[Sammelthread] DFI LANparty DK 790FXB-M2RS / -M2RSH / -M3H5 / 790GX-M2RS (AMD 790FX / 790GX) [2]
Sammelthread
Inhaltsverzeichniss:
top
AM2+
AM3
Anhang:
AM2+
AM3
Vorwort:
Da die Boards nahezu identisch ausgestattet sind habe ich nur die Details zusammengefasst, die sich von den anderen unterscheiden. Die Features die fehlen, kann man vom M2RSH übernehmen.
Nun gehts also los mit dem Sammelthread der DFI Lanparty DK series:
AM2+:
790FXB
DFI Lanparty DK 790FXB-M2RS
I. Technische Details zum Board:
CPU:
  • AMD Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
  • Socket 940 AM2 65nm
Chipset:
  • Northbridge: AMD 790FX
  • Southbridge: AMD SB750
System Memory:
  • Four 240-pin DDR2 DIMM sockets
  • Supports DDR2 667 and DDR2 800 DIMMs
  • Supports dual channel (128-bit wide) memory interface
  • Supports up to 8GB system memory
  • Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots
    - 2-way or 4-way CrossFire at x16/x16/NC bandwidth
    - 3-way CrossFire at x16/x8/x8 bandwidth
    - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
  • 3 PCI slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM overclocking
  • CPU/DRAM/Chipset overvoltage
  • 8Mbit flash memory
  • AM3 support ab BIOS-Version R7SD327 (beta), bzw. R7SD421 (final)
Audio:
  • Realtek ALC885 8-channel HD Audio Codec
  • High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN:
  • Marvell 88E8053 PCIE Gigabit LAN controller
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Power Management:
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 Keyboard/Mouse
  • Wake-On-USB Keyboard/Mouse
  • Wake-On-Ring
  • Wake-On-LAN
  • RTC timer to power-on the system
  • AC power failure recovery
Hardware Monitor:
  • Monitors CPU/system/chipset temperature
  • Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature during system boot-up
IDE:
  • One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Serial ATA with RAID:
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O:
  • 1 mini-DIN-6 PS/2 mouse port
  • 1 mini-DIN-6 PS/2 keyboard port
  • 1 optical S/PDIF-out port
  • 1 coaxial RCA S/PDIF-out port
  • 6 USB 2.0/1.1 ports
  • 1 RJ45 LAN port
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
Internal I/O:
  • 2 connectors for 4 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 front audio connector
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 4 Serial ATA connectors
  • 1 40-pin IDE connector
  • 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 6 fan connectors
  • EZ touch switches (power switch and reset switch)
PCB:
  • ATX form factor
  • 24.5cm (9.64") x 30.5cm (12")
II. Layout:
III. Reviews:
http://www.ur-hardware.com/mainboard/40-review-dfi-lanparty-dk-790fx
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...ormal&mode=view&downloadFlag=false&itemId=539
Treiber: http://www.dfi.com.tw:8080/portal/C...normal&mode=view&downloadFlag=true&itemId=539
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383889.html
M2RSH
DFI Lanparty DK 790FX-M2RSH
CPU:
  • AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron
  • HyperTransport 3.0 (5200MT/s for AM2+)
  • AMD OverDrive provides tuning options using the new“Advanced Clock Calibration” overclocking feature.
  • Socket 940 AM2+ 65nm
Chipset:
System Memory:
  • Supports DDR2 667/800/1066 MHz DIMMs
Expansion Slots:
  • 3 PCI slots
II. Layout:
III. Reviews:
http://www.modreactor.com/english/R...XB-M2RSH-AMD-LanParty-Motherboard-Review.html
http://www.overclock.net/amd-motherboards/399854-smt-review-dfi-lanparty-790fxb-m2rsh.html
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Treiber: http://www.dfi.com.tw:8080/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=driverTab&windowstate=normal&mode=view&downloadFlag=true&itemId=547
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383891.html
790GX
DFI Lanparty DK 790GX-M2RS
CPU:
Chipset:
  • Northbridge: AMD 790GX (RS780)
Expansion Slots:
  • 2 PCI Express (Gen 2) x16 slots
    - Hybrid CrossFireX - combination of the integrated graphics and a discretegraphics card in a PCIE slot (8-lane port).
    - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports)bandwidth
  • 1 PCI Express x1 slot
  • 3 PCI slots
Graphics:
  • Integrated ATI Radeon HD 3300 graphics core
  • One DVI-I connector for digital LCD display (ACHTUNG!! DVI Anschluss nur als Pin-Connector ausgeführt)
  • Microsoft® DirectX 10
  • Hybrid CrossFireX technology combines the onboard GPU and adiscrete PCIE graphics card
  • Onboard Performance cache for added performance
II. Layout:
III. Reviews:
http://www.madshrimps.be/?action=getarticle&articID=894
IV. Links:
Link zum "DVI-Problem": http://www.csd.dficlub.org/forum/showthread.php?t=8221
Treiber: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a356442.html
Lanparty JR Sammelthread: http://www.hardwareluxx.de/community/showthread.php?t=590779
hex
Anhang:
Für erweiterte Optionen im BIOS F9 drücken!
Achtung an alle Extrem-OC´er: das Board zeigt nur maximal -83°C an !
Hexcode Tabellen Für CPU-NB-VID und NB-Multi(790FXBM2RS/H):
tabelle
Vergleich zwischen den Boards:
kühler
Kompatible Kühler:
790FXB-M2RS(H):
passt:
Cooler Master Hyper TX (bläst nach hinten)
EKL Alenföhn Groß Clock'ner Blue Edition (bläst nach hinten)
EKL Alpenföhn Brocken (bläßt nach oben)
Scythe Infinity/Mugen (bläst nach oben)
Thermalright IFX-14 (bläst nach hinten), (ACHTUNG: bei verwendung der Thermalright Backplate auf Isolierung achten!)
Thermaltake GunMetal Orb (bläst nach unten)
OCZ Vanquisher (bläst nach oben)
Xigmatek HDT-S1283 (bläst nach oben)
Zalman CNPS 9500AM2 (nach hinten)
passt mit Modifikationen:
passt nicht:
790GX-M2RS:
passt:
passt nicht:
passende Wasserkühler für NB/SB und Spawa´s gibt es bei Anfi-tec oder Watercool
Lochabstände vom NB-kühler, Danke an Andreoid von Anfi-tec :bigok:
ram
RAM Kompatibilitätsliste:
790FX-M2RS/H:
läuft:
Cellshock 2x 1GB DDR2-667 (CS2110650)
GeIL DIMM 4 GB kit DDR2-800 (GX24GB6400C4UDC)
G.Skill Pi Series 4GB DDR2 1100 (F2-8800CL5D-4GBPI)
G.Skill 4GB kit DDR-1000 (F2-8000CL5D-4GBPQ)
Kingston HyperX 4GB kit DDR-1066 (KHX8500D2K2/4G)
Mushkin 4GB kit DDR-1066 (996599)
OCZ Platinum XTC 4GB kit DDR-800 (OCZ2P10004GK)
OCZ Titanium 4GB kit DDR-1150 (OCZ2T11504GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800C32GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800EB2GK)
OCZ Reaper HPC 2x2GB kit DDR2-1066 (OCZ2RPR10662G), (Tony´s SPD)
OCZ XTC Platinum 2 GB kit DDR2-1066 (OCZ2N10662GK)
macht Probleme:
läuft nicht:
Vollbestückung:
4GB
2x1GB OCZ Reaper (OCZ2RPR800C32GK) + 2x1GB OCZ Reaper (OCZ2RPR800EB2GK)
DDR800 | CL4-4-4-12 | Vdimm 2,0V
4x1GB Aenon Xtune DDR1066 | CL5-5-5-15 | Vdimm 1,85V
6GB
2x2GB Geil Ultra Plus (GX24GB6400C4UDC) + 2x1GB Cellshock
DDR800 | CL4-4-4-10 | Vdimm 1,85V
8GB
4x2GB G.Skill Pi Series (F2-8800CL5D-4GBPI) | DDR800 | CL5-5-5-18 | Vdimm 1,9V
2x4GB kit Mushkin XP2-8000 (996591) | DDR1000 | CL5-5-5-15 | Vdimm 2,1V
