[Sammelthread] DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [11]
Zitat:
  • CPU
    • LGA 775 socket for:
      - Intel® Core2 Quad and Intel® Core2 Duo
    • Supports Intel Enhanced Memory 64 Technology (EMT64T)
    • Supports Enhanced Intel SpeedStep Technology (EIST)
    • Supports Intel Hyper-Threading Technology
    • Supports 1333/1066/800MHz FSB
  • Intel® chipset
    • Intel® chipset
      - Northbridge:
      Intel® P45 Express chipset
      Intel® Fast Memory Access technology
      - Southbridge: Intel® ICH10R
  • Memory
    • Four 240-pin DDR2 DIMM sockets
    • Supports DDR2 1200(O.C.)/1066/800/667 MHz
    • Delivers up to 12.8Gb/s bandwidth
    • Supports dual channel (128-bit wide) memory interface
    • Supports non-ECC unbuffered DIMMs
    • Supports up to 16GB system memory
  • Expansion Slots
    • 2 PCI Express (Gen 2) x16 slots - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
    • 2 PCI Express x1 slots
    • 2 PCI slots
  • BIOS
    • Award BIOS
    • 8Mbit SPI flash BIOS
    • CMOS Reloaded
  • Audio
    • Realtek ALC885 High Definition audio CODEC
    • 8-channel audio output
    • DAC SNR/ADC SNR of 106dB/101dB
    • Full-rate lossless content protection technology
    • Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
  • LAN
    • Marvell 88E8053 PCIE Gigabit LAN controller
    • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  • IDE
    • JMicron JMB363 PCI Express to PATA host controller
    • Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
  • Serial ATA with RAID
    • Intel Matrix Storage technology
    • Supports up to 6 SATA devices
    • SATA speed up to 3Gb/s
    • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • Rear Panel I/O Ports
    • 1 mini-DIN-6 PS/2 mouse port
    • 1 mini-DIN-6 PS/2 keyboard port
    • 1 optical S/PDIF-out port
    • 1 coaxial RCA S/PDIF-out port
    • 6 USB 2.0/1.1 ports
    • 1 RJ45 LAN port
    • Center/subwoofer, rear R/L and side R/L jacks
    • Line-in, line-out (front R/L) and mic-in jacks
  • Power Management
    • ACPI and OS Directed Power Management
    • ACPI STR (Suspend to RAM) function
    • Wake-On-PS/2 Keyboard/Mouse
    • Wake-On-USB Keyboard/Mouse
    • Wake-On-LAN
    • Wake-On-Ring
    • RTC timer to power-on the system
    • AC power failure recovery
  • Hardware Monitor
    • Monitors CPU/system/Northbridge temperature and overheat alarm
    • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    • Monitors the speed of the cooling fans
    • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
  • PCB
    • 4 layers, ATX form factor
    • 24.5cm (9.64") x 30.5cm (12")
Wasserkühlung NB-SB-Mosfets:
Wasserkühlung Zusammenstellungen vom "riverdief":
Luftkühlung:
Passt mit Problemen:
EKL Alpföhn Groß Clockner ( passt nur mit Modifikationen ...entweder am Kühler oder Chipsatzkühler )
Scythe Andi Samurai (gedreht)
Scythe Mugen 2 (der Lüfter muss 5mm verschoben werden)
Thermalright HR-01 Plus (gedreht)
Kompatibler Arbeitsspeicher:
A-DATA Vitesta Extreme Edition 2 GB PC2 9600
Cellshock DIMM Kit 2GB PC2-8500U CL5-5-5-15 (DDR2-1066) (CS2221550)
Chaintech Apogee GT DIMM Kit 4GB PC2-8500U CL5-5-5-15
Chaintech Apogee GT DIMM Kit 4GB PC2-9200U CL5-5-5-15 (DDR2-1150)R2-1150-4GDHS
Corsair DIMM 4 GB DDR2-800 DHX Kit (TWIN2X4096-6400C4DHX)
Corsair XMS2 Dominator 2GB PC2-8500U CL5-5-5-15 TWIN2X2048-8500C5D
Crucial Ballistix Tracer PC8500 1066MHz BL12864AL1065.8FE5
GeiL Value DIMM Kit 2GB PC2-6400U CL5-5-5-15 (DDR2-800) (GX22GB6400DC)
GeIL Ultra DIMM Kit 2GB PC2-8500U CL5-5-5-12 (DDR2-1066) (GX22GB8500UDC)
G.Skill Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8500U CL5-5-5-15 (DDR2-1066) (F2-8500CL5D-4GBPI-B)
G.Skill Kit 4GB PC2-8800U CL5-5-5-15 (DDR2-1100) (F2-8800CL5D-4GBPI)
G.Skill Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
G.Skill Trident Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBTD)
G.Skill DIMM Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
Kingston HyperX DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (KHX6400D2K2/4G)
OCZ Flex II 4GB Kit PC2-9200 CL5-5-5-18 (OCZ2FXT11504GK)
OCZ Reaper HPC Edition Kit 2GB PC2-9200U CL5-5-5-18 (OCZ2RPR11502GK)
OCZ Flex XLC Edition 4 x 1024 MB PC2-9600U @ 1200 Mhz
OCZ Reaper HPC Edition 2GB Kit PC2-9600 CL5-5-5-18 (OCZ2RPR12002GK)
OCZ Blade Low Voltage DIMM Kit 4GB PC2-9600U CL5-5-5-18 (DDR2-1200) (OCZ2B1200LV4GK)
Patriot Viper DDR2-800 4 GB
takeMS Mach2 2GB PC2-8500U CL5-5-5-18 TMS1GB264C082-105EP
TeamGroup Xtreem Dark 4GB Kit PC2-8500U CL5-5-5-15 TXDD4096M1066HC5DC-D​
Kompatibler Netzteile:
Biosupdate mit USB Stick
Anleitung vom Fresh_Thing
1. Programm runterladen und installieren.
2. Dos files und Bios runterladen - Bios findest du hier -> http://img.lanparty.tw/Upload/BIOS/CM/D45PD320.zip
Dann den pfad für die Dos files im programm angeben und den USB-Stick formatieren
3. Die 3 datein die beim Bios dabei sind auf den Stick kopieren.
4. Im Bios die setup defaults laden und direkt den USB-Stick als erstes Bootgerät einstellen.
Dann einfach nur neustarten und der Flash nimmt seinen Lauf​
USB-Stick Bootfähig machen !!!
Downloads
Wichtige Links
Real Volt - Messung im Windows @ IDLE
mit einem Q9550 E0 @ FSB 500 @ 4255 Mhz​
Gemessen vom mahaudi
CPU PLL ( Bios 1.55v.) ......Real : 1.578v...........Droop : + ~ 0.03v.
NB Core ( Bios 1.420v.) .....Real : 1.420v...........Droop : nichts
VDIMM ( Bios 2.218v. ) .....Real : 2.245v. .........Droop : + ~ 0.03v.
VTT ( Bios 1.280v. ) .......Real : 1.298v. ..........Droop : + ~ 0.02v.​
Messpunkte DFI LP DK P45-T2RS Plus
Wie bekommt man den C1-Fehler weg?
Hier die Lösung vom Fresh_Thing
ohne Rams booten
dann PC am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen Ram reinstecken und PC starten
.....wenn das nicht geht :
ohne Rams booten
noch mal ohne Rams booten und am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen ( Wichtig ) Ram reinstecken und PC starten​
VID-Bug Behebung!
Computer neu starten und ab ins BIOS
Load optimal Defaults
Computer herunterfahren
Netzteilstecker abziehen
Jumper umstecken und Batterie für ein paar Min. raus
Computer starten
Unter Hardware Monitoring nachschauen, ob die anliegende Spannung stimmt (C1E und EIST an!)
Mit F10 raus und wieder rein, dabei ist zu beachten, dass beim ersten Mal, niemals mehreren Einstellungen gleichzeitig getätigt werden dürfen
Sollte die anliegende Spannung stimmen, speichern und starten
Wenn das der Fall ist, seid Ihr den Bug für immer los!
Ansonsten, die CPU a+e!​
Smartguardian Design`s ( inkl.SG.exe vom UT P35 )
: http://rapidshare.com/files/18075196...DK_Edition.rar
Achtung!
Die mitgelieferten SATA-Kabeln können unter Umständen zum einem instabilen Betrieb führen, dies ist allerdings nicht immer der Fall.
Fazit:
Das Board kann echt eine Zicke sein und bestrafft auch den kleinsten Fehler mit einem Bluescreen/Reboot oder startet erst gar nicht, deshalb sollte man die Finger davon lassen, wenn man nicht genügend oder gar keine Erfahrung mitbringt, ansonsten bietet das Board mehr als genug Einstellungen und eine sehr gute Performance!;)
An dieser Stelle, möchte ich mich für die zur Verfügung gestellten Daten und wirklich gute Vorarbeit bei mahaudi bedanken!:hail:
Bildquellen:
patrock84 und [EKM] SeLecT , auch Euch beiden vielen Dank!:hail:
Alter Thread:
DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [10]
Na ja ich hab dann ja 4x 12V Leitungen an den Karten da ist eigentlich mehr als genug saft da würd ich sagen ;)
Aber ich kenn das von meinen 680i Boards auch noch da musste extra noch ein Stecker dran:
@ UHJJ36
daa bin ich mal gespannt! Wenn es was taugt, das cf auf p45 mach ich es nach!
Allerdings befürchte ich, das das theoretisch nicht vorandenen Bandbreitenlimit, spürbar sein wird!
Das "neue" bios scheint nichts besonderes zu sein.... zumindest bei mir, allerdings hat das nichts zu heißen für niemand, schließlich habe ich schon alles am Anschlag ausgelotet. Da ist wahrscheinlich einfach nichts mehr zu holen!
Ich habe mich schon belesen ;)
Im Extremfall soll man 7-8% Einbuße bei 8x-8x im vergleich zu 16x-16x haben.
Du darfst nicht vergessen das es 8x PCIe 2.0 ist also ist es 16x PCIe 1.1 ;)
Ich hoffe Du teilst Deine Erfahrungen mit :)
Auf jedenfall hatte hier im luxx mal einen gefunden der ein dk + c2q + 2x hd5870 verkaufte. Als ich ihn fragte was der grund sei sagte er das cf lief nicht rund!
Vielleicht ist die leistung wirklich nur marginal geringer, dafür um so mehr microruckler und sonstiges gestotter. Abgesehen davon würde ich persöhnlich gerade bei einen cf auf 2gb-Karten setzen, sonst macht sgssaa und sonstige filter sowie downsampling auch keinen spass
Bei meiner Auflösung (1920x1080 reicht die 1GB Variante noch mehr als aus ;)
Kein Geschwindigkeitsvorteil der 2GB Variante außerdem kosten die Schweine viel Geld ;)
Na ja, bei 2Karten komme ich schnell zu dowsampling und oder aa, und ob in den bereichen die 1gb variante schlußendlich limitiert oder nicht, ist meine frage.
Dazu noch die Überlegung, das in einem solchen szenario dann der pci e mit 2x16fach begrenzt + die üblichen cf-probleme und schon weißte warum ich mich noch nicht getraut habe... (auf nem so775 p45 halt)
Ich gehe jetzt mal bei der i5 fraktion zum thema stöbern vielleicht findet sich was
mal um die ecke gefragt, was machst du denn mit der mehrleistung, oder zockst du nur games welche eh hw fresser sind?
Ich war kurz davor mir nen i7-950 mit nem MSI X58 Big Bang zu kaufen...
Da hab ich mir überlegt das ja Anfang 2011 Sandy Bridge kommt und das also zum jetzigen Moment sehr schlecht sich da Hardware zu kaufen...
SLI hatte ich schon zu G80 Zeiten also will ich mal Crossfire testen (einfach auch aus Neugierde wie das so mit aktuellen Games skaliert)
Dann hab ich mit meinen Wilden aus dem alten Striker II Extreme thread noch ne Rechnung offen... die haben jetzt alle fette i7 und GTX480 SLI, die MUSS ich im 3DMark Vantage im Extreme test einfach mal in die schranken weisen ;)
Ich habs schon gegen eine GTX480 getestet... im Vantage Extreme sind beide Karten gleich auf (die ATI skaliert mit 8xAA besser als mit 4xAA;))
So, in Vorbereitung auf dieverse pl7 Experimente noch mal fsb500 4.25ghz pl8!
Gleichzeitig sieht man sehr schön die enorme Kühlkraft von Megahelms, mk13 und Hafx. Ich bin sehr zufrieden, auch wenn ich anfangs mit widerlichen Resonanzen zu kämpfen hatte! (Festplatten mit Kabelbinder entkoppeln ist einfach genial!!!!!!)
Du brauchst aber wenig V-Core für den Takt...
