[Sammelthread] DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [11]
Zitat:
  • CPU
    • LGA 775 socket for:
      - Intel® Core2 Quad and Intel® Core2 Duo
    • Supports Intel Enhanced Memory 64 Technology (EMT64T)
    • Supports Enhanced Intel SpeedStep Technology (EIST)
    • Supports Intel Hyper-Threading Technology
    • Supports 1333/1066/800MHz FSB
  • Intel® chipset
    • Intel® chipset
      - Northbridge:
      Intel® P45 Express chipset
      Intel® Fast Memory Access technology
      - Southbridge: Intel® ICH10R
  • Memory
    • Four 240-pin DDR2 DIMM sockets
    • Supports DDR2 1200(O.C.)/1066/800/667 MHz
    • Delivers up to 12.8Gb/s bandwidth
    • Supports dual channel (128-bit wide) memory interface
    • Supports non-ECC unbuffered DIMMs
    • Supports up to 16GB system memory
  • Expansion Slots
    • 2 PCI Express (Gen 2) x16 slots - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
    • 2 PCI Express x1 slots
    • 2 PCI slots
  • BIOS
    • Award BIOS
    • 8Mbit SPI flash BIOS
    • CMOS Reloaded
  • Audio
    • Realtek ALC885 High Definition audio CODEC
    • 8-channel audio output
    • DAC SNR/ADC SNR of 106dB/101dB
    • Full-rate lossless content protection technology
    • Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
  • LAN
    • Marvell 88E8053 PCIE Gigabit LAN controller
    • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  • IDE
    • JMicron JMB363 PCI Express to PATA host controller
    • Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
  • Serial ATA with RAID
    • Intel Matrix Storage technology
    • Supports up to 6 SATA devices
    • SATA speed up to 3Gb/s
    • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • Rear Panel I/O Ports
    • 1 mini-DIN-6 PS/2 mouse port
    • 1 mini-DIN-6 PS/2 keyboard port
    • 1 optical S/PDIF-out port
    • 1 coaxial RCA S/PDIF-out port
    • 6 USB 2.0/1.1 ports
    • 1 RJ45 LAN port
    • Center/subwoofer, rear R/L and side R/L jacks
    • Line-in, line-out (front R/L) and mic-in jacks
  • Power Management
    • ACPI and OS Directed Power Management
    • ACPI STR (Suspend to RAM) function
    • Wake-On-PS/2 Keyboard/Mouse
    • Wake-On-USB Keyboard/Mouse
    • Wake-On-LAN
    • Wake-On-Ring
    • RTC timer to power-on the system
    • AC power failure recovery
  • Hardware Monitor
    • Monitors CPU/system/Northbridge temperature and overheat alarm
    • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    • Monitors the speed of the cooling fans
    • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
  • PCB
    • 4 layers, ATX form factor
    • 24.5cm (9.64") x 30.5cm (12")
Wasserkühlung NB-SB-Mosfets:
Wasserkühlung Zusammenstellungen vom "riverdief":
Luftkühlung:
Passt mit Problemen:
EKL Alpföhn Groß Clockner ( passt nur mit Modifikationen ...entweder am Kühler oder Chipsatzkühler )
Scythe Andi Samurai (gedreht)
Scythe Mugen 2 (der Lüfter muss 5mm verschoben werden)
Thermalright HR-01 Plus (gedreht)
Kompatibler Arbeitsspeicher:
A-DATA Vitesta Extreme Edition 2 GB PC2 9600
Cellshock DIMM Kit 2GB PC2-8500U CL5-5-5-15 (DDR2-1066) (CS2221550)
Chaintech Apogee GT DIMM Kit 4GB PC2-8500U CL5-5-5-15
Chaintech Apogee GT DIMM Kit 4GB PC2-9200U CL5-5-5-15 (DDR2-1150)R2-1150-4GDHS
