// ENBSeries 0.82 effect file
// OriginalCodes: Boris, Ice, Dkt70, AAA, AMD, gp65cj04 and specially MasterKontrol
// Edited and modifed by schakusa
// Added different DoF-Versions, tweaking lines and many more by schakusa
// Copyright 2010 (c) Boris Vorontsov
////////////////////////// If you need, tweak, but READ!!!
//////// DEPTH OF FIELD
//// Choose the Depth of Field Version you want. (More taps, more quality, less fps!!!) Choose what you want!
//// PLAYABLESTATIC is a 24taps static-dof. original code by icelaglace
//// SCREENSTATIC is a 60taps static-dof. original code by gp65cj04
//// SCREENDYNAMIC is a 60taps dynamic-dof with autofocus. original code by icelaglace
//// PLAYABLEDYNAMIC is a 5taps dyanmic-dof. original code by gp65cj04
//// !!! NEVER !!! enable more than one DOF at THE SAME TIME !!!
//#define PLAYABLESTATIC
//#define SCREENSTATIC
#define SCREENDYNAMIC
//#define PLAYABLEDYNAMIC
//// DOF Settings - Higher Values, stronger DoF for ALL DoF-Versions (change it to 2.00 if you use SSAA in .ini file)
float DOFSizeMulti = 1.005;
//// DOF Settings - Higher Values, stronger DoF for individual DoF
float PDOFAMOUNT = 0.45; // value for PLAYABLESTATIC
float SDOFAMOUNT = 0.65; // value for SCREENSTATIC
float SDDOFAmount = 0.2; // value for SCREENDYNAMIC
float PDDOFAmount = 0.20; // value for PLAYABLEDYNAMIC
//////// MOTION BLUR. original code by MasterKontrol
int MBSteps = 12;
int MBAmount = -0.2;
//////// VIGNETTE SETTINGS. original code by MasterKontrol
//#define VIGNETTE_FX_NEW
float SquareTop = 0.56; // TOP of Screen.
float SquareBottom = 0.53; // BOTTOM of Screen.
float CircularPower = 0.50; // CIRCULAR Vignette Amount.
float ColorDistortion = 1.00; // COLOR Distortion Strength.
float ContrastSharpen = 1.20; // Contrast & Sharpness Increase.
float NightStrength = 6.5; // Strength at Night of Effect.
//#define VIGNETTE_FX_OLD
float VignetteFocus = 8; // Old Version Vignette - Focus.
float VignetteAmount = 0.4; // Old Version Vignette - Amount.
//////// Color, Saturation, Bloom, Filmcurve etc. original codes by icelaglace
float BloomAmountMix = 0.40;
float BloomAdditive = 0;
float AdaptationValue = 0.95;
#define GlobalSaturation
float Saturation = 1.22;
#define GAMMACORRECTION
float GammaAmount = 1.0;
//#define FILMICCURVE
float A = 0.20; // Shoulder Strength
float B = 1.50; // Linear Strength
float C = 0.20; // Linear Angle
float D = 1.90; // Toe Strength
float E = 0.02; // Toe Numerator
float F = 1.50; // Toe Denominator
float W = 11.2; // White Scale
//#define BLEACH
float BP_factor = 0.0;
///////// END
// sampler2D AdapLumSampler;
// sampler2D BloomSampler;
// float4 ColorCorrect;
// float4 ColorShift;
// float Exposure;
// sampler2D GBufferTextureSampler2;
// sampler2D GBufferTextureSampler3;
// sampler2D HDRSampler;
// sampler2D JitterSampler;
// float PLAYER_MASK;
// sampler2D StencilCopySampler;
// float4 TexelSize;
// float4 ToneMapParams;
// float4 deSatContrastGamma;
// float4 dofBlur;
// float4 dofDist;
// float4 dofProj;
// float gDirectionalMotionBlurLength;
// float4 globalScreenSize;
// row_major float4x4 motionBlurMatrix;
// Registers:
// Name Reg Size
// globalScreenSize c44 1
// Exposure c66 1
// motionBlurMatrix c72 4
