Von PC Tweaker![]()
Hab ich auch aber das Ding spinnt auf dem DFI![]()
Hat das Biostar auch so ne <VID nogo Macke yoshi?Das war mir jetzt so sympathisch
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Excecute Disable Bit: Enabled
- Virtualization Technology: Enabled
- Core Multi-Processing: Enabled
Exit Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
O.C Fail retry counter: 0
CLOCK VCO divider: Auto
CPU Clock Ratio: 8,5
CPU Clock Ratio Unlock: Enabled
- Target CPU Clock: 3808Mhz
CPU Clock: 448
Boot Up Clock:335
DRAM Speed: 333/667
- Target DRAM Speed:DDR2 897
PCIE Clock: 100mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
Voltage Settings
CPU VID Control: 1.37500
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
DRAM Voltage Control: 2.150V
SB Core/CPU PLL Voltage: 1.640V
NB Core Voltage: 1.591V
CPU VTT Voltage: 1.280V
Vcore Droop Control: Disabled
Clockgen Voltage Control: 3.75V
GTL+ Buffers Strength: Strong
Host Slew Rate: Strong
MCH RON Offset Value: 00
MCH RTT Offset Value: 00
MCH Slew Rate Offset Value: 00
MCH VREF 1 Value: 00
MCH VREF 2 Value: 00
MCH VREF 3 Value: 80
GTL REF Voltage Control: Enable
x CPU GTL1/2 REF Volt: 65
x CPU GTL 0/3 REF Volt: 83
x North Bridge GTL REF Volt: 96
Real:
CPU Core: 1.42V springt unter Prime: 1.4204 -1.4225
Drfam 2.14V
NB Core 1.60V Everest:1.55V
CPU VTT 1.29V Everest:1.28
DRAM Timing
- Enhance Data transmitting: Normal
- Enhance Addressing: Normal
- T2 Dispatch: Disable
Clock Setting Fine Delay
DRAM CLK Driving Strength: Level 6
DRAM Data Driving Strength: Level 8
Ch1 DLL Default Skew Model: Mode 0
Ch2 DLL Default Skew Model: Mode 0
Fine Delay Step Degree: 5ps
Ch1 Clock Crossing Setting: More Relaxed
- DIMM 1 Clock fine delay: Current 1900ps
- DIMM 2 Clock fine delay: Current 812ps
- DIMM 2 Control fine delay Current 900ps
- DiMM 1 Control fine delay Current 224ps
- Ch 1 Command fine delay: Current 1200PS
Ch2 Clock Crossing Setting: More Relaxed
- DIMM 3 Clock fine delay: Current 1900ps
- DIMM 4 Clock fine delay: Current 749ps
- DIMM 4 Control fine delay Current 712ps
- DiMM 3 Control fine delay Current 700ps
- Ch 2 Command fine delay: Current 1200PS
Ch1Ch2 CommonClock Setting: More Relaxed
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto
CAS Latency Time (tCL):5
RAS# to CAS# Delay (tRCD):5
RAS# Precharge (tRP):5
Precharge Delay (tRAS):18
All Precharge to Act: Auto
REF to ACT Delay (tRFC):58
Performance LVL (Read Delay) (tRD): 15
Read delay phase adjust: Press Enter
Ch1 Read delay phase (4~0)
- Channel 1 Phase 0 Pull-In: Enable
- Channel 1 Phase 1 Pull-In: Auto
- Channel 1 Phase 2 Pull-In: Auto
- Channel 1 Phase 3 Pull-In: Auto
- Channel 1 Phase 4 Pull-In: Auto
Ch2 Read delay phase (4~0)
- Channel 2 Phase 0 Pull-In: Auto
- Channel 2 Phase 1 Pull-In: Auto
- Channel 2 Phase 2 Pull-In: Auto
- Channel 2 Phase 3 Pull-In: Auto
- Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: Auto
Write to PRE Delay (tWR): Auto
Rank Write to Read (tWTR):Auto
ACT to ACT Delay (tRRD): Auto
Read to Write Delay (tRDWR): Auto
Ranks Write to Write (tWRWR): Auto
Ranks Read to Read (tRDRD): Auto
Ranks Write to Read (tWRRD): Auto
Read CAS# Precharge (tRTP): Auto
ALL PRE to Refresh: Auto
hallo leute,
stimmt das eigentlich, dass man einen prozzi erst 400 stunden lang laufen lassen soll, bevor man ihn übertacktet oder ist das so ein an-aus-bug märchen
danke
@ orange so lange haben hier manche garnicht ihre cpu`´s ggggggg![]()
Hallo @ all ich Hoffe mir kann jemand Helfen.
Spiel mich schon die ganze nacht rum:
Und zwar hab ich des Problem das er bei 640K ab schmiert mal bei kern 1 und mal bei kern 2 hab GTL schon probiert es ist auch schon besser geworden läuft jetzt ein par stunden immer, vorher warns nur min.
Des Hauptproblem ist draran das immer weider einer von den beiden des macht, der andere läuft dan durch. bzw. alle andern.
Meine Frage ist soll ich an der GTL noch weiter nach unten?
Ich Hoffe ihr könnnt mir Helfen bin für alle tips dankbar
Prime95 Screans mit einstellungen memset everest CPU Z:
1 Test:
2Test Custom640K:
Danke im Voraus Alex
