^^.. sind schon sehr schöne Werte! Da könnte man glat schwach werden!
Aber für 1080i wird man wohl trotzdem nicht um eine HD4670(HD5670 bald
) oder GT220 rumkommen!
Nicht Zwangsweise TDO hat nen Test von Missing Remote gepostet:
hier mal Auszüge zum Video Test
Integrated graphics (IGP) have historically struggled with proper deinterlacing support, so we are going to dig into the i5-661’s capabilities in this area. To probe the capabilities of the different graphics solutions tested, patterns found on the Spears & Munsil HD Benchmark disc were selected. There are several patterns on the disc so just the most common types will be discussed.
We will be looking at the source adaptive 2-2 (two fields per frame, equivalent to 30fps)and 2-3-2-3 (PF-T) (two fields for the first frame then three fields containing one frame and one field of the next image, most commonly used for transferring 24p film to 60i video) wedge and the edge adaptive “Jaggies” (tests the ability to deinterlace without jagged stairstep patterns on edges) tests below.
In the source adaptive tests moiré should be present only in the last quarter of the wedge, overall brightness should be consistent, and there should not be any flickering. In the “Jaggies” test a rectangular bar rotates through a large inner circle of alternating black and white lines, as it moves the edge of the bar should remain smooth (not jagged) along the length of the bar, any distortion that occurs as it passes through the alternating lines should remain close to the bar and the alternating lines in the circle must be solid and not flicker.
Intel Core i5-661 (15.16.5.2021)
* 2-2: moiré was present up to ½ of the wedge, pattern was consistent and solid
* 2-3-2-3 (PF-T): moiré was present up to ½ of the wedge, pattern was consistent and solid
* Jaggies: The moving bar is very straight. The circle maintains alternating pattern, and only a thin line of distortion is present as the bar moves through it.
ATI 4650 (Catalyst 9.12)
* 2-2: moiré was present on slightly more than ½ of the wedge, pattern was consistent and solid
* 2-3-2-3 (PF-T): moiré was present on slightly more than ½ of the wedge, pattern was consistent and solid
* Jaggies: The moving bar is quite jagged as it moves. The circle is drawn correctly, but a long tail of distortion trails the bar as it moves.
Based on the results across all of the tests it’s obvious that Clarkdale is a solid performer; owning the edge adaptive and performing as well as or better than the discrete cards in the source adaptive; unless the HTPC will also be used for serious gaming there’s not much need for a discrete card.
Soviel erstmal nur als zusammengekröpfter Auszug, man sollte es halt mal
gesamt lesen.
http://www.missingremote.com/index....=view&id=4489&Itemid=238&limit=1&limitstart=5
Das hört sich so prinzipiell schon mal gar nicht so schlecht an, wir reden hier
immer noch von einer IGP, welche sogar die HD4650 in bezug auf Videowiedergabe (HD) -> Zitat:
"Owend..., ...performing as well or as better..."
Ist zwar jetzt ein bissel reiserrisch aber wollte es halt nochmal erwähnen
Schaun mehr mal, eine Schwalbe macht noch kein Sommer
aber nach Regen siehts aktuell auch nicht unbedingt aus....
Auch hier wurden noch Probleme angesprochen zur Videowiedergabe.
Auch wurde hier angesprochen, das sie PDVD, WDVD, Arcsoft theatre?? zum
laufen gebracht haben, HT4u schrieb nur von PDVD.
Alles in allem scheint es nicht so schlecht auszusehen, mit ein bischen
Zeit und Treiber Reifung könnte das auch noch sehr ordentlich werden,
kommt zeit kommt rat und nähere ergebnisse.
Aktuell stört mich halt noch der Preis für eine solche Plattform, desweiteren
würde ich gerne auch Wissen ob sich die GPU im i3/Pentium G bzw. mit
den verfügbaren GPU Taktraten(900/733/533) in ihren fähigkeiten unterscheidet.
Mising Remote hatte mit dem i5 661 zumindest die GPU Sperspitze mit
900Mhz im Test.
Wenn die Plattform für umme 125€ zugänglich wäre (CPU/Board/min. 2gb
Speicher) könnte ich mal schwach werden, im Prinzip wäre es eh nur
zum Probieren weil es so eh nicht ganz in mein HTPC Profil passt.
Desweiteren müsste ich aber dann wohl auch noch nen aktuelles OS mit einbeziehen.
Es würde mich jedenfalls nicht wundern und auch teils verständlich(wenn auch schade) wenn hier Intels prio bei Vista/W7 liegt und mit XP man da etwas auf verlorenen posten steht aber how knows.
Letztendlich würde das vielleicht ja auch meine bestehenden ATI mit
MediaPortal Probleme unter XP lösen..