// TexelSize c76 1
// dofProj c77 1
// dofDist c78 1
// dofBlur c79 1
// gDirectionalMotionBlurLength c80 1
// ToneMapParams c81 1
// deSatContrastGamma c82 1
// ColorCorrect c83 1
// ColorShift c84 1
// PLAYER_MASK c85 1
// GBufferTextureSampler2 s0 1
// GBufferTextureSampler3 s1 1
// HDRSampler s2 1
// BloomSampler s3 1
// AdapLumSampler s4 1
// JitterSampler s5 1
// StencilCopySampler s6 1
//quad
struct VS_OUTPUT_POST
float4 vpos : POSITION;
float2 txcoord0 : TEXCOORD0;
struct VS_INPUT_POST
float3 pos : POSITION;
float4 _c44 : register(c44);
float4 _c66 : register(c66);
float4 _c72 : register(c72);
float4 _c73 : register(c73);
float4 _c74 : register(c74);
float4 _c75 : register(c75);
float4 _c76 : register(c76);
float4 _c77 : register(c77);
float4 _c78 : register(c78);
float4 _c79 : register(c79);
float4 _c80 : register(c80);
float4 _c81 : register(c81);
float4 _c82 : register(c82);
float4 _c83 : register(c83);
float4 _c84 : register(c84);
float4 _c85 : register(c85);
texture2D texs0 : register(s0);
texture2D texs1 : register(s1);
texture2D texs2 : register(s2);
texture2D texs3 : register(s3);
texture2D texs4 : register(s4);
texture2D texs5 : register(s5);
texture2D texs6 : register(s6);
texture2D texs7 : register(s7);
texture2D texs15 : register(s15);
sampler2D s2=sampler_state { Texture=<texs2>; };
sampler2D s4=sampler_state { Texture=<texs4>; };
//sampler2D s5=sampler_state { Texture=<texs5>; };
sampler2D s6=sampler_state { Texture=<texs6>; };
sampler2D s7=sampler_state { Texture=<texs7>; };
sampler2D s15=sampler_state { Texture=<texs15>; };
sampler2D s0 = sampler_state
Texture = <texs0>;
MinFilter = LINEAR;//
MagFilter = LINEAR;//
MipFilter = NONE;//NONE;//LINEAR;
AddressU = Clamp;
AddressV = Clamp;
SRGBTexture=FALSE;
MaxMipLevel=0;
MipMapLodBias=0;
sampler2D s1 = sampler_state
Texture = <texs1>;
AddressU = Clamp;
AddressV = Clamp;
SRGBTexture=FALSE;
MaxMipLevel=0;
MipMapLodBias=0;
sampler2D s3 = sampler_state
Texture = <texs3>;
AddressU = Clamp;
AddressV = Clamp;
SRGBTexture=FALSE;
MaxMipLevel=0;
MipMapLodBias=0;
sampler2D s5 = sampler_state
Texture = <texs5>;
MinFilter = GaussianQuad;
MagFilter = GaussianQuad;
MipFilter = LINEAR;
AddressU = Wrap;
AddressV = wrap;
SRGBTexture=FALSE;
MaxMipLevel=0;
MipMapLodBias=0;
float4 PS_C215BE6E(VS_OUTPUT_POST IN) : COLOR
float4 _oC0=0.0; //output
float4 _c0=float4(0, 0.212500006, 0.715399981, 0.0720999986);
float4 _c1=float4(0.25, 1, 256, 0);
float4 _c2=float4(0, 2, 4, 8);
float4 _c3=float4(58.1640015, 47.1300011, 0, 0);
float4 _c4=float4(-0.5, -1.5, 1.5, 0.5);
float4 _c5=float4(2, -1, 0.125, 0);
float4 _c6=float4(256, 2, 4, 8);
float4 _c7=float4(1.0, 0.1, 0.8, 1.0);
float4 _c8=float4(0.0, 0.1, 0.8, 0.333);
float4 _c9=float4(0.06, 0.1, 0.8, 0.1);
float4 _c10=float4(0.01, 1.4, 0.0, 0.32);
float4 _c11=float4(0.333333, 1.0, 0.0, 0.0);
float4 _c12=float4(0.299, 0.587, 0.114, 0.0);
float4 _c13=float4(0.0, 0.0, 0.0, 0.00001);
float4 _c150=float4(0.55, 0.9, 0.85, 0.9);
float4 _c195=float4(0.0, 0.0, 0.0, 0.07);//0.7
float4 r0;
float4 r1;
float4 r2;
float4 r3;
float4 r4;
float4 r5;
float4 r6;
float4 r7;
float4 r8;
float4 r9;
float4 r10;
float4 r11;
float4 _v0=0.0;
_v0.xy=IN.txcoord0.xy;
r0=tex2D(s1, _v0.xy); //GBufferTextureSampler3
