GTA V [Snapmatic, Screenshots and more]
Real Clock ist vielleicht kein slechter mod :P
Am Samstag wars 02:18 AM als ich abschließ... ouch
Lord und Scrush: Mögt ihr mir eure Settings zur Verfügung stellen? Sieht beides geil aus und ich wollt mir das gerne mal ingame anschauen :)
http://www67.zippyshare.com/v/Z7sXl81V/file.html
http://pastebin.com/4kUV0sPU
files: http://gtauniverse.com/index.php?mods/razeds-high-end-preset.3/
/ Description /
Preset: Razed's High-End Preset v1.2
Game: Grand Theft Auto V
Author: Razed (razed@gtauniverse.com)
SweetFX/Injector Version: 2.0 Preview 8 by CeeJay.dk
Reshade Version: 0.18.3 by Crosire
• SMAA
• FXAA
• HDR
• LUMASHARPEN
• LEVELS
• TONEMAP
• CURVES
• DPX
• TONEMAP
• VIBRANCE
• CURVES
• VIGNETTE
• DITHER
Updates in v1.2
• Includes my "settings.xml" file for high-end computers
• Increased Vibrance from 0.58 to 0.66
• Updated for ReShade 0.18.3 beta - includes tons of fixes
• Uses dxgi.dll now instead of d3d11.dll
• Enabled automatically at the start - no more slowdown on loading screens
/ Choose effects /
// Effects are listed in the order that they are applied.
// Set to 1 for ON or 0 for OFF
#define USE_ASCII 0 //[0 or 1] Ascii : Converts the image to Ascii-art.
#define USE_CARTOON 0 //[0 or 1] Cartoon : "Toon"s the image.
#define USE_SMAA 0 //[0 or 1] SMAA Anti-aliasing : Smoothens jagged lines using the SMAA technique.
#define USE_FXAA 0 //[0 or 1] FXAA Anti-aliasing : Smoothens jagged lines using the FXAA technique.
#define USE_EXPLOSION 0 //[0 or 1] Explosion : Scatters the pixels, making the image look fuzzy.
#define USE_CA 0 //[0 or 1] Chromatic Aberration : Mimics the look of a cheap camera lens, by distorting the colors.
#define USE_ADVANCED_CRT 0 //[0 or 1] Advanced CRT : Simulates an old CRT TV display. (has a very high performance cost)
#define USE_PIXELART_CRT 0 //[0 or 1] PixelArt CRT : Scanlines for pixel art (high performance cost)
#define USE_BLOOM 0 //[0 or 1] Bloom : Makes bright lights bleed their light into their surroundings (relatively high performance cost)
#define USE_HDR 1 //[0 or 1] HDR : Not actual HDR - It just tries to mimic an HDR look (relatively high performance cost)
#define USE_LUMASHARPEN 1 //[0 or 1] LumaSharpen : Sharpens the image.
#define USE_LENS_DISTORTION 0 //[0 or 1] Cubic Lens Distortion : Distorts the lens cubicly.
#define USE_PALETTE 0 //[0 or 1] Palette : Matches the color to a constrained palette.
#define USE_LEVELS 1 //[0 or 1] Levels : Sets a new black and white point. This increases contrast but causes clipping. Use Curves instead if you want to avoid that.
#define USE_TECHNICOLOR 0 //[0 or 1] TECHNICOLOR : Attempts to mimic the look of an old movie using the Technicolor three-strip color process (Techicolor Process 4)
#define USE_DPX 1 //[0 or 1] Cineon DPX : Should make the image look like it's been converted to DXP Cineon - basically it's another movie-like look similar to technicolor.
#define USE_MONOCHROME 0 //[0 or 1] Monochrome : Monochrome makes the colors disappear.
#define USE_COLORMATRIX 0 //[0 or 1] Color Matrix : Allows color modification using a user-defined color matrix.
#define USE_LIFTGAMMAGAIN 0 //[0 or 1] Lift Gamma Gain : Adjust brightness and color of shadows, midtones and highlights.
#define USE_TONEMAP 1 //[0 or 1] Tonemap : Adjust gamma, exposure, saturation, bleach and defog. (may cause clipping)
#define USE_VIBRANCE 1 //[0 or 1] Vibrance : Intelligently saturates (or desaturates if you use negative values) the pixels depending on their original saturation.
#define USE_CURVES 1 //[0 or 1] Curves : Contrast adjustments using S-curves.
#define USE_SEPIA 0 //[0 or 1] Sepia : Sepia tones the image.
#define USE_FILMICPASS 0 //[0 or 1] Filmic Pass: Applies some common color adjustments to mimic a more cinema-like look.
#define USE_REINHARDLINEAR 0 //[0 or 1] Reinhard: Reinhard mixed with some linear tonemapping.
#define USE_VIGNETTE 0 //[0 or 1] Vignette : Darkens the edges of the image to make it look more like it was shot with a camera lens. May cause banding artifacts.
#define USE_FILMGRAIN 0 //[0 or 1] Film Grain : Adds film grain to the image.
#define USE_DITHER 1 //[0 or 1] Dither : Applies dithering to simulate more colors than your monitor can display. This lessens banding artifacts (mostly caused by Vignette)
#define USE_BORDER 0 //[0 or 1] Border : Can be used to create letterbox borders around the image.
#define USE_SPLITSCREEN 0 //[0 or 1] Splitscreen : Enables the before-and-after splitscreen comparison mode. (Only partially working right now)
#define USE_Transition 0 //[0 or 1] Transition : Shows transitions to the regularly scheduled programming
/ Ascii settings /
#define Ascii_input_image 1 //[1 or 2] 1 = Color buffer, 2 = Depth buffer.
#define Ascii_spacing 1 //[0 to 9] Determines the spacing between characters. I feel 1 to 3 looks best.
#define Ascii_font 2 //[1 or 2] 1 = 5x5 font, 2 = 3x5 font
#define Ascii_font_color float3(255, 255, 255) //[0 to 255, 0 to 255, 0 to 255] What color the font should be. In integer RGB colors.
#define Ascii_background_color float3(0, 0, 0) //[0 to 255, 0 to 255, 0 to 255] What color the background should be. In integer RGB colors.
#define Ascii_swap_colors 0 //Swaps the font and background color when you are too lazy to edit the settings above (I know I am)
#define Ascii_invert_brightness 0 //[0 or 1]
#define Ascii_font_color_mode 1 //[0 to 2] 0 = font_color, 1 = image color, 2 = colorized grayscale
#define Ascii_ToggleKey RFX_ToggleKey
/ Transition /
#define Transition_time 5000 //[1 to 60000] Milliseconds the transition lasts (1000 milliseconds is 1 second)
#define Transition_texture "Test_Image.png" //["filename"] Filename for the texture to use. Put your custom textures in SweetFX/Textures/
#define Transition_texture_width 720 //Image width.
#define Transition_texture_height 480 //Image height.
#define Transition_type ImageFadeOut //Can be "FadeIn", "FadeOut", "CurtainOpen", "CurtainClose" or "ImageFadeOut"
#define Transition_ToggleKey RFX_ToggleKey
/ SMAA Anti-aliasing settings /
#define SMAA_THRESHOLD 0.08 //[0.05 to 0.20] Edge detection threshold. If SMAA misses some edges try lowering this slightly. I prefer between 0.08 and 0.12.
#define SMAA_MAX_SEARCH_STEPS 25 //[0 to 98] Determines the radius SMAA will search for aliased edges
#define SMAA_MAX_SEARCH_STEPS_DIAG 12 //[0 to 16] Determines the radius SMAA will search for diagonal aliased edges
#define SMAA_CORNER_ROUNDING 25 //[0 to 100] Determines the percent of antialiasing to apply to corners. 0 seems to affect fine text the least so it's the default.
// -- Advanced SMAA settings --
#define SMAA_EDGE_DETECTION 2 //[1|2|3] 1 = Luma edge detection, 2 = Color edge detection, 3 = Depth edge detection
#define SMAA_DIRECTX9_LINEAR_BLEND 0 //[0 or 1] Using DX9 HARDWARE? (software version doesn't matter) if so this needs to be 1 - If not, leave it at 0.
//Enable this only if you use a Geforce 7xxx series or older card, or a Radeon X1xxx series or older card.
// -- SMAA Predication settings --
#define SMAA_PREDICATION 0 //[0 or 1] Enables predication which uses BOTH the color and the depth texture for edge detection to more accurately detect edges.
#define SMAA_PREDICATION_THRESHOLD 0.09 // Threshold to be used in the depth buffer.
#define SMAA_PREDICATION_SCALE 1.0 // How much to scale the global threshold used for luma or color edge detection when using predication
#define SMAA_PREDICATION_STRENGTH 20.4 // How much to locally decrease the threshold.
// -- Debug SMAA settings --
#define SMAA_DEBUG_OUTPUT 0 //[0 to 4] 0 = Normal, 1 = edgesTex, 2 = blendTex, 3 = areaTex, 4 = searchTex - Only for troubleshooting. Users don't need to mess with this.
/ FXAA Anti-aliasing settings /
#define FXAA_QUALITY__PRESET 9 //[1 to 9] Choose the quality preset. 9 is the highest quality.
#define fxaa_Subpix 0.210 //[0.000 to 1.000] Choose the amount of sub-pixel aliasing removal. Higher values makes the image softer/blurrier.
#define fxaa_EdgeThreshold 0.100 //[0.000 to 1.000] Edge detection threshold. The minimum amount of local contrast required to apply algorithm. Similar to SMAA_THRESHOLD
#define fxaa_EdgeThresholdMin 0.001 //[0.000 to 1.000] Darkness threshold. Pixels darker than this are not processed in order to increase performance.
/ Explosion settings /
#define Explosion_Radius 2.0 //[0.2 to 100.0] Amount of effect you want.
#define Explosion_ToggleKey RFX_ToggleKey
/ Chromatic Aberration settings /
#define Chromatic_shift float2(2.5,-0.5) //[-100.0 to 100.0, -100.00 to 100.0] Distance (X,Y) in pixels to shift the color components.
//For a slightly blurred look try fractional values (.5) between two pixels.
#define Chromatic_strength 0.5 //Adjust the strength of the effect.
#define CA_ToggleKey RFX_ToggleKey
/ Cartoon settings /
#define CartoonPower 1.5 //[0.1 to 10.0] Amount of effect you want.
#define CartoonEdgeSlope 1.5 //[0.1 to 8.0] Raise this to filter out fainter edges. You might need to increase the power to compensate. Whole numbers are faster.
