[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
immerhin kannst du spielen, ich hab momentan nicht mal ne Graka zum Zocken, beide kaputt. Aber dafür hab ich ordentlich Sound :bigok:
Klassischer Fall von dumm gelaufen!^^
Warum was haste den gemacht?
oh das is scheisse, sowas hab ich auch noch nich gesehen.
vielleicht liegts am dfi kable?
aber nu mal wieder was zum mars!^^
kann sein, wenn man den vcore multiplier einstellt das sys stabiler wird? bzw primefehler nich so leicht auftreten?
Bin grad zwar am anfang des testens, aber wollt mal fragen, ob vielleicht schon erfahrungen mit gemacht wurden. morgen weis ich mehr
also das mit dem Multiplikator funktioniert bei mir auch erst seit dem neuestem Bios, vorher wurde das einfach nicht übernommen. Der Vdroop ist genauso groß, also einen Unterschied hab ich bis jetzt auch noch nicht damit ausgemacht...
Ja aber es scheint stbiler zu sen hab den 1.036 und 09xxx vcore und mom läuft prime noch(small ftt oder so)
bei ner vcore von 1.0125 is er mir sifort abgeschmiert etz mit dem multi
ab ich ne vcore von 1.0101 und er läuft noch 0,960 vcore unter last hab ich mom.
Kann es aber iwie sein, das sich eist nich mehr aktivieren lässt? habs vorhin enabled und etz als ich wieder ins bios reingeschaut hab wars disabled.
c1e is auf auto.
der multi wird aber von 8x300 auf 6x300 gesenkt.
und die vcore is im idle auch geringer 0.918
hast du des auch festegellt?
weiß gerade nicht mit welchem Profil ich hier unterwegs bin... Welches Bios hast du denn?
neuste offfizelle p11
2. bios p09
vielleicht liegts auch am neuen bios!?!
hab auch das aktuelle drauf, aber um das jetzt zu testen müsste ich neu booten :fresse:
Sehr intersant, kann eist nicht mehr auswählen, springt, soblad ich aus dem menü rasgeh wieder auf disable.
auch interresant is,das wenn man die vcore zuweit senkt unter idle und 6x300 (gab nen bluescreen)die vcore höher is als mit einer leicht höhren vcore, die aber stable zu sein scheint
naja die is ja älter oder nicht?
außerdem was bringt den EIST überhaupt?
runtertakten und vcore senken macht es auch so
gut. THX
naja mal schaun ob EIST bei vcore auf standard funzt wenn nich beta bios.
ich bin mal weg servus
wär schon komisch wenn nicht... Hast du eigentlich schon mal max FSB ausprobiert?
Also war wohl nix war nich stable läuft etz wieder auf 1.0250 laut bios. ohne multi.
was soll des max FSB denn bringen?
ach anscheinend geht EIST nicht mehr beim undervolten zumindest mit dem P11 wenn alles auf standard laufen lass, dann gehts wieder.
obs sich des beim ocen genauso verhält weiß ich nicht
wollte bloß wissen welchen max. FSB dein Quad in Verbindung mit dem Mars macht.
aso hab ich noch nich so ganz raus hohl mir übernächste woche erstmal ein neues nt, da meins ein 20/4pin is und da schon ziemliche schwankungen da sin.
Moin moin!
Mein Board geht jetzt mal ab wie Schmitz-Katze....
Habs jetzt primestable auf 3,4GHz @ LuKü mit 1,34V.
Find ich mal Hammer, das konnte mein gutes, altes Striker nicht.
Läuft mit 8x425MHz, max fsb hab ich zwar noch nicht getestet, aber 500FSB habe ich schon primestable hinbekommen. Sollte aber noch gut was drin sein.
Also echt jetzt mal....Foxconn rockt die Hütte!! Das erste Gamerboard und der Oberhammer. Da sollte sich ASUS mal ne Scheibe abschneiden, aber die Boards kommen mit auch net mehr in die Kiste.
hast du die 500Mhz FSB mit deinem Quad geschafft? Das wäre ja richtig gut...
Hab jetzt bei mir mal nachgeschaut und das gleiche wie bei °Leon° beobachtet. Allerdings undervolte ich nicht. Bei oc wird im Bios EIST jedesmal wieder auf disabled gesetzt. Bios ist
G29. Schon komisch, wo doch immer wieder behauptet wird beim Mars funktioniere C1E und
EIST auch beim oc ohne Probleme.
es funktioniert ja auch. Weiß nicht warum es das bei euch Beiden nicht tut?!
Bei mir funktioniert es auch problemlos, sowohl Undervolting als auch Overclocking. Hab als Bios P09.
@Kurbel: Jo, hab die mit meinem Quad erreicht. Allerdings hab ich jetzt 425FSB als 24/7 gewählt, gefällt mir so super.
Und bei mir gehen C1E und EIST auch beide mit OC, hab sie aber jetzt aus, einfach noch aus alter Gewohnheit, weil das ja oft net so harmoniert. Bios hab ich auch P09 drauf.
Dann scheint es an der bios version zu liegen. bei meinem p09 gings auch noch wunderbar. naja egal spannung und multi senken machts ja trotzdem
Joa, find ich auch gut. :)
Mein alter E6600 hat das nicht gepackt, der war allerdings auch mal so gar nicht taktfreudig.
Aber der neue Quad ist echt mal ne Wucht, hab auch n echt nettes Modell abbekommen...lässt alles auch bei niedrigen Spannungen mit sich machen. Momentan fahre ich 3,4Ghz bei im Bios eingestellten 1,35V. :eek:
Und die ganzen Biosversionen bei Quantum-Force sind aber auch mal verwirrend...hab mir schon einige davon gesaugt, aber irgendwie will ich die glaub ich gar nich draufspielen, läuft ja so schon alles super.
Nur mit meinem Speicher hab ich leichte Probleme. Der ließ sich mit dem Striker besser takten als jetzt. Normal hatte ich ihn stabil auf 1066MHz, jetzt komme ich mit Ach und Krach an die 1000 ran, aber das auch nur bei besch***enen Timings...Vielleicht doch mal n anderes Bios?
