Wer noch etwas testen will, ... hier noch ein paar Parameter
==== [AUDIO] ====
-fullspecaudio: Force High-end CPU audio footprint
-minspecaudio: Force low-end CPU audio footprint
==== [GLOBAL] ====
-benchmark: Determines if we run the benchmark immediately
-safemode: Sets the graphics setting to lowest setting
==== [GRAPHICS] ====
-forcer2vb: force r2vb
-frameLimit: number of frames to limit game to
-framelockinwindow: Force framelock to work even in a window (works best with 60Hz monitor refresh)
-fullscreen: Force fullscreen mode
-height: Set height of main render window (default is 600)
-renderquality: Set the render quality of the game. (0-4)
-shadowdensity: Set the shadow density of the game. (0-16)
-texturequality: Set the texture quality of the game. (0-2)
-viewdistance: Set the view distance of the game (0-99)
-detailquality: Set the detail quality of the game. (0-99)
-novblank: Disable wait for vblank (No Vsync)
-norestrictions: Do not limit graphics settings
-width: Set width of main render window (default is 800)
-safemode: Run the graphics in the lowest setting possible
-frameLimit: Limit frame to interval of refresh rate
(ex If refreshrate is 60HZ –frameLimit 1 = Locks down to 60HZ)
-refreshrate: Set the refresh rate of main render window
– Warning - Monitor must support (ex. –refreshrate 60)
-windowed: Force windowed mode
-availablevidmem: Set amount of physical Video Memory(ex. –availablevidmem 0.9)
-percentvidmem: Percentage of video memory to make available to GTA
==== [SYSTEM] ====
-noprecache: Disable precache of resources
-nomemrestrict: Disable memory restrictions