r0.y=-_c77.x + _c77.y; //-dofProj.x + dofProj.y
r0.y=1.0/r0.y;
r0.z=r0.y * _c77.y; //dofProj.y
r0.z=r0.z * -_c77.x; //dofProj.x
r0.x=_c77.y * -r0.y + r0.x;
r0.x=1.0/r0.x;
r0.y=r0.z * r0.x;
r1=tex2D(s2, _v0.xy); //HDRSampler
r2=tex2D(s3, _v0.xy); //BloomSampler
float2 center;
float depth;
float focus;
float distance;
r0.y=1.0/r0.y;
r0.x=1.0/r0.x;
r0.y=r0.z * r0.x;
r0.w=abs(_c79.w);
r3=_c4; //-0.5, -1.5, 1.5, 0.5
depth=r0.z * r0.x - _c78.w; //dofDist.w
depth+=_c78.y * -r3.w; //dofDist.y
depth+=148;//offset
center.x=_v0.x-0.5;
center.y=0.5-_v0.y;
#ifdef PLAYABLESTATIC
float4 vDofParams = float4(-35, 1.5, 800.0, 1.0); //near blur depth, focal plane depth, far blur depth, blurriness cut off constant
depth = max(depth, 0);
float dist;
if(depth < vDofParams.y)
dist = (depth - vDofParams.y)/(vDofParams.y - vDofParams.x);
else
dist = (depth - vDofParams.y)/(vDofParams.z - vDofParams.y);
dist = clamp(dist, 0, vDofParams.w);
dist = dist * 0.5 + 0.5;
static float3 poisson[24]=
float3(1.0, 0.0, 1.0000 ), //0 degrees
float3(0.0, -1.0, 1.0000 ),
float3(-1.0, 0.0, 1.0000 ),
float3(0.0, 1.0, 1.0000 ),
float3(0.7071, 0.7071, 1.0000 ), //45 degrees
float3(-0.7071, -0.7071, 1.0000 ),
float3(-0.7071, 0.7071, 1.0000 ),
float3(0.9659, 0.2588, 1.0000 ), //15 degrees
float3(0.2588, -0.9659, 1.0000 ),
float3(-0.9659, -0.2588, 1.0000 ),
float3(-0.2588, 0.9659, 1.0000 ),
float3(0.8660, 0.5000, 1.0000 ), //60 degrees
float3(0.5000, -0.8660, 1.0000 ),
float3(-0.8660, -0.5000, 1.0000 ),
float3(-0.5000, 0.8660, 1.0000 ),
float3(0.5000, 0.8660, 1.0000 ), //30 degrees
float3(0.8660, -0.5000, 1.0000 ),
float3(-0.5000, -0.8660, 1.0000 ),
float3(-0.8660, 0.5000, 1.0000 ),
float3(0.2588, 0.9659, 1.0000 ), //75 degrees
float3(0.9659, -0.2588, 1.0000 ),
float3(-0.2588, -0.9659, 1.0000 ),
float3(-0.9659, 0.2588, 1.0000 ),
float2 pixelSizeHigh;
float2 pixelSizeLow;
pixelSizeHigh.x = 1.000 / _c44.x;
pixelSizeHigh.y = 1.000 / _c44.y;
//pixelSizeHigh.x = 2.0 / _c44.x;
//pixelSizeHigh.y = 2.0 / _c44.y;
pixelSizeHigh.xy *= DOFSizeMulti;
pixelSizeLow.xy = pixelSizeHigh.xy;
float2 vMaxCoC = float2(5.0, 10.0);
float radiusScale = PDOFAMOUNT;
float discRadius;
float discRadiusLow;
float centerDepth;
float4 tdepth;
float4 tapHigh;
float4 tapLow;
centerDepth = dist;
discRadius = abs(centerDepth * vMaxCoC.y - vMaxCoC.x);
discRadiusLow = discRadius * radiusScale;
r1 = 0.0;
for(int t = 0; t < 24; t++)
float2 coordLow = _v0.xy + (pixelSizeLow.xy * poisson[t].xy * discRadiusLow);
float2 coordHigh = _v0.xy + (pixelSizeHigh.xy * poisson[t].xy * discRadius);
tapLow = tex2D(s2, coordLow.xy) * poisson[t].z;
tapHigh = tex2D(s2, coordHigh.xy) * poisson[t].z;
tdepth = tex2D(s1, coordHigh.xy); //GBufferTextureSampler3
tdepth.y = -_c77.x + _c77.y; //-dofProj.x + dofProj.y
tdepth.y = 1.0 / tdepth.y;
tdepth.z = tdepth.y * _c77.y; //dofProj.y
tdepth.z = tdepth.z * -_c77.x; //dofProj.x
tdepth.x = _c77.y * -tdepth.y + tdepth.x;
tdepth.x = 1.0 / tdepth.x;
tdepth.w = tdepth.z * tdepth.x - _c78.w; //dofDist.w
tdepth.w += _c78.y * -r3.w; //dofDist.y
tdepth.w += 148;//offset
tdepth.w = max(tdepth.w, 0); //fix zoom bug
if(tdepth.w < vDofParams.y)
tapHigh.w = (tdepth.w - vDofParams.y)/(vDofParams.y - vDofParams.x);
