*****INSTALLATION*****
1- Download ENB 0.275 from here ->
http://enbdev.com/download_mod_gta5.htm
2- Extract all the files from "WrapperVersion" to your main GTAV root folder
3- Download ReShade+SweetFX 2.0 from here ->
http://reshade.me/#download
4- Extract the "SweetFX" folder, "Reshade.fx", "Reshade64.dll" and "Sweet.fx" to your main GTAV root folder
3- Extract all the files from my "ROOT" folder to your main GTAV root folder,
replace all files when asked
4- Start your game and enjoy
+INGAME OPTIONS+
-You can take screenshots by pressing "PrintScreen" (no more external software needed)
-Both effects will be activated at startup,
but you can still activate/desactivate one if you like:
-For Reshade (colors & lights): Press "Scroll Lock"
-For ENB (MSAA, reflections, sky & lightsprites): Press"Shift + F12"
*****UNINSTALL*****
- Remove all the files previously installed from your main GTAV root folder
*****REQUIREMENTS & TIPS*****
- Make sure all you GPU drivers are updated
- Programs like Steam Overlay or MSI Afterburn may interfer with Reshade,
so it's recommended to disable it.
- This mod is set for a fresh install, so if you already have some other
graphic mods installed, make sure there's no conflict between them.
I would highly recommand you to uninstall them before you install this mod.
You will still be able to mix things later if you want.
- If you have some performance issues, try to disable AA in ...\Grand Theft Auto V\"enblocal.ini"
by replacing existing values with:
[ANTIALIASING]
HighQualityMSAA=false
HighQualityVehicleMSAA=false
and disable FXAA in ...\Grand Theft Auto V\SweetFX\"SweetFX_settings.txt"
#define USE_FXAA 0 //[0 or 1]
- If you feel like the game is too dark for you, raise your ingame gamma setting, it has a huge influence on my mod.
