[Sammelthread] Gigabyte GA-MA78GM-S2H (AMD 780G) "Deneb" Ready! [2]
dreyerspezi
Schüttorf/Braunschweig
So weil es bisher noch keinen Sammelthread zu dem Board gibt habe ich mir gedacht, dass ich einfach mal einen erstelle.
1. Das Mainboard
Noch mehr Bilder
1.1 Spezifikationen
Spezifikationen
CPU
1. Support for Socket AM2+/ AM2 processors: AMD Phenom™FX processor/ AMD Phenom™ processor/ AMD Athlon™ 64 FX processor/AMD Athlon™ 64 X2 Dual-Core processor/AMD Athlon™ 64 processor/AMD Sempron™ processor
Hyper Transport Bus
1. 5200/2000 MT/s
Chipset
1. North Bridge: AMD 780G
2. South Bridge: AMD SB700
Memory
1. 4 x 1.8V DDR2 DIMM sockets supporting up to 16 GB of system memory (Note 1)
2. Dual channel memory architecture
3. Support for DDR2 1066 (Note 2)/800/667 MHz memory modules
Audio
1. Realtek ALC889A codec
2. High Definition Audio
3. 2/4/5.1/7.1-channel
4. Support for DTS (dts NEO:PC)
5. Support for S/PDIF In/Out
6. Support for CD In
LAN
1. Realtek 8111C chip (10/100/1000 Mbit)
Expansion Slots
1. 1 x PCI Express x16 slot (The PCI Express x16 slot conforms to PCI Express 2.0 standard.)
2. 1 x PCI Express x1 slot
3. 2 x PCI slots
Storage Interface South Bridge:
1. 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
2. 5 x SATA 3Gb/s connectors (SATAII0, SATAII1, SATAII2, SATAII3, SATAII4) supporting up to 5 SATA 3Gb/s devices
3. 1 x eSATA 3Gb/s port on the back panel supporting up to 1 SATA 3Gb/s device
4. Support for SATA RAID 0, RAID 1 and RAID 10
South Bridge:
iTE IT8718 chip:
1. 1 x floppy disk drive connector supporting up to 1 floppy disk drive 1 x floppy disk drive connector supporting up to 1 floppy disk drive
IEEE 1394 T.I. TSB43AB23 chip
1. Up to 2 IEEE 1394a ports (1 on the back panel, 1 via the IEEE 1394a bracket connected to the internal IEEE 1394a header)
USB Integrated in the South Bridge
1. Up to 12 USB 2.0/1.1 ports (4 on the back panel, 8 via the USB brackets connected to the internal USB headers)
Internal I/O Connectors
1. 1 x 24-pin ATX main power connector
2. 1 x 4-pin ATX 12V power connector
3. 1 x floppy disk drive connector
4. 1 x IDE connector
5. 5 x SATA 3Gb/s connectors
6. 1 x CPU fan header
7. 1 x system fan header
8. 1 x front panel header
9. 1 x front panel audio header
10. 1 x CD In connector
11. 1 x S/PDIF In/Out header
12. 1 x IEEE 1394a header
13. 4 x USB 2.0/1.1 headers
14. 1 x parallel port header
15. 1 x Trusted Platform Module (TPM) header
16. 1 x serial port header
17. 1 x chassis intrusion header
18. 1 x power LED header
Back Panel Connectors
1. 1 x PS/2 keyboard port
2. 1 x PS/2 mouse port
3. 1 x D-Sub port
4. 1 x DVI-D port (Note 3)
5. 1 x HDMI port
6. 1 x optical S/PDIF Out connector
7. 1 x eSATA 3Gb/s port
8. 1 x IEEE 1394a port
9. 4 x USB 2.0/1.1 ports
10. 1 x RJ-45 port
11. 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
I/O Controller
1. ITE IT8718 chip
H/W Monitoring System voltage detection
1. CPU/System temperature detection
2. CPU/System fan speed detection
3. CPU overheating warning
4. CPU/System fan fail warning
5. CPU/System fan speed control (Note 4)
BIOS
1. 1 x 8 Mbit flash
2. Use of licensed AWARD BIOS
3. PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features
1. Support for @BIOS
2. Support for Download Center
3. Support for Q-Flash
4. Support for EasyTune (Note 5)
5. Support for Xpress Install
6. Support for Xpress Recovery2
7. Support for Virtual Dual BIOS
Bundle Software
1. Norton Internet Security (OEM version)
Operating System
1. Support for Microsoft Windows Vista/ XP
Form Factor
1. Micro ATX Form Factor; 24.4cm x 24.4cm​
1.2 Ausstattung
Soweit ersichtlich:
-1x IDE Kabel
-1x Floppy Kabel
-2x SATA Kabel (1x gewinklet, 1x normal)
-I/O Shield
-Anleitung
2. Hilfen
2.1 Speicher Kompatiblitätsliste
->Speicher Kompatiblitätsliste
-> Falls Speicher die nicht in der Liste stehen und funktionieren bzw. nicht funktionieren stehen sie hier.
