[Sammelthread] DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [11]
Zitat:
  • CPU
    • LGA 775 socket for:
      - Intel® Core2 Quad and Intel® Core2 Duo
    • Supports Intel Enhanced Memory 64 Technology (EMT64T)
    • Supports Enhanced Intel SpeedStep Technology (EIST)
    • Supports Intel Hyper-Threading Technology
    • Supports 1333/1066/800MHz FSB
  • Intel® chipset
    • Intel® chipset
      - Northbridge:
      Intel® P45 Express chipset
      Intel® Fast Memory Access technology
      - Southbridge: Intel® ICH10R
  • Memory
    • Four 240-pin DDR2 DIMM sockets
    • Supports DDR2 1200(O.C.)/1066/800/667 MHz
    • Delivers up to 12.8Gb/s bandwidth
    • Supports dual channel (128-bit wide) memory interface
    • Supports non-ECC unbuffered DIMMs
    • Supports up to 16GB system memory
  • Expansion Slots
    • 2 PCI Express (Gen 2) x16 slots - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
    • 2 PCI Express x1 slots
    • 2 PCI slots
  • BIOS
    • Award BIOS
    • 8Mbit SPI flash BIOS
    • CMOS Reloaded
  • Audio
    • Realtek ALC885 High Definition audio CODEC
    • 8-channel audio output
    • DAC SNR/ADC SNR of 106dB/101dB
    • Full-rate lossless content protection technology
    • Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
  • LAN
    • Marvell 88E8053 PCIE Gigabit LAN controller
    • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  • IDE
    • JMicron JMB363 PCI Express to PATA host controller
    • Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
  • Serial ATA with RAID
    • Intel Matrix Storage technology
    • Supports up to 6 SATA devices
    • SATA speed up to 3Gb/s
    • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • Rear Panel I/O Ports
    • 1 mini-DIN-6 PS/2 mouse port
    • 1 mini-DIN-6 PS/2 keyboard port
    • 1 optical S/PDIF-out port
    • 1 coaxial RCA S/PDIF-out port
    • 6 USB 2.0/1.1 ports
    • 1 RJ45 LAN port
    • Center/subwoofer, rear R/L and side R/L jacks
    • Line-in, line-out (front R/L) and mic-in jacks
  • Power Management
    • ACPI and OS Directed Power Management
    • ACPI STR (Suspend to RAM) function
    • Wake-On-PS/2 Keyboard/Mouse
    • Wake-On-USB Keyboard/Mouse
    • Wake-On-LAN
    • Wake-On-Ring
    • RTC timer to power-on the system
    • AC power failure recovery
  • Hardware Monitor
    • Monitors CPU/system/Northbridge temperature and overheat alarm
    • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    • Monitors the speed of the cooling fans
    • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
  • PCB
    • 4 layers, ATX form factor
    • 24.5cm (9.64") x 30.5cm (12")
Wasserkühlung NB-SB-Mosfets:
Wasserkühlung Zusammenstellungen vom "riverdief":
Luftkühlung:
Passt mit Problemen:
EKL Alpföhn Groß Clockner ( passt nur mit Modifikationen ...entweder am Kühler oder Chipsatzkühler )
Scythe Andi Samurai (gedreht)
Scythe Mugen 2 (der Lüfter muss 5mm verschoben werden)
Thermalright HR-01 Plus (gedreht)
Kompatibler Arbeitsspeicher:
A-DATA Vitesta Extreme Edition 2 GB PC2 9600
Cellshock DIMM Kit 2GB PC2-8500U CL5-5-5-15 (DDR2-1066) (CS2221550)
Chaintech Apogee GT DIMM Kit 4GB PC2-8500U CL5-5-5-15
Chaintech Apogee GT DIMM Kit 4GB PC2-9200U CL5-5-5-15 (DDR2-1150)R2-1150-4GDHS
Corsair DIMM 4 GB DDR2-800 DHX Kit (TWIN2X4096-6400C4DHX)
Corsair XMS2 Dominator 2GB PC2-8500U CL5-5-5-15 TWIN2X2048-8500C5D
Crucial Ballistix Tracer PC8500 1066MHz BL12864AL1065.8FE5
GeiL Value DIMM Kit 2GB PC2-6400U CL5-5-5-15 (DDR2-800) (GX22GB6400DC)
GeIL Ultra DIMM Kit 2GB PC2-8500U CL5-5-5-12 (DDR2-1066) (GX22GB8500UDC)
G.Skill Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8500U CL5-5-5-15 (DDR2-1066) (F2-8500CL5D-4GBPI-B)
G.Skill Kit 4GB PC2-8800U CL5-5-5-15 (DDR2-1100) (F2-8800CL5D-4GBPI)