Corsair DIMM 4 GB DDR2-800 DHX Kit (TWIN2X4096-6400C4DHX)
Corsair XMS2 Dominator 2GB PC2-8500U CL5-5-5-15 TWIN2X2048-8500C5D
Crucial Ballistix Tracer PC8500 1066MHz BL12864AL1065.8FE5
GeiL Value DIMM Kit 2GB PC2-6400U CL5-5-5-15 (DDR2-800) (GX22GB6400DC)
GeIL Ultra DIMM Kit 2GB PC2-8500U CL5-5-5-12 (DDR2-1066) (GX22GB8500UDC)
G.Skill Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8500U CL5-5-5-15 (DDR2-1066) (F2-8500CL5D-4GBPI-B)
G.Skill Kit 4GB PC2-8800U CL5-5-5-15 (DDR2-1100) (F2-8800CL5D-4GBPI)
G.Skill Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
G.Skill Trident Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBTD)
G.Skill DIMM Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
Kingston HyperX DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (KHX6400D2K2/4G)
OCZ Flex II 4GB Kit PC2-9200 CL5-5-5-18 (OCZ2FXT11504GK)
OCZ Reaper HPC Edition Kit 2GB PC2-9200U CL5-5-5-18 (OCZ2RPR11502GK)
OCZ Flex XLC Edition 4 x 1024 MB PC2-9600U @ 1200 Mhz
OCZ Reaper HPC Edition 2GB Kit PC2-9600 CL5-5-5-18 (OCZ2RPR12002GK)
OCZ Blade Low Voltage DIMM Kit 4GB PC2-9600U CL5-5-5-18 (DDR2-1200) (OCZ2B1200LV4GK)
Patriot Viper DDR2-800 4 GB
takeMS Mach2 2GB PC2-8500U CL5-5-5-18 TMS1GB264C082-105EP
TeamGroup Xtreem Dark 4GB Kit PC2-8500U CL5-5-5-15 TXDD4096M1066HC5DC-D​
Kompatibler Netzteile:
Biosupdate mit USB Stick
Anleitung vom Fresh_Thing
1. Programm runterladen und installieren.
2. Dos files und Bios runterladen - Bios findest du hier -> http://img.lanparty.tw/Upload/BIOS/CM/D45PD320.zip
Dann den pfad für die Dos files im programm angeben und den USB-Stick formatieren
3. Die 3 datein die beim Bios dabei sind auf den Stick kopieren.
4. Im Bios die setup defaults laden und direkt den USB-Stick als erstes Bootgerät einstellen.
Dann einfach nur neustarten und der Flash nimmt seinen Lauf​
USB-Stick Bootfähig machen !!!
Downloads
Wichtige Links
Real Volt - Messung im Windows @ IDLE
mit einem Q9550 E0 @ FSB 500 @ 4255 Mhz​
Gemessen vom mahaudi
CPU PLL ( Bios 1.55v.) ......Real : 1.578v...........Droop : + ~ 0.03v.
NB Core ( Bios 1.420v.) .....Real : 1.420v...........Droop : nichts
VDIMM ( Bios 2.218v. ) .....Real : 2.245v. .........Droop : + ~ 0.03v.
VTT ( Bios 1.280v. ) .......Real : 1.298v. ..........Droop : + ~ 0.02v.​
Messpunkte DFI LP DK P45-T2RS Plus
Wie bekommt man den C1-Fehler weg?
Hier die Lösung vom Fresh_Thing
ohne Rams booten
dann PC am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen Ram reinstecken und PC starten
.....wenn das nicht geht :
ohne Rams booten
noch mal ohne Rams booten und am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen ( Wichtig ) Ram reinstecken und PC starten​
VID-Bug Behebung!
Computer neu starten und ab ins BIOS
Load optimal Defaults
Computer herunterfahren
Netzteilstecker abziehen
Jumper umstecken und Batterie für ein paar Min. raus
Computer starten
Unter Hardware Monitoring nachschauen, ob die anliegende Spannung stimmt (C1E und EIST an!)
Mit F10 raus und wieder rein, dabei ist zu beachten, dass beim ersten Mal, niemals mehreren Einstellungen gleichzeitig getätigt werden dürfen
Sollte die anliegende Spannung stimmen, speichern und starten
Wenn das der Fall ist, seid Ihr den Bug für immer los!
