Grafikkarten ***Bilder*** Thread (2) (Part 3)
@exxe:
Der CL GD5464 benutzt RAMBUS Speicher. So alt kann die Karte nicht sein, der Chip ist Kalenderwoche 04/98 hergestellt:
Spaeter hat dann selbst Intel Rambus verbaut auf den P3 Mainboards, war aber nicht soo erfolgreich. Die Preisgestaltung war ein wenig abgehoben.
64-bit graphics engine with integrated 3D game acceleration (CL-GD5464)
— Perspective textures mapping
— Bilinear/trilinear filtering
— Mip mapping
— Lit, copy, decal, and blend textures
— Texture decompression
— Mono rasterization (single-pass lighting)
— Stippling
— Polygon, line, and point drawing
— 16-bit Z-buffer
— Gouraud shading
— Alpha blending, fog, and transparency
— Display list processing for maximum performance
— Hardware page flipping
— Sub-pixel accuracy
High-performance 64-bit GUI accelerator
— Three-operand BitBLT (bit block transfer)
— Color expansion for 8-, 16-, 24-, and 32-bpp modes
— Stretch BLT
PCI 2.1-compliant bus master (CL-GD5464)
— DMA maximizes system performance
— Host-rendered/cached texture maps
AGP (accelerated graphics port) support (CL-GD5465)
Video playback acceleration
— Single-pass X, Y interpolated scaling
— Hardware occlusion for three video windows
— YUV-to-RGB conversion
— Color and chroma key
Rambus memory architecture
— Low-latency devices supported
— Single memory for color-buffer, Z-buffer, and texture store
V-Port for peripheral expansion
— MPEG decoder
— TV tuner
— Teleconferencing
Integrated VGA controller
Integrated 230-MHz palette DAC and clock synthesizer
(CL-GD5462 is 170 MHz)
— Supports resolutions up to 1600x1200 at 85 Hz
— True-color operation up to 1024x768
— Hardware cursor
DDC (display data channel) level 2B-compliant monitor signaling
‘Green PC’ power-saving features support
— DPMS (display power management signaling)
— System power-down
gar nicht mal so schlecht
auf dem CL chip steht 50 96
und P III Rambus wa dann doch n paar jahre später
aber naja ich lass mich halt gern eines besserenbeleren.
@exxe
Jo ... der Laguna3D (CL-GD5464, GD5462 und GD5465 (AGP) ) waren die letzten Grafikchips von Cirrus Logic.
Von der Leistung waren die aber ca. bei einer S3 Virge / DX ... was also ziemlich lahm bedeutete.
RD-RAM ist schon was feines - aber anscheinend hat es die Karte nicht rausgerissen.
Unglaublich wie viele Chiphersteller es damals gab, und auch wieviele versucht haben auf den 3D Zug aufzuspringen.
Ich denke daß die meisten da gescheitert sind liegt teils an der Software bzw. den 3D Schnittstellen. Da gab's ja echt viele damals, OpenGL, Glide, Direct3D, Heidi, S3Metal, RenderWare, BRender, PowerSGL und und und.
Die meisten waren ja Eigenentwicklungen der einzelnen Chiphersteller (Glide = 3DFX, PowerSGL = NEC PowerVR, S3Metal bzw. RenderWare/BRender = S3 usw.) und DirectX / Direct3D steckte noch in den Kinderschuhen.
OpenGL, Direct3D und Glide kritstallisierten sich dann als die Favoriten der Softwarehersteller heraus, wobei Glide mit 3DFX starb.
Heute wird eigentlich nur noch Direct3D und OpenGL verwendet.
Also wer noch alte Grakas hat (und auch seltene wie z.B. die Cirrus Logic von exxe) immer her mit den Bildern !
@szene_kenner
Hab' damals lange überlegt welche TNT2 ich mir nehmen sollte, und die Xentor 32 war auch ein Top Favorit. Es ist dann aber die ASUS V3800 Ultra Deluxe geworden.
Bald kann ich GF256 SDR, GF256 DDR und GF2GTS ablichten :banana:
Ich such aba noch einiges ;)
@SigZeig :wink: :d
jaaa GTS meinelieblingskarte
Leider gibts die nur in rot...
Och mensch...
Immernoch keine Hotlinks...
Also nimm das Bild wieder raus oder mach ein eigenes.
Ich schau immer ganz gespannt in den Fred und dann ist nur so ein Mist drin :fresse:
Vor allem interessiert so ein Bild doch auch keinen...
von welcher Graka stammt hierder Ausschnitt? //TM30 ist von der Umfrage ausgeschlossen :d
mama schrieb:
sli auch,
aber 2 ati's , einfach nur schön :)
SLi läuft aber wenisgtens in Games und hat einen Leistungszuwachs.
Crossfire stürzt öffters mal gerne ab oder läuft nicht viel schneller als mit einer Karte.
BTT, also fröhliches Bilderposten
Weiter... ;)
Aber dürfte dann wohl eindeutlig sein ;)
Ist ne Voodoo3 3500TV
Das tolle ist, dass ich von der Karte garnichts hab, weil ich die aufgrund der fehlenden Kabel nicht anschließen kann... ergo ich weis nichmal ob die funktioniert...
Aber davon geh ich mal seeehr stark aus ;)
Uih ne TV grünes PCB?
Meine erste 7600GT ... eine PNY,
danach kam eine Asus 7600GT Silent ...
und seit gestern diese Gigabyte 7600GT :love:
lol aber echt :lol:
@VL125
jep ist grün
nur eben 3dfx grün, also ziemlich dunkelgrün.
Da es eben schon ziemlich dunkel war und ich den Blitz nich nehmen wollte ist die Karte demensprechend "schwarz" ;)
Weiss jemand um welche Grafikkarte es sich hier handelt?
Sie war in einem Rechner eingebaut und dann stand der Keller unter Wasser.
Aufloesung gibts spaeter.
Bild in gross
Ich würde sagen, es ist einen Karte mit dem weltweit schmalsten Kühler: Dem Schlamm-O-Matic :haha:
