Hey schakusa ...
hier mal die Daten aus der ScriptHookDotNet
ich hoffe es sind die richtigen
hat etwas gedauert war letzte Woche unterwegs
2012-07-08 19:16:23 - Initializing ScriptHookDotNet v1.7.1.7 BETA (on GTA IV version 1.0.3.0 with C++ Hook version 0.4.0)
2012-07-08 19:17:21 - Direct3D device created!
2012-07-08 19:17:21 - SEARCHING FOR SCRIPTS...
2012-07-08 19:17:21 - Loading scripts in Assembly 'scripts\cameraControl.net.dll' ...
2012-07-08 19:17:21 - ...found script 'cameras.cameraScript'!
2012-07-08 19:17:21 - Loading scripts in Assembly 'scripts\moveDoors.net.dll' ...
2012-07-08 19:17:21 - ...found script 'EPM_v1_4.EPM0'!
2012-07-08 19:17:21 - ...found script 'EPM_v1_4.EPM5'!
2012-07-08 19:17:21 - ...found script 'EPM_v1_4.EPM4'!
2012-07-08 19:17:21 - ...found script 'EPM_v1_4.EPM3'!
2012-07-08 19:17:21 - ...found script 'EPM_v1_4.EPM2'!
2012-07-08 19:17:21 - ...found script 'EPM_v1_4.EPM1'!
2012-07-08 19:17:21 - DONE! 7 valid scripts found!
2012-07-08 19:17:21 - STARTING SCRIPTS...
2012-07-08 19:17:21 - INFO: Phone number checks are not available!
2012-07-08 19:17:21 - ...successfully started script 'EPM_v1_4.EPM1'!
2012-07-08 19:17:21 - ...successfully started script 'EPM_v1_4.EPM2'!
2012-07-08 19:17:21 - ...successfully started script 'EPM_v1_4.EPM3'!
2012-07-08 19:17:21 - ...successfully started script 'EPM_v1_4.EPM4'!
2012-07-08 19:17:21 - ...successfully started script 'EPM_v1_4.EPM5'!
2012-07-08 19:17:21 - ...successfully started script 'EPM_v1_4.EPM0'!
2012-07-08 19:17:21 - ...successfully started script 'cameras.cameraScript'!
2012-07-08 19:18:53 - Error during Tick in script 'EPM_v1_4.EPM1':
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at EPM_v1_4.EPM1.ReadSettings(String key, Int32 keyT, String which1, String iniFilePath)
at EPM_v1_4.EPM1.GetLightsOnOff_Tick(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at GTA.Script.TryTick()
at GTA.Script.DoTick()
at GTA.ScriptThread.OnTick()
2012-07-08 19:18:53 - Error during Tick in script 'EPM_v1_4.EPM2':
at EPM_v1_4.EPM2.ReadSettings(String key, Int32 keyT, String which1, String iniFilePath)
at EPM_v1_4.EPM2.GetLightsOnOff_Tick(Object sender, EventArgs e)
2012-07-08 19:18:53 - Error during Tick in script 'EPM_v1_4.EPM3':
at EPM_v1_4.EPM3.ReadSettings(String key, Int32 keyT, String which1, String iniFilePath)
at EPM_v1_4.EPM3.GetLightsOnOff_Tick(Object sender, EventArgs e)
2012-07-08 19:18:53 - Error during Tick in script 'EPM_v1_4.EPM4':
at EPM_v1_4.EPM4.ReadSettings(String key, Int32 keyT, String which1, String iniFilePath)
at EPM_v1_4.EPM4.GetLightsOnOff_Tick(Object sender, EventArgs e)
2012-07-08 19:18:53 - Error during Tick in script 'EPM_v1_4.EPM5':
at EPM_v1_4.EPM5.ReadSettings(String key, Int32 keyT, String which1, String iniFilePath)
at EPM_v1_4.EPM5.GetLightsOnOff_Tick(Object sender, EventArgs e)
2012-07-08 19:18:53 - Error during Tick in script 'EPM_v1_4.EPM0':
at EPM_v1_4.EPM0.ReadSettings(String key, Int32 keyT, String which1, String iniFilePath)
at EPM_v1_4.EPM0.GetLightsOnOff_Tick(Object sender, EventArgs e)
2012-07-08 20:18:22 - Direct3D device lost!
2012-07-08 20:18:22 - SCRIPTS TERMINATED!