G.Skill Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
G.Skill Trident Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBTD)
G.Skill DIMM Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
Kingston HyperX DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (KHX6400D2K2/4G)
OCZ Flex II 4GB Kit PC2-9200 CL5-5-5-18 (OCZ2FXT11504GK)
OCZ Reaper HPC Edition Kit 2GB PC2-9200U CL5-5-5-18 (OCZ2RPR11502GK)
OCZ Flex XLC Edition 4 x 1024 MB PC2-9600U @ 1200 Mhz
OCZ Reaper HPC Edition 2GB Kit PC2-9600 CL5-5-5-18 (OCZ2RPR12002GK)
OCZ Blade Low Voltage DIMM Kit 4GB PC2-9600U CL5-5-5-18 (DDR2-1200) (OCZ2B1200LV4GK)
Patriot Viper DDR2-800 4 GB
takeMS Mach2 2GB PC2-8500U CL5-5-5-18 TMS1GB264C082-105EP
TeamGroup Xtreem Dark 4GB Kit PC2-8500U CL5-5-5-15 TXDD4096M1066HC5DC-D​
Kompatibler Netzteile:
Biosupdate mit USB Stick
Anleitung vom Fresh_Thing
1. Programm runterladen und installieren.
2. Dos files und Bios runterladen - Bios findest du hier -> http://img.lanparty.tw/Upload/BIOS/CM/D45PD320.zip
Dann den pfad für die Dos files im programm angeben und den USB-Stick formatieren
3. Die 3 datein die beim Bios dabei sind auf den Stick kopieren.
4. Im Bios die setup defaults laden und direkt den USB-Stick als erstes Bootgerät einstellen.
Dann einfach nur neustarten und der Flash nimmt seinen Lauf​
USB-Stick Bootfähig machen !!!
Downloads
Wichtige Links
Real Volt - Messung im Windows @ IDLE
mit einem Q9550 E0 @ FSB 500 @ 4255 Mhz​
Gemessen vom mahaudi
CPU PLL ( Bios 1.55v.) ......Real : 1.578v...........Droop : + ~ 0.03v.
NB Core ( Bios 1.420v.) .....Real : 1.420v...........Droop : nichts
VDIMM ( Bios 2.218v. ) .....Real : 2.245v. .........Droop : + ~ 0.03v.
VTT ( Bios 1.280v. ) .......Real : 1.298v. ..........Droop : + ~ 0.02v.​
Messpunkte DFI LP DK P45-T2RS Plus
Wie bekommt man den C1-Fehler weg?
Hier die Lösung vom Fresh_Thing
ohne Rams booten
dann PC am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen Ram reinstecken und PC starten
.....wenn das nicht geht :
ohne Rams booten
noch mal ohne Rams booten und am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen ( Wichtig ) Ram reinstecken und PC starten​
VID-Bug Behebung!
Computer neu starten und ab ins BIOS
Load optimal Defaults
Computer herunterfahren
Netzteilstecker abziehen
Jumper umstecken und Batterie für ein paar Min. raus
Computer starten
Unter Hardware Monitoring nachschauen, ob die anliegende Spannung stimmt (C1E und EIST an!)
Mit F10 raus und wieder rein, dabei ist zu beachten, dass beim ersten Mal, niemals mehreren Einstellungen gleichzeitig getätigt werden dürfen
Sollte die anliegende Spannung stimmen, speichern und starten
Wenn das der Fall ist, seid Ihr den Bug für immer los!
Ansonsten, die CPU a+e!​
Smartguardian Design`s ( inkl.SG.exe vom UT P35 )
: http://rapidshare.com/files/18075196...DK_Edition.rar
Achtung!
Die mitgelieferten SATA-Kabeln können unter Umständen zum einem instabilen Betrieb führen, dies ist allerdings nicht immer der Fall.
Fazit:
Das Board kann echt eine Zicke sein und bestrafft auch den kleinsten Fehler mit einem Bluescreen/Reboot oder startet erst gar nicht, deshalb sollte man die Finger davon lassen, wenn man nicht genügend oder gar keine Erfahrung mitbringt, ansonsten bietet das Board mehr als genug Einstellungen und eine sehr gute Performance!;)
An dieser Stelle, möchte ich mich für die zur Verfügung gestellten Daten und wirklich gute Vorarbeit bei mahaudi bedanken!:hail:
Bildquellen:
patrock84 und [EKM] SeLecT , auch Euch beiden vielen Dank!:hail:
Alter Thread:
DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [10]
Dachte gerade das meine SSD gekommen ist aber es war meine Front für´s TJ07 von Martma :d
Genau so mache ich das auch Tom. Als reiner Datenträger kommt entweder meine WD oder F1 zum Einsatz.
