Folding@Home - Hardwareluxx Team
who cares hat mich schon überholt. werd mit meiner hardware auch nicht merh aufholen können :(
nur extra wegen folding neue hardware? irgendwo isses dann auch zuviel des guten^^
Hallöle!
Hatte heute schon 3x einen Bluescreen mit folgendem STOP-Error:
STOP: 0x0000008E (0xC0000005, 0x00BEAEDB, 0xB6F31CEC, 0x00000000)
Das Windbg Crashdump sieht folgendermaßen aus (falls sich jemand auskennt):
Microsoft (R) Windows Debugger Version 6.9.0003.113 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini070108-03.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: C:\WINDOWS\Symbols
Executable search path is:
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055d720
Debug session time: Tue Jul 1 12:33:22.625 2008 (GMT+2)
System Uptime: 0 days 0:09:19.400
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, beaedb, b6f31cec, 0}
*** WARNING: Unable to verify timestamp for NDIS.sys
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
Und nach "!analyze -v" kommt:
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 00beaedb, The address that the exception occurred at
Arg3: b6f31cec, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in "0x%08lx" verweist auf Speicher in "0x%08lx". Der Vorgang "%s" konnte nicht auf dem Speicher durchgeführt werden.
FAULTING_IP:
+beaedb
00beaedb 0174bfbe add dword ptr [edi+edi*4-42h],esi
TRAP_FRAME: b6f31cec -- (.trap 0xffffffffb6f31cec)
ErrCode = 00000002
eax=bab38000 ebx=00000000 ecx=00000000 edx=ffffffff esi=cf900600 edi=6e543015
eip=00beaedb esp=b6f31d60 ebp=b6f31d64 iopl=0 nv up ei ng nz ac pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010296
00beaedb 0174bfbe add dword ptr [edi+edi*4-42h],esi ds:0023:27a4f027=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 3
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x8E
PROCESS_NAME: FahCore_11.exe
LAST_CONTROL_TRANSFER: from 00d00804 to 00beaedb
STACK_TEXT:
WARNING: Frame IP not in any known module. Following frames may be wrong.
b6f31d64 00d00804 badb0d00 01420000 b6791d98 0xbeaedb
b6f31d68 badb0d00 01420000 b6791d98 b6791dcc 0xd00804
b6f31d6c 01420000 b6791d98 b6791dcc 00000000 0xbadb0d00
b6f31d70 b6791d98 b6791dcc 00000000 00000000 0x1420000
b6f31d74 b6791dcc 00000000 00000000 00000000 0xb6791d98
b6f31d78 00000000 00000000 00000000 00000000 0xb6791dcc
STACK_COMMAND: .trap 0xffffffffb6f31cec ; kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: 0x8E_ANALYSIS_INCONCLUSIVE
Weiß jemand wie ich das in den Griff bekommen kann?
tut mir leid, davon hab ich wenig bis keine ahnung.
Mal ne andere frage, wie kann ich es anstellen, dass der cpu client meine cpu auch richtig auslastet? habe nie vollauslastung trotz gpu und cpu client..
Bei mir zeigt er im Taskmanager bei Systemleistung einen Kern 100% (CPU-Client) und beim anderen zwischen 60-80% (GPU-Client) an.
Bei Prozesse stehen bei mir:
FahCore_79.exe CPU-Auslastung 50% (CPU-Client)
FahCore_11.exe CPU-Auslastung 30% (GPU-Client)
Dein "Problem" scheint normal zu sein.
Hatte ich vor ein paar Seiten schonmal geschrieben, momentan 446,53 PPD.
Hatte aber auch schon, bei längerer Laufzeit, also wenn die Kiste mal nicht abstürzt, über 900 PPD.
Und wieviel schafft deiner?
hab vor lauter punkte geilheit mal den 5.03 installiert. da komm ich grad mal auf 280ppd^^
das ding is für die tonne
Das ändert sich im Laufe der Berechnungen.