- 2 x 1 GB Extrememory von COS Memory DDR2 - 800-er RAM PC2 - 6400 (400 MHz) mit 5-5-5-18
2x 1GB - 2048MB Aeneon X-TuneKit CL4
2 x 2 GB OCZ Titanium XTC OCZ2T800C42G
2 x 1024MB G Skill F2-6400CL4-1GBPK
4GB G.SKILL DDR2-800 RAM 5.0-5-5-15 (Man muss nur die Spannung um 0.1V erhöhen)
2x Cellshock DIMM 1024MB PC2-5300U CL5-5-5-15 (DDR2-667) (CS2110650)
2.2 Vergleich 780G vs. GF8200
Geforce 8200
AMD 780G
2.3 Hybrid-Crossfire
-Infos zu Hybrid-Crossfire
-Möglich ab Catalyst 8.3
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
->BIOS
->Treiber
->Bedienungsanleitung
3.2 Komplettes Wakü set von Anfitec
-Bilder
-Bilder
-Bilder
-Bilder
-Northbridge Kühler 40,00€ (pci-1 fach slot unbrauchbar)
-Spannungswandler Kühler 43,00€
-Southbridge Kühler 37,00€ (pci-16 fach slot unbrauchbar)
-Bestellungen an info@anfi-tec.de
3.3 Allg. Links
Reviews: -@ ocworkbench
-@ bit-tech
-@ hardtecs4u
-@ tomshardware
-@ PCGH
-@ hothardware
-@ techreport
-@ BareboneCenter.de
-@ techwarelabs
-@ silentpcreview
-Aussagen über Stromverbrauch
3.4 Geizhals Link
->Geizhals.at
Mittlerweile lässt sich auf der Gigabyte Hompage schon eine neuere Revision (Rev. 1.1) finden.
Die Größten, bisher bekannten Unterschiede sind das Wegfallen des TPM-Headers, der geänderte Kühlkörper und ein zusätzlicher Lüfteranschluss links neben dem PCIe x1 Slot
Hier ein Bild
Ich bin offen für Verbesserungsvorschläge.
@buzzzer
wo bist denn die ATI Beta 8.4.9x zum Download.
Ich hab hier auch DVBViewer und das hängt sich ab und zu mal auf
schon den 8.4 von der amd/ati page genommen? ist zwar 8.47 glaub ich...versuchen kannst es ja aber!
hat noch jemand unter XP (nicht Vista, da ist das Problem bekannt) Abstürze in Verbindung von:
- Catalyst 8.5
- PowerDVD7 H264 Dekoder (aktueller Build)
- DVBViewer aktuelle Beta + Overlay als Renderer
Bei mir schmiert in dieser Kombination regelmäßig der DVBViewer ab ("DVBViewer Pro hat ein Problem festgestellt und muss beendet werden").
Hat noch jemand das Problem?
Hallöchen..
Welche Version von PowerDVD hast du denn?
Ich habe Catalyst 8.5 PowerDVD8 unter Vista 32bit und bei mir läuft die Hardwarebeschleunigung.
Die Hardwarebeschleunigung geht nur unter PowerDVD7.3 mit aktuellen Update/Patsch oder PowerDVD8.
Rolf
Das stimmt zumindest unter XP nicht ganz.
Ich habe den PowerDVD 7.3 mit nicht dem ganz aktuellen Patch sondern eine Version davor, müsste ich mal genau zuhause gucken. Kann sein das auch 8.5 geht, aber da hier viele von Abstürzen unter XP schreiben, habe ich den garnicht erst probiert.
Mit den ganz normalen Windows-Funktionen (Wiederherstellungspunkt, Systemplatte unter Überwachung) kann man Treiber gefahrlos ausprobieren. Ich würde 8.5 installieren, habe noch nichts Negatives unter XP SP2 bemerkt.
PowerDVD8 stürzt unter Vista mit Catalyst 8.5 bei HD-Videos (z.B. ts-Format) regelmäßig ab. Keine Probleme hat PowerDVD8 mit Mpeg2. Mit Catalyst 8.4 unter Vista gibts mit PowerDVD8 keine Probleme. Weder bei hochauflösende Videos noch andere Formate.
@Dietmar: Klar kann ich den probieren. Die Frage ist nur: Warum ? Es läuft ja beides gerade wie es soll.
(Habe auch ein Backup, das ist genauso schnell wieder eingespielt)
Folgende Frage tut sich gerade noch auf:
Kann ich PowerDVD so in DVBViewer einbinden, dass ich auch HDDVD darüber steuern kann ?
Bzw. kann ich DVBViewer mit einer Kabelkarte und PowerDVD im Vista MCE ohne Probleme einbinden ?
Gerne würde ich die Technotrend Fernbedienung oder zumindestens den Empfäger davon nutzen. Fernbedienung kann ich mit meiner Logitech Harmony ja anpassen.
MediaPortal wäre ntürlich eine Möglichkeit, aber ich lese immer wieder, dass plötzlich irgendwas nicht mehr hinhaut. Da habe ich keine Lust zu und warte mal auf eine Final 1.0.
Wenn es unter Windows läuft, dann werde ich linuxmce antesten. Da freue ich mich schon richtig drauf ;)
Hey, gibt es mittlerweile oder wird es ein Update geben, sodass man HDMI zeitgleich mit DVI nutzen kann ? Ich habe mir gerade das HDMI Kabel (5m) gekauft und musste feststellen, dass es bisher nicht geht.
Ich glaub das hängt von der Hardware (Chipsatz) ab und wird nicht möglich sein. In den Testberichten über das Board und den Chipsatz ist zu lesen das ein Dual-Monitorbetrieb nur über HDMI+VGA oder DVI+VGA möglich ist.
Gruß Rolf
Also die CCC 8.4 Treiber von der ATI/ AMD Seite habe ich ja heruntergeladen.
Hab auch POWER DVD, und benutze DVBViewer und hab da die ganzen Decoder von POWER DVD7 genommen.
Mal läufts undd ann auf einmal bleibt das Bild stehen aber der Ton läuft weiter, das ist echt komsich.
Im Gegensatz zur letzten offiziellen Version bringt der Treiber den XP-Usern HD-Beschleunigung unter PowerDVD und einen Fix für das "kein-Bild-an-meinem-Fernseher-nach-Umschalten"-Problem. Andere Verbesserungen:
Catalyst™ Control Center Component Video
ATI Graphics Driver Un-install Enhancement
SECAM TV Out Support
1080p HDTV custom mode
HDMI Audio for non-standard TV modes
Adaptive AA on OpenGL for Catalyst™ Control Center
1080p24 Mode Support
Windows XP Service Pack 3 support
Performance Improvements
... und haufenweise korrigierte Probleme unter XP. Zu viele, um hier alle aufzuzählen, siehe deshalb Release-Notes. Die 8.49-Beta hatte zwar einige dieser Verbesserungen auch gebracht, aber Betas installiere ich nicht.
Hey, danke für die Antwort. Dass das hardwaremäßig nicht funktioniert ist natürlich "bescheiden" ^^
Naja, dann werde ich mein neues HDMI Kabel als neu weiterverkaufen ^^
Erstmal ist ein Grafiktreiber heute fast immer eine Beta. Es wird ja ständig etwas gefixt ;)
Zudem funktionierte bei mir die Hardwarebeschleunigung unter XP bei PowerDVD mit dem 8.4 nicht. Es gab keinen 8.5, also hatte ich nur diese Wahl wenn ich kein Vista installieren möchte.
Aber um mal vom Treiber wegzukommen:
Wie und in was kann ich PowerDVD integrieren ausser Mediaportal ?
Interessanterweise scheint der Chipsatz neben RGB (VGA) und digital (DVI/HDMI) auch noch einen TV-Ausgang zu zu unterstützen. Leider unbestückt:
Das ist nicht der Punkt. Ich installiere keine durchgesickerten Betas von irgendwelchen Webseiten (statt der Treiber von der Hersteller-Webseite). Wer weiss, durch welche Hände solche Betas gegangen ist. Ausserdem kann man sich nicht darauf verlasssen, dass die regulären Versionen bei Treiber-Updates durchgesickerte Versionen korrekt aktualisieren können.
Ht den mal jemand den 8.475er Treiber von der Gigaybte.com.tw Seite probiert? Der ist etwas neuer, leider kommt da kein CCC mit.
hatte mit dem 8.5 + powerdvd8 update da kein problem mehr. ohne jedoch schon.
gruß!
Hat schon jemand den Northbridgekühler gegen einen Alternativkühler wie den Hr-05 getauscht?
jo gibts sogar einen test zu. findest du im ersten thread ...
Ahso das aber schade... :(
Komischerweise komm ich aber hin wenn ich draufklicke, liegt vielleicht daran das es noch im Cache liegt.
EDIT: Hab mich voll verlesen, du hast den Link zum Test auf deinem Webspace geändert :d
Hoi Leute,
könnt Ihr mir bitte helfen?
1. Wenn ich meine Rechner in Standby oder Ruhezustand schalte, alles wunderbar, will ich ihn aber wider einschalten fährt er hoch nur mein TV bleibt aus?!?
2. Muste meinen Rechner über VGA anschließen weil über HDMI ich ein unscharfes Bild hatte. Konnte zwar im CCC bei overlay regeln, wenn ich es aber ganz auf 0% stelle, fehlen Oben unten und an der Seite teile vom Bild! Treiber 8.5. Mit VGA TIPTOP-Bild.
Hab nen 4850e, Vista 32bit und an nem Samsung LE46M86 über VGA hängen. Treiber 8.3 weil 8.5 viele Abstürze verursachte. Dickes Danke an euch!!
habe den gleichen LCD, stelle ihn mal auf TRUE SCAN
habe für den LCD in einem Forum Einstellungen gefunden - jetzt - Hammerbild
die TV Kartte bleibt aus, da sie kein wakeup unterstützt
Sagt mal verwenden alle Hersteller Standardmäßig Wärmeleitpads bei der Passivkühlkörpermontage?
Wollte mir den Ötzi draufmachen und da ist mir das aufgefallen.
Komischerweise hab ich dann den Scythe Mini nicht mehr draufbekommen muss ich demnächst nochmal gucken.
Nu hab ich grad erstmal wieder den Standardpassivkühler drauf mit WLP und allein das macht imho schon einen kleinen Wärmeunterschied aus auch wenn der nicht sooo groß ist.
in der Regel sind die "Pflaster" drauf
und eigentlich machen das alle Hersteller
so, die entscheidung ist gefallen.
das gigabyte mainboard ging zurück und ich habe mich für das asus
M3A78-EMH HDMI entschieden.
bei dem gigabyte gab es einfach zuviele kinderkrankheiten/ungereimtheiten.
das fing bei dem nicht funktionierenden wecken, per usb, mit der mce remote v2 aus dem ruhzustand an und hört bei den schrecklich-nervtötenden störgeräuschen über den analog-ausgang leider nicht auf.
dazwischen gab es so sachen, wie eine nicht richtig funktionierende lüftersteuerung, die bei dem amd-boxed lüfter diesen viel zu schnell drehen liess. das gigabyte icool-tool war kompletter schrott und funktionierte auch nicht richtig.
um objektiv zu sein:
das mit der lüftersteuerung ist beim asus auch so, was ich zimlich unbefriedgend finde. da ist biostar weit voraus. dort hört man den lüfter nämlich wirklich kaum und auch nur so macht eine "smartfan-option" überhaupt sinn.
beim ausus sind die besagten störgeräusche ebenfalls vorhanden, aber lange nicht so ausgeprägt wie beim gigabyte. da muss man schon wirklich dicht mit dem ohr vor dem lautsprecher sein, um selbige zu hören. unschön ist es natürlich trotzdem.
dann hat das asus jumper für usb-wakeup ,mit denen man auch sicherstellen kann, das wakeup per usb funktioniert. man ist da nicht wie beim gigabyte auf die (bei mir) nicht funktionierende bios-option angewiesen.
das asus hat auch einen größeren chipsatzkühler und wird deshalb nicht so heiss, wie das gigabyte.
insgesamt kommt mir das asus-mainboard solider vor.
ich möchte mich bei allen für die doch recht gute zusammenarbeit bedanken und würde mich freuen, den ein oder anderen vielleicht im nächsten thread wideder zu treffen:)
Grüß
g.m
@gm: schade das Du das Board getauscht hast. Vielleicht hast Du ja ein Montagsboard erwischt.
Die Lüftersteuerung funktioniert bei mir im BIOS schon wunderbar, da braucht man kein Tool unter Windows. Analogsound ist mir schnuppe, ich brauche nur den digitalen ;) Und den Chipsatzkühler kann man ja tauschen...