Ansonsten, die CPU a+e!​
Smartguardian Design`s ( inkl.SG.exe vom UT P35 )
: http://rapidshare.com/files/18075196...DK_Edition.rar
Achtung!
Die mitgelieferten SATA-Kabeln können unter Umständen zum einem instabilen Betrieb führen, dies ist allerdings nicht immer der Fall.
Fazit:
Das Board kann echt eine Zicke sein und bestrafft auch den kleinsten Fehler mit einem Bluescreen/Reboot oder startet erst gar nicht, deshalb sollte man die Finger davon lassen, wenn man nicht genügend oder gar keine Erfahrung mitbringt, ansonsten bietet das Board mehr als genug Einstellungen und eine sehr gute Performance!;)
An dieser Stelle, möchte ich mich für die zur Verfügung gestellten Daten und wirklich gute Vorarbeit bei mahaudi bedanken!:hail:
Bildquellen:
patrock84 und [EKM] SeLecT , auch Euch beiden vielen Dank!:hail:
Alter Thread:
DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [10]
nb GTL und vref habe ich folgendes getestet:
22/63
22/61
23/63
23/61
24/63
24/61
da sind 24/63 und 23/63 das einzigste was bootet
die trfc ist immer auf 64
desweiteren habe ich den ram entspannt über 5:6 pl8 Normal/Normal 3xRelaxed trfc64 und dieses dingsda von 70 auf 60 (du weißt was ich meine ;) ) bis hin zu 1:1 und pl9
merke gerade, du meinst fsb 510 während ich schon bei fsb 520 bin, weil bei fsb 510 habe ich noch nicht so ausführlich mit den settings getestet....
das prime95 nicht funktioniert ist schon eher ein mysterium, bsp.w. bin ich gerade mit meinen 3,69ghz a´la 410x9 1233 pl6 on, zocke, habe nen player an, browse etc. pp und alles gleichzeitig und das funktioniert seit mindestens 6monaten, weil das mein 24/7 ist. aber wehe ich mache prime an, dann kommt das oben beschriebene!
eigentlich schon, mußte nur schon mal ne system wiederherstellung machen, da hatte ich es wohl mit dem ram zu wild getrieben..... nach 20 minuten memtest test 5 konnte ich nicht mehr booten.... aber das schließe ich eigentlich aus, den mein kalader mit prime zieht sich schon ne weile hin! will sagen ist nicht das erste os wo ich die probleme habe.
Wenn LinX läuft und die Large bei 1024k abschmiert, kann eigentlich nur Ram oder Prime selbst dahin sein, Du kannst schon mal folgendes tun, Prime=>Large FFT in Plase anklicken, dann auf Custom und von 768k bis 640k angeben, dann sehen wir mal was passiert.
hi, mit ein wenig verspätung!
Also wenn ich das obenbeschriebene mache, fängt prime mit 1024k an zu rechnen. Ist das richtig so, müßte das nicht mit 768k anfangen?
Das war mein Fehler sorry, im Fenster rechts die 768k eingeben und da wo 128k stehen, kannst 640k eigeben oder auch bei 128k lassen.
Habe ich mir schon fast gedacht ;)
na mal schauen wann ich dazu komme, jetzt muß ich erstmal den modded ati treiber testen! :d
Bin zur zeit immer mit 4.25 und 500 unterwegs.... seit ich nochmal die heatpipe runtergenommen habe um die auflage und den anpressdruck zu optimiert, sind die temperaturen nur noch traumhaft!
Stellt euch mal vor mein nb kühlkörper hatte wie so metallschorf, als wäre ein stück durchgebrannte nb verkrustet drann kleben.... aber das war metall, halt ein stück mit dem kühlkörper oh mann :fresse: und bei den spawas hatte ich mit kühlpaste anstatt siliconpads experimentiert, war nicht so optimal... ja, ja, ich bin halt ne spieler natur! (oh man wie komme ich nur dazu wp auf die spawas zu schmieren, da sich das bord ja verformt und die Kühlkörper der spawas, produktionsbedingt, eh nicht so perfekt sitzen)
ABER jetzt ist es perfekt, die nb temps steigen so alle +0.1v um 2-5°c unter last, die spawas gehen, mit eigen temperatur sensoren gemessen, zwischen den einzelnen modulen unter dem kühlkörper, auf max. 60-62°C bei ca. 20°c raumtemp und 4.25ghz @ fsb 500.
