[Sammelthread] DFI LANparty DK 790FXB-M2RS / -M2RSH / -M3H5 / 790GX-M2RS (AMD 790FX / 790GX) [2]
Sammelthread
Inhaltsverzeichniss:
top
AM2+
AM3
Anhang:
AM2+
AM3
Vorwort:
Da die Boards nahezu identisch ausgestattet sind habe ich nur die Details zusammengefasst, die sich von den anderen unterscheiden. Die Features die fehlen, kann man vom M2RSH übernehmen.
Nun gehts also los mit dem Sammelthread der DFI Lanparty DK series:
AM2+:
790FXB
DFI Lanparty DK 790FXB-M2RS
I. Technische Details zum Board:
CPU:
  • AMD Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
  • Socket 940 AM2 65nm
Chipset:
  • Northbridge: AMD 790FX
  • Southbridge: AMD SB750
System Memory:
  • Four 240-pin DDR2 DIMM sockets
  • Supports DDR2 667 and DDR2 800 DIMMs
  • Supports dual channel (128-bit wide) memory interface
  • Supports up to 8GB system memory
  • Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots
    - 2-way or 4-way CrossFire at x16/x16/NC bandwidth
    - 3-way CrossFire at x16/x8/x8 bandwidth
    - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
  • 3 PCI slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM overclocking
  • CPU/DRAM/Chipset overvoltage
  • 8Mbit flash memory
  • AM3 support ab BIOS-Version R7SD327 (beta), bzw. R7SD421 (final)
Audio:
  • Realtek ALC885 8-channel HD Audio Codec
  • High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN:
  • Marvell 88E8053 PCIE Gigabit LAN controller
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Power Management:
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 Keyboard/Mouse
  • Wake-On-USB Keyboard/Mouse
  • Wake-On-Ring
  • Wake-On-LAN
  • RTC timer to power-on the system
  • AC power failure recovery
Hardware Monitor:
  • Monitors CPU/system/chipset temperature
  • Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature during system boot-up
IDE:
  • One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Serial ATA with RAID:
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O:
  • 1 mini-DIN-6 PS/2 mouse port
  • 1 mini-DIN-6 PS/2 keyboard port
  • 1 optical S/PDIF-out port
  • 1 coaxial RCA S/PDIF-out port
  • 6 USB 2.0/1.1 ports
  • 1 RJ45 LAN port
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
Internal I/O:
  • 2 connectors for 4 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 front audio connector
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 4 Serial ATA connectors
  • 1 40-pin IDE connector
  • 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 6 fan connectors
  • EZ touch switches (power switch and reset switch)
PCB:
  • ATX form factor
  • 24.5cm (9.64") x 30.5cm (12")
II. Layout:
III. Reviews:
http://www.ur-hardware.com/mainboard/40-review-dfi-lanparty-dk-790fx
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...ormal&mode=view&downloadFlag=false&itemId=539
Treiber: http://www.dfi.com.tw:8080/portal/C...normal&mode=view&downloadFlag=true&itemId=539
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383889.html
M2RSH
DFI Lanparty DK 790FX-M2RSH
CPU:
  • AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron
  • HyperTransport 3.0 (5200MT/s for AM2+)
  • AMD OverDrive provides tuning options using the new“Advanced Clock Calibration” overclocking feature.
  • Socket 940 AM2+ 65nm
Chipset:
System Memory:
  • Supports DDR2 667/800/1066 MHz DIMMs
Expansion Slots:
  • 3 PCI slots
II. Layout:
III. Reviews:
http://www.modreactor.com/english/R...XB-M2RSH-AMD-LanParty-Motherboard-Review.html
http://www.overclock.net/amd-motherboards/399854-smt-review-dfi-lanparty-790fxb-m2rsh.html
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Treiber: http://www.dfi.com.tw:8080/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=driverTab&windowstate=normal&mode=view&downloadFlag=true&itemId=547
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383891.html
790GX
DFI Lanparty DK 790GX-M2RS
CPU:
Chipset:
  • Northbridge: AMD 790GX (RS780)
Expansion Slots:
  • 2 PCI Express (Gen 2) x16 slots
    - Hybrid CrossFireX - combination of the integrated graphics and a discretegraphics card in a PCIE slot (8-lane port).
    - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports)bandwidth
  • 1 PCI Express x1 slot
  • 3 PCI slots
Graphics:
  • Integrated ATI Radeon HD 3300 graphics core
  • One DVI-I connector for digital LCD display (ACHTUNG!! DVI Anschluss nur als Pin-Connector ausgeführt)
  • Microsoft® DirectX 10
  • Hybrid CrossFireX technology combines the onboard GPU and adiscrete PCIE graphics card
  • Onboard Performance cache for added performance
II. Layout:
III. Reviews:
http://www.madshrimps.be/?action=getarticle&articID=894
IV. Links:
Link zum "DVI-Problem": http://www.csd.dficlub.org/forum/showthread.php?t=8221
Treiber: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a356442.html
Lanparty JR Sammelthread: http://www.hardwareluxx.de/community/showthread.php?t=590779
hex
Anhang:
Für erweiterte Optionen im BIOS F9 drücken!
Achtung an alle Extrem-OC´er: das Board zeigt nur maximal -83°C an !
Hexcode Tabellen Für CPU-NB-VID und NB-Multi(790FXBM2RS/H):
tabelle
Vergleich zwischen den Boards:
kühler
Kompatible Kühler:
790FXB-M2RS(H):
passt:
Cooler Master Hyper TX (bläst nach hinten)
EKL Alenföhn Groß Clock'ner Blue Edition (bläst nach hinten)
EKL Alpenföhn Brocken (bläßt nach oben)
Scythe Infinity/Mugen (bläst nach oben)
Thermalright IFX-14 (bläst nach hinten), (ACHTUNG: bei verwendung der Thermalright Backplate auf Isolierung achten!)
Thermaltake GunMetal Orb (bläst nach unten)
OCZ Vanquisher (bläst nach oben)
Xigmatek HDT-S1283 (bläst nach oben)
Zalman CNPS 9500AM2 (nach hinten)
passt mit Modifikationen:
passt nicht:
790GX-M2RS:
passt:
passt nicht:
passende Wasserkühler für NB/SB und Spawa´s gibt es bei Anfi-tec oder Watercool
Lochabstände vom NB-kühler, Danke an Andreoid von Anfi-tec :bigok:
ram
RAM Kompatibilitätsliste:
790FX-M2RS/H:
läuft:
Cellshock 2x 1GB DDR2-667 (CS2110650)
GeIL DIMM 4 GB kit DDR2-800 (GX24GB6400C4UDC)
G.Skill Pi Series 4GB DDR2 1100 (F2-8800CL5D-4GBPI)
G.Skill 4GB kit DDR-1000 (F2-8000CL5D-4GBPQ)
Kingston HyperX 4GB kit DDR-1066 (KHX8500D2K2/4G)
Mushkin 4GB kit DDR-1066 (996599)
OCZ Platinum XTC 4GB kit DDR-800 (OCZ2P10004GK)
OCZ Titanium 4GB kit DDR-1150 (OCZ2T11504GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800C32GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800EB2GK)
OCZ Reaper HPC 2x2GB kit DDR2-1066 (OCZ2RPR10662G), (Tony´s SPD)
OCZ XTC Platinum 2 GB kit DDR2-1066 (OCZ2N10662GK)
macht Probleme:
läuft nicht:
Vollbestückung:
4GB
2x1GB OCZ Reaper (OCZ2RPR800C32GK) + 2x1GB OCZ Reaper (OCZ2RPR800EB2GK)
DDR800 | CL4-4-4-12 | Vdimm 2,0V
4x1GB Aenon Xtune DDR1066 | CL5-5-5-15 | Vdimm 1,85V
6GB
2x2GB Geil Ultra Plus (GX24GB6400C4UDC) + 2x1GB Cellshock
DDR800 | CL4-4-4-10 | Vdimm 1,85V
8GB
4x2GB G.Skill Pi Series (F2-8800CL5D-4GBPI) | DDR800 | CL5-5-5-18 | Vdimm 1,9V
2x4GB kit Mushkin XP2-8000 (996591) | DDR1000 | CL5-5-5-15 | Vdimm 2,1V
2x4GB kit
Mushkin DDR-1066 (996599) | DDR1066 | CL5-5-5-15 | Vdimm 2,05V
790GX-M2RS:
läuft:
Aeneon Xtune DIMM 2 GB DDR2-1066 Kit (AXT760UD00-19DM97-K-2G)
macht Probleme:
OCZ Reaper HPC 2 GB DDR2-1066 Kit (OCZ2RPR10662GK); (abstürtze mit 1066Mhz)
läuft nicht:
Vollbestückung:
4GB
6GB
8GB
Tipps für 8GB RAM bei 1066Mhz *klick*
FAQ
FAQ:
Q: Ab welcher BIOS-Version bietet das Board Deneb-Support?
A: Ab FinalVersion R7SDC26
Q: Ab welcher BIOS-Version bietet das Board AM3-Support?
A: Ab Final Bios R7SD421 bzw. ab Beta R7SD327
Q: Mit welcher BIOS-Version lassen sich die X3´s freischalten?
A: Beta Version R7SD310A
Q: Wie flashe ich mein BIOS mit einem USB-Stick?
A: Tutorial auf der DFI-Club-Seite *klick*
Eine deutsche Übersetzung der POST Codes aus dem Handbuch findet ihr HIER
under construction...
AM3:
m3h5
DFI Lanparty DK 790FXB-M3H5
CPU:
  • AMD Phenom II processor
  • HyperTransport 3.0 (5200MT/s), HyperTransport 1.0 (2000/1600MT/s)
  • AMD OverDrive provides tuning options using the new "Advanced Clock Calibration" overclocking feature.
  • Socket 938 AM3 45nm
Chipset:
System Memory:
  • Four 240-pin DDR3 DIMM sockets
  • Supports DDR3 1600 (O.C.)/1333/1066Mhz
  • Supports non-ECC unbuffered DIMMs
  • Supports up to 16GB system memory
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots - 2-way crossfire at x16/x16 or x16/x4 bandwith - 3-way crossfire at x16/x16/x4 bandwith
  • 3 PCI-Slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM Overclocking
  • CPU/DRAM/Chipset Overvolting
  • 8Mbit SPI Flash Memory
Audio:
Lan:
  • Marvell 88E8056 PCIE Gigabit LAN controller
  • SATA speed up to 3GB/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
IDE:
  • One IDE connector allows up to two UltraDMA 133Mbps hard drives
Rear Panel I/O Ports:
  • 1 RJ45 LAN port
  • line-in, line-out (front R/L) and mic-in jacks
I/O Connectors:
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 6 Serial-ATA connectors
  • 6 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power and reset switch)
Power Management:
  • ACPI STR (Suspend to RAM) funktion
  • Wake-On-Ring
  • Wake-On-LAN
Hardware Monitor:
  • Monitors 12V/5V/3,3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • CPU Over Heat Protection function monitors CPU temperature during system boot-up
PCB:
  • ATX form factor
  • 24,5cm (9,64") x 30,5cm (12")
II. Layout:
III. Reviews:
User-Review von Öse:
http://www.hardwareluxx.de/community/showpost.php?p=11771090&postcount=1
http://www.ninjalane.com/reviews/motherboards/lanpartydk-790fxb-m3h5
IV: Links:
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a417781.html
kühler
Anhang:
Kompatible Kühler:
Die Sockelhalterung entspricht exakt der AM2(+) version, daher passen alle Kühler die auch mit dem M2RS(H) kompatibel sind.
Passende Wasserkühler:
Das Boardlayout entspricht ebenfalls dem des M2RSH, daher passen alle Wasserkühler die auch mit dem 790FXB-M2RS(H) verwendet werden können.
@Bulldog72:
OK, I will make a Video of the error wich i described to you so long. The video will be finished at Friday 10:30PM GMT+1
I will post the Video here and in the forum of DFI Club.
