Ich habe auch 2 PC's, aber der andere (an dem ich imo sitze) unterstützt eben maximal PC 266 - und damit kann ich unmöglich meinen Speicher testen
Also ich habe da mal was gefunden:
"The MD Driving Strength determines the signal strength of the memory data line. The higher the value, the stronger the signal. It is mainly used to boost the DRAM driving capability with heavier DRAM loads (multiple and/or double-sided DIMMs). So, if you are using a heavy DRAM load, you should set this function to Hi or High. Due to the nature of this BIOS option, it's possible to use it as an aid in overclocking the memory bus. Your SDRAM DIMM may not overclock as well as you wanted it to. But by raising the signal strength of the memory data line, it is possible to improve its stability at overclocked speeds. But this is not a surefire way of overclocking the memory bus. In addition, increasing the memory bus signal strength will not improve the performance of the SDRAM DIMMs. So, it's advisable to leave the MD Driving Strength at Lo/Low unless you have a high DRAM load or if you are trying to stabilize an overclocked DIMM."
“Sometimes called driving strength. This feature allows you to control the memory data bus' signal strength. Increasing the drive strength of the memory bus can increase stability during overclocking. DRAM drive strength refers to the signal strength of the memory data line. A higher number means a stronger signal and is generally recommended for an overclocked module to improve stability. Supposedly TCCD works better with weak drive strength while just about everything else prefers a stronger signal.”
From bigtoe: “If you leave the option at Auto this will set a weak drive strength, this is good for TCCD based modules but bad for anything else. From testing and debugging the board I have concluded the following. Options 1 3 5 7 are all weak, as is Auto, setting. 1 is actually the weakest option with 7 being as close to the normal weak setting DFI will allow us. Options 2 4 6 8 are the Normal settings, with 8 being the highest strength setting. If you are using TCCD you may want to try 3 5 or 7 as the drive settings as they usually seem to allow the modules to clock well. If you are using VX, or the new BH Gold, or any other modules from the OCZ range you may want to try 8 or 6.”
Also was lernen wir daraus? 1 ist bei Data Drive Strength sicher, 2,3, oder 4 nur sehr selten stabil, aber sehr performant.
Bei dem anderen sind Settings mit geraden Zahlen gut für meine Speicher, vor allem ein hoher Wert sollte helfen, da die niedrigen nur für TCCD's geeignet sind.
Man man man, bei der Seite stehen mehr Infos als ich lesen will
Edit: Wir sind doch nicht alleine
Memtest läuft nun schon 34 Runden ohne Fehler...also für mich sieht es fast so aus, als hätte ich mit der Tras-Einstellung den Fehler gefunden...