#define Cartoon_ToggleKey RFX_ToggleKey
/ Advanced CRT settings /
#define CRTAmount 0.07 //[0.00 to 1.00] Amount of CRT effect you want
#define CRTResolution 1.15 //[1.0 to 8.0] Input size coefficent (low values gives the "low-res retro look"). Default is 1.2
#define CRTgamma 2.4 //[0.0 to 4.0] Gamma of simulated CRT (default 2.2)
#define CRTmonitorgamma 2.2 //[0.0 to 4.0] Gamma of display monitor (typically 2.2 is correct)
#define CRTBrightness 0.9 //[1.0 to 3.0] Used to boost brightness a little. Default is 1.0
#define CRTScanlineIntensity 2.0 //[2.0 to 4.0] Scanlines intensity (use integer values preferably). Default is 2.0
#define CRTScanlineGaussian 1 //[0 or 1] Use the "new nongaussian scanlines bloom effect". Default is on
#define CRTCurvature 0 //[[0 or 1] "Barrel effect" enabled (1) or off (0)
#define CRTCurvatureRadius 1.5 //[0.0 to 2.0] Curvature Radius (only effective when Curvature is enabled). Default is 1.5
#define CRTCornerSize 0.0100 //[0.0000 to 0.0020] Higher values, more rounded corner. Default is 0.001
#define CRTDistance 2.00 //[0.00 to 4.00] Simulated distance from viewer to monitor. Default is 2.00
#define CRTAngleX 0.00 //[-0.20 to 0.20] Tilt angle in radians (X coordinates)
#define CRTAngleY 0.00 //[-0.20 to 0.20] Tilt angle in radians (Y coordinates). (Value of -0.15 gives the 'arcade tilt' look)
#define CRTOverScan 1.01 //[1.00 to 1.10] Overscan (e.g. 1.02 for 2% overscan). Default is 1.01
#define CRTOversample 1 //[0 or 1] Enable 3x oversampling of the beam profile (warning : performance hit)
#define AdvancedCRT_ToggleKey RFX_ToggleKey
/ Pixel Art CRT /
// -- Emulated input resolution --
#define PixelArtCRT_resolution_mode 1 //[1 or 2] 1 = Ratio, 2 = Fixed resolution
#define PixelArtCRT_resolution_ratio (1.0/4.0) //
#define PixelArtCRT_fixed_resolution float2(320.0,160.0) //
// -- Hardness --
#define PixelArtCRT_hardScan -24.0 // Hardness of scanline : -8.0 = soft, -16.0 = medium
#define PixelArtCRT_hardPix -24.0 // Hardness of pixels in scanline : -2.0 = soft, -4.0 = hard
// -- Display warp --
#define PixelArtCRT_warp float2(1.0/64.0,1.0/24.0) // Display warp : 0.0 = none , 1.0/8.0 = extreme
// -- Type of shadow mask --
#define PixelArtCRT_ShadowMask 3 // Type of shadow mask : 1 = Very compressed TV style shadow mask, 2 = Aperture-grille, 3 = Stretched VGA style shadow mask, 4 = VGA style shadow mask
// -- Amount of shadow mask --
#define PixelArtCRT_maskDark 0.5 //
#define PixelArtCRT_maskLight 1.5 //
// -- Falloff shape --
#define PixelArtCRT_shape 3.0 // Falloff shape : 1.0 = exp(x), 1.25 = in between, 2.0 = gaussian, 3.0 = more square
// -- Amp signal --
#define PixelArtCRT_overdrive 1.25 //
#define PixelArt_ToggleKey RFX_ToggleKey
/ Bloom settings /
#define BloomThreshold 20.25 //[0.00 to 50.00] Threshold for what is a bright light (that causes bloom) and what isn't.
#define BloomPower 1.446 //[0.000 to 8.000] Strength of the bloom
#define BloomWidth 0.0142 //[0.0000 to 1.0000] Width of the bloom
#define Bloom_ToggleKey RFX_ToggleKey
/ HDR settings /
#define HDRPower 1.87 //[0.00 to 8.00] Strangely lowering this makes the image brighter
#define radius2 0.97 //[0.00 to 8.00] Raising this seems to make the effect stronger and also brighter
#define HDR_ToggleKey RFX_ToggleKey
/ LumaSharpen settings /
// -- Sharpening --
#define sharp_strength 0.4 //[0.10 to 3.00] Strength of the sharpening
#define sharp_clamp 0.038 //[0.000 to 1.000] Limits maximum amount of sharpening a pixel recieves - Default is 0.035
// -- Advanced sharpening settings --
#define pattern 1 //[1|2|3|4] Choose a sample pattern. 1 = Fast, 2 = Normal, 3 = Wider, 4 = Pyramid shaped.
#define offset_bias 1.3 //[0.0 to 6.0] Offset bias adjusts the radius of the sampling pattern.
//I designed the pattern for offset_bias 1.0, but feel free to experiment.
// -- Debug sharpening settings --
#define show_sharpen 0 //[0 or 1] Visualize the strength of the sharpen (multiplied by 4 to see it better)
#define LumaSharpen_ToggleKey RFX_ToggleKey
/ Shared Shaders settings /
//Below you can find all shared shader and their settings
#define SharedShader_ToggleKey RFX_ToggleKey
/ Levels settings /
#define Levels_black_point 10 //[0 to 255] The black point is the new black - literally. Everything darker than this will become completely black. Default is 16.0
#define Levels_white_point 260 //[0 to 255] The new white point. Everything brighter than this becomes completely white. Default is 235.0
//Colors between the two points will stretched, which increases contrast, but details above and below the points are lost (this is called clipping).
// -- Debug settings --
#define Levels_highlight_clipping 0 //[0 or 1] Highlight the pixels that clip. Red = Some detail is lost in the highlights, Yellow = All detail is lost in the highlights,
// Blue = Some detail is lost in the shadows, Cyan = All detail is lost in the shadows.
/ TECHNICOLOR settings /
#define TechniAmount 0.40 //[0.00 to 1.00]
#define TechniPower 4.00 //[0.00 to 8.00]
#define redNegativeAmount 0.88 //[0.00 to 1.00]
#define greenNegativeAmount 0.88 //[0.00 to 1.00]
#define blueNegativeAmount 0.88 //[0.00 to 1.00]
/ Cineon DPX settings /
#define Red 9.0 //[1.0 to 15.0]
#define Green 9.0 //[1.0 to 15.0]
#define Blue 9.0 //[1.0 to 15.0]
#define ColorGamma 1.9 //[0.1 to 2.5] Adjusts the colorfulness of the effect in a manner similar to Vibrance. 1.0 is neutral.
#define DPXSaturation 1.0 //[0.0 to 8.0] Adjust saturation of the effect. 1.0 is neutral.
#define RedC 0.38 //[0.60 to 0.20]
#define GreenC 0.48 //[0.60 to 0.20]
#define BlueC 0.38 //[0.60 to 0.20]
#define Blend 0.06 //[0.00 to 1.00] How strong the effect should bed be
/ Monochrome settings /
#define Monochrome_conversion_values float3(0.21, 0.72, 0.07) //[0.00 to 1.00] Percentage of RGB to include (should sum up to 1.00)
#define Monochrome_color_saturation 0.00 //[0.00 to 2.00] Percentage of saturation to keep. Default is 0.00 , values above 1.00 boost saturation above normal.
/ Color Matrix settings /
// Red Green Blue
#define ColorMatrix_Red float3(0.817, 0.183, 0.000) //[0.00 to 1.00] How much of Red, Green and Blue the new red value should contain - Should sum to 1.000 if you don't wish to change the brightness
#define ColorMatrix_Green float3(0.333, 0.667, 0.000) //[0.00 to 1.00] How much of Red, Green and Blue the new green value should contain - Should sum to 1.000 if you don't wish to change the brightness
#define ColorMatrix_Blue float3(0.000, 0.125, 0.875) //[0.00 to 1.00] How much of Red, Green and Blue the new blue value should contain - Should sum to 1.000 if you don't wish to change the brightness
#define ColorMatrix_strength 1.0 //Adjust the strength
/ Lift Gamma Gain settings /
#define RGB_Lift float3(1.006, 1.003, 0.982) //[0.000 to 2.000] Adjust shadows for Red, Green and Blue.
#define RGB_Gamma float3(1.008, 1.002, 1.022) //[0.000 to 2.000] Adjust midtones for Red, Green and Blue
#define RGB_Gain float3(1.004, 1.003, 1.010) //[0.000 to 2.000] Adjust highlights for Red, Green and Blue
//Note that a value of 1.000 is a neutral setting that leave the color unchanged.
/ Tonemap settings /
#define Gamma 0.65 //[0.000 to 2.000] Adjust midtones
#define Exposure -0.1 //[-1.000 to 1.000] Adjust exposure
#define Saturation 0.010 //[-1.000 to 1.000] Adjust saturation
#define Bleach -0.10 //[0.000 to 1.000] Brightens the shadows and fades the colors
#define Defog 1.0 //[0.000 to 1.000] How much of the color tint to remove
#define FogColor float3(0.000, 0.00, 0.0) //[0.00 to 2.55, 0.00 to 2.55, 0.00 to 2.55] What color to remove - default is blue
/ Vibrance settings /
#define Vibrance 0.50 //[-1.00 to 1.00] Intelligently saturates (or desaturates if you use negative values) the pixels depending on their original saturation.
#define Vibrance_RGB_balance float3(0.74, 1.00, 1.04) //[-10.00 to 10.00,-10.00 to 10.00,-10.00 to 10.00] A per channel multiplier to the Vibrance strength so you can give more boost to certain colors over others
/ Curves settings /
#define Curves_mode 2 //[0|1|2] Choose what to apply contrast to. 0 = Luma, 1 = Chroma, 2 = both Luma and Chroma. Default is 0 (Luma)
#define Curves_contrast -0.50 //[-1.00 to 1.00] The amount of contrast you want
// -- Advanced curve settings --
#define Curves_formula 9 //[1|2|3|4|5|6|7|8|9|10] The contrast s-curve you want to use.
//1 = Sine, 2 = Abs split, 3 = Smoothstep, 4 = Exp formula, 5 = Simplified Catmull-Rom (0,0,1,1), 6 = Perlins Smootherstep
//7 = Abs add, 8 = Techicolor Cinestyle, 9 = Parabola, 10 = Half-circles.
//Note that Technicolor Cinestyle is practically identical to Sine, but runs slower. In fact I think the difference might only be due to rounding errors.
//I prefer 2 myself, but 3 is a nice alternative with a little more effect (but harsher on the highlight and shadows) and it's the fastest formula.
/ Sepia settings /
#define ColorTone float3(1.40, 1.10, 0.90) //[0.00 to 2.55, 0.00 to 2.55, 0.00 to 2.55] What color to tint the image
#define GreyPower 0.11 //[0.00 to 1.00] How much desaturate the image before tinting it
#define SepiaPower 0.58 //[0.00 to 1.00] How much to tint the image
/ FilmicPass settings /
#define Strenght 0.10 //[0.05 to 1.5] Strength of the color curve altering
#define BaseGamma 1.0 //[0.7 to 2.0] Gamma Curve
#define Fade 0.0 //[0.0 to 0.6] Decreases contrast to imitate faded image
#define Contrast 0.8 //[0.5 to 2.0] Contrast.
#define FSaturation 0.00
#define FBleach 0.00 //[-0.5 to 1.0] More bleach means more contrasted and less colorful image
#define FRedCurve 1.0
#define FGreenCurve 1.0
#define FBlueCurve 1.0
#define BaseCurve 1.5
#define EffectGammaR 1.0
#define EffectGammaG 1.0
#define EffectGammaB 1.0
#define EffectGamma 0.68
#define Linearization 0.6 //[0.5 to 2.0] Linearizes the color curve
#define LumCoeff float3(0.212656, 0.715158, 0.072186)
/ ReinhardLinear settings /
#define ReinhardLinearWhitepoint 3.0
#define ReinhardLinearPoint 0.15
#define ReinhardLinearSlope 2.25 //[1.0 to 5.0] how steep the color curve is at linear point. You need color curve understanding to know what this means, just experiment.
/ Daltonize settings /
#define Daltonize_type 1 //[1|2|3] Type of colorblindness. 1 = Protanopia (missing red spectrum), 2 = Deuteranopia (missing green spectrum), 3 = Tritanopia (missing blue spectrum)
/ Film Grain settings /
#define FilmGrain_intensity 0.48 //[0.00 to 1.00] How visible the grain is. Higher is more visible.
#define FilmGrain_variance 0.26 //[0.00 to 1.00] Controls the variance of the gaussian noise. Lower values look smoother.
#define FilmGrain_SNR 8 //[0 to 16] Higher Signal-to-Noise Ratio values give less grain to brighter pixels. 0 disables this feature.
// -- Advanced Film Grain settings --
#define FilmGrain_mean 0.50 //[0.00 to 1.00] The average mean of the gaussian noise. Probably best kept at the middle value (0.50)
//A sideeffect of the Film Grain effect is that it also dithers the screen.
//You don't need both the Film Grain and the Dither effect enabled at the same time.
/ Vignette settings /
#define VignetteType 1 //[1|2|3] 1 = Original, 2 = New, 3 = TV style
#define VignetteRatio 1.60 //[0.15 to 6.00] Sets a width to height ratio. 1.00 (1/1) is perfectly round, while 1.60 (16/10) is 60 % wider than it's high.
#define VignetteRadius 3.60 //[-1.00 to 3.00] lower values = stronger radial effect from center
#define VignetteAmount -0.20 //[-2.00 to 1.00] Strength of black. -2.00 = Max Black, 1.00 = Max White.
#define VignetteSlope 1.01 //[2 to 16] How far away from the center the change should start to really grow strong (odd numbers cause a larger fps drop than even numbers)
#define VignetteCenter float2(0.500, 0.500) //[0.000 to 1.000, 0.000 to 1.000] Center of effect for VignetteType 1. 2 and 3 do not obey this setting.
/ Dither settings /
#define dither_method 1 //[1 or 2] 1 = Ordered dithering (very good and very fast), 2 = Random dithering (different but slightly slower dithering)
//Note that the patterns used by Dither, makes an image harder to compress.
//This can make your screenshots and video recordings take up more space.
/ Border settings /
#define border_width float2(0,100) //[0 to 2048, 0 to 2048] (X,Y)-width of the border. Measured in pixels. If this is set to 0,0 then the border_ratio will be used instead
#define border_ratio float(1920.0 / 1080.0) //[0.1000 to 10.0000] Set the desired ratio for the visible area. You MUST use floating point - Integers do not work right.
//Examples that work: (1680.0 / 1050.0), (16.0 / 10.0), (1.6) Examples that does NOT work right: (1680 / 1050), (16 / 10)
#define border_color float3(0, 0, 0) //[0 to 255, 0 to 255, 0 to 255] What color the border should be. In integer RGB colors, meaning 0,0,0 is black and 255,255,255 is full white.
/ Splitscreen settings /
#define splitscreen_mode 1 //[1|2|3|4|5|6] 1 = Vertical 50/50 split, 2 = Vertical 25/50/25 split, 3 = Vertical 50/50 angled split, 4 = Horizontal 50/50 split, 5 = Horizontal 25/50/25 split, 6 = Curvy vertical 50/50 split
/ Custom settings /
#define custom_strength 1.0 //[0.00 to 1.00] Adjust the strength of the effect
Gibts es für Master Effect auch eine Zeile, in der bei Spielstart den Effekt ausgeschaltet ist? Oder kann ich die Zeile aus der Global_settings.txt von SweetFX in die Masterfeffect.h übernehmen?
so genau weiß ich das nicht. bei dem paket von razed funktioniert es direkt das es erst danach lädt
also die Nachtbilder der Stadt und ALAMO-See/Umgebung sind sehr genial, vor allem die ganzen Lichtquellen am Boden ;)
Schon sehr fotorealistisch :)
Muss ja gestehen das ich deine screens schon besonders geil finde, lord!
@Scrush
Habe diesen Thread hier durch Zufall entdeckt und mir die Settings von dir geladen 1 Seite zuvor, vielen lieben Dank dafür, das ist ja mal ein völlig neues GTA 5 Erlebnis, sieht super aus, habe eine HD6950@6970 Shadermod im Rechner und einen etwas betagteren ASUS FHD Monitor mit 1920x1200@60 Hz, wenn mir jetzt noch jemand erklären könnte, wie ich am besten Downsampling hinbekomme, wäre ich mega glücklich.
