• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Hm jetzt wollte ich die Timings von meinem Ram wieder so einstellen wie früher (und wie auch vom Hersteller angegeben), nämlich mit 800Mhz und Cl4-4-4-12, und zack fährt der Rechner nicht mehr hoch...auch nicht ins Bios...geht gar nix mehr.
Naja dann hab ich da mitm Jumper die Einstellungen im Bios zurückgesetzt.
Bei meinem alten Board musste ich immer ein bissl die Spannung erhöhen für den Speicher, damit alles stabil lief. ABER hochfahren tat der alte IMMER, ist dann halt nur in Windoof abgeschmiert bei zu niedriger Spannung. Angeblich können die Riegel aber bis 2,1V also kein Problem.
Also Frage an euch - ist das normal bei dem Board, dass man mit schärferen Timings von vorneherein die Spannung hoch stellen muss, weil der sonst gar nicht mehr klar kommt?
ich hab 2x2GB 1066er was anderes als 5-5-5-15 (Standard) hab ich nicht probiert...
Das kann daran liegen das die Subtimings auf Auto nicht so sind wie auf deinem anderen Board, am besten alles manuell einstellen / ausloten oder ne Stufe höher setzen.
Läuft die USB Maus?
Bei mir war mal das Prob, dass ich die immer wieder NACH dem start ein und austecken musste, dann gings!
EDIT///Schön in meine Gruppe kommen :d
Edit: Ah jetzt hab ich den Post von Mr.Wifi verstanden...die Subtimings machen das Problem...das kann sein, ich hab die bei dem J&W alle auf Auto gelassen.
Auf was soll ich die einstellen, erst mal alle auf 5 etc?
Kann mir einer mal nen Screenshot geben was er so eingestellt hat?
Mit der Maus das probier ich aus wenn ich es das nächste mal übertrieben habe mit den Timings :)
Ist einfach durchgelaufen :d
Mit der CPU und dem Board erste Sahne :coolblue:
ist das denn ein WR? ich hab nen Thermalright IFX14 da sind zwei Enermax Cluster 120mm. drauf im Antec Twelvehundred ...
Grüße
du verstehst mich nicht ganz :P
Also,
ich sagte:
1.Ich:Gib den WR ein
2.Du :Ist das einer?
3.Ich:Nicht ganz
4.Du:Gug mal mitwas die kühlen.
5.Ich:ich verdeutliche mein Nicht ganz
---->Ich wollte eigtl. nur sagen, dass es nicht ganz ein WR ist :d:d
Unter den Voraussetzungen (LuKü) wird das auch nichts werden von daher könntest dir das eigentlich sparen...
Ist doch klar das mit LN2 5Ghz oder 6GHz drinnen sind :fresse:
Der einzige der auch die 4,1GHz Stabil hat ist Motkachler mit seiner WaKü und wir haben fast die selben Temps ;)
also vom support bin ich jetzt schon begeistert:love:
Hallo Herr *******,
wegen des chinesischen Neujahrs/Frühlingsfestes hatten die Kollegen in Asien
bis zum letzten Wochenende Betriebsferien.
Wir erwarten die nächste Lieferung unseres 790GX-EXTREME ab ca. 09.02.2009.
Ein Termin für das nächste Bios Release ist uns leider nicht bekannt.
Danke für Ihr Interesse.
klare Antwort und das schon nach 25min!!
bei asus oder gigabyte träumt man von sowas:hail:
Was bei mir nix gebracht hat, wenn ich den Speicher auf 300mhz runternehme, und die "fsb" zu erhöhen.
Hmm...2becontinued
EDIT///Heb mal den "FSB" auf 205 an...und geh auf x21 (21,5).
Geht das?
Also Bootable?
moinmoin mädels...
also wenn das ding wieder verfügbar ist (und das konto nicht wieder leer ;) wird geordert... was ich hier glaube schonmal angesprochen habe bzw. wo ich mir unsicher bin, ist die sache mit dem lüfter... habe nun gelesen, dass man nen xigmatek auf "amd-boards" nur nach oben blasend montieren kann, was für meine zwecke nicht so optimal ist -.-
nun wollte ich fragen ob da jemand nen xigmatek schon montiert hat bzw ne ahnung ob ich den speziell auf diesem board auch anders montieren kann? quasi blowjob nach hinten ;)
thx schonmal
greetz Zim
Ziehe den Kauf des Boards in Erwägung. Lässt sich die Heatpipe von den Kühlern abnehmen? Wisst ihr welcher Wasserkühler auf die Northbridge passt? Dachte da an einen aus der günstigen Watercool NSB-Serie. Wie sieht es mit der Kompatiblität zu OCZ Platinum XTC PC2-8000U Modulen aus?
Chubaka, ich meinte, ob man die Heatpipe trennen kann, sodass man z.B. einen Wakühler auf die Northbridge packt und den originalen Passivkühlkörper auf den Spawas belässt. Bei meinem Abit war die Heatpipe nur mit einer Art Wärmeleitkleber an den Kühlern fixiert.