Dazu ist die kiste mit 4.25 unter last ruhig!!! und im idel silence (halt noch ruhiger wie ruhig) :d
hmm, vielleicht doch mal prime anschmeißen...
Du und Dein DK, Ihr seid quasi eins, ich glaube das DK ist Dir auch wichtiger, als die andere bessere Hälfte.:shot:
UHJJ36 schrieb:
Elpida Hyper MGH-N :fire:
Schöne Teile hast Du da, schick sie mir, ich würde sie gern für Dich testen.:d
Die Kunst bei obsessionen ist, irgendwann wieder damit aufzuhören!
Nein mal ernsthaft, man bekommt erfahrung nur durch testen, testen und gegen testen, das ist halt aufwendig und anfangs fehlerbehaftet.
Außerdem habe ich, außer hier, kaum einen Ort wo man erkennt, was für ein schnuckliges kisten ich da habe....
...aber irgendwie muß ich Dir recht geben, manchmal frage ich mich auch wen ich denn mehr liebe und ob ich zur polygamie überhaupt fähig bin....
---------- Beitrag hinzugefügt um 18:48 ---------- Vorheriger Beitrag war um 18:35 ----------
@nfzocker
hmm, prime fängt immer! mit 1024k an, egal was ich da eingebe!
---------- Beitrag hinzugefügt um 19:10 ---------- Vorheriger Beitrag war um 18:35 ----------
muaha, ich hab`s: exe mit rechtsklick als admin ausführen. aua
Geht mir genauso, zumal mein schwarzes Schätzchen, ist wesentlich stiller, als dat Helle!:asthanos:
Hi!
Ich habe PRobs mit dem DFI LP DK P45-T2RS PLUS und der Vollbestückung mit 8 GB RAM.
Beim Ram handelt es sich um G.Skill F2-9600CL5D-4GBPI Kit's.
Windows bootet zwar, doch gibt es bei Linx ständig einen BS. Interessant ist auch, dass bei der Verwendung von 768MB bei Lix ca 10 Durchläufe bei ca. 51 GFlops durchlaufen. Doch stelle ich 6144 MB ein, schaffe ich keinen einzigen Durchlauf (Die Zeit läuft ca 5 Minuten, bis es dann den BS gibt).
Folgende Einstellungen sind aktuell gespeichert (neustes Bios):
CPU Feature Page
Thermal Management Control................Enabled
PPM(EIST) Mode............................Enabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Auto
Execute Disable Bit.......................Enabled
Virtualization Technology.................Enabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown after AC loss....................Enabled
AC Shutdown free..........................Enabled
O.C. Fail Retry Counter...................1
O.C. Fail CMOS Reload.....................Disabled
CPU Clock Ratio...........................9 x
CPU N/2 Ratio.............................Disabled
CPU Clock.................................445 MHz
Boot Up Clock.............................Auto
CPU Clock Amplitude....................... 700mV
CPU Clock0 Skew........................... 0ps
DRAM Speed................................333/800
PCIE Clock................................100MHz
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Special Add.......................+75.0mV
DRAM Voltage Control......................2.100V
SB Core/CPU PLL Voltage...................1.550V
NB Core Voltage...........................1.245v
CPU VTT Voltage...........................1.25V
VCore Droop Control.......................Enabled
Clockgen Voltage Control..................3.45V
CPU GTL 0/2 REF Volt......................0.67X
CPU GTL 1/3 REF Volt......................0.67X
North Bridge GTL REF Volt ................0.63X
FSB Vref..................................23
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
T2 Dispatch...............................Disabled
Clock Setting Fine Delay..................Listed Below
Flex Memory Mode..........................Auto
CAS Latency Time (tCL)....................5
RAS# to CAS# Delay (tRCD).................5
RAS# Precharge (tRP)......................5
Precharge Delay (tRAS)....................15
