[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Kann mir jemand mal erklären warum ich mich bei Quantum-Force nicht einloggen kann?
Ich komm da nicht rein:hmm:.
Liegen meine Bootprobleme am flash mit dem Foxconn liveupdate? Nach jedem Neustart bleibt das Sys hängen. Nach CMOS clear und erneutem Starten läuft es bis ins Windows und ist da auch stabil. Ich habe auf ein zwei Seiten gelesen, dass es mit dem Tool Probleme geben kann. Foxconn selbst weist ja bei einigen BIOS Vers. darauf hin.
Kann mir mal jemand 1-2 G-BIOS Versionen irgendwo hochladen, damit ich die testen kann? Bei QF kann ich mich selbst ja nicht einloggen:(.
EDIT:
Die 2900XT/512 überfordert ein Seasonic S12II 430W? Das hätte ich nicht gedacht.
Allerdings gab es nur Probleme beim Start des Sys. und im 3D. Ich dachte zuerst, es würde am BIOS update über das Liveupdate Prg. liegen. Nach Einbau einer X800gto läuft das Sys wieder fehlerfrei.
...versuch einen anderen Browser, doch davor noch: bist du dir sicher den richtigen Usernamen und Passwort verwendet zu haben...? Ich hatte mit dem Login noch nie Probleme, auch eben gerade nochmal versucht, ging problemlos...
...ansonsten neu anmelden, dürftze ja auch nicht so schwer sein...
BIOS findest du auch bei XS im Foxconn-Forum. Oder bei Google...
Zum BIOS-Update kann ich nichts sagen: Ich hab das Windows-Tool gleich nach installtion des MB und neuazfsetzen von Vista benutzt, und er bleib auch gleich hängen. Danach hab ich das G30 per Floppy-Blindflash aufgespielt, und seitdem keine Probleme mehr. Der On-Off-Bug mit dem alten BIOS ist auch verschwunden, dass kann aber auch andere Ursachen haben...
Danke für den Hinweis. Mit dem IE geht der login, allerdings will awdflash nicht, dass ich das G30 flashe. : bin doesn´t match with your System:hmm:.
Hallo Zusammen!¨
Ich möchte gerne meine Kiste etwas aufwerten
und habe nun ein paar Fragen
ich will einen neuen Prozi (aktuell E6600)
ich habe an etwas zwischen E8400 und E8600 gedacht.
Dazu Ein passender Kühler passt der Zalman CNPS9700 NT auf das Board?
Hat da jemand erfahrungen?
Und dann noch eine Frage zu den RAM
mir wurden Crucial Ballistix Tracer 2x2GB Kit, DDR2-800, CL4-4-4-12 RAM empfohlen
Ist daran was auszusetzen?
Packt das Board 8giga?
Danke für eure Hilfe
Grüässli
Oli
meinen E84 hab ich auf dem Mars locker auf 4.25GHZ bekommen (4,5GHZ würden auch noch laufen aber da die Kiste bei mir nur auf default läuft war es mir dann egal....).
Ram hab ich auch tracer aber nur 2X1GB 1066er, 8 gig sollten funkt., event. musst du die Spannung an der NB etwas anheben, aber für was brauchst du 8GB?! falls du OC willst ist vollbestückung sicher nicht das beste...
Zum kühler kann ich nix sagen, ich hab nen alpenföhn drauf....
Hallo, ich habe auch 8 GB am laufen, und zwar 4 Mushkin Module.
Ist kein Problem auf dem Board, habe das Verhältniss so eingestellt, das der RAM auf 1000 MHz läuft, und der Rest auf Standard.
Bei 1000 MHz hat er die beste Performance, bei 1066 bricht der Durchsatz wieder ein.
Die Spannungen habe ich sogar noch undervoltet, auf für den E8400.
Ich habe nen Thermalright HR-01 Plus drauf, das passt so grade mit dem NB Kühler, wenn das obere Blech herausgenommen wird.
Hallo Freunde,
wenn zufällig jemand das Board, worum es in diesem thread geht gerade verkaufen möchte, soll er sich bei mir per PN melden. Am besten gleich mit Preisvorstellung.
__________________
Nix gibts des bleibt meins^^
hab mal ne Frage auf was muss ich bei Vollbestückung achten? würd mir die gleichen Speicher wie in meiner Sig nochmal kaufen. Gibt es da was zu beachten?
Alex
Müsste klappen. Evtl. musst du diverse Spannungen anheben oder Timings entschärfen.
Ausprobieren!
So da ich nun 8Gb drin hab wollt ich mal angangen zu ocen. mageres ergebnis 480 fsb 490 friert er beim laden von vista ein und 500 bootet er dreimal. was schafft ihr den so und vorallem mit welcher spannung.
Spannung von der NB war bei standard 1.250V auch ein höher stellen hat nix gebacht.
Und wieso kann man den Ram nicht 1:1 laufen lassen? Sondern nur 1:2?
Der Speicherteiler will manchmal nicht so ganz, das habe ich bei mir auch schon mal gemerkt!
Irgendwie ist da auch ein Sprung drin, wenn man die Spannung von SB oder NB ändert.
Ich habe meine 8 GB damals mal Testweise auf 560 MHz laufen gehabt, bei welchem Teiler und welche Spannungen kann ich dir aber leider nicht mehr sagen!
Es war auf jeden Fall nicht viel, was ich anheben musste.
Stelle mal Testweise den tRFC Wert auf 60!
Okay werd ich mal testen.
hab grad in deiner Sig gesehen das du P16 Bios drauf hast wo hastet des den her? Bzw irgendwelche änderungen gemerkt?
Edit: Has gefunden auf der Haupthomepage
Genau, ist von der Foxconn Seite, nicht von Quantum Force.
Ich weiß auch nicht genau, was die da für ne Politik in Sachen Bios fahren.
Klar!
Meines läuft noch immer mit dem E84... fette 3GHZ@ ~1V:fresse: Das Mars ist sicher eines der besten Mobos die ich je hatte, und das gebe ich nie wieder her:)....Ist zwar fast Verschwendung als "Surf-Pc-Mobo" aber wie gesagt, solange es läuft bleibt es in meinem Gehäuse:banana:
Da gebe ich dir recht!
Mein eines musste zur RMA, habe in der Zwischenzeit nach weiteren Boards geschaut, aber mir dann letztendlich ein 2tes Mars bei eBay geschossen, da kein anderes Board eist im undervolteten Zustand unterstützt, und keines so sparsam läuft wie das Mars.
Meins läuft auch noch tadellos (Q6600 auf 3,2GHz bei Standard-VCore). Hatte auch selten ein derart unproblematisches Board. Da hatten die davor (Asus S939-Boards, SockelA-Boards) schon eher ihre Wehwehchen.
Bin sehr zufrieden mit dem Teil.
Ja meines läuft auch noch tadellos :)
Oh ja, von Asus Boards bin ich auch geheilt!
Ich mag es nicht, wenn man im Bios etwas einstellt, und das Board macht was anderes, oder macht es gar nicht!
falls jemand noch zufällig eine atx blende über hat vom mars...ich bräuchte eine :)
Hat vielleicht jemand das Aegis Panel 1.0.2.32 für mich zur Hand?
Das 1.0.2.34 läuft bei mir nicht, und die Quantum-Force HP ist down!
Hey ich brauch mal Hilfe.
Ich hab im
1. 1x PCIe ne soundkarte, creative audio xtreme
2. 16x PCIe 9800gx2
3. 1x nix, da verdeckt
4. 4x PCIe 3ware raid controller.
Seitdem ich den Raid controller drin habe, funktioniert die Soundkarte nicht mehr, also der 1. PCIe slot ist somit tot. Wie kann ich wieder gerade biegen?
@earth: das 1.0.2.34 hätte ich da, bei mir läufts problemlos, es soll scheinbar ein neues geben, darf man der Foxconn-HP glauben schenken, die Version 1.0.7., nur leider ist der entsprechende Link nicht korrekt, man lädt nur die uralte version 1.0.1. runter. Hba mal gegoogelt, die 7er aber noch nicht gefunden...
...wenn die einer hat, bitte mal verlinken! Danke!
Hat oder hatte jemand mal die Q9550 oder Q9550s drauf? Der Multi 8,5 geht nur bei FSB 333 mit BIOS P16. Bei erhöhtem FSB geht der Multi auf 8 zurück. Ist das vielleicht bei einem anderen BIOS gefixet?