Ich muss für 4300 1,39V einstellen, der andere Q9650 will 1,45V!
Habt ihr vielleicht noch irgendwas eingestellt was ich nicht habe^^
Die cpu ist einfach gut!
Schau Dir vtt und vnb für fsb500 an! Die sind auch sehr gut!
aber zur sicherheit:
skews 800/100/100
gtl 67/67/63
vref 23
Ram: 3/3/1, n/n/n
wenn du sonst noch was wissen willst frag ruhig!
apropo neues betabios: in cpuz steht was von version 09/14/2009 komisch ist das...
GTL hab ich noch nie verstellt... hatte immer die Erfahrung gemacht das das System dann sehr schnell instabil wird.
Außerdem hab ich auch einen sehr guten CPU mit einem angeblichen Hammer Batch.
Ich nehme ganz sicher kein anderes Bios wenn ich mit diesem hervorragende Ergebnisse erziele ;)
So mal den Karten ein bisschen feuer gegeben (1030/1300)
Zu späterer Stunde werden meine gewohnten Benchsettings (4,6GHz) angelegt und der PL vom Ram ordentlich runter geknallt :)
WLP hab ich schon gewechselt^^
Update: Vantage ist immun gegen die 300MHz mehr CPU takt das Ergebnis bleibt fast gleich.
Moin Björn:)
Bringt eine 2te Graka spürbar eine Mehrleistung in spielen und wie ist es mit dem Microrucklern?
Würde mich echt mal interessieren...kann nämlich günstig an eine 2te HD5850 ran kommen.
Das es keine 100% Steigerung ist weiß ich...
Werner
Ich hab zwar gelesen das es Microruckler geben soll aber irgendwie finde ich läuft Battlefield Bad Company 2 jetzt mit mehr AA wesentlich runder.
Die FPS sind in dem Game zwar vielleicht nur um 30-40% hoch gegangen aber es läuft echt viel schöner finde ich.
Und von ner Bandbreitenlimitierung durch die geringere PCIe Anbindung merk ich auch nichts...
Bis jetzt bin ich zu frieden mit den Karten falls sich was ändert berichte ich :)
Aber eins will ich mal wissen woher wissen hier eigentlich alle wie ich heiße :fresse:
edit: Hab mal PCIe so weit es geht übertaktet (max 111MHz Bench stable)
Reicht für son altes LGA775 System :)
Sieht einfach nur geil, was Du dahin gezaubert hast, 59GFlops, alter Schwede.;):bigok:
erstmal thx for solution :hail:
ähm, fresh thing... Du meinst meine temps sind zu hoch?
Ich bin damit sehr zufrieden (Linx ist ja nicht gerade der realzustand)
@uhjj36
gratulation, sieht doch schon mal ganz schön aus....
---------- Beitrag hinzugefügt um 19:47 ---------- Vorheriger Beitrag war um 19:31 ----------
edit die 2t
lass gerade prime laufen, ist ja nen zacken kühler wie linx! Muß eh noch mal checken ob da auch alles rund läuft!
Will einfach 1000% sicher sein mit meinen settings bevor ich die Grenzen auslote! Darf ausserdem ruhig noch kälter werden!
Die cpu welche ich habe war schon immer ein hitzkopf!
Hat hier schon jemand mal des neue Prime getestet? Benutze immer noch das alte da weiß ich wenigstens an welcher schraube man drehen muss ;)
edit die 3t
ja, ja, wie das Schicksal so will bricht prime noch in den 8k ab, obwoh die cpu nicht mal auf 1.23v droopt (wie bei linx immer) sonder auf 1.24v hängenbleibt!
Erstmal wieder das beta bios wegflashen!
Aber trotzdem lustig! Dieses Setting ist immerhin schon ein halbes jahr alt und hat mich noch nie enttäuscht!
Muß wohl so sein weil live! The show must go on...
---------- Beitrag hinzugefügt um 20:14 ---------- Vorheriger Beitrag war um 19:59 ----------
@prime73
Ich hab die version 25.11 build2
Welche ist den die aktuellste?
---------- Beitrag hinzugefügt um 20:17 ---------- Vorheriger Beitrag war um 19:59 ----------
hmm, verflixt auch mit dem ursprungsbios geht prime hops.
Soll ich jetzt prime glauben, oder linx und allen anderen programmen? Immerhin lief das setting insgesamt schon einiges auf dem rechner.