All Precharge to Act......................Auto
REF to ACT Delay (tRFC)...................60
Performance Level.........................8
Read Delay Phase Adjust...................Listed Below
Write to PRE Delay (tWR)..................Auto
Rank Write to Read (tWTR).................Auto
ACT to ACT Delay (tRRD)...................Auto
Read to Write Delay (tRDWR)...............Auto
Ranks Write to Write (tWRWR)..............Auto
Ranks Write to Read (tWRRD)...............Auto
Read CAS# Precharge (tRTP)................Auto
ALL PRE to Refresh........................Auto
Read Delay Phase Adjust Page
Ch1 Read delay phase (4"0) 7-8-8-8-7 *******
Channel 1 Phase 0 Pull-In.................Auto
Channel 1 Phase 1 Pull-In.................Auto
Channel 1 Phase 2 Pull-In.................Auto
Channel 1 Phase 3 Pull-In.................Auto
Channel 1 Phase 4 Pull-In.................Auto
Ch2 Read delay phase (4"0) 8-8-8-8-7 *******
Channel 2 Phase 0 Pull-In.................Auto
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Auto
Channel 2 Phase 3 Pull-In.................Auto
Channel 2 Phase 4 Pull-In.................Auto
Clock Setting Fine Delay Pagey Menu
Ch1 DRAM Default Skew.....................Model 3
Ch2 DRAM Default Skew.....................Model 3
RCOMP Setting.............................Model 1
Fine Delay Step Degree....................70ps
Ch1 Clock Crossing Setting................Nominal
DIMM 1 Clock fine delay...................Current 1924ps
DIMM 2 Clock fine delay...................Current 1924ps
Ch 1 Control0 fine delay..................Current 194ps
Ch 1 Control1 fine delay..................Current 194ps
Ch 1 Control2 fine delay..................Current 110ps
Ch 1 Control3 fine delay..................Current 96ps
Ch 1 Command fine delay...................Current 194ps
Ch2 Clock Crossing Setting................Nominal
DIMM 3 Clock fine delay...................Current 1924ps
DIMM 4 Clock fine delay...................Current 1882ps
Ch 2 Control0 fine delay..................Current 152ps
Ch 2 Control1 fine delay..................Current 152ps
Ch 2 Control2 fine delay..................Current 70ps
Ch 2 Control3 fine delay..................Current 56ps
Ch 2 Command fine delay...................Current 152ps
Ch1Ch2 CommonClock Setting................Nominal
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
Folgende Veränderungen habe ich schon ausprobiert:
- PL von 8-12 verändert
- NB Core auf reale 1.28V erhöht
- FSB Vref auf 21 gestellt
- DLL and RCOMP auf 7-7-1 und 3x relaxed bzw 3x more relaxed (auch bei 3-3-1 ausprobiert)
Nichts brachte Veränderungen. Ich bin ratlos und bräuchte eure Hilfe!
Execute Disable Bit.......................Enabled - auf disable
Virtualization Technology...............Enabled - auf disable
VCore Droop Control......................Enabled - auf disable (da braucht man dann so ca 1-3x weniger vcore)
zumindest bis es erstmal läuft, dann kannste ja immer noch mal mit enabled testen
-Was für ne vid hat deine cpu?
-welches bios?
-Läuft das setting mit 4gb?
.....wenn du das noch nicht getestet hast, würd ich erstmal machen! und dabei die minimal nötige vtt und vnb ausloten, damit du ein anhaltspunkt hast! 4 riegel vs 2 riegel brauchen in der regel 1-3x mehr vnb und wenn überhaupt 1x mehr vtt. Beide werte finde ich bei dir recht hoch für fsb 445 (ich brauch da 1.12v vtt und 1.16v vnb für 4gb mit pl8 hab aber einen lowvidler!)
Die temp vom ram im blick?
bzw:
vdimm +1x testen - wenn nein
vdimm +1x und vnb +1x testen ...also ich meine insgesamt nur einmal vdimm erhöhen, nicht mehr!
nur mal so spontan was mir einfällt...
Mit nur einem Kit läuft das Setting.