Nach all meinen Recherchen über Google blicke ich da immer noch nicht durch, würde mir das bitte nochmal einer erklären können, wie ich das am besten anstelle, habe Ingame FXAA und MSAA aus, sowohl auch im Treiber, habe noch eine leichte Treppchenbildung und erhoffe mir durch Downsampling das ganze verschwinden zu lassen, bin für jegliche Hilfe dankbar!
selbst mit downsampling kriegst du das bild nicht sauber. leider
es gibt 2 möglichkeiten
1. durch das Nvidia DSR in den 3 einstellungen. da baut er mir aber lustige auflösungen zusammen die recht wenig sinn ergeben
2. manuelle erstellung einer 1,25 oder 1,5x auflösung zur nativen im nvidia treiber oder amd treiber je nachdem.
variante 2 hab ich probiert. funktioniert zwar ist aber wirklich nicht richtig bruachbar. ich surfe zwischen dem gamen ab und zu mal rum und bin da natürlich aufm desktop. wenn man zurück ins game geht, ist die native auflösung wieder drin. nur noch nervig.
aufgrunddessen spiel ich mit 1080p + 2x msaa + fxaa. das ist gerade so ertragbar.
so sauber wie bei der source engine werden heutige spiele wohl nie mehr werden ... -.-
MFAA ausm nv treiber mit den maxwell karten glättet recht gut, leider mit grafikfehlern. somit unbrauchbar
Erst einmal vielen lieben Dank für deine Antwort. 2x msaa + fxaa hatte ich vorher auch und erscheint mir als die beste Lösung die Treppchenbildung etwas zu umgehen, läuft auch noch recht annehmbar, finde aber die Optik ohne schöner, desweiteren habe ich festgestellt, das im Treiber aktiviertes Supersampling besser aussieht als Multisampling, werde den Versuch dann mit Downsampling wohl besser sein lassen, habe mich inzwischen noch etwas einbelesen, scheint wohl doch komplizierter zu sein als angenommen, nutze derzeit den 15.4.1 beta, hast du vielleicht noch ein paar Tips für die Grafik Ingame Einstellungen?
Habe zur Zeit alles auf sehr hoch ausser Schatten und Reflektion, die nur auf hoch, Nachbearbeitung auf normal, bei den erweiterten Einstellungen habe ich nur die Detaildarstellung beim Flug auf AN.
@schack
Danke dir, ich find die meist aber selber nur so lala...da ich der meinung bein das es ingame immern och anders/besser aussieht
Also in finde 2xMSAA + 2xTXAA (eigentlich ist es nicht dazu, weil er dann wohl 2xTXAA fährt oder) recht ordentlich, klar nicht die 8x-Glättung aber dafür flimmert nix und 16xAF mach ich aus dem NV-Treiber forcieren, weil es laut NVIDIA settings guide besseres Ergebnisse liefert als ingame AF...
Hätte ich TitanX und fetten PC :P würde ich fast alles MAXEN, aber mit der jetzigen H/W ist TXAA imo ein gutes Ergebnis im spiel...
geht mir genauso. obwohl ich sogar zeit hätte treibts mich nicht ins game :d
ihr armen :P bin gestern etwas too much geflogen ,o) dafür aber diese KnifeFlights und UnterTheBridge completed :)
Das war mal anstrengend, trotzdem ein geiles Gefühl wenn mans geschafft hat ;) Zumal das fliegen sehr viel fun macht :)
Duster zum rumcruisen *G*
oder Buzzard für bissl HELI action ,)
Hi lange nicht gemeldet :-)
Hier ein Trailer zu Clear HD v4.1
mag mir jemand folgende Dateien hochladen?
D:\Steam Games\SteamApps\common\Grand Theft Auto V\update\update.rpf\common\data
lensflare_t.xml
lensflare_m.xml
lensflare_f.xml
zu öffnen mit open IV
