=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 116 099 006 Pre-fail Always - 113016712
3 Spin_Up_Time 0x0003 092 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 125
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 046 046 030 Pre-fail Always - 103080442240
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 343
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 098 098 020 Old_age Always - 2724
183 Runtime_Bad_Block 0x0032 093 093 000 Old_age Always - 7
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 10 10 10
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 073 053 045 Old_age Always - 27 (Min/Max 26/27)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 53
193 Load_Cycle_Count 0x0032 095 095 000 Old_age Always - 11678
194 Temperature_Celsius 0x0022 027 047 000 Old_age Always - 27 (0 19 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 5
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 725h+58m+40.129s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 18578878829
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 35152202874
1 Raw_Read_Error_Rate 0x000f 100 065 006 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 098 098 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 5
7 Seek_Error_Rate 0x000f 100 253 045 Pre-fail Always - 7074
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 228 (132 111 0)
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 139
183 Runtime_Bad_Block 0x0032 099 099 000 Old_age Always - 1
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
190 Airflow_Temperature_Cel 0x0022 069 064 040 Old_age Always - 31 (Min/Max 31/31)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 10
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 253
194 Temperature_Celsius 0x0022 031 040 000 Old_age Always - 31 (0 28 0 0 0)
195 Hardware_ECC_Recovered 0x001a 100 065 000 Old_age Always - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 1
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 30h+12m+49.405s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 3832475824
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2466221
SMART Attributes Data Structure revision number: 16
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 175 173 021 Pre-fail Always - 8250
4 Start_Stop_Count 0x0032 098 098 000 Old_age Always - 2858
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 092 092 000 Old_age Always - 5908
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 2839
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 329
193 Load_Cycle_Count 0x0032 189 189 000 Old_age Always - 33958
194 Temperature_Celsius 0x0022 124 109 000 Old_age Always - 28
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
Wenn Du sie also ersetzt, solltest Du zu NAS Platten greifen, wo schon die einfachen Modelle für bis zu 8 HDDs pro Gehäuse ausgelegt sind.
achte darauf ob der Rohwert vom Attribut 199 steigt, wenn ja, dann ist das Problem aktuell noch vorhanden.
Weil man praktisch jede SSD für jeden Zweck verwenden kann, zumindest im Heimbereich, denn die sind alle für Dauerbetrieb und den Betrieb mit mehreren anderen SSDs im gleichen Gehäuse geeignet, was bei HDDs nicht so ist. Bei SSDs muss man dann neben der Performance nur noch darauf achten das das Schreibvolumen zur TBW passt.Bei SSDs stellt doch auch kaum jemand die Frage nach dem Verwendungszweck.
Die IronWolf Reihe wurde von Seagate früher nur Seagate NAS genannt, bevor sie in IronWolf umbenannt wurden. Die Händler und Preisvergleichsportale aktualisieren die Angabe und erst recht die Bilder aber oft nicht, wenn eine neue Version vom Hersteller kommt. Entscheidend ist die Modellnummer, nicht das Bild auf irgendeiner InternetseiteZum Beispiel bei Seagate IronWolf ist die Menge der Modellnummern verwirrend. Dann wird die Version PRO angeboten und auf dem Foto steht NAS.
Das sind etwa 2,5TB pro Jahr. Selbst eine Crucial BX500 1TB für etwas über 60€ hat 360TB TBW und es würde über 140 Jahre dauern bis die bei 20GB alle 3 Tage ausgeschöpft wärenIch habe das Gefühl, dass bei regelmäßigen Backups alle 3 Tage von etwa 20GB die SSDs relativ schnell altern.
Viel Spaß damit, die sind einmal über die vom Hersteller vorgesehenen Nutzungsdauer von 5 Jahren hinaus und dann auch noch überlagert.Ich habe jetzt 2 USB-Platten hervor gekramt, die länger als 10 Jahre herum liegen und die noch einwandfrei lesbar sind.
Bei einer Toshiba HG6 Sata SSD zeigt CDI nur noch 90% an. Kann mich nicht erinnern, was ich da großartig geschrieben habe. Die lag etwa 1 Jahr nur rum bzw. steckte in der alten WS mit Ubuntu(?) drauf.würde über 140 Jahre dauern bis die bei 20GB alle
Diese Seagate stirbt wohl langsam vor sich hin. Ich habe zufällig Bilder von unseren früheren Hunden gefunden. Wäre vllt schade darum.Man lernt ja nie aus.![]()
Problem ist das eigentlich alle 'aktuellen' HDD bis 8 TB keine Helium HDD mehr sind und damit nicht besonders Stromsparend sind.Preis/Leistung wäre ich jetzt auf der Suche nach guten/stromsparenden HDD’s mit 8TB.
Platten laufen 24/7 als „zfs mirror“ mit TrueNAS.
Du solltest bei 8TB darauf achten das es KEINE SMR HDD sind, ansonsten gibt es auf der Technischen Seite nur extrem geringe Unterschiede.Wieder IronWolf Pro, oder WD Red Pro, oder Toshiba N300!?