Ich habe vergessen zu erwähnen, dass ich den Vdimm schon bis 2.192V hochgepumpt habe. (vnb war da auch bei 1.28V real eingestellt)
vtt und vnb sind in der tat hoch, da ich noch nie Zeit gefunden habe, das Minimum auszutesten.
VID liegt bei 1.25V
Die Temp des RAM kann ich dir nicht wirklich sagen. Die Heatspreader werden unter Last vllt etwas mehr als Handwarm.
Dazu sei auch gesagt, dass ich den Rechner mit 4 GB mit keinem vernünftigen setting bei 6x500MHz stabil bekommen habe (um den RAM mit 600 MHZ befeuern zu können). G.Skill konnte mir auch kein funktionierendes Setting geben, obwohl sie den RAM laut ihrer Seite für das Board ausgelegt haben.
Das Execute Disable Bit und die Virtualization Technology werde ich mal kurz deaktivieren und schauen was passiert.
edit: wie schon im ersten post geschrieben, handelt es sich um das aktuellste bios
na das board macht bei zu viel volt auch gerne fehler!
Ich würde echt erstmal mit 2 riegeln testen und zwar mit deinem oben geposteten setting und meinen 3 abänderungen. da kannste eigentlich mit real anliegenden 1.20v vtt und 1.21v vnb anfangen und beide werte nach unten oder gegebenen fall, oben auslotsen. Dazu noch die vcoore bei droop controll disable neu ausloten!
Wenn du bei linx testen nichts groß im hintergrund laufen hast, sollteste dann mit 4ghz fsb 445 und pl8 so ca 56 gflops haben! 55 ist auch noch ok, aber 54 sind dann definitiv zu wenig für das setting!
weil ich es gerade mit pl7 laufen hatte, und ich eitel bin :d noch nen pic, die vtt ist da aber noch zu hoch eingestellt!
Alles klar...werde ich jetzt mal machen. Schonmal ein dickes Danke für die bisherige Hilfe ;)
Kleine noobie Frage, weil ich ständig was anderes lese. Deaktiviertes vDrop mach bei nem 24/7 Rechner Sinn?
Bin jetzt erstmal mit 4GB "ausloten", aber weiterhin mitm Lappi online um den aktuellen Status zu melden.
edit: @UHJJ36: du meinst mehr als schon die ausgetestetetn realen 1.28V? Mehr empfand ich für meinen geringen FSB schon sehr viel, da ich mit 4GB bisher bei 1.216V real gefahren bin.
ach ja ram ist auch sicher zu 100% ganz?
---------- Beitrag hinzugefügt um 21:10 ---------- Vorheriger Beitrag war um 21:09 ----------
Du kannst es ja wenn alles läuft wieder aktivieren! aber ob ja oder nein weiß keiner so richtig! beste antwort die ich bis jetzt gefunden habe war: bis 1.25v vcore disable, darüber enabled
mann weiß nie vielleicht haste ja die krücke die 1.32v vnb für fsb 445 braucht, aber dann würden 4gb bestimmt auch schon ne höhere vnb wie der durchschnitt brauchen!
vcoore droop enabled bei erhöhter vcore kann die sache auch wackelig machen - habe ich zumindest bei mir schon beobachted!
welches bios hast du denn am laufen?
also ich habe das aktuellste bios drauf (105).
So folgende Feststellung habe ich gemacht. Ich bin bisher nur zu einem Kit (meinem alten) gekommen.
Mit Stratposteinstellungen und 3-3-1 geht nichts.
Mit 7-7-1 und vnb 1.21V (real) schwankt linx zwischen 48 und 52 GFlops, bis der Rechner dann im 17. Durchlauf abschmiert.
Gerade teste ich mit 7-7-1 und vnb 1.24V und vtt 1.2V. Aber hier zeichnet sich sogar eine Verschlechterung ab, da die GFLops sich jetzt im Bereich zwischen 45-48 aufhalten.
Wenn ich den DLL auf Auto stelle mit vnb 1.21V und vtt auf 1.21V erreiche ich gerade mal 29 GFlops.
Mein Fail-Safe Bios wurde leider von mir gelöscht, und ich habe die Einstellungen nicht mehr wirklich im Kopf.
Jetzt muss ich mich nochmal komplett durcharbeiten. Wird also ne lange Nacht *fg*
Ich würde ja so anfangen:
CPU Feature Page
Execute Disable Bit.......................Enabled - disabled
Virtualization Technology.................Enabled - disabled
Main BIOS Page
CPU Clock.................................445 MHz - 400
CPU VID Special Add.......................+75.0mV - auto
NB Core Voltage...........................1.245v - kleinster wert
CPU VTT Voltage...........................1.25V - kleinster wert
North Bridge GTL REF Volt ................0.63X - 0.67X
FSB Vref..................................23 - auto
DRAM Timing Page
REF to ACT Delay (tRFC)...................60 - auto
wenn das läuft langsam hoch testen bis 445 (z.bsp.irgendwo bei 420-430mhz brauch ich dann die gtl und vref.) auf jedenfall ist das die sicherste methode um rauszubekommen wieviel volt wirklich nötig sind.
---------- Beitrag hinzugefügt um 22:50 ---------- Vorheriger Beitrag war um 22:44 ----------
hmm zu deinen oben genannten setting, hast du schonmal mit 1.18v-1.19v vtt, also weniger, getestet
also ich fang jetzt mal mit deinen settings an und arbeite mich nochmal ganz durch.
was hälst du davon, dass windows gar nicht erst bootet mit 3-3-1?
bei 7-7-1 bootet er zwar, aber linx schwankt zwischen 37 und 39 GFlops.
vnb liegt jetzt bei 1.152V und vtt bei 1.072V.
Die sind wohl noch bissel zu gering für 9x400Mhz.
na dann mußte wohl die spannungen erhöhen und die 7/7/1 nehmen, ich würde erstmal die vtt 1-2xerhöhen, bringt es nicht vtt wieder runter vnb hoch, bringt das nichts vtt und vnb einmal hoch irgendwie halt so, geht dan immer noch nichts mußte schon an die nb gtl und vref.
---------- Beitrag hinzugefügt um 23:15 ---------- Vorheriger Beitrag war um 23:10 ----------
bestimmt ist es zu wenig vtt! brauchst wahrscheinlich 1.12v
So ich habe jetzt auch ein schmuckes P45 T2RS plus:coolblue:...
...und hatte schon zum Anfang mein erstes Problem:fresse:
Natürlich habe ich vor mit dem Board ein paar 775er CPUs zu testen und zu benchen, erstmal aber ältere und kleinere CPUs.
Naja blablabla, auf jedenfall habe ich gleich zu Anfang einen Celeron D 336 eingebaut und mir nix weiter dabei gedacht.
Mache das Board an und auf einmal will mir das Display nur noch "C1" anzeigen. Aber da ich ja diesen Thread schon kenne und auch eine Lösung dafür hier schon gesehen habe, dachte ich mir "wird schon gehen" - der "Ram raus usw.-Trick" half aber nicht.
3 unterschiedliche Ram-Riegel getestet, ging auch net. Ohne-alles Booten brachte auch nix.
Dann habe ich einen Pentium E2180 probiert - genau das gleiche Problem:motz:
Ich zu meinen Kumpel Icke&Er hingefahren, von dem ich das Board habe, und wir haben seine CPU (E6300) ausprobiert, mit der das Board auch schon lief. Und gucke an, es läuft wieder!
Dann haben wir meinen E2180 wieder eingebaut und aufeinmal lief es nun damit auch wieder.
Ich Trottel hätte gleich mal auf die CPU Support Liste gucken können, denn da wird der Celeron D 336 nicht gelistet bzw. nicht unterstützt.:wall:
Mich wundert dann aber nur, warum das Board mit dem E2180 anfangs nicht booten wollte...
Naja jetzt läuft es und jetzt gehts ran ans tweaken und ocen.
Gibt es eigentlich für dieses Board eine besonders gute Bios-Version, mit der bessere OC Werte drin sind? z.B. so wie bei dem Classified mit manchen Bios-Versionen.
Gibt sonst noch irgendwelche Macken, die man schon im Vorfeld vermeiden kann, also z.B. bestimmte Settings nicht setzen?
Gruß timbola