else
tapHigh.w = (tdepth.w - vDofParams.y)/(vDofParams.z - vDofParams.y);
tapHigh.w = clamp(tapHigh.w, 0, vDofParams.w);
tapHigh.w = tapHigh.w * 0.5 + 0.5;
tapLow.w = tapHigh.w;
float tapBlur = abs(tapHigh.w * 2.0 - 1.0);
float4 tap = lerp(tapHigh, tapLow, tapBlur);
if(tap.w >= centerDepth) tap.w = 1.0;
else tap.w = abs(tap.w * 2.0 - 1.0);
r1.xyz += tap.xyz * tap.w;
r1.w += tap.w;
r1.xyz /= r1.w;
#endif
#ifdef SCREENSTATIC
//depth+=148;//offset
depth = max(depth, 0); //fix zoom bug
float4 vDofParams = float4(-25, 1.5, 700.0, 0.7); //near blur depth, focal plane depth, far blur depth, blurriness cut off constant
float dist;
else
static float3 poisson[60] =
float3( 0.2165, 0.1250, 1.0000 ),
float3( 0.0000, 0.2500, 1.0000 ),
float3( -0.2165, 0.1250, 1.0000 ),
float3( -0.2165, -0.1250, 1.0000 ),
float3( -0.0000, -0.2500, 1.0000 ),
float3( 0.2165, -0.1250, 1.0000 ),
float3( 0.4330, 0.2500, 1.0000 ),
float3( 0.0000, 0.5000, 1.0000 ),
float3( -0.4330, 0.2500, 1.0000 ),
float3( -0.4330, -0.2500, 1.0000 ),
float3( -0.0000, -0.5000, 1.0000 ),
float3( 0.4330, -0.2500, 1.0000 ),
float3( 0.6495, 0.3750, 1.0000 ),
float3( 0.0000, 0.7500, 1.0000 ),
float3( -0.6495, 0.3750, 1.0000 ),
float3( -0.6495, -0.3750, 1.0000 ),
float3( -0.0000, -0.7500, 1.0000 ),
float3( 0.6495, -0.3750, 1.0000 ),
float3( 0.8660, 0.5000, 1.0000 ),
float3( 0.0000, 1.0000, 1.0000 ),
float3( -0.8660, 0.5000, 1.0000 ),
float3( -0.8660, -0.5000, 1.0000 ),
float3( -0.0000, -1.0000, 1.0000 ),
float3( 0.8660, -0.5000, 1.0000 ),
float3( 0.2163, 0.3754, 0.8670 ),
float3( -0.2170, 0.3750, 0.8670 ),
float3( -0.4333, -0.0004, 0.8670 ),
float3( -0.2163, -0.3754, 0.8670 ),
float3( 0.2170, -0.3750, 0.8670 ),
float3( 0.4333, 0.0004, 0.8670 ),
float3( 0.4328, 0.5004, 0.8847 ),
float3( -0.2170, 0.6250, 0.8847 ),
float3( -0.6498, 0.1246, 0.8847 ),
float3( -0.4328, -0.5004, 0.8847 ),
float3( 0.2170, -0.6250, 0.8847 ),
float3( 0.6498, -0.1246, 0.8847 ),
float3( 0.6493, 0.6254, 0.9065 ),
float3( -0.2170, 0.8750, 0.9065 ),
float3( -0.8663, 0.2496, 0.9065 ),
float3( -0.6493, -0.6254, 0.9065 ),
float3( 0.2170, -0.8750, 0.9065 ),
float3( 0.8663, -0.2496, 0.9065 ),
float3( 0.2160, 0.6259, 0.8851 ),
float3( -0.4340, 0.5000, 0.8851 ),
float3( -0.6500, -0.1259, 0.8851 ),
float3( -0.2160, -0.6259, 0.8851 ),
float3( 0.4340, -0.5000, 0.8851 ),
float3( 0.6500, 0.1259, 0.8851 ),
float3( 0.4325, 0.7509, 0.8670 ),
float3( -0.4340, 0.7500, 0.8670 ),
float3( -0.8665, -0.0009, 0.8670 ),
float3( -0.4325, -0.7509, 0.8670 ),
float3( 0.4340, -0.7500, 0.8670 ),
float3( 0.8665, 0.0009, 0.8670 ),
float3( 0.2158, 0.8763, 0.9070 ),
float3( -0.6510, 0.6250, 0.9070 ),
float3( -0.8668, -0.2513, 0.9070 ),
float3( -0.2158, -0.8763, 0.9070 ),
float3( 0.6510, -0.6250, 0.9070 ),
float3( 0.8668, 0.2513, 0.9070 )
float radiusScale = SDOFAMOUNT;
float discRadius;
float centerDepth;
float4 tdepth;
float4 tapHigh;
float4 tapLow;
centerDepth = dist;
r1 = 0.0;
for(int t = 0; t < 60; t++)
//tdepth.w += 148;//offset
else
r1.w += tap.w;
r1.xyz /= r1.w;
//float4 dofcolor = r1;
//dofcolor.w = r1.w / DoF_TAPS;
#endif
#ifdef SCREENDYNAMIC
float4 vDofParams = float4(-30, 1.5, 25000, 1.00); //near blur depth, focal plane depth, far blur depth, blurriness cut off constant