2x4GB kit
Mushkin DDR-1066 (996599) | DDR1066 | CL5-5-5-15 | Vdimm 2,05V
790GX-M2RS:
läuft:
Aeneon Xtune DIMM 2 GB DDR2-1066 Kit (AXT760UD00-19DM97-K-2G)
macht Probleme:
OCZ Reaper HPC 2 GB DDR2-1066 Kit (OCZ2RPR10662GK); (abstürtze mit 1066Mhz)
läuft nicht:
Vollbestückung:
4GB
6GB
8GB
Tipps für 8GB RAM bei 1066Mhz *klick*
FAQ
FAQ:
Q: Ab welcher BIOS-Version bietet das Board Deneb-Support?
A: Ab FinalVersion R7SDC26
Q: Ab welcher BIOS-Version bietet das Board AM3-Support?
A: Ab Final Bios R7SD421 bzw. ab Beta R7SD327
Q: Mit welcher BIOS-Version lassen sich die X3´s freischalten?
A: Beta Version R7SD310A
Q: Wie flashe ich mein BIOS mit einem USB-Stick?
A: Tutorial auf der DFI-Club-Seite *klick*
Eine deutsche Übersetzung der POST Codes aus dem Handbuch findet ihr HIER
under construction...
AM3:
m3h5
DFI Lanparty DK 790FXB-M3H5
CPU:
  • AMD Phenom II processor
  • HyperTransport 3.0 (5200MT/s), HyperTransport 1.0 (2000/1600MT/s)
  • AMD OverDrive provides tuning options using the new "Advanced Clock Calibration" overclocking feature.
  • Socket 938 AM3 45nm
Chipset:
System Memory:
  • Four 240-pin DDR3 DIMM sockets
  • Supports DDR3 1600 (O.C.)/1333/1066Mhz
  • Supports non-ECC unbuffered DIMMs
  • Supports up to 16GB system memory
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots - 2-way crossfire at x16/x16 or x16/x4 bandwith - 3-way crossfire at x16/x16/x4 bandwith
  • 3 PCI-Slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM Overclocking
  • CPU/DRAM/Chipset Overvolting
  • 8Mbit SPI Flash Memory
Audio:
Lan:
  • Marvell 88E8056 PCIE Gigabit LAN controller
  • SATA speed up to 3GB/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
IDE:
  • One IDE connector allows up to two UltraDMA 133Mbps hard drives
Rear Panel I/O Ports:
  • 1 RJ45 LAN port
  • line-in, line-out (front R/L) and mic-in jacks
I/O Connectors:
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 6 Serial-ATA connectors
  • 6 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power and reset switch)
Power Management:
  • ACPI STR (Suspend to RAM) funktion
  • Wake-On-Ring
  • Wake-On-LAN
Hardware Monitor:
  • Monitors 12V/5V/3,3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • CPU Over Heat Protection function monitors CPU temperature during system boot-up
PCB:
  • ATX form factor
  • 24,5cm (9,64") x 30,5cm (12")
II. Layout:
III. Reviews:
User-Review von Öse:
http://www.hardwareluxx.de/community/showpost.php?p=11771090&postcount=1
http://www.ninjalane.com/reviews/motherboards/lanpartydk-790fxb-m3h5
IV: Links:
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a417781.html
kühler
Anhang:
Kompatible Kühler:
Die Sockelhalterung entspricht exakt der AM2(+) version, daher passen alle Kühler die auch mit dem M2RS(H) kompatibel sind.
