etwas wenig , aber im allgemeinen bleiben die P2 recht Kühl . Ich hab wie Du einen "X4 B50" unter einem AC Freezer 64pro-PWM und komme selbst bei 3,8GHz und 1,42V nicht über 55° bei Prime 95 . Und da läuft der Lüfter noch nicht mal vollgas . Bei 1,07V (Bios 1,1) habe ich 2,8GHz , bei 1,28V (VID = 1,3V) macht das gute Stück 3,5GHz .
Nicht schlecht. Ich bin noch nicht dazu gekommen viel zu testen. Der Rechner läuft erst seit gestern. Als 24/7 werd ich aber bei 4x 3GHz bleiben und schauen wie weit ich mit der Spannung runter gehen kann. Ich finde nur dass die Schritte beim DFI Board etwas groß sind.
Oh man das ist schon bitter, wobei ich es auch verstehen kann, nachdem ich nach 3 Wochen nicht an die Werte des Gigabyts gekommen bin.....
aber zumindest im Fileserver macht es eine gute Figuar nach 2h im Bios rumprobieren läuft jetzt auch der Adaptec Raidcontroller. Jetzt muss ich nur noch auf nen neues Bios zum Freischalten warten und diesen blöden NB-"Kühler" tauschen. Beim gleichzeitigem Kopieren mit ings. 4 Platten wird das Teil 60C heiß...
Moin Jungs,
ich hoffe, ihr könnt mir weiterhelfen, ich bin kurz vorm verzweifeln :shot:
Also ich hab mir neulich mal wieder seit 2 Jahren nen neuen Rechner gegönnt. Der besteht aus den Komponenten aus meiner Sig..
Ich hab das Problem, dass ich einfach nicht die richtigen Bios-settings finde, um meinen ram mit 1600mhz laufen zu lassen bei den Soll-timings von 8-8-8-24 und 1,65v. Er bootet dann entweder gar nicht (Fehler 1b oder 2b) oder belibt kurz vorm biospost hängen...
Hab schon einiges durch probiert... Spannung auf 1,75v, NBvid etwas höher, IMCvid etwas höher... aber bringt alles nix. Mit 9-9-9-? läugt er allerdings.
Ist denn auf dem board generell 1600er Takt bei vollbestückung mit 8GB machbar bei den Timings? Oder kann ich es ganz vergessen? Ich hab übrigens grad das letzte betabios druff.
Danke schonmal für eure Hilfe ;)
Brad
Moin moin , der Speichercontroler sitzt ja in der CPU und nicht auf dem Board . Von AMD ist er soweit ich weiss nur bis 1333 freigegeben , und das auch nur mit 2 Modulen . Das die 1600 bei Dir mit 9-9-9-24 laufen mit 4 Riegeln ist also eher positiv zu sehen .
Ja, aber der Teiler für 1600 ist doch im bios nicht völlig umsonst implementiert worden, oder?
Mich würd mal interessieren (ohne 30 Seiten zu lesen), ob das jmd. schon hinbekommen hat auf dem board (auch mit anderem Speicher).
Erstmal danke für deine Infos.
Klar ist mir bewusst, dass die CPU nur bis 1333 unterstützt. Alles andere ist natürlich oc. Aber ich komm beim oc eben nicht weiter... das muss doch machbar sein, das der ram, der vom hersteller pretested wurde, seine spezis erfüllt. Aber wie krieg ich die cpu / das board dazu, soweit zu kommen... könnt ihr mir denn mal ein paar empfehlungen für die settings im ram-menü des bios geben?
Ich habe hier nur das M2RSH . Eventuell bald noch das DFI LANparty BI 785G-M35 aber nur DDRIII 1333 .
Dann laß den Speicher doch einfach mit 9-9-9 laufen, wenn's damit läuft. Die Unterschiede dazwischen und 8-8-8 sind nur äußerst minimal und bestenfalls mit einem Memorybenchmark gerade eben meßbar.
Gude,
ich habe jetz endlich mein m2rsh und habe da auch gleich mal ein problem. mein rechner fährt nicht mehr herunter sondern startet neu. selbst mit power schalter funktioniert das ganze erst so nach 3-4 probieren, damit er auch aus bleibt. woran könnte das liegen, meine vermutung war wake on lan aber diese funktion gibt es ja nicht mehr im bios.