float2 FocusPoint = float2(0.5, 0.45);
r4=tex2D(s1, FocusPoint); //GBufferTextureSampler3
r4.y=-_c77.x + _c77.y; //-dofProj.x + dofProj.y
r4.y=1/r4.y;
r4.z=r4.y * _c77.y; //dofProj.y
r4.z=r4.z * -_c77.x; //dofProj.x
r4.x=_c77.y * -r4.y + r4.x;
r4.x=1/r4.x;
r4.y=r4.z * r4.x;
float cdepth;
cdepth=r4.z * r4.x - _c78.w; //dofDist.w
cdepth+=_c78.y * -r3.w; //dofDist.y
cdepth+=148;//offset
r4.w = tex2D(s0, FocusPoint).w;
if(r4.w > 0)
vDofParams.z = cdepth*2.0;
vDofParams.y = cdepth;
float dist;
else
float radiusScale = SDDOFAmount;
float discRadius;
float centerDepth;
float4 tdepth;
float4 tapHigh;
float4 tapLow;
centerDepth = dist;
r1 = 0.0;
for(int t = 0; t < 60; t++){
else
if(tap.w >= centerDepth) tap.w = 1;
r1.w += tap.w;
r1.xyz /= r1.w;
#endif
#ifdef PLAYABLEDYNAMIC
float4 vDofParams = float4(-20, 1.5, 20000, 0.85); //near blur depth, focal plane depth, far blur depth, blurriness cut off constant
float2 FocusPoint = float2(0.5, 0.5);
r4.y=1/r4.y;
r4.x=1/r4.x;
r4.y=r4.z * r4.x;
float cdepth;
if(r4.w > 0)
float dist;
else
static float3 poisson[5] =
float3 (0.809, 0.41, 1),
float3 (-0.809, 0.41, 1),
float3 (0, 1 , 1),
float3 (-0.58, -0.809, 1),
float3 (0.58, -0.809, 1)
float radiusScale = PDDOFAmount;
float discRadius;
float centerDepth;
float4 tdepth;
float4 tapHigh;
float4 tapLow;
centerDepth = dist;
r1 = 0.0;
for(int t = 0; t < 5; t++){
else
r1.w += tap.w;
r1.xyz /= r1.w;
#endif
r1.w=dot(r1.xyz, r1.xyz); //dp3
r1.w=1.0/r1.w;
r3 = lerp(_c0.x, r1, saturate(r1.w * 10000));
r4 = r3;
r5 = r3;
r6 = r3;
r7 = r3;
r0.x=r0.z * r0.x - _c78.w; //dofDist.w
r0.x=_c78.y * -r3.w + r0.x; //dofDist.y
r1.w=max(r0.x, _c0.x); //0.0
r0.x=1.0/_c78.z; //dofDist.z
r0.x=r1.w * r0.x;
r1.w=lerp(_c79.y, _c79.z, r0.x);//dofBlur
r0.x=min(_c79.z, r1.w); //dofBlur.z
r0.z=dot(r7.xyz, _c0.yzw); //0.212500006, 0.715399981, 0.0720999986
r8.x=dot(r3.xyz, _c0.yzw); //0.212500006, 0.715399981, 0.0720999986
r8.y=dot(r4.xyz, _c0.yzw); //0.212500006, 0.715399981, 0.0720999986
r8.z=dot(r5.xyz, _c0.yzw); //0.212500006, 0.715399981, 0.0720999986
r8.w=dot(r6.xyz, _c0.yzw); //0.212500006, 0.715399981, 0.0720999986
r1.w=dot(r8, _c1.xxxx); //0.25
r8=r8 - r1.w;
r2.w=dot(r8, r8);
r0.z=r0.z - r1.w;
r0.z=r0.z * r0.z - r2.w;
r0.x=r0.x*r0.x;
if (r0.z<0.0)
r0.x=r0.x;
} else r0.x=_c1.y; //1.0
r8=tex2D(s0, _v0.xy); //GBufferTextureSampler2
r8.yz=_c1.yz; // 1.0, 256.0
r9=r8.w * -r8.z + _c2; //0, 2, 4, 8
if (r9.w<0.0) //r9<0.0
r9=_c1.w; //0.0
} else r9=_c1.y; //1.0
//r9 is filtered sky mask
//r10=r8.w + tempc6;//c6.yzwx; //256, 2, 4, 8
r10=r8.w * -_c6.x + _c6.yzwx; //256, 2, 4, 8
if (r10.x<0.0)
r10.x=-_c1.w; //0.0
} else r10.x=-_c1.y; //1.0
if (r10.y<0.0)
r10.y=-_c1.w; //0.0
} else r10.y=-_c1.y; //1.0
if (r10.z<0.0)
r10.z=-_c1.w; //0.0
} else r10.z=-_c1.y; //1.0
if (r10.w<0.0)
r10.w=-_c1.w; //0.0
} else r10.w=-_c1.y; //1.0
r9=r9 + r10;
r9=r9 * _c4.x; //-0.5
r0.z=dot(r9, _c1.yyyy); //1.0
r0.z=r0.z + _c4.w; //0.5
r0.z=1.0/r0.z;
r8.xzw=r3.xyz * r9.x;
r7.xyz=r7 * _c4.w + r8.xzw; //0.5
r7.xyz=r4 * r9.y + r7;
r7.xyz=r5 * r9.z + r7;
r7.xyz=r6 * r9.w + r7;
r7.xyz=r0.z * r7;
r0.z=-r0.x + _c1.y; //1.0
r1.w=r0.x * _c1.x; //0.25
r3.xyz=r3 * r1.w;
r3.xyz=r7 * r0.z + r3;
r3.xyz=r4 * r1.w + r3;
r3.xyz=r5 * r1.w + r3;
