[Sammelthread] DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [11]
Zitat:
  • CPU
    • LGA 775 socket for:
      - Intel® Core2 Quad and Intel® Core2 Duo
    • Supports Intel Enhanced Memory 64 Technology (EMT64T)
    • Supports Enhanced Intel SpeedStep Technology (EIST)
    • Supports Intel Hyper-Threading Technology
    • Supports 1333/1066/800MHz FSB
  • Intel® chipset
    • Intel® chipset
      - Northbridge:
      Intel® P45 Express chipset
      Intel® Fast Memory Access technology
      - Southbridge: Intel® ICH10R
  • Memory
    • Four 240-pin DDR2 DIMM sockets
    • Supports DDR2 1200(O.C.)/1066/800/667 MHz
    • Delivers up to 12.8Gb/s bandwidth
    • Supports dual channel (128-bit wide) memory interface
    • Supports non-ECC unbuffered DIMMs
    • Supports up to 16GB system memory
  • Expansion Slots
    • 2 PCI Express (Gen 2) x16 slots - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
    • 2 PCI Express x1 slots
    • 2 PCI slots
  • BIOS
    • Award BIOS
    • 8Mbit SPI flash BIOS
    • CMOS Reloaded
  • Audio
    • Realtek ALC885 High Definition audio CODEC
    • 8-channel audio output
    • DAC SNR/ADC SNR of 106dB/101dB
    • Full-rate lossless content protection technology
    • Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
  • LAN
    • Marvell 88E8053 PCIE Gigabit LAN controller
    • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  • IDE
    • JMicron JMB363 PCI Express to PATA host controller
    • Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
  • Serial ATA with RAID
    • Intel Matrix Storage technology
    • Supports up to 6 SATA devices
    • SATA speed up to 3Gb/s
    • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • Rear Panel I/O Ports
    • 1 mini-DIN-6 PS/2 mouse port
    • 1 mini-DIN-6 PS/2 keyboard port
    • 1 optical S/PDIF-out port
    • 1 coaxial RCA S/PDIF-out port
    • 6 USB 2.0/1.1 ports
    • 1 RJ45 LAN port
    • Center/subwoofer, rear R/L and side R/L jacks
    • Line-in, line-out (front R/L) and mic-in jacks
  • Power Management
    • ACPI and OS Directed Power Management
    • ACPI STR (Suspend to RAM) function
    • Wake-On-PS/2 Keyboard/Mouse
    • Wake-On-USB Keyboard/Mouse
    • Wake-On-LAN
    • Wake-On-Ring
    • RTC timer to power-on the system
    • AC power failure recovery
  • Hardware Monitor
    • Monitors CPU/system/Northbridge temperature and overheat alarm
    • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    • Monitors the speed of the cooling fans
    • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
  • PCB
    • 4 layers, ATX form factor
    • 24.5cm (9.64") x 30.5cm (12")
Wasserkühlung NB-SB-Mosfets:
Wasserkühlung Zusammenstellungen vom "riverdief":
Luftkühlung:
Passt mit Problemen:
EKL Alpföhn Groß Clockner ( passt nur mit Modifikationen ...entweder am Kühler oder Chipsatzkühler )
Scythe Andi Samurai (gedreht)
Scythe Mugen 2 (der Lüfter muss 5mm verschoben werden)
Thermalright HR-01 Plus (gedreht)
Kompatibler Arbeitsspeicher:
A-DATA Vitesta Extreme Edition 2 GB PC2 9600
Cellshock DIMM Kit 2GB PC2-8500U CL5-5-5-15 (DDR2-1066) (CS2221550)
Chaintech Apogee GT DIMM Kit 4GB PC2-8500U CL5-5-5-15
Chaintech Apogee GT DIMM Kit 4GB PC2-9200U CL5-5-5-15 (DDR2-1150)R2-1150-4GDHS
Corsair DIMM 4 GB DDR2-800 DHX Kit (TWIN2X4096-6400C4DHX)
Corsair XMS2 Dominator 2GB PC2-8500U CL5-5-5-15 TWIN2X2048-8500C5D
Crucial Ballistix Tracer PC8500 1066MHz BL12864AL1065.8FE5
GeiL Value DIMM Kit 2GB PC2-6400U CL5-5-5-15 (DDR2-800) (GX22GB6400DC)
GeIL Ultra DIMM Kit 2GB PC2-8500U CL5-5-5-12 (DDR2-1066) (GX22GB8500UDC)
G.Skill Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8500U CL5-5-5-15 (DDR2-1066) (F2-8500CL5D-4GBPI-B)
G.Skill Kit 4GB PC2-8800U CL5-5-5-15 (DDR2-1100) (F2-8800CL5D-4GBPI)
G.Skill Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
G.Skill Trident Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBTD)
G.Skill DIMM Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
Kingston HyperX DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (KHX6400D2K2/4G)
OCZ Flex II 4GB Kit PC2-9200 CL5-5-5-18 (OCZ2FXT11504GK)
OCZ Reaper HPC Edition Kit 2GB PC2-9200U CL5-5-5-18 (OCZ2RPR11502GK)
OCZ Flex XLC Edition 4 x 1024 MB PC2-9600U @ 1200 Mhz
OCZ Reaper HPC Edition 2GB Kit PC2-9600 CL5-5-5-18 (OCZ2RPR12002GK)
OCZ Blade Low Voltage DIMM Kit 4GB PC2-9600U CL5-5-5-18 (DDR2-1200) (OCZ2B1200LV4GK)
Patriot Viper DDR2-800 4 GB
takeMS Mach2 2GB PC2-8500U CL5-5-5-18 TMS1GB264C082-105EP
TeamGroup Xtreem Dark 4GB Kit PC2-8500U CL5-5-5-15 TXDD4096M1066HC5DC-D​
Kompatibler Netzteile:
Biosupdate mit USB Stick
Anleitung vom Fresh_Thing
1. Programm runterladen und installieren.
2. Dos files und Bios runterladen - Bios findest du hier -> http://img.lanparty.tw/Upload/BIOS/CM/D45PD320.zip
Dann den pfad für die Dos files im programm angeben und den USB-Stick formatieren
3. Die 3 datein die beim Bios dabei sind auf den Stick kopieren.
4. Im Bios die setup defaults laden und direkt den USB-Stick als erstes Bootgerät einstellen.
Dann einfach nur neustarten und der Flash nimmt seinen Lauf​
USB-Stick Bootfähig machen !!!
Downloads
Wichtige Links
Real Volt - Messung im Windows @ IDLE
mit einem Q9550 E0 @ FSB 500 @ 4255 Mhz​
Gemessen vom mahaudi
CPU PLL ( Bios 1.55v.) ......Real : 1.578v...........Droop : + ~ 0.03v.
NB Core ( Bios 1.420v.) .....Real : 1.420v...........Droop : nichts
VDIMM ( Bios 2.218v. ) .....Real : 2.245v. .........Droop : + ~ 0.03v.
VTT ( Bios 1.280v. ) .......Real : 1.298v. ..........Droop : + ~ 0.02v.​
Messpunkte DFI LP DK P45-T2RS Plus
Wie bekommt man den C1-Fehler weg?
Hier die Lösung vom Fresh_Thing
ohne Rams booten
dann PC am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen Ram reinstecken und PC starten
.....wenn das nicht geht :
ohne Rams booten
noch mal ohne Rams booten und am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen ( Wichtig ) Ram reinstecken und PC starten​
VID-Bug Behebung!
Computer neu starten und ab ins BIOS
Load optimal Defaults
Computer herunterfahren
Netzteilstecker abziehen
Jumper umstecken und Batterie für ein paar Min. raus
Computer starten
Unter Hardware Monitoring nachschauen, ob die anliegende Spannung stimmt (C1E und EIST an!)
Mit F10 raus und wieder rein, dabei ist zu beachten, dass beim ersten Mal, niemals mehreren Einstellungen gleichzeitig getätigt werden dürfen
Sollte die anliegende Spannung stimmen, speichern und starten
Wenn das der Fall ist, seid Ihr den Bug für immer los!
Ansonsten, die CPU a+e!​
Smartguardian Design`s ( inkl.SG.exe vom UT P35 )
: http://rapidshare.com/files/18075196...DK_Edition.rar
Achtung!
Die mitgelieferten SATA-Kabeln können unter Umständen zum einem instabilen Betrieb führen, dies ist allerdings nicht immer der Fall.
Fazit:
Das Board kann echt eine Zicke sein und bestrafft auch den kleinsten Fehler mit einem Bluescreen/Reboot oder startet erst gar nicht, deshalb sollte man die Finger davon lassen, wenn man nicht genügend oder gar keine Erfahrung mitbringt, ansonsten bietet das Board mehr als genug Einstellungen und eine sehr gute Performance!;)
An dieser Stelle, möchte ich mich für die zur Verfügung gestellten Daten und wirklich gute Vorarbeit bei mahaudi bedanken!:hail:
Bildquellen:
patrock84 und [EKM] SeLecT , auch Euch beiden vielen Dank!:hail:
Alter Thread:
DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [10]
Das glaube ich nicht... Die war zumindest bei meinem Board nicht dabei da es ja nicht für SLI gedacht ist eig. Hab ich ausm MP hier.
