[Sammelthread] DFI LANparty DK 790FXB-M2RS / -M2RSH / -M3H5 / 790GX-M2RS (AMD 790FX / 790GX) [2]
Sammelthread
Inhaltsverzeichniss:
top
AM2+
AM3
Anhang:
AM2+
AM3
Vorwort:
Da die Boards nahezu identisch ausgestattet sind habe ich nur die Details zusammengefasst, die sich von den anderen unterscheiden. Die Features die fehlen, kann man vom M2RSH übernehmen.
Nun gehts also los mit dem Sammelthread der DFI Lanparty DK series:
AM2+:
790FXB
DFI Lanparty DK 790FXB-M2RS
I. Technische Details zum Board:
CPU:
  • AMD Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
  • Socket 940 AM2 65nm
Chipset:
  • Northbridge: AMD 790FX
  • Southbridge: AMD SB750
System Memory:
  • Four 240-pin DDR2 DIMM sockets
  • Supports DDR2 667 and DDR2 800 DIMMs
  • Supports dual channel (128-bit wide) memory interface
  • Supports up to 8GB system memory
  • Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots
    - 2-way or 4-way CrossFire at x16/x16/NC bandwidth
    - 3-way CrossFire at x16/x8/x8 bandwidth
    - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
  • 3 PCI slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM overclocking
  • CPU/DRAM/Chipset overvoltage
  • 8Mbit flash memory
  • AM3 support ab BIOS-Version R7SD327 (beta), bzw. R7SD421 (final)
Audio:
  • Realtek ALC885 8-channel HD Audio Codec
  • High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN:
  • Marvell 88E8053 PCIE Gigabit LAN controller
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Power Management:
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 Keyboard/Mouse
  • Wake-On-USB Keyboard/Mouse
  • Wake-On-Ring
  • Wake-On-LAN
  • RTC timer to power-on the system
  • AC power failure recovery
Hardware Monitor:
  • Monitors CPU/system/chipset temperature
  • Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature during system boot-up
IDE:
  • One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Serial ATA with RAID:
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O:
  • 1 mini-DIN-6 PS/2 mouse port
  • 1 mini-DIN-6 PS/2 keyboard port
  • 1 optical S/PDIF-out port
  • 1 coaxial RCA S/PDIF-out port
  • 6 USB 2.0/1.1 ports
  • 1 RJ45 LAN port
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
Internal I/O:
  • 2 connectors for 4 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 front audio connector
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 4 Serial ATA connectors
  • 1 40-pin IDE connector
  • 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 6 fan connectors
  • EZ touch switches (power switch and reset switch)
PCB:
  • ATX form factor
  • 24.5cm (9.64") x 30.5cm (12")
II. Layout:
III. Reviews:
http://www.ur-hardware.com/mainboard/40-review-dfi-lanparty-dk-790fx
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...ormal&mode=view&downloadFlag=false&itemId=539
Treiber: http://www.dfi.com.tw:8080/portal/C...normal&mode=view&downloadFlag=true&itemId=539
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383889.html
M2RSH
DFI Lanparty DK 790FX-M2RSH
CPU:
  • AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron
  • HyperTransport 3.0 (5200MT/s for AM2+)
  • AMD OverDrive provides tuning options using the new“Advanced Clock Calibration” overclocking feature.
  • Socket 940 AM2+ 65nm
Chipset:
System Memory:
  • Supports DDR2 667/800/1066 MHz DIMMs
Expansion Slots:
  • 3 PCI slots
II. Layout:
III. Reviews:
http://www.modreactor.com/english/R...XB-M2RSH-AMD-LanParty-Motherboard-Review.html
http://www.overclock.net/amd-motherboards/399854-smt-review-dfi-lanparty-790fxb-m2rsh.html
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Treiber: http://www.dfi.com.tw:8080/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=driverTab&windowstate=normal&mode=view&downloadFlag=true&itemId=547
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383891.html
790GX
DFI Lanparty DK 790GX-M2RS
CPU:
Chipset:
  • Northbridge: AMD 790GX (RS780)
Expansion Slots:
  • 2 PCI Express (Gen 2) x16 slots
    - Hybrid CrossFireX - combination of the integrated graphics and a discretegraphics card in a PCIE slot (8-lane port).
    - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports)bandwidth
  • 1 PCI Express x1 slot
  • 3 PCI slots
Graphics:
  • Integrated ATI Radeon HD 3300 graphics core
  • One DVI-I connector for digital LCD display (ACHTUNG!! DVI Anschluss nur als Pin-Connector ausgeführt)
  • Microsoft® DirectX 10
  • Hybrid CrossFireX technology combines the onboard GPU and adiscrete PCIE graphics card
  • Onboard Performance cache for added performance
II. Layout:
III. Reviews:
http://www.madshrimps.be/?action=getarticle&articID=894
IV. Links:
Link zum "DVI-Problem": http://www.csd.dficlub.org/forum/showthread.php?t=8221
Treiber: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a356442.html
Lanparty JR Sammelthread: http://www.hardwareluxx.de/community/showthread.php?t=590779
hex
Anhang:
Für erweiterte Optionen im BIOS F9 drücken!
Achtung an alle Extrem-OC´er: das Board zeigt nur maximal -83°C an !
Hexcode Tabellen Für CPU-NB-VID und NB-Multi(790FXBM2RS/H):
tabelle
Vergleich zwischen den Boards:
kühler
Kompatible Kühler:
790FXB-M2RS(H):
passt:
Cooler Master Hyper TX (bläst nach hinten)
EKL Alenföhn Groß Clock'ner Blue Edition (bläst nach hinten)
EKL Alpenföhn Brocken (bläßt nach oben)
Scythe Infinity/Mugen (bläst nach oben)
Thermalright IFX-14 (bläst nach hinten), (ACHTUNG: bei verwendung der Thermalright Backplate auf Isolierung achten!)
Thermaltake GunMetal Orb (bläst nach unten)
OCZ Vanquisher (bläst nach oben)
Xigmatek HDT-S1283 (bläst nach oben)
Zalman CNPS 9500AM2 (nach hinten)
passt mit Modifikationen:
passt nicht:
790GX-M2RS:
passt:
passt nicht:
passende Wasserkühler für NB/SB und Spawa´s gibt es bei Anfi-tec oder Watercool
Lochabstände vom NB-kühler, Danke an Andreoid von Anfi-tec :bigok:
ram
RAM Kompatibilitätsliste:
790FX-M2RS/H:
läuft:
Cellshock 2x 1GB DDR2-667 (CS2110650)
GeIL DIMM 4 GB kit DDR2-800 (GX24GB6400C4UDC)
G.Skill Pi Series 4GB DDR2 1100 (F2-8800CL5D-4GBPI)
G.Skill 4GB kit DDR-1000 (F2-8000CL5D-4GBPQ)
Kingston HyperX 4GB kit DDR-1066 (KHX8500D2K2/4G)
Mushkin 4GB kit DDR-1066 (996599)
OCZ Platinum XTC 4GB kit DDR-800 (OCZ2P10004GK)
OCZ Titanium 4GB kit DDR-1150 (OCZ2T11504GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800C32GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800EB2GK)
OCZ Reaper HPC 2x2GB kit DDR2-1066 (OCZ2RPR10662G), (Tony´s SPD)
OCZ XTC Platinum 2 GB kit DDR2-1066 (OCZ2N10662GK)
macht Probleme:
läuft nicht:
Vollbestückung:
4GB
2x1GB OCZ Reaper (OCZ2RPR800C32GK) + 2x1GB OCZ Reaper (OCZ2RPR800EB2GK)
DDR800 | CL4-4-4-12 | Vdimm 2,0V
4x1GB Aenon Xtune DDR1066 | CL5-5-5-15 | Vdimm 1,85V
6GB
2x2GB Geil Ultra Plus (GX24GB6400C4UDC) + 2x1GB Cellshock
DDR800 | CL4-4-4-10 | Vdimm 1,85V
8GB
4x2GB G.Skill Pi Series (F2-8800CL5D-4GBPI) | DDR800 | CL5-5-5-18 | Vdimm 1,9V
2x4GB kit Mushkin XP2-8000 (996591) | DDR1000 | CL5-5-5-15 | Vdimm 2,1V
2x4GB kit
Mushkin DDR-1066 (996599) | DDR1066 | CL5-5-5-15 | Vdimm 2,05V
790GX-M2RS:
läuft:
Aeneon Xtune DIMM 2 GB DDR2-1066 Kit (AXT760UD00-19DM97-K-2G)
macht Probleme:
OCZ Reaper HPC 2 GB DDR2-1066 Kit (OCZ2RPR10662GK); (abstürtze mit 1066Mhz)
läuft nicht:
Vollbestückung:
4GB
6GB
8GB
Tipps für 8GB RAM bei 1066Mhz *klick*
FAQ
FAQ:
Q: Ab welcher BIOS-Version bietet das Board Deneb-Support?