r3.xyz=r6 * r1.w + r3;
//r4.xyz=_v0.yxy * _c5.x + _c5.y; //2, -1
r4.x=_v0.y * _c5.x + _c5.y;
r4.y=_v0.x * _c5.x + _c5.y;
r4.z=_v0.y * _c5.x + _c5.y;
r0.z=r4.y * _c77.z; //dofProj.z
r0.z=r0.y * r0.z;
r1.w=-r4.x * _c77.w; //dofProj.w
r1.w=r0.y * r1.w;
r5.xyz=r1.w * _c73; //motionBlurMatrix.2
r5.xyz=r0.z * _c72 + r5; //motionBlurMatrix.1
r5.xyz=-r0.y * _c74 + r5; //motionBlurMatrix.3
r5.xyz=r5 + _c75; //motionBlurMatrix.4
r0.y=-r5.z * _c77.z; //dofProj.z
r0.y=1/r0.y;
r6.x=r5.x * r0.y;
r0.y=r5.z * _c77.w; //dofProj.w
r0.y=1/r0.y;
r6.y=r5.y * r0.y;
//r0.yz=-r4 + r6.xxyw;
r0.yz=-r4.yz + r6.xy;
//MOTION BLUR - MasterKontrol 2012
//r0.xy=r0.xyw * _c80.zxyw; //MK - This One = just landscape blur
r0.xy=r0.xy * _c80.wxyz; //MK - LAST
r0.z=r0.z * _c80.x; //MK - LAST
r0.w=r0.w * _c80.y; //MK - LAST
//r0.y=r0.y * _c80.x;
//r0.z=r0.z * _c80.x;
r4.xy=r0.yz * _c5.z;
r5=tex2D(s6, _v0.xy);
//r1.w=r5.xy * _c85.xy + -_c85.wzx; //Player Mask //MK - This One = just landscape blur
r1.w=r5.x + -_c85.xy; //Player Mask //MK - This one = all objects blur
//r1.w=r5.x - _c85.x;
r4.zw=r3.xy * _c2.w;
r4.zw=_v0.xy * _c3.xy + r4.zw;
r5=tex2D(s5, r4.zw);
r4.zw=r4.xy * (r5.x - 4) + _v0.xy;
r5.xyz=r3.xyz;
r2.w=_c1.y;
r3.w=_c1.y;
// MOTION BLUR STRENGTH - Masterkontrol 2012
for (int iii=0; iii<MBSteps; iii++)
r6.x=r4.x * r3.w + r4.z;
r6.y=r4.y * r3.w + r4.w;
r7=tex2D(s6, r6.xy);
r5.w=r7.x - _c85.x;
if (r5.w<MBAmount)
r5.w=_c1.y; //1.0
} else r5.w=_c1.w; //0.0
r6=tex2D(s2, r6.xy);
r5.xyz=r6.xyz * r5.w + r5.xyz;
r2.w=r2.w + r5.w;
r3.w=r3.w + _c1.y; //1.0
r2.w=1.0/r2.w;
r0.y=r0.y * _c44.x; //GlobalScreenSize
r0.z=r0.z * _c44.y; //GlobalScreenSize
r0.y=dot(r0.yz, r0.yz)+_c0.x; //dp2
//r0.y=sqrt(r0.y);
//r0.y=1.0/r0.y;
r0.y=pow(r0.y, _c4.w); //0.5
r0.y=r0.y * _c4.w; //0.5
r0.x=r0.x + _c1.y; //1.0
r0.x=1.0/r0.x;
r0.x=saturate(r0.y * r0.x);
r4.xyz=r5 * r2.w - r3;
r0.xyz=r0.x * r4 + r3;
if (-r1.w<0.0) r0.xyz=r3.xyz;
if (-r0.w<0.0) r0.xyz=r1.xyz;
//for future use
r11=r0;
r1=tex2D(s4, _c0.x); //AdapLumSampler , 0.0
r0.w=1.0/r1.x;
r0.w=r0.w * _c81.y; //ToneMapParams.y
r1.x=1.0/r0.w;
r1.x=r1.x * _c81.x; //ToneMapParams.x
r1.xyz=r2 * _c66.x - r1.x; //Exposure.x
r2.xyz=max(r1, _c0.x); //0.0
r1.xyz=r2 * _c81.z; //ToneMapParams.z
r1.xyz=r1 * _c1.x; //0.25
r0.xyz=r0 * _c66.x + r1; //Exposure.x
r1.xyz=r0.w * r0;
r1.x=dot(r1.xyz, _c0.yzw); //0.2125, 0.7154, 0.0721
r0.xyz=r0 * r0.w - r1.x;
r0.xyz=_c82.x * r0 + r1.x; //deSatContrastGamma.x
r0.w=r1.x * _c84.w; //ColorShift.w
r1.yzw=r0.w * _c84.xxyz; //ColorShift
//darken as DarkeningAmount, but keeps colors
r2.x=saturate(r0.w);
r0.xyz=r0.xyz - _c84.xyz * r0.w; //ColorShift
r0.xyz=r2.x * r0.xyz + r1.yzww;
//coloring (green, brown, ...)
r0.xyz=2.0 * r0.xyz * _c83.xyz; //ColorCorrect
//keeps colors, changes luma
r1.x=saturate(r1.x);
r0.w=_c82.z - _c1.y; //deSatContrastGamma.z
r2.x=pow(r1.x, r0.w);
_oC0.xyz=r0.xyz * r2.x; //orig
_oC0.w=_c1.y; //1.0
r5=tex2D(s4, _c0.x);//adaptation luminance
r0=tex2D(s2, _v0.xy);
r0=r11;
r5.w=r5.x;
r5.w=AdaptationValue/r5.w;
r0.xyz=r0 * r5.w;
r3.xy=_c10.xwxw;
r3.xy=r3.xy * r5.w;
r7=tex2D(s3, _v0.xy);
r0=r7 * BloomAdditive + r0; //0.05 //TEMP DISABLED
r10=dot(r0.xyz, _c12.xyz);
r9.x=r10.x * 1.30;//c199.x; <<<<<<<<----- brightness?