Joh in soetwa dachte ich auch, ne veloci für games und sound behalten, welche ich mit hotswap per bedarf aktiviere! Eine 60-80gb ssd wird mir dicke reichen.
Ich hatte bisher einen Q9550 E0 auf meinem Board.
Da ich in jüngster Zeit aber ständig den VID BUG hatte (manchmal erkannte das BIOS des T2RS+ die CPU mit einer VID von 1.05V und manchmal (was korrekt ist) mit einer VID von 1.25V), habe ich mir einen Q9650 aus der Bucht besorgt.
Zunächst schien alles bestens, denn auch nach unzähligen Neustarts erkannte er stets die korrekte VID (im Falle meines Q9650 sind das 1,275V). Als ich heute jedoch mal wissen wollte was so "maximal" geht, legte ich +200mV Vcore an und beim Neustart dann die Ernüchterung: Laut BIOS lagen grade mal 1.20V Vcore an - er erkannte also eine VID von 1.00V. Windows bootete natürlich keinen Meter..
Es scheint dass je höher ich die den Vcore Special Add setze, desto wahrscheinlich wird der VID BUG.
Ich hatte bereits mit meiner vorherigen CPU den Lösungsansatz zu dem Problem lt. Seite 1 (CMOS Bat. raus, etc) ohne Erfolg durchgeführt.
Nun war die CPU ganz raus und es werkelt eine ganz andere und das Problem will immer noch nicht verschwinden.
Kann ich also davon ausgehen, dass mein Board fehlerhaft ist? Ich hab das neuste BIOS drauf.. wäre vielleicht ein älteres weniger VID BUG anfällig?
Was kann man noch tun?? :(
Soweit ich mich erinnere hat der VID Bug immer ne VID von 1,100 angezeigt. Unter CoreTemp kann man ganz gut sehen das unter last die richtige VID angezeigt wird und im Idle eine kleinere. Wenn du den Lösungsansatz noch mal befolgst dann solltest du keines deiner Settings neu Laden sein neu Eingeben.
Die im vorherigen Post erwähnten VID Werte habe ich durch eine einfache Subtraktion des "VID Special Add" von der im BIOS angezeigten Vcore errechnet.
Ich landete dabei jedoch nie bei 1.1V - was aber auch eher zweitrangig ist, denn Fakt ist und bleibt, dass sporadisch von einer falschen VID ausgegangen wird, was dann zu einem instabilen und nicht bootfähigen System führt.
Ich werde wohl auch nie verstehen, warum DFI den Nutzer nicht einfach die Vcore mit absoluten Werten angeben lässt...
Aber wurscht - der Tipp, dass man die "Reloaded" Settings nach Anwenden des VID BUG "Workarounds" nicht mehr laden darf bzw. sollte, könnte natürlich meine Rettung sein, denn ich habe selbst nachdem ich den Q9650 eingebaut habe immer wieder abgespeicherte Settings als Basis für mein OC genommen.
Wurde aber auch nirgends erwähnt, dass man das dann nicht mehr tun sollte !?
Also, danke nochmals für deinen Tipp - werd's ausprobieren.
Moin!:wink:
Wenn Dein Systeminfo immer noch aktuell ist und Dein Q9550(VID 1,250V) 4GHz @ 1,280V schafft, dann kann ich Dich beruhigen, ich hatte auch drei oder vier davon, mit der gleiche VID und die haben alle 1,280V für 4GHz gebraucht und waren nach oben raus, ziemlich schlecht.
....und wieder ein gescheiterter Anlauf, diesmal mit fast/normal. Und es sah wieder extrem gut aus, bis auf die temperaturen...
fsb 500x9 1250 pl7
PL7 ist schon sehr derb bei dem FSB ist das 100% stabil?
Ich kann nämlich auch übelst heftige PL fahren und Prime usw laufen Tagelang nur Battlefield stürzt dann immer ab :d
Hier noch everest dazu:
---------- Beitrag hinzugefügt um 11:52 ---------- Vorheriger Beitrag war um 11:51 ----------
Na ja ist ja sichtlich schon mal nicht linxstabel, gezockt habe ich damit noch gar nicht!
Hi!