A: Ab FinalVersion R7SDC26
Q: Ab welcher BIOS-Version bietet das Board AM3-Support?
A: Ab Final Bios R7SD421 bzw. ab Beta R7SD327
Q: Mit welcher BIOS-Version lassen sich die X3´s freischalten?
A: Beta Version R7SD310A
Q: Wie flashe ich mein BIOS mit einem USB-Stick?
A: Tutorial auf der DFI-Club-Seite *klick*
Eine deutsche Übersetzung der POST Codes aus dem Handbuch findet ihr HIER
under construction...
AM3:
m3h5
DFI Lanparty DK 790FXB-M3H5
CPU:
  • AMD Phenom II processor
  • HyperTransport 3.0 (5200MT/s), HyperTransport 1.0 (2000/1600MT/s)
  • AMD OverDrive provides tuning options using the new "Advanced Clock Calibration" overclocking feature.
  • Socket 938 AM3 45nm
Chipset:
System Memory:
  • Four 240-pin DDR3 DIMM sockets
  • Supports DDR3 1600 (O.C.)/1333/1066Mhz
  • Supports non-ECC unbuffered DIMMs
  • Supports up to 16GB system memory
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots - 2-way crossfire at x16/x16 or x16/x4 bandwith - 3-way crossfire at x16/x16/x4 bandwith
  • 3 PCI-Slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM Overclocking
  • CPU/DRAM/Chipset Overvolting
  • 8Mbit SPI Flash Memory
Audio:
Lan:
  • Marvell 88E8056 PCIE Gigabit LAN controller
  • SATA speed up to 3GB/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
IDE:
  • One IDE connector allows up to two UltraDMA 133Mbps hard drives
Rear Panel I/O Ports:
  • 1 RJ45 LAN port
  • line-in, line-out (front R/L) and mic-in jacks
I/O Connectors:
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 6 Serial-ATA connectors
  • 6 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power and reset switch)
Power Management:
  • ACPI STR (Suspend to RAM) funktion
  • Wake-On-Ring
  • Wake-On-LAN
Hardware Monitor:
  • Monitors 12V/5V/3,3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • CPU Over Heat Protection function monitors CPU temperature during system boot-up
PCB:
  • ATX form factor
  • 24,5cm (9,64") x 30,5cm (12")
II. Layout:
III. Reviews:
User-Review von Öse:
http://www.hardwareluxx.de/community/showpost.php?p=11771090&postcount=1
http://www.ninjalane.com/reviews/motherboards/lanpartydk-790fxb-m3h5
IV: Links:
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a417781.html
kühler
Anhang:
Kompatible Kühler:
Die Sockelhalterung entspricht exakt der AM2(+) version, daher passen alle Kühler die auch mit dem M2RS(H) kompatibel sind.
Passende Wasserkühler:
Das Boardlayout entspricht ebenfalls dem des M2RSH, daher passen alle Wasserkühler die auch mit dem 790FXB-M2RS(H) verwendet werden können.
Wo ist denn der Root-Link zu den ganzen Beta BIOS Files und was ist das aktuellste?
Was bedeutet das hier und wie führt man das durch:
!!!WARNING!!! Update "D7SDxxx.ABS" bevor Biosupdate !!!WARNING!!!
die root-links funktionieren nicht.
du musst über
http://lp.lanparty.com.tw/portal/CM
dort via "download" model auswählen und dann BIOS beta-site. sind dann alle gelistet.
die warnung kannst du ignorieren wenn du kein ABS benutzt.
falls doch: das update unter windows in der ABS-software mit dem .abs-file, findest auch auf der seite.
Danke dir! Heißt also, wenn ich traditionell unter DOS per USB-Stick oder Boot-CD update, dann kann ich das ignorieren. Was heißt das ABS?
Vielleicht komme ich morgen endlich mal dazu meinen Rechner aufzubauen, dann kann ich endlich wieder mal nen schnellen Rechner benutzen.
Wieso ist mir das nicht aufgefallen?
du hast doch mich :d
viel erfolg !
das BIOS kannste ganz normal flashen, wie gewohnt.
das ABS auto boost system tut nichts anderes, als softwarebasiert BIOS-profile zu erstellen und zu laden. kann man aber genausogut und besser selber machen, im BIOS selbst, hast 4 bänke zur verfügung.
für mich n marketing-tool, benutzen tu ich es nich ;)
manual gibts hier:
http://dfics.dfi.com.tw/dfi_cs/ABS_Profile/ABS_M.pdf
viel spass beim zusammenbau
Hi wiesel201
ich dachte du hast dieses Bios drauf, ok nächste mal frage ich erst ;)
Und halt uns mal auf dem laufenden wie es gelaufen ist.
lg
So, geflasht, getestet, gestrandet: Es wird nix. Weder mit den Kernen 0,1,2 noch mit 0,1,3. Scheinen wohl beide Kerne so richtig im Allerwertesten zu sein. Nun, nächste Woche kommt noch mal ein 550BE rein, der zumindestens als Dreikerner stabil läuft, und als 4-Kerner geht der auch ins BIOS. Mal sehen ob dann alles funzt...
@Mafle21: BIOS hatte ich angegeben ;):
BIOS ist das aktuelle R7SD820A.
hi wiesel
das hab ich doch geflissentlich überlesen da es nicht alt klang :)
ich drücke dir die daumen.
lg
Für die Kompatibilitätslisten:
1) Thermalright Ultra 120 passt problemlos. Ist mit dem mitgelieferten Material sogar vertikal montierbar, wodurch sich alle 4 RAM-Slots belegen lassen. Vermutlich könnten auch die PWM noch mit einer anderen Kühlung belegt werden, eventuell sogar die Northbridge. Mal schauen, hab grad Temperaturen um die 50-60°, vielleicht mach ich da irgendwann mal was anderes drauf.
2) Corsair Dominator 1066 laufen problemlos. Ich hab 4 Riegel à 2 GB drin, grade aber nur mit 800 Mhz. Die 1066 probier ich in den Ferien.
Hoffentlich war das jetzt noch nicht bekannt, in der Liste stehts jedenfalls noch nicht drin.
Wollte nur sagen, dass ich die GSkill Ripjaws 2x2GB DDR3-1600 CL9-9-9-24 problemlos auf dem M3H5 betreibe.
Nur mal so eine Frage am Rande: Funktioniert C'n'Q denn nicht, wenn man auf dem DFI per Multiplikator übertaktet? Kann man dieses Manko irgendwie umgehen, zur Not auch mit Tools ala K10Stat?
Okay, hier auch noch was für die Kompatibilitätsliste :)
Board:
790FX-M2RS
CPU-Kühler:
Cooler Master V8, keine Modifikationen nötig, passt wunderbar , auch die RAMS danach *g*
RAM(s):
A-DATA XPG G Series DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (AD2800G002GM(O)U2K/AX2U800GB2G5-AG) - läuft prima, wird jedoch mit 5-5-5-18 erkannt, Manuelles Umstellen kein Problem :)
GeIL Ultra DIMM Kit 4GB PC2-8500U CL5-5-5-15 (DDR2-1066) (GX24GB8500C5UDC)- läuft prima, wird sofort richtig erkannt
Einzig was mich stört sind die 60-61° der NB im Idle / 2D Windows Modus (2 Karten im Crossfire Modus davor die genau da hin heizen). Kennt einer ne gute Lösung zum Kühlen? NB Kühler/Lüfter die in die Höhe gehen, sind durch den Cooler Master V8 der sich etwas breit macht leider nicht möglich *ggg*
P.S. Suche noch die 790FX-M2RSH Heatpipe.. Hat einer vielleicht eine über (durch Wakü Umbau)? Bitte melden. :hail: Danke
für das M3H5 kann ichs leider nicht sagen. für die AM2+ boards wurde das mit dem aktuellen BIOS gefixt. C&Q läuft nun bei verändertem multi.
schau doch mal ob du das neueste BIOS drauf hast.
mit K10STAT kannst du natürlich arbeiten, funktioniert tadellos. multi, vcore, cpu-nb-voltage etc. lässt sich problemlos an die 4 P-states anpassen.
p.s. ich glaub die startseite wird nichtmehr gepflegt , da lord86 2 oder 3 boards abgeraucht sind ^^
Habe vorhin das letzte Beta BIOS geflsht, was ich auf der DFI Seite gefunden habe: http://img.lanparty.tw/Upload/BIOS/CM/D7SDA09.zip
Jedenfalls hab ich manuell den Multi im Moment auf 19,5 und der geht im IDLE nicht mehr mit dem Multi runter. Hatte damals auch das Problem mit nen DFI Board.
Wobei ich im Moment ziemlich begeistert bin von meinem AMD System. In keinster Weise kann ich sagen, dass das Intel besser war. Muss jetzt nur mal meine Sig aktualisieren... 3,8GHz gehen schonmal mit Standard-VCore. Teste grad 3,9GHz @ standard VCore. Ist lustig, für den Intel Q6600 brauchte ich ca. 1,5V für 3,4GHz.
---------- Beitrag hinzugefügt um 22:41 ---------- Vorheriger Beitrag war um 22:20 ----------
Ach ich hab noch was vergessen: Wie warm darf die SB werden und reicht beim M3H5 der Standard-Kühler auf der SB? Ich habe nur einen Wasserkühler auf der NB montiert, zur Not könnte ich einen noch auf die SB machen, aber wenn es nicht unbedingt muss, würde ich es gerne lassen.
also bei mir funktioniert C&Q bis multi 18,5 .. danach nichmehr. rest musst du per referenztakt machen.
über die SB hab ich mir noch keine sorgen gemacht, auch nicht aktiv gekühlt.
p.s. 3,8GHz bei standard vcore find ich sexy :d
Geht beim M2RS(H) auch. Angeblich soll das eingetragene Stepping Auswirkungen auf die Übertaktbarkeit der CPU haben.
Ok, heißt also, wenn ich einen C3 habe muss ich im BIOS PE3 auswählen. Ist ja PE0 bis PE3 als Stepping möglich. Bringt die Eintragung was, wenn ich ACC aus habe?
Noch ne andere Frage:
Wie bekommt ihr Command-Rate 1T stabil zum laufen? Weil bei mir zickt das bissl rum und will nur im Moment mit 2T.
das ist einer der gründe, der andere ist, dass ich gerade ne woche im urlaub war ;) wenn ich noch zeit und muße finde werde ich noch updaten. und es waren 3 :fresse:
p.s. ich suche immer noch jemanden der den thread hier übernimmt ;)
Hallo Leute, erstmal wünsch ich allen ein frohes Fest.