![:D :d :d](/community/styles/default/xenforo/smilies/luxx/biggrin.gif)
r10.x=1.0/r10.x;
r10=r10 * r9.x;
r0=r0 * r10.x;
r0=r0 * _c7.y;
r1=r0 * _c7.z;
r1=r1 + _c7.w;
r1.xyz=1.0/r1.xyz;
r0=r0 * r1;
#ifdef GAMMACORRECTION
r0=pow(r0,GammaAmount);
#endif
r0=BloomAmountMix*r7 * r3.x + r0;
#ifdef FILMICCURVE
float4 curr = ((r0*(A*r0+C*B)+D*E)/(r0*(A*r0+B)+D*F))-E/F;
float4 whiteScale = ((W*(A*W+C*B)+D*E)/(W*(A*W+B)+D*F))-E/F;
r0 = curr*whiteScale;
#endif
#ifdef BLEACH
float luma = dot(r0.xyz, _c12.xyz);
float3 blend = luma.xxx;
float L = min(1, max(0, 10*(luma - 0.45)));
float3 result1 = 2.0 * r0.xyz * blend;
float3 result2 = 1.0 - 2.0*(1.0 - blend)*(1.0 - r0.xyz);
float3 newColor = lerp(result1.xyz, result2.xyz, L);
float3 mixRGB = BP_factor * newColor.xyz;
mixRGB += ((1.0f - BP_factor) * r0.xyz);
r0.xyz = mixRGB;
#endif
#ifdef GlobalSaturation
float luma=dot(r0.xyz,_c12.xyz);
float gris=dot(r0.xyz, 0.333);
float3 SaturatedColor=pow(r0.xyz, Saturation);
float Niveaudegris=dot(SaturatedColor.xyz, 0.333);
r0.xyz=SaturatedColor.xyz*gris/(Niveaudegris+0.0001);
#endif
_oC0.xyz=r0.xyz;
//_oC0=0.077*tex2D(s15, _v0.xy);//s2
//_oC0.xyz=1.0;
//_oC0.w=1.0;
return _oC0;
//mine temporary post process
technique Shader_C215BE6E
pass p0
PixelShader = compile ps_3_0 PS_C215BE6E();
//original shader of post processing
technique Shader_ORIGINALPOSTPROCESS
pass p0
PixelShader=
asm
// Generated by Microsoft (R) HLSL Shader Compiler 9.23.949.2378
// Parameters:
// float Exposure;
// float4 dofBlur;
// float4 dofDist;
// float4 dofProj;
// Registers:
// Name Reg Size
// Exposure c66 1
// TexelSize c76 1
// dofProj c77 1
// dofDist c78 1
// dofBlur c79 1
// ColorShift c84 1
// HDRSampler s2 1
ps_3_0
def c0, 0, 0.212500006, 0.715399981, 0.0720999986
def c1, 0.25, 1, 256, 0
def c2, 0, 2, 4, 8
def c3, 58.1640015, 47.1300011, 0, 0
def c4, -0.5, -1.5, 1.5, 0.5
def c5, 2, -1, 0.125, 0
def c6, 256, 2, 4, 8
def c180, 0.0, 0.0, 0.0, 100.5
def c181, 1.0, 0.0, 0.0, 20.01
def c183, 800.0, 600.0, 0.0, 100.5
defi i0, 7, 0, 0, 0
dcl_texcoord v0.xy
dcl_2d s0
dcl_2d s1
dcl_2d s2
dcl_2d s3
dcl_2d s4
dcl_2d s5
dcl_2d s6
texld r0, v0, s1
add r0.y, -c77.x, c77.y
rcp r0.y, r0.y
mul r0.z, r0.y, c77.y
mul r0.z, r0.z, -c77.x
mad r0.x, c77.y, -r0.y, r0.x
rcp r0.x, r0.x
mul r0.y, r0.z, r0.x
texld r1, v0, s2
texld r2, v0, s3
abs r0.w, c79.w
mov r3, c4
mad r4.xy, c76, r3, v0
texld r4, r4, s2
mad r5.xy, c76, r3.zxzw, v0
texld r5, r5, s2
mad r3.xz, c76.xyyw, r3.wyzw, v0.xyyw
texld r6, r3.xzzw, s2
mad r3.xy, c76, r3.ywzw, v0
texld r7, r3, s2
dp3 r1.w, r4, r4
rcp r1.w, r1.w
cmp r3.xyz, -r1.w, c0.x, r4
dp3 r1.w, r5, r5
rcp r1.w, r1.w
cmp r4.xyz, -r1.w, c0.x, r5
dp3 r1.w, r6, r6
rcp r1.w, r1.w
cmp r5.xyz, -r1.w, c0.x, r6
dp3 r1.w, r7, r7
rcp r1.w, r1.w
cmp r6.xyz, -r1.w, c0.x, r7
dp3 r1.w, r1, r1
rcp r1.w, r1.w
cmp r7.xyz, -r1.w, c0.x, r1
mad r0.x, r0.z, r0.x, -c78.w
mad r0.x, c78.y, -r3.w, r0.x
max r1.w, r0.x, c0.x
rcp r0.x, c78.z
mul r0.x, r1.w, r0.x
lrp r1.w, r0.x, c79.z, c79.y
min r0.x, c79.z, r1.w
dp3 r0.z, r7, c0.yzww
dp3 r8.x, r3, c0.yzww
dp3 r8.y, r4, c0.yzww
dp3 r8.z, r5, c0.yzww
dp3 r8.w, r6, c0.yzww
dp4 r1.w, r8, c1.x
add r8, r8, -r1.w
dp4 r2.w, r8, r8
add r0.z, r0.z, -r1.w
mad r0.z, r0.z, r0.z, -r2.w
mul r0.x, r0.x, r0.x
cmp r0.x, r0.z, c1.y, r0.x
texld r8, v0, s0
mov r8.yz, c1
mad r9, r8.w, -r8.z, c2
cmp r9, r9, c1.y, c1.w
mad r10, r8.w, -c6.x, c6.yzwx
cmp r10, r10, -c1.y, -c1.w
add r9, r9, r10
mul r9, r9, c4.x
dp4 r0.z, r9, c1.y
add r0.z, r0.z, c4.w
rcp r0.z, r0.z
mul r8.xzw, r3.xyyz, r9.x
mad r7.xyz, r7, c4.w, r8.xzww
mad r7.xyz, r4, r9.y, r7
mad r7.xyz, r5, r9.z, r7
mad r7.xyz, r6, r9.w, r7
mul r7.xyz, r0.z, r7
add r0.z, -r0.x, c1.y
mul r1.w, r0.x, c1.x
mul r3.xyz, r3, r1.w
mad r3.xyz, r7, r0.z, r3
mad r3.xyz, r4, r1.w, r3
mad r3.xyz, r5, r1.w, r3
mad r3.xyz, r6, r1.w, r3
mad r4.xyz, v0.yxyw, c5.x, c5.y
mul r0.z, r4.y, c77.z
mul r0.z, r0.y, r0.z
mul r1.w, -r4.x, c77.w
mul r1.w, r0.y, r1.w
mul r5.xyz, r1.w, c73
mad r5.xyz, r0.z, c72, r5
mad r5.xyz, -r0.y, c74, r5
add r5.xyz, r5, c75
mul r0.y, -r5.z, c77.z
rcp r0.y, r0.y
mul r6.x, r5.x, r0.y
mul r0.y, r5.z, c77.w
rcp r0.y, r0.y
mul r6.y, r5.y, r0.y
add r0.yz, -r4, r6.xxyw
mul r0.yz, r0, c80.x
mul r4.xy, r0.yzzw, c5.z
texld r5, v0, s6
add r1.w, r5.x, -c85.x
mul r4.zw, r3.xyxy, c2.w
mad r4.zw, v0.xyxy, c3.xyxy, r4
texld r5, r4.zwzw, s5
add r2.w, r5.x, c4.x
mad r4.zw, r4.xyxy, r2.w, v0.xyxy
mov r5.xyz, r3
mov r2.w, c1.y
mov r3.w, c1.y
rep i0
mad r6.xy, r4, r3.w, r4.zwzw
texld r7, r6, s6
add r5.w, r7.x, -c85.x
cmp r5.w, r5.w, c1.w, c1.y
texld r6, r6, s2
mad r5.xyz, r6, r5.w, r5
add r2.w, r2.w, r5.w
add r3.w, r3.w, c1.y
endrep
rcp r2.w, r2.w
mul r0.yz, r0, c183.xxyw//c44.xxyw
dp2add r0.y, r0.yzzw, r0.yzzw, c0.x
rsq r0.y, r0.y
rcp r0.y, r0.y
mul r0.y, r0.y, c4.w
add r0.x, r0.x, c1.y
rcp r0.x, r0.x
mul_sat r0.x, r0.y, r0.x
mad r4.xyz, r5, r2.w, -r3
mad r0.xyz, r0.x, r4, r3
cmp r0.xyz, r1.w, r3, r0
cmp r0.xyz, -r0.w, r0, r1
texld r1, c0.x, s4
rcp r0.w, r1.x
mul r0.w, r0.w, c81.y
rcp r1.x, r0.w
mul r1.x, r1.x, c81.x
mad r1.xyz, r2, c66.x, -r1.x
max r2.xyz, r1, c0.x
mul r1.xyz, r2, c81.z
mul r1.xyz, r1, c1.x
mad r0.xyz, r0, c66.x, r1
mul r1.xyz, r0.w, r0
dp3 r1.x, r1, c0.yzww
mad r0.xyz, r0, r0.w, -r1.x
mad r0.xyz, c82.x, r0, r1.x
mul r0.w, r1.x, c84.w
mul r1.yzw, r0.w, c84.xxyz
mov_sat r2.x, r0.w
mad r0.xyz, c84, -r0.w, r0
mad r0.xyz, r2.x, r0, r1.yzww
mul r0.xyz, r0, c83
add r0.xyz, r0, r0
mov_sat r1.x, r1.x
add r0.w, -r8.y, c82.z
pow r2.x, r1.x, r0.w
//mul r2.x, r2.x, c181.x
mul oC0.xyz, r0, r2.x
mov oC0.w, c1.y
//texld r1, v0, s2
//mul oC0.xyz, r1, c199.z