Hab zwar das "Turbo" und nicht das P45-T2RS "Plus", aber bei meinem Frage sollte ihr mir eigentlich weiter helfen können.
Ich habe festgestellt, daß wenn ich VCore DropControll auf "enabled" stelle meine VCore unter Last (Prime) niedriger ist (~1,28V) als bei "disabled" (~1,31V). Die VCore (Special Add) hab ich nicht weiter verändert.
Bis eben war ich noch der Meinung, daß bei aktiviertem LLC die Lastspannung "dichter" am im BIOS eingestellten Wert für die VCore liegen sollte, zumindest bin ich das von meinen GB-Brettern so gewohnt.
Ist das so gewollt oder ein Bug? Ich wollte eigentlich ohne LLC übertakten, von daher verwirrt mich das jetzt etwas.
Folterknecht
Moin!
Ich würde sagen, allein von dem Durchsatz her, hat sich nicht wirklich gelohnt,:shake: Speichertakt 625MHz @ PL7 liest sich gut an.:d:wink:
Vcore Droop Control [Enabled] ist an und genau so sollte es bleiben, wenn Du deine CPU noch ne Weile behalten willst.;)
Hi!
Danke für die Antwort. Könntest Du mir erklären wieso das so ist? Bis jetzt hab ich LLC bei meinen Boards immer ausgeschaltet, von wegen "bösen Spannungsspitzen".
Deswegen verwirrt mich das ganze ja im Moment!
Lastwechsel und "bösen Spannungspitzen" darfst Du nicht unterschätzen um das Ganze zu begreifen, solltest Du vorher wissen, was man als VDroop und VOffset bezeichnet;
VOffset= ist die Differenz zwischen BIOS eingestellt(VID) und Windows anliegend(VIdle). VOffset schütz Deine CPU beim Lastwechsel, sodas die Spannung, die Du im BIOS einstellst, immer etwas höher ist als das, was Du unter CPU-Z angezeigt bekommst, dass heißt, die Spannung unter Windows wird niemals höher sein als die, die Du im BIOS einstellst und ´genau deshalb, solltest Du es an lassen.
VDroop= ist die Defferenz zwischen Windows Idle(VIdle) und Windows Last(VLast)
Das mit dem Offset und dem VDroop ist mir schon klar, auch wenn "steter Tropfen bekanntlich den Stein höhlt".
Ist das also bei DFI (generell?) mit der BIOS-Einstellung genau entgegengesetzt zu GB? Wenn ich da (GB) das LLC ausschalte ist alles I.O., angeschaltet können mir die SPannungspitzen die CPU braten.
Bei DFI stellt dann also "Vcore Droop Control auf enabled" den Sollzustand dar (= GB LLC off)?
@nfzocker
Ich weiß ja nicht was du von pl7 erwartest, aber bei mir ist der pl7@500fsb ungefähr so stark wie der Durchsatz von pl8@512fsb. Ich finde das ist schon beachtlich! Ich weiß ja nicht wie Dein Durchsatz mit pl8@500fsb ist, äääh war.
....und überhaupt kostet mich das Ganze, im Vergleich zu pl8@500fsb nur 0,01v+ auf der nb und 0,1v mehr auf dem ram.
Ich habe auch eine Idee wo mein Problem liegt! Ich bin zuversichtlich Dir (und Euch) das ganze als Stabel zu präsentieren.
Mein Hauptproblem sind die temps von cpu und den pwm`. und genau da werde ich ansetzen.
Aber davon mehr wenn ich wieder Zuhause bin.....
@nfzocker, tom2k, uhjj36 und all ihr anderen:
-Wie sind Eure Werte bei fsb 500 und pl8?
-Was sind Eure bestwerte!
...thx in vorraus
Wie gesagt ich hab die PL auf 9 angehoben zwecks Bad Company, das Game stürzt sonst an und zu mal ab mit PL8... ist aber auch das einzeigste Spiel was ich bis jetzt kenne welchen bei ner niedrigen PL rumzickt.
Was kann man dann so im 24/7 an Spannung auf die NB und VTT geben bei dem P45-T2RS+ ? Kühlung ist nur der 120mm Lüfter @ 12v von dem CPU Tower-Kühler.
Kann es möglich sein das dieses Mobo mal so saftig undervolten? Beine CPU hat vid von 1,225v aber im Windows kommen nur 1,16v unter last/idle an. War bei meinem anderen mobo nicht der Fall, zumindest nicht so viel.
@ Br@in
na wie läuft die Cpu bei dir ?!
Einige Bios screens findest du im Profiel vom Luxxer Prime73 !