I think the reason of this escalation is that my english is to bad to describe the error as i want.
@ Bulldog72
There might be a problem with the CMOS or something around it.
@ Bulldog72
That is unlikely. A BIOS is at heart nothing more than a small bit of software code. If something was wrong with that code the entire board wouldn't start. It is far too simple too be adaptive. If a BIOS version was published with flaws in it then everyone else would be reporting this issue with it. In all my years of working with troublesome motherboards I have never seen a BIOS work in such a way that one part of it was in error and the rest worked. In a nutshell either a BIOS works 100% as programmed or is dead.
@Bulldog72:
Please, I've never said that the BIOS is corrupted.
I will test the tipps wich are posted at DFI Club this day and i hope tht this will work.
I won't declare a war or semething, but i hope you can understand that i want to have a 100% working board. So please don't take this personaly.
@all:
im DFI Club Forum gabs nen Tipp der mir sinnvoll und erfolgsversprechend scheint. Es hat mit dem ABS System des Boards zu tun welches mit einem BIOS flash im Werk nicht mehr für meine CPU ausgelegt sein könnte.
Als Beispiel für einen neuen Flash des ABS Systems wurden andere CMOS Reload Settings angegeben, Sprich wenn andere Settings da waren als vorher (welches ja bei mir der fall war) könnte das ein beleg dafür sein das das ABS System geändert wurde
English translation for Bulldog72:
There was a tip in the DFI Club forum wich sounds like it could help. It has to do with the ABS system of the board wich could be not ok with my cpu. In DFI Club was an example wich said that some different CMOS Reloaded Settings could be a proof for a different ABS System than before.
Extra Text for Bulldog72:
If that tipp will help and my board will run as ike before, then I'm happy and will not annoy you anymore.
@Bulldog72:
It's always just business with me:) People do all kinds of crazy things with DFI boards thou so I often have to be quite strict.
Hey Leute, hab ein riesen Problem und hoffe ihr könnt mir da helfen. Also, da mein alter CPU-Kühler zu breit war, um ihn mit hohen Speichern auf dem Dfi 790fxb laufen zu lassen hab ich mir nen Schmalen Kühler bestellt, den Xigmatek Hdts1283. Er ist nun heut gekommen, wollte ihn montieren und da musste ich feststellen, dass die Halterung für den Kühler horizontal auf dem Board sitzt, also nun auch der Xigmatek nicht passt weil er nun vertikal, statt horizontal da drin sitzt :wall:
Weiß vielleicht jemand was ich nun machen kann bzw ob es die halterung für den Kühler für DFI Boards extra zu kaufen gibt, dass ich den dann auch rein bekomm!?
Wenn das nicht funktionieren sollte, muss ich ja weiter den Boxed nehmen, da kein anderer vernünftiger reinpassen würde und das kann ja eigentlich nich sein oder!???
Gerschi
Hi gerschi
du meins dieses hier.
wenn du es holst berichte mal drüber könnte das auch gebrauchen ;)
lg
Du hast nicht nur, wie vorher beschrieben, PWM Control von "Auto" auf "Manual" gestellt, sondern auch die Spannung von Speicher und angehoben. Somit kommen diese Komponenten natürlich auch als Fehlerquelle in Frage.
Was passiert, wenn Du PWM Control auf "manual" stellst, aber keine Spannung anhebst?
Wenn der Rechner dann starten sollte:
Was passiert, wenn Du nur die Speicherspannung bzw. nur die CPU-Vcore anhebst?
es passiert nie etwas anderes als im video, das is ja mein Problem. Nur wurde mir gesagt ich soll die Spannungen auf default setzen was ja bei meinem RAM 2,2V sind und der CPU hab ich einfach so ma 0,1V mehr gegeben.
Egal was ich mache, was ich verändere, alles klappt. nur wenn ich versuche die Spannung von auto auf manuell zu stellen oder anzuheben läuft nix mehr
Passiert das auch in Minimalkonfiguration (nur CPU und Kühler, ein Speicherriegel, Grafikkarte und Netzteil, alles andere abgeklemmt)?