MFG
setz mal tRFC auf 127,5 oder höher (alle vier)
probier mal das:
http://www.hardwareluxx.de/community/showpost.php?p=10355812&postcount=316
Ich danke dir tupax, genau daran lag es aber auch nur dann wenn ich die 518 an der g15 direkt anschliesse. Mach ich das nicht kann ich es auf default lassen. Aber nun geht es ja wieder. Danke Danke :)
MFG
Weiß zufällig jemand ob das 790GX-M2RS Dual Link DVI unterstützt (also 2560x1600)? Der Chipsatz an sich kann es ja - aber ich hab leider keine passende Quelle gefunden, die sagt ob DFI das auch entsprechend umgesetzt hat.
mfg vibes
Problem beim Freischalten Athlon II X4 620
Hallo alle zusammen,
ich besitze ein Dk790FXB-M2R2 sowie einen Athlon II X4 620 mit folgender Kennung CACYC. Dahinter müsste sich nach allem was ich bisher gelesen habe ein Deneb kern verbergen. Wenn ich jetzt aber im Bios ACC auf auto stelle den rechner ausschalte und dann neustarte ändert sich leider nichts der rechner fährt wie gewohnt hoch aber ohne irgendw. Das aktuelle bios ist drauf (0820). Stell ich mich einfach zu blöd an oder hab ich vlt doch nen non Deneb erwischt.
Schonmal danke für die Antworten
@hardcorevibes also ich kann es dir leider nicht genau sagen, aber da bei den dfi's auf einen analogen anschluss komplett verzicht wurde und auch keine analoge ausgabe via dvi möglich ist sollte es wenigstens dual-dvi sein. ich kanns leider nit austesten da ich nur nen 22" TFT hab^^
Danke - das ist doch schon mal ein Hinweis - die Boards mit dem Nvidia 9400 Chipset von DFI kommen auch alle mit Dual Link DVI - ich kann mir demnach nicht vorstellen, dass man das Feature beim 790GX dann brach liegen lässt - zumal Asus auch ein Board mit 790GX und Dual Link DVI hat.
mfg vibes
€: Ich habe eben mal die Spezifikationen von DVI mit dem PIN Header auf dem Board verglichen - leider ist es Single Link DVI - auf dem Board ist ein 20er PIN Header (mit einem "toten" PIN) - das entspricht genau den 18+1 PINs für Single Link DVI - für Dual Link DVI müssten es aber 24+1 sein....
So, ich habe hier ein Problem mit einem Phenom II x2 550 BE auf einem 790FXB-M2RSH. Beim Versuch ihn auf einen x4 freizuschalten (ACC auf Auto) fährt der Rechner nicht mehr hoch. Der Grafikkartenlüfter dreht voll auf, Fehlercode 88 auf der MB-Anzeige. BIOS ist das aktuelle R7SD820A. Auch wenn ich den Multi zusätzlich auf x4 stelle bleibt die Kiste tot mit Code 88. Sicher ist mindestens ein Kern hinüber. Wie zum Geier kann ich aber nun testen, ob die CPU mit drei Kernen funktioniert?
ahoi wiesel,
nur ne idee, ka obs klappt:
wenn du mit 2 cores bootest und ins BIOS gehst, kannst du dann unter CPU/downcore auf Tri (3-kern) stellen? oder werden nur 2 kerne optioniert?
falls doch, dann ACC an und testen.
wär nen versuch wert, wobei ich nicht weiss nach welchen kriterien dann die einzelnen kerne abgeschaltet werden.
andere idee hab ich nicht ^^
viel glück
Leider wird ds nichts, es wird nur Single Core und Dual Core angeboten. Auch wenn ich ACC aktiviere (ohne neu zu booten, weil das ja bekanntlich bei mir nicht funktioniert)...:shake:
Hi wiesel
aktiviere mal Acc und stelle auf dualcore dann ausschalten neu starten ins Bios jetzt solltest du auch tri einstellen können ;)
ich hoffe das er mit ACC so startet bei dir.
lg
Klappt auch nicht. Ich habe daraufhin die CPU im BIOS erst einmal auf 2 und später sogar auf einen Core gesetzt, natürlich startete der Rechner so wie es sich gehört. Aber auch als ich mit diesen Konfigurationen ACC aktivierte trat der gleiche Fehler auf. Ich denke ich gebe es auf. Ich habe die CPU für 60 Euro inklusive Versand erstanden, da kann ich auch bei einem "echten" x2 nicht meckern...
Ähnliche Themen