Du kannst im Bios mit der Option vcore droop control den vcore drop ausschalten.
Welche spannungen und settings liegen bei dir an ?
Schmeiss mal ein paar pics auf dem Markt :wink:
Habe momentan 3 Board's hier um die CPU's zu testen
- GA-X48-DQ6 : Fertig getested, max 3,9Ghz sind 24/7 möglich bei 1,275v Vcore
Linx läuft schon bei 1,25V stable aber das trifft nicht auf Prime95 und den altag zu.
hier mal nen stable screen bei 3,8Ghz @ 1,25v vcore
- DK P45-T2RS : Heute angefangen zu testen....
- GA-EP45-Extreme: noch nicht angefangen zu testen.
Das X48 ist wirklich eine gute Wahl für nen c2d aber das trifft leider nicht mal ansatzweise auf nen quad zu :shake: (quad fsb wall und co)
Mal schauen mit welcher Kombo die CPU am besten läuft dann wird sich vom rest wieder getrennt :d
Nun muss ich mich erst mal nach und nach mit dem dfi mobo anfreunden. Hast du den ein paar Richtwerte für die NB und VTT?
Aber merke dir ein Satz: weniger ist mehr ;)
naja alle vorigen t2rs thread werde ich wohl nicht schaffen durch zu arbeiten, das sind Unmengen an post :shot:
Jedoch muss sollte man vorher schon wissen das einige auf ihren screens verdammt hohe volts haben...wenn man dann so ein Bild als Grundlage nimmt dann hat man wohl möglich nicht lange Freude an seinem Mobo.
Der Spruch weniger ist mehr hätte glatt von mir sein können :p
Den screens aus dem Album sagen NB 1,245V und Vtt 1,23V was sich schon sehr viel anhört gegenüber den default wert. Aber wenn Volts noch im grünen Bereich sind dann kann ich mich immerhin schon mal langsam bis dort hin ran testen sofern dies überhaupt nötig sein sollte.
Habe gesehen das du ein anderes bios drauf hast als ich. Gibt es dafür einen Grund - da es älter ist? Aktuellste beta ist mai 2010
Auf dem desktop liegen dann aber 1,21 v @ 471 FSB an und das ist absolut garnix ;)
solltest dir nur evtl nen 80mm Lüfter auf die Graka stellen der die NB kühlt.
Schau dir die screens vom luxxer Prime gut an denn es kommt beim DFI nicht nur auf die Spannungen und Ram settings an.
Da gibt es welche die sind fast wichtiger ;)
Die cpu wird viel wärmer als auf dem gigabyte, und das um locker 9c ^^
vermute es liegt am höheren vtt den man beim gigabyte nicht einstellen konnte.
Kann eigwntlich nicht !
Hab due cpu ja auch auf dwm DK getestet und zudem noch @ luft !
Poste mal deine bios settings
Werde morgen noch mal den kühler abnehmen, evtl ist dort nen Sandkorn zwischen.
Habe eben 63c bekommen bei 1,20v bei einer zimmer temp von 22c, auf meinen x48 habe ich gerade mal 58-62c bei 1,275v.
Ist ja auch wumpe, wenn über 65c geht dann kommt die wakü drauf, wobei ich das eigentlich vermeiden wollte.
So habe eben mal nen 3,8ghz run auf linx gemacht, nun werde ich mal die 3,9ghz angehen.
Sag mal, hast du bei dir die 2 extra Stromanschlüsse angeschlossen? Ich bei mir nicht da die ja nur für 2 Grakas sind.
Bios screen schiebe ich mal gleich nach.
Beschäftige dich mal mit dem DFI.... bei 423mhz FSB braucht das Board keine 1,21 vtt/vnb.
@ Prime73
damit habe ich vor ein paar Stunden angefangen ^^
Hatte das mobo vorher auch noch nie im Betrieb.
@ Fresh_Thing
hier mal bios screens, ist eigentlich alles default gewesen bis auf Spannungen.
Bei 3,9Ghz Bootet er schon nicht mehr ins Windows.
Dann Vergleich doch mal meine Pic´s mit deinen. Da hast du alles was man für FSB 471 braucht. Sind zwar immer nur Richtwerte aber besser als nix :d
die hatte ich schon vor 2 std getestet, aber ging auch nur bis 3,8ghz - bei 3,9ghz ebenfalls Absturz.
Bin jetzt mal bei 3,8Ghz wieder auf default NB & Vtt spannung gegangen - aber NB muss schon auf 1,19v angehoben werden damit er ins windows bootet, vtt bleibt bei 1,10V.
Code:
