smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate Exos X16
Device Model: ST16000NM001G-2KK103
Serial Number: ZL2DJC1L
LU WWN Device Id: 5 000c50 0c8b5a455
Firmware Version: SN03
User Capacity: 16,000,900,661,248 bytes [16.0 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Jun 4 07:00:28 2022 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
Total time to complete Offline
data collection: ( 559) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: (1400) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 081 064 044 Pre-fail Always - 122769200
3 Spin_Up_Time 0x0003 090 089 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 90
5 Reallocated_Sector_Ct 0x0033 099 099 010 Pre-fail Always - 5016
7 Seek_Error_Rate 0x000f 084 060 045 Pre-fail Always - 241408937
9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 10184
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 73
18 Head_Health 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 098 098 000 Old_age Always - 2
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 064 048 040 Old_age Always - 36 (Min/Max 22/38)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 37
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 560
194 Temperature_Celsius 0x0022 036 041 000 Old_age Always - 36 (0 16 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Pressure_Limit 0x0023 100 100 001 Pre-fail Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 10131h+46m+09.933s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 42757734214
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 133046681282
SMART Error Log Version: 1
ATA Error Count: 2
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 2 occurred at disk power-on lifetime: 10177 hours (424 days + 1 hours)
When the command that caused the error occurred, the device was doing SMART Offline or Self-test.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 53 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 c8 ff ff ff 4f 00 36d+09:15:27.628 READ FPDMA QUEUED
60 00 50 ff ff ff 4f 00 36d+09:15:18.608 READ FPDMA QUEUED
60 00 c8 ff ff ff 4f 00 36d+09:15:18.433 READ FPDMA QUEUED
60 00 d0 ff ff ff 4f 00 36d+09:15:18.403 READ FPDMA QUEUED
60 00 c0 ff ff ff 4f 00 36d+09:15:18.401 READ FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 10073 hours (419 days + 17 hours)
When the command that caused the error occurred, the device was active or idle.
40 53 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455
61 00 08 ff ff ff 4f 00 32d+00:24:39.942 WRITE FPDMA QUEUED
60 00 08 ff ff ff 4f 00 32d+00:24:39.942 READ FPDMA QUEUED
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Self-test routine in progress 90% 10184 -
# 2 Extended offline Aborted by host 30% 10168 -
# 3 Extended offline Completed without error 00% 1535 -
# 4 Short offline Completed without error 00% 77 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