Passende Wasserkühler:
Das Boardlayout entspricht ebenfalls dem des M2RSH, daher passen alle Wasserkühler die auch mit dem 790FXB-M2RS(H) verwendet werden können.
@ dongeilo: was hast du denn unter dem kühler? das pad? oder ne wlp?
und gruß / gratulation an die schwester xD feier schön :)
Das Pad!!!
Sent from my iPhone using Hardwareluxx
mmh
und geht turbo wenn cnq an ist?
oese schrieb:
mmh
Hab ich seit Jahren nicht mehr benutzt. Teste ich mal bei Zeit.
Hi @all,
ist es möglich eine ATI Radeon 5750 und eine Nvidea 9600GT als SLI Verbund zu betreiben? Würde das funktionieren?
Hi Tomish
nein, dazu benötigts du einen Hydra chip um das zu bewerkstelligen.
lg
@Tomish wie kommsten darauf? SLI nein, zusammen gleichzeitig betreiben geht, dafür brauchste nen board mit lucid hydra chip und da biste hier im gaaaaaaanz falschen Thread^^
(über den sinn oder unsinn dieser technologie mal ganz zu schweigen)
Danke für die Antworten! Hab die frage für nen Kollegen gestellt. Naja...wird er evtl. weinen! ;-)
Danke...
Was aber durchaus geht ist der Betrieb der Nvidia Karte als PhysX Knecht. Allerdings muss man da etwas mit den Treibern tricksen weil Nvidia das nicht so toll findet.
Jo Turbo geht. Also soweit alles fein. Ich mess mal die vcore...
Vcore ist ok. Idle soll 1,225v sein bei meinem prozzi, ist 1,223v. Turbo soll 1,475v sein, ist 1,476, normal Vcore idle soll 1,375v ist 1,374v unter last 1,388v. Also alles in bester butter...
Turbo kann disabled werden wenn man cnq ausschaltet...
Ich bin soweit erstmal zufrieden :)
Das ist ja cool mit dem neuen BIOS. Was schön wäre: C'n'Q aktiv und dazu Turbo deaktivieren. Da könnte ich das gleiche verhalten wie jetzt genießen. Also im IDLE runtertakten und bei Anwendungen, die Leistung brauchen, einfach volle Pulle! :d
hab grad bissl probs im cnq, es taktet nur die ersten beiden cores
hab aber win draufgemacht als er noch als 1-core erkannt war. mal sehen...
3,8GHz 1,375 v
Leerlauf: 130Watt ohne C&Q & C1E
Prime: 300Watt
LINX: 360Watt
3,8GHz 1,5 v
Leerlauf: 150Watt ohne C&Q & C1E
Prime: 400Watt
LINX: 460Watt
kein Wunder das das Board bei 1,55 v ausgestiegen ist. NT sollte aber ausreichen mit 700Watt.
teste mal bitte mit cnq, ob er alle cores taktet oder nur die ersten beiden. ich glaube das ist ein bug.
c1e funkt auch nicht.. naja ich habs mal dfi gemailt hoffe die fixen es schnell
Habe ich eben versucht, resultierte in einen Freeze unter Windows....
genau, c1e funzt nicht.
cnq? @std settings?
Hiho,
könnt ihr einen Luftkühler für das M2RSH für die Northbridge empfehlen?
Ich weiß nicht so recht ob der Xigmatek Porter oder der Thermalright hr-05 passen.
Grüße
KnallFrosch schrieb:
Hiho,
Grüße
Auf der Heatpipe ist das schwer, du musst mal die Sammelthreads durchwuehlen einige, mir eingeschlossen hatten nen paar Montiert, aber keine ahnung mehr welche das waren.
cnq? @std settings?