Wie gesagt, hatte auch meist 450 PPD, aber später auf einmal 9900 PPD.
Keine Ahnung wovon das abhängt.
Berechnungsfehler.
Passiert, wenn du kurz vor der Fertigstellung 1% einer WU bist, den Client beendest und neustartest.
In ein paar Tagen Folde ich weiter, derzeit bin ich auf Urlaub und mein System lief nicht stabil 24h durch.
Werde die paar Tage einholen..dank meiner GTX 260 und den Q9450^^
Ich kann leider auch nicht 24/7 durchfolden, da mir laufend mein Game-PC abschmiert.
Ich hoffe, dass es der RAM ist und nicht das Mainboard.
Mit welchem Proggi könnte man testen ob am Board alles in Ordnung ist?
Der RAM ist ja schnell ausgetauscht und momentan nicht sooo kosteninstensiv. ;)
EDIT:
Hab gerade ein mieses Projekt, nämlich 3903.
Double Gromacs
Meine CPU brauch noch über 13h dafür.
EDIT2
Ich Depp weiß auch warum:
Der läuft nach dem Absturz nur mit Standarttakt. :fire:
Heute und Morgen werde ich nur in den Abendstunden crunshen/falten können,
da es mir sonst zu warm werden würde hier in der Bude. :d
Nicht direkt - nein. :d Nur über die im Sommer recht unangenehme extra Wärme in der Bude. :fresse:
Jein... Habs mal ausgerechnet und komm bei nem Verbrauch von 200 Watt auf knapp 1€ mehr pro Tag. Lässt sich noch aushalten und ich lass meinen PC sowieso seit 2 Tagen im 2D-Takt falten. Somit ist der Stromverbauch geringer und ich hab trotzdem was getan ;-)
Sonst hab ich auch nur ein Problem mit der Hitze die sich in meinem Zimmer sammelt, aber damit kommt ich schon irgendwie klar, bzw. geht dann einfach vor die Tür, wenn ich es kühl haben möchte :d
das hab ich gleich in den stats gemerkt, dass du langsamer faltest ;)
Alter Gegner :lol:
Hehe
Jo, glaub so reichts auch... Meinen Anteil leiste ich ja trotzdem ;-)
Die ganze Zeit Vollgas hat meinen Radiator schon förmlich glühen lassen. Jetzt wird er erstmal getauscht und dann schau ich mal, ob nicht doch wieder mehr geht...
hehe, meine g80 läuft am limit übertaktet um überhaupt mithalten zu können :shot:
dazu ein cpu client^^
OT: hab eben mal auf Liquid Pro WLP gewechselt, im Lieferumfang waren Wattestäbchen, eine Art Schleiffleece und ein Tuch getränkt mit Isopropanol :d
Lol. Also das wär mir dann doch ein bissel viel...
@Liquid Pro: Benutz ich auch, aber als Pad. Das Flüssige ist mir bei meinem Geschick zu unsicher... Bei den Pads ist auch immer ein Schleiffleece und ein Reinigungstuch dabei. Das Tuch ist aber nach dem erstmal benutzen schon für die Tonne und dann nehm ich immer Brillenputztücher. So duften die Heatspreader noch gut :lol:
Die LiquidPro Spritze ist gefährlich. Das hängt am Anfang etwas, dann drückt man bisserl mehr und schon hat man eine Metal-Fontäne, die durchs Zimmer geht. Aber mit Wattestäbchen lässt es sich gut verteilen :fresse:
Ich will mehr Punkte...die PS3-WUs sind...:shot:
hehe, musst mit 2 händen abspritzen, das geht besser..
Ich hab mir inder apotheke gegenüber fürn euro isopropanol geholt. erst nach demm alles wieder lief und ich die packung wegschmeissen wollte, hab ich das "zubehör" gesehn..
warum nimmst du keinen cpu/gpu client, don?
