o$$!ram schrieb:aha
@ bestellung
gbts was neues? irgendwas schon angekommen?
The o-rings are cheap. One piece costs 0,07 Eur.Terrorbifi schrieb:Hey Eddy,
how much are the bigger O-rings if you´d send it to me?
I´m quite interested in the new ones cause im not a real friend of that teflon thing![]()
Please Send me an e-mail info @ ekwaterblocks.com!Terrorbifi schrieb:Hey thats great.
And if i have to pay shipping, i think, that i will also order that delrim plate for my graphic card cooler. That black one looks nice
Well, order via PM or shop order?
Cyberwar schrieb:Status?
Eddy_EK schrieb:Interesting.
Could you tell me if that is when using 13,3 fittings or 14mm?
Because if using 13,3 barbs the thread hole has to have cutted edges a little bit more so the o-ring could contact the surface.
One option is to use thicker O-rings, which I can supply.
Great!KoxBox schrieb:I had the same Problem with 5 of 12 piece with the 13.3 Fittings , after change @ thicker Alphacool O-Rings its already ok now![]()
**BEISTIMM**EvilMoe schrieb:Juhu!
Nochmal Danke fürs Engagement Wakeman![]()
**DANKESCHÖN**Auch wenn ich selbst noch warten muss, kann ich mich EvilMoe nur anschließenEvilMoe schrieb:Juhu!
warum?o$$!ram schrieb:das is jetzt aber blöd![]()