Dann mach doch davon auch mal ein kleines Video (Minimalkonfiguration, im BIOS nur PWM control auf Auto, alle Spannungen unverändert lassen) und schick es an Mr. Sm..., dann begreift er vielleicht worum es geht.
So, das teil ist jetzt angekommen!
Der einbau war relativ einfach und der Kühler sitzt Bombenfest.
Allerdings bezweifel ich, dass man einen größeren Kühler, als den Xigmatek HDT S1283 drauf bekommt, wenn man hohen RAM hat. Zwischen RAM und Kühler ist noch ca 0,5mm platz :eek:
Die Montagehöhe für den Kühler sollte sich eigentlich nicht ändern durch den Einsatz des Montagekits. CPU und CPU-Sockel werden schließlich nicht in ihrer Höhe verändert.
Nein, konnte den Kühler aber nur vertikal befestigen(mit der Standardboardbefestigung) und durch das Kit kann man ihn nun auch senkrecht montieren und trotzdem ist zum RAM nur sehr sehr wenig Platz.
Hey, hat einer von euch Erfahrung mit dem Auto boost system von dfi.
man muss ja beim system start f1 drücken, bei mir lädst aber wahllos aus einer der 4 bänke??? Kann man da irgendwie einstellen, dass es von einer speziellen Bank lädt???
gruß
gerschi
So habe da ein kleines Problem mit meinem DK und zwar wenn ich übertakte auf 3,6 ghz und dann CnQ wieder aktiviere habe ich das problem das er wieder nur bis 3ghz hochtaktet.
Nochwas habe mir überlegt auf einen 955 BE im C3 Stepping aufzurüsten was meint ihr lohnt das ?
MFG
welches BIOS haste drauf? mit dem aktuellen sollte C&Q bis multi 18 funktionieren.
die 965 C3 gehen ganz gut, brauchen etwas weniger vcore und einige schaffen auch locker die 4GHz bei guter kühlung.
lohnen tut es sich für nen benchmark oder langen ~piep~ :d
kommt drauf an was du vorhast ;)
Hallo
habe noch die Version vom 20.01.2009 drauf. R7SD120 müsste das sein. Denke ich sollte mal ein Update machen. Welche Methode empfehlt ihr unter Vista64. Was ich vorhabe naja ich wollte mit dem verbrauch runter. Das mit dem CnQ nervt etwas.
MFG
Weis jemand wo der Sensor für die Chipsatztemperatur sitzt? Unter der NB direkt links neben der CPU oder über der dem ersten PCIe Slot, oder ganz wo anders?
Grüße Mikester
In den alten Bios Versionen gibt's kein Down-Core, oder..? Hau vielleicht mal Öse oder jemanden im DFI Forum an, dann wird's bestimmt irgendwann gefixt.
Ich habe mich vor mittlerweile 3 Wochen im DFI-Forum angemeldet. Die Jungs haben mir auch den einen oder anderen Tip gegeben, aber geholfen hat es letztendlich nicht.
Gleichzeitig habe ich Kontakt zum DFI-Support aufgenommen. Schmidtchen-Schleicher vom Support war aber der Meinung, mir sei nicht zu helfen, da auf der DFI-Homepage kein aktuelleres BIOS zur Verfügung steht. Meine Bitte, sich doch einmal mit dem BIOS-Programmierer in Verbindung zu setzen wegen meines Problems (nur wenn man ein Problem kennt kann man sich mit ihm auseinandersetzen) ignorierte er. Klar, ich bin ja auch nur ein dämlicher Kunde... :rolleyes:
Nun gut, letztendlich habe ich das Problem auf meine Art gelöst: Das Board wird gewechselt, es kommt das gleiche rein wie beim Threadersteller. :bigok:
Habe jetzt seit gestern Abend mein erstes DFI (das M3H5) am laufen - gefällt mir eigentlich sehr gut. Ich hatte allerdings einen Schreck bekommen, als ich das erste Mal ins BIOS schaute...
:eek:
So viele Einstellmöglichkeiten habe ich vorher noch nie gesehen!
lol, da kuck ich nach wochen mal wieder hier in meinen thread und dann muss ich sowas lesen. das bekräftigt meine entscheidung noch mehr das msi gekauft zu haben. is schon heftig was sich der support da leistet, evtl stimmen die gerüchte ja doch dass sich dfi aus dem endkundenmarkt zurück zieht, würde zumindest dieses verhalten erklären :fresse:
das msi is auf jeden fall top, und es läuft jetzt schon länger als meine letzten 2 dfi´s :fresse:
Ist beim 790FXB-M2RSH irgend etwas bezüglich Netzteil-Inkompatibilitäten bekannt?
O.g. Mobo lief mit einem 450W BeQuiet NT über ein halbes Jahr problemlos, mit meinem neuen Cougar S 700 hat es keinen Monat ausgehalten.
Fehlercode 88 beim Booten und kein Bild.
Ich find die DFI Homepage echt das letzte, hab letztes mal 2 Tage gebraucht, bis ich ein neues bios downloaden konnte, da kam immer so ein http fehler :shake: Da is ja mehr werbung drauf als alles andere:confused:
Hmm.. Also mir iss nichts bekannt (was aber nichts heisst :p)
Hast Du vielleicht den ATX12V Stecker - oft bestehend aus 2x4-Pin Steckern die nicht verwechslungssicher sind) falsch nebeneinander in die 8-Pin Buchse reingesteckt? Das mögen die Boards nämlich garnicht und passiert schneller als man denkt wenn man nicht genau darauf achtet, ganz besonders wenn man noch eine Verlängerung benutzt :shot:
Aber es kann auch sein das das Board einfach nimmer wollte :p Gibt genug denen das Board frühzeitig über die Wupper gegangen ist. ;)
Das M2RSH Hat zwar ne Heatpipe auf der Northbrigde aber so wirklich kühl wird se auch nicht. Ich hab nen M2RS und hab jetzt nen 30x30er Lüfter draufgeschraubt *g* Hat ne Menge ausgemacht *g*
Aber ich hab hier auch ne Frage in die Runde der M2RS(H) Boardbesitzer ... Vielleicht kennt das ja wer :)
Und zwar hab ich ab und an mal kürzer oder länger irgend ein Warnsignal was ich aber nicht identifizieren oder zuordnen kann. Das Signal hört sich an als würde der aufgesteckte PC-Laustsprecher in verschieden Beep-Tönen (hört sich noch nid mal nach Beep-Tönen sondern eher nach melodischen Klängen an) immer wieder die gleiche Melodie spielet :eek: Sowas hab ich jedenfalls noch nie gehört.
An den Temperaturen kanns eigentlich nicht liegen CPU Ok, NB und SB (lüftergekühlt) OK, Festplatten Lüftergekühlt OK. Beide Grafikkarten absolut im Limit. Der Smartguardian zeigt auch bei den Spannungen alles im grünen Bereich an - nichts rot...
Bin völlig Ratlos was es sein könnte bzw auf was die Warnsignal-Melodie aufmerksam machen will :wall:
Greets
ch1ller
---------- Beitrag hinzugefügt um 04:25 ---------- Vorheriger Beitrag war um 04:16 ----------
:eek:
Jap geht mir auch so...
Schonmal F9 im BIOS gedrückt... Da kommen noch viel mehr Einstellungen zum Vorschein :hail:
Hi Advanced
Also mit einigen NT gab es probleme das Cugar war bisher aber noch nie dabei, aber wenn du sagt das sofort 88 kommt geht das Board mit einem anderen NT derzeit, nicht das du das Symtom hast wie leider einige das sich das Board mit 88 aufhängt.
@ch1ller
hm also da bin ich etwas platt wie muss ich mir das vorstellen deine "melodien" ich hatte früher mal ein MB lange her das hat ab und zu den empfang meiner TV karte leise wiedergeben bis ich den Spiecker abgebaut hatte, ok geht heute nicht mehr da auf Board gelötet, nein kann du mal genau nachschauen ob das vom Spiecker kommt?
lg