So nun zu meinem problem, ich will das neuste Bios Flashen auf das DFI Lanparty DK 790FXB M2RSH. Habe allerdings Windows 7 drauf, nun zu meiner frage kann ich das ruhigens gewissens mit dem Tool "WinFlash192" machen oder muss ich es unbedingt mit einem "bootable usb stick" machen so wie es bei DFI auf der internet seite für Windows Vista beschrieben ist?
Danke schon mal für eure hilfe...
Hallo zusammen,
ich wollte hier mal nach Erfahrungswerten nachfragen.
Habe einen PII X4 920, und muss daher über den Ref.-Takt OC´en.
Mein Board mach aber mehr als 250 x 14 nicht mit. Hat einer erfolgreich seinen PII mit mehr als 250 MHz Ref.-Takt OC´en können? Vor allem funnt C & Q dann noch?
AN alle ein schönes Fest
Hallo Flexxx
ja du solltest es wie unter vista betrachten also kein winflash nutzen.
Hi mgbott
ja nach einigen versuchen hab ich meinen reftakt auf 287 bekommen mit meinen X3
dazu ein parr hinweise, um 250 war bei fast jedem eine wand wo man denkt es geht nicht weiter, ich hatte damals dann den ht und nb auf 1ghrz runtergneommen die speicher ganz runter genommen und die NB stannung und die CPU-NB vid etwas erhöt
das ganze war etwas langwierig sodas du da recht viel gedult brauchst für.
lg
Alles klar, Danke.
Mein letztes DFI ist schon eine Weile her :d
@Mafle21
ok danke für die info, hat alles geklappt per USB Stick.
Warum ist das so das man bei Vista und Win7 kein WinFlash mehr nutzen soll? Wegen der Kompatibilität ?
Hallo Luxx`er,
ich habe nun meinen PC "unter Wasser gesetzt".
Vor dem hatte ich problem mit der NB Temperatur meines Boards. Ich hatte folgende Temps im Bios:
CPU 34°C
System 39°C
Chipset 68°C
Vor den Chipsatz habe ich dann noch einen kleinen Lüfter gesetzt, damit ich noch ein paar Grad raushole.
Nun nachdem ich die Wakü eingebaut habe habe ich folgende Werte:
CPU 20°C
System 34°C
Chipset 47°C
Da dies meine erste Wasserkühlung ist wollte ich mal fragen, wie ihr die Temps findet. Also die CPU kommt mir gut gekühlt vor, beim System hätte ich eine niedrigere Temp erwartet ebenso wie beim Chipset.
Wie gesagt die Temperaturen sind ohne Belastung, einfach im Bios gestartet.
Dann habe ich noch eine Frage und zwar zur NB Spannung. Ich habe hier im Forum mal gelesen, dass die so bei 1,15V liegen sollt. Ich habe nun im Bios mal unter Genie BIOS Setting --> PMW Setting mal nachgeschaut, dort steht für die NB folgende Werte:
Core 1,25V
PCIe 1,12V
HT 1,27V
Sind die zu hoch und darum die Temperatur auch?
Grüße Mikester
hi Mikester
die temps sind in ordnung, ich hatte mit nem wakü block auf der nb auch so 45°C. Liegt wohl am temp sensor, denn eigentlich hat der 790FX und 790GX nur ne verschwindend geringe verlustleistung.
1,25V auf der NB-core sind noch sehr human, ich hab dauerhaft 1,35V drauf ;)
mfg Ferry
Also sind die Temps der NB real niedriger?
ich wollt mein Bios Updaten und habe das sonst immer mit disketten laufwerk gemacht. Habe aber keins mehr drine. Mit Winflash will ich es nicht machen. Also bleibt nur noch per USB stick bootbar. ok ich habe mir die Anleitung bei DFI angeschaut und mein Stick bootbar gemacht. Kann da was passieren per USB stick oder is das das selbe wie Diskette?
Oder sind nicht alle USB Sticks Kommpatibel zum Booten
