[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Hi
Bin jetzt auch Besitzer des 790GX Extreme. Aber leider funzt bei mir noch nix.
Also um es genauer zu sagen: Ich bekomm KEIN Bild. Ich hab als CPU einen Phenom II 940. Der Speicher ist der in meiner Signatur.
Wenn ich Strom anschließe dann Leuchten ein paar LEDs. Aber leider ist die Anleitung irgendwie total schwer verständlich, bzw. unstrukturiert. Die LEDs, die leuchten, haben die Beschriftung D30 (leuchtet immer), D29 und eine, an der Vdimm_LED steht (die letzten beiden leuchten erst, wenn ich den PC anmache).
Wie gesagt hab alles zusammengebaut und will das Teil jetzt starten und aufsetzten - aber bekomm kein Bild. Die Lüfter laufen alle.
Weiß einer was die LEDs bedeuten und welche vllt einen Fehler andeuten und welche normalerweise immer Leuchten?
Viele danke für bitte schnelle :) Hilfe
Welchen Code sagt das Display?
Hi
Nein leider nicht - ich hab gar kein Bild
Ich hab schon per DVI und Per Hdmi versucht, mit den Anschlüssen der Onboard Grafik und mit der Grafikkarte aus der Signatur.
Das Display sagt 88 .... ich vermute das sagt gar nix oder?
stromkabel alle angeschlossen? d.h. p4-stecker?
gruß
manu
Ja der P4 stecker mit erweiterung ist dran, also son 8 Pin teil. Muss ich denn vllt irgendwas "Jumpern" auf dem Board oder so?
bei mir gings so zu sagen Plug and Play, Board raus CPU rein und gut... bei dir auf dem Board ist unten rechts auf einem Chip ein Aufkleber, welche Rev. hast du?
Haste das mal versucht ( PM ) ? Also 1 Ram Riegel und Reset sobald der Rechner startet ? Benutzt du die Onboardgrafik ?
Was heißt PM? Noch nicht von gehört. Hab jetzt mal nur einen Ram-Riegel drin, und Reset beim starten gedrückt, hat noch nichts gebracht. Ich tausch noch mal die Riegel und Rambänke..
Wie gesagt ich versuche alles, Onboard Grafik und Grafikkarte aus Signatur. Ich versuche immer alle Parameter durch zu wechseln wenn ich was verändere...
versuch erstmal nur mit der Onboard Grafik...
wie sind deine jumper gesetzt?
JAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!
DER RAM WARS....die ROTEN Bänke haben gemeckert! Jetzt hab ich Bild!
Viele Dank erst mal, ich probier hier weiter!
Hast du Ahnung von Diesem Jumper Kram? Ich hab bis jetzt GAR KEINE Jumer gesetzt / umgesetzt - was muss ich da einstellen?
PM oder PN = private Nachricht, kannst ja auch mal nen cmos clear versuchen ( Rechner vom Netz, Jumper Rechts Jumper Links, jumper ist über der Biosbatterie. Hörst du denn nen Piepton beim Start ?
Zu spät :p
Hab die roten Rambänke selber noch nie ausprobiert, gleich die schwarzen genutzt da das rot so schön aussieht..... :o
Hab jetzt einen Ram in den Roten - er startet...
Zu den Jumpern: Habe bis jetzt keinen verstellt!
Habe noch ein paar Probleme mit den USBs...die Maus geht irgendwie nicht.
Bin auch noch nicht Problemlos ins Win gekommen, bin da jetzt immer nur im abgesicherten Modus drin, kann auch an den Treiberresten von Intel liegen, setzte eh gleich neu auf. Will aber erst sichergehen, dass die CPU nicht zu heiß wird, hab den Mugen 2 drauf, aber bin immer unsicher mit der Menge an Wärmeleitpaste.
Werde jetzt wieder 2 Rams in den roten Bänken ausprobieren.
also @stock wird der nicht zu heiß. wenn du noch xp drauf hast dann mach mal ein bios update...
Hm also hab jetzt wieder 2 in den Roten. Er startet (hab Bild) das alte Windoof. Dann Bluescreen...son Mist. Ich will doch nur einmal da rein und die Temps im Idle checken...
Wie gesagt im abgesicherten Modus funzt es dann.
achja wenn er dann nach dem Bluescreen abgekackt ist dann piepst er ein zwei mal...dann kommt die Auswahlmöglichkeit für abgesicherten Modus.
versuch mal als erstes nen bios update zu machen. und dann das OS neu aufsetzen... die temps siehst ja auch im bios ;)
Also um das nochmal genauer zu sagen: hab doch noch ein zwei Probs mehr:
-> Wenn ich einschalte piepst er grundsätzlich ein zwei mal...
-> im abgesicherten Modus geht die Tastatur und die Maus (also alle USB geräte) nicht
-> Nen Bios Update kann ich also nur ohne Win machen. Geht das problemlos bei diesem Board?
-> im Bios war ich noch nicht versuche ich grade...klappt auch grade ne soo dolle
-> die Dioden leuchte immer noch fröhlich...welche Leuchte denn bei euch so?
Beiträge zusammengeführt, da Antwort auf eigenen Beitrag innerhalb von 4 Stunden:
-> Ok bin im Bios und da geht die Tasta...
Also Temps sind laut Bios voll ok...wobei NB 52°C find ich schon viel dafür das der gar nix macht außer im Bios zu sein.
Wie kann ich denn nun am einfachsten das Bios aktualisieren? Kann der von USB Stick booten? hab das grade noch nicht gefunden im Bios.
bei mir leuchten alle drei led´s und es piept auch immer zweimal... bios update habe ich in win xp gemacht über usb noch nicht versucht... das mit der NB kann nicht stimmen bei mir sagt er 34°C und die läuft auf 2400MHz
Das Problem ist ich komm nicht in Windows rein, nur im abgesicherten Modus.
Und da funzen irgendwie Maus und Tasta nicht...aber ich versuchs nochmal
So jetzt mit ner PS2 Tasta bin ich im abgesicherten Modus. Meinst du man kann das auch in diesem Modus machen, das Bios Update?
versuch es doch du loadest das bios und gehst in den ordner wintool dort ist die flash datei, doppel klick und gucken ob sich ein dos Fenster öffnet. wenn ja nichts machen geht von alleine, wenn nein dann gehts nicht....
Ich tippe aber eher auf das OS
Also was ich mich auch noch frage ist: Die CPU wird im Moment noch nicht richtig erkannt, aber das BIOS was es im Internet gibts (1.1) ist von November 2008...ob die Phenom II CPU damit erkannt wird halte ich mal gelinde gesagt für fraglich. Ich installier jetzt erst mal Win neu.
die 1.1 erkennt auch nicht die CPU... ist ja noch in der mache das neue :d von daher kannst es dir sparen dachte nur wegen deinen start Problemen....
So hab jetzt mal die Windoof 7 Beta drauf gemacht um das mal zu testen. Und was soll ich sagen klappt. Kein Bluescreen bottet ganz normal.
Installier jetzt treiber etc und gucke wie schnell das neue BS von Microsoft ist.
grüße und danke an alle die geholfen haben!
das hört sich besser an :d habe auch W7/64bit als OS am laufen kann dir sagen das es gut läuft :wink:
Bin schon mal ganz zufrieden, in 3D Murks 06 von 113xx oder so auf 135xx ... find ich schon mal recht krass.
Sagt mal habt ihr irgendwelche Treiber fürs Board installiert? Die Onboard Audio Sachen und die Onboard Grafik verwendet ich auf keinen Fall, brauch ich noch für was anderes nen Treiber?