Morgen teste ich das. Freezed dein System auch mit c1E??
yap mit c1e freeze..
bestimmt ist DFI das auch noch aufgefallen deshalb ham ses wieder von der hp genommen..
muss ich erstmal ohne cnq und turbo auskommen.
geil ist allerdings der imc vom thuban. Vollbestückung ist kein Prob mehr jetzt, und die Wall oberhalb 1600mhz ist auch weg...
also ich hab auf die Northbridge-Heatpipe ein Tt Extreme Sprit gebaut
musste mit den halter etwas tricksen, ging dann aber
hatte allerdings erst bessere Temps nach dem ich in die Front noch ein Lüfter verbaut hatte, werde mogen mal ein bild machen
mmh also meine temps sind ok, chipsatz max 56°C pwm max 35°C 3500Mhz @ 1,280v NB @ 2500Mhz @ 1,265v 6GB linx-stable :)
Wakü? Paste oder Pad?
Standardkühler^^ mit Pad also..
WaKü mache ich meinen Kühler wenn überhaupt nur oben auf die heatpipe drauf, nicht mehr direkt auf die nb, der Kühler hat mir schon 2 NB's geschrottet wenn man später an die Schläuche kommt...
Am Freitag Bastel ich mit nem Kollegen, dann mache ich auch Paste auf die PWM´s unter den Wakühler.....
Mein Board mit ordentlichem Kühler ist noch zu haben, das weißt du ja aber..............................
So DFI hat sich gemeldet, c1e und cnq bugs sind bestätigt, wird dran gearbeitet.
von mir kleines Ergebnis:
:banana: find ich gut :) Und das sind 4 Dimms 1T das ging mitm Deneb niemals :)
Wie jetzt? Oese, ich hatte dich doch extra wegen der Vollbestückung mal angeschrieben. Da hast du doch auch gesagt, dass 1T mit Vollbestückung geht, nur musste der Multi fürn Ram auf 800 oder 1066 stehen. Hieß also: hoher HTT Takt, dann ging auch 1T beim Deneb unter Vollbestückung.
Wie schaut das jetzt aus? Kann der RAM Teiler auch bei 1333 1T erreichen oder wird das vom BIOS immernoch verworfen?
Mein PC steht momentan noch nicht an seinem Platz... Kann somit das BIOS noch nicht testen. Nen X6 fehlt mir auch noch, frage mich aber, ob ich mir überhaupt einen zulege... hab nur nen 550W Netzteil und die Graka zieht auch so viel. Mit nen X6 wird alles ziemlich knapp...
Wie gehen die 1055T zu Ocen? der 1090T ist mir zu teuer.
Hi Ultrazauberer
hm wenn ich mir so die Wattzahlen oben anschauen frage ich mich das auch die ganze zeit, aber ich hab ja das Am2+ und muss eh erstmal warten ob da was kommt.
lg
PS: Oese das sieht sehr nett aus was du da hast, was eigentlich mit dem M3H7 ?
@ Ultrazauberer: Das ist jetzt mit 1066er Teiler, nur per HTT OC. Ob das Bios bei 1333 auf 2T zurückgeht weiss ich nicht, teste ich aus. Das war in jedem Fall mit einem anderen Bios und einem Deneb, keinem Thuban. Mit dem Deneb konnte ich Vollbestückung nicht stabil kriegen. Der Thuban kann das jetzt...
Edit: Bei 1333 geht er doch wieder automatisch in den 2T-Modus. Ich werd DFI mal anmeiln ob die das evtl. ändern könnten, wenn der Thuban das schon kann :p
@ Mafle: Wenn Du nicht mega-oc'st geht das mit nem 550w. Der Prozzi braucht so wie oben gezeigt 285w Gesamtsystem unter Last, mit GraKabelastung real max. 350w, wenn Du mehr ocst, könnte es knapp werden, aber ansonsten müsste es reichen.
Das M3eH7 wird nicht auf den Markt kommen, ergo gibt es kein x6-Bios, daher hab ich das DK wieder drin..
Ähnliche Themen