Ich nutze das CF gespann eigentlich auch nur richtig bei BFBC2 :d
Ist schon fein immer über 60 FPS mit 8xAA und 16xAF und alles Details am Anschlag :)
Edit bis aber mit Dualcore und zwei 8800GT+ 680i schon auf 20400 Punkte im 3DMark06 gekommen ;)
@nfszocker
hmm, ich vergleiche da eher archtikturgleich... das das so nicht hinhaut mit den gflops als leistungsindex ist mir schon klar ;)
aber als ex unserer diva:
och nicht unlecker nich wa:
soviel zum thema pl7... :)
irgendwie hätte ich schon fruher auf die idee kommen müssen fsb 500+ mit runtergesetzten multi und pl8 zu testen, jetzt habe ich meine ganze energie an irgendwelchen nutzlosen pl7 gebasche verhauen! Bin irgendwie nicht mehr soo geduldig am testen wie vor einem jahr.
Nichtdestsotrotz, ich bin einfach noch nicht durch mit dem board!
wie das? bzw wie hoch war die cpu getaktet?
Jo da gibts ja nen Fred hier. Hätte das vorher auch nie gedacht aber is eig. relativ einfach. naja. sollte irgendwann eine gtx 470 nicht reichen weiß ich ja wie es geht^^:haha: das mit meinem umbau könnte sich wohl noch ein wenig hinziehen... hab kein bock die originale heatpipe draufzubasteln für die paar wochen wo ich mein wakü-case nicht fertig hab...
Ich reiß meine zwei Karten demnächst wieder raus und kauf ne OC GTX580 :)
Die Treiber im Crossfire sind einfach nicht zufriedenstellend.
Ich hab kein bock hier alle Treiber durch zu testen bis meine Lieblingsspiele mal einwandfrei laufen, früher hätte mich das nicht gestört aber ich werd alt und hab keine Zeit :fresse:
Moin!:wink:
Das mit dem PL8, ist gar nicht mal so verkehrt:
und mit dem Board wird man erst fertig, wenn man keine Herausforderung mehr sieht, bzw. einfach kein bock mehr hat.;)
@ nfzocker
sag mal, memtest gibt ja auch an, wie viel der speicher an mb/s schafft! Bei mir zwischen ca. 6322mb/s bei 410/1233/pl6 und 6675mb/s bei 500/1253/pl7, 510/1223/pl8 hat da "nur" 6645mb/s. Kann man das als bandbreiten leistungsindex ernst nehmen?
Ich habe ab sonntag ne halbe woche frei und meine Freundin ist weg.... mal schauen wozu ich komme, immerhin habe ich dann kein Eifesuchtstheater zwischen meinen beiden Süßen hehehee!
Das fsb 510 mit 1.28v vtt läuft macht mich schon ein wenig zappelig!
Nicht wirklich, ist zwar ein Anhaltspunkt, aber die Bandbreite unter Windows, ist schon ein bisschen anders, als das, was bei MemTest86+ angezeigt bekommst.:wink:
:bigok::lol::lol::lol:
thx...
intressiert mich, weil ich mit fsb 500 und pl7 laut memtestx86 eine höhere bandbreite habe wie mit 510 und pl8! Im gegensatz zu everest wo 510/pl8 viel mehr bandbreite hat...
cool endlich WE...:cool:
Moin!:wink:
Jeep!
Dann bin ich mal gespannt, ob Du die 510 zum Laufen bekommst, wird sicherlich nicht einfach, aber machbar sein.
moin moin
ok, dann mal an die arbeit!
---------- Beitrag hinzugefügt um 10:10 ---------- Vorheriger Beitrag war um 08:36 ----------
Wir lieben uns einfach, die diva und ich.
War mal wieder eine kurze Spannungsausloterei per linx
510x8/1223/pl8 4.08ghz
Moin!:wink:
Sehr schönes Érgebnis!:bigok:
Ihr seid quasi für einander geschaffen!:fresse2:
jetzt habe ich nur ein problem! prime95, ich glaub die kommt in die jahre, zumindest stresst sie bei mir nur noch rum, garnichts mehr geht und das bei ALLEN settings welche bei mir mal die hüfte schwingen dürfen; und es schon zum teil seit einem jahr fehlerlos(!) tun.
Dabei haben meine alten settings alle mindesten 3stunden large bestanden!
Ich mein, zum Glück bin ich mal auf die idee gekommen gegenzutesten, ansonsten würde ich ja heute noch suchen wie 510mhz largestabel werden.....
....hat vielleicht irgendjemand ähnliche probleme?
gleich bei 1024k large, und da nach 2-5 runs :fresse:
ach ja und bei small in der regel bei 8k, auch so nach 2-5 runs
Ihr seit echt Freaks :d
Neuer Ram ist da, leider kann ich den nicht auf den DFI testen^^
Elpida Hyper MGH-N :fire:
edit: hab ich aber schon auf nem AM3 Board getestet, macht 1800MHz 6-6-6-18 1T
Leider geht da bei AMD nicht so viel was MHz angeht sonst hätte ich es ihnen mal richtig gegeben :d
joh, gehört so in die ecke: versteht sich von selbst :d
habe heute schon mal fsb 520 bootstabel gemacht und den ram ausgelotet bei 5:6 und pl8 :cool:
