• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
weiss jemand von euch, ob man bei dem Board sofort AM3 CPUs installieren kann oder muss man vorher ein BIOS Update fahren, damit die CPUs erkannt werden?
Falls ein BIOS Update notwendig ist: Kann man mit einem AM3 Prozzi überhaupt starten (halt falsch erkannt) oder startet der PC nicht einmal?
Ich dachte an den Phenom II X3 720 BE.
Und dann noch sowas gaaanz allgemeines: Ist J&W überhaupt eine Qualitätsmarke mit gutem Support? Man hört von der Marke rein garnichts, bin nur zufällig auf sie gestoßen und halt was das angeht kritisch, da ich oft mit Nieschenmarken schlechte Erfahrungen hatte.
Grüße
Light
Grüße
Light
Also der Support ist allererste Sahne würd ich mal so behaupten. Chubaka hat ja zum Beispiel Beta-Bios-Versionen bekommen, was nicht unbedingt Gang und Gebe ist..
Zum CPU kann ich so nichts sagen, mal gucken was die anderen dazu meinen.
Das Release Bios unterstütze auch keine PII's und ich bin damit trotzdem mit meinem 940er auf 4GHz gekommen ;-)
Im Bios und in CPUz steht dann halt Unknown Processor, das ist aber nicht schlimm...
Klingt doch nicht schlecht.
Dein PII ist wohl ein AM2+ Prozzi oder? Weiss ja leider nicht, ob sich das auch auf AM3 CPUs übertragen lässt. Gibts überhaupt ein Bios für AM3 CPUs? Irgendwie gibts zu dem Board leider etwas wenig Infos, was Kompatibilität angeht.
Von dem was ich bisher gelesen habe muss das Board ja der Wahnsinn auf Erden sein. Und optisch ist es auch mal nur noch als göttlich zu beschreiben.
Alternativ bin ich derzeit am Überlegen, das MSI 790FX-GD70 zu kaufen, aber das ist halt nochmal einen 20er teurer und hat wie jede AM3 Platine mit jedem 2. Ram seine Tücken.
Ich komme einfach nicht weiter, was meine Überlegungen angehen. Wenn ich wüsste, dass ich den PII X3 720 BE einfach installieren und dann ggf. Bios flashen kann, wäre ja alles in Butter. Aber wenn das Board jetzt meint: "Nee, is nich!" Naja, dann... aua, habe nämlich keine andere passende CPU und stände da wie die Axt in der Wüste. :(
Der X3 läuft problemlos.. Steht hier zumindest irgendwo im Thread.. Musste mal suchen.
Wenn du das Board haben willst und noch ca 3 Wochen warten kannst, kannst du meins haben. Ich werde nämlich komplett auf AM3 umsteigen...
Muss aber trotzdem sagen, dass das J&W ein geiles Board ist. Ich steig lediglich wegen noch mehr Zukunftssicherheit um.
Kannst auch die Liquid-Ectasy Wasserkühler haben (gegen Aufpreis), die es noch nicht gibt, weil Erstanfertigung. WaKü ist noch nicht einmal benutzt. Bei Interesse kannste dich ja per PN melden.
Mein PII 940BE swird dann auch zum Verkauf stehen. Lief alles gerade einmal knapp 3 Monate, wenn überhaupt.
Klingt wohl gut. Dann wird die Entscheidung jetzt verdaaaaamt hart zwischen dem MSI und dem J&W.
Auf was für eine Konfig steigst du eigentlich um? Bzw: Welches Board?
Auf das GD70 :fresse: :lol:
mit dem 955BE und wenns geht 8GB 1600 CL7.. ich such nur noch passenden Ram und wenn Anfang des Monats mein Konto lächelt wird in 2 Etappen umgestiegen.
Habe gelesen Crucial DIMM (ohne Heatsprader) soll super stabil laufen.
Womit kühlst du? Die linken Ramslots werden ja meistens von fast jedem Kühler blockiert. (AMD Layout ist irgendwie unsinnig...)
Edit: Ist das Problem mit dem Multi jetzt eigentlich gelöst oder ist das Problem noch bestehend? Wenn es noch besteht, kann ich das Board für den 720 vergessen, da ich schon gerne 1 - 2 nach oben wollte.
Was meinste @ Kühlung?
Das aktuelle J&W mit dem 940er Boxed-Kühler, das MSI werd ich irgendwann unter Wasser setzen.
Das J&W läuft auch offen auf meinem Schreibtisch, besitzt also null Einbauspuren oder Ähnliches. Alle 3 Tage wirds vorsichtig entstaubt, zumindest so gut es geht ;)
Hier mal ein Bild:
Die Ram´s werden dann auch vertickt, also fast ein komplettes System ;)
Jungs, ich spiele mit dem Gedanken, mir so ein Board zu holen.
Ich habe mir jetzt nicht alle Seiten hier durchgelesen, aber es scheint ziemlich viel positive Resonanz zu dem Board zu geben.
Ich denke mal allein die OC-Ergebnisse sprechen für sich ;)
Das Layout ist sehr gut durchdacht und die farbliche Gestaltung einfach Bombe.
Laut der Herstellerseite wird ab dem 6.2.2009 ein Bios angeboten, das AM3 CPUs freischaltet. Kann man davon ausgehen, dass dieses BIOS bei den derzeit vertriebenen Platinen drauf ist?
Das MSI ist leider auch fast nirgends zu haben. :(
Und irgendwie werde ich wegen dem Multibug die Sorge nicht los.
War es eigentlich schonmal schwerer als heute, sich für ein Board zu entscheiden? Gerade, wo man jetzt quasi schon zwei Plattformen für eine CPU haben kann. oO
@ Daniel N: Ich überlege mir, ob ich vielleicht deins nehme, sobald du es anbietest. :) Klingt schonmal gut. Und du scheinst es ja auch echt zu pflegen, wenn ich mir das Pic so anschaue.
Gerade bei den aktuellen Marktpreisen finde ich die Entscheidung sehr schwer.
Die Preise fallen teilweise übelst in den Keller, auch was RAM und CPU´s angeht.
Ich hab laut CPU-Z das 1.01 Bios drauf vom 4.2.09 komische Angabe Oo
Da ich mir aber eh erst die neue CPU holen werde, kann ich dir dann definitiv sagen das der X3 läuft oder nicht ;) Denn wenn der 955 läuft wird der X3 null Probleme machen.
Zur not muss ich halt n Bios-Update machen.
Wegen Pflege: Joa so gut es geht. Im mom isses wieder n bissel eingestaubt, morgen wird wieder entstaubt ;)
Hab auch extra das rote Plastik-Flies oder wasses ist drunter gelassen, damit keine Kratzer an Board und Tisch entstehen.
Kann mir mal jemand ne Anleitung geben um das Bios update durch zu führen?
Ich krieg bei mir unter Win Vista 64 weder das 1.02 noch das 955 Bios drauf.
Und unter dos hab ich keine Ahnung wegen den Parametern /dies /das /irgendwas.
Oder einfach die übernehmen die im fenster stehen wenns unter win nicht klappt?
//EDIT:
Habs Bios grad vom USB-Stick geupdated, allerdings zeigt mir CPU-Z immernoch 080015 an?
Oder ist das schon aktuelle Bios mit AM3-Support? Ich steig da nicht durch -.-'
Die 1.0 Version hieß bei mir aber auch 08015 soweit ich mich erinnern kann, ich habe mehr auf das Datum und CPU-Z geachtet, 1.0 ist 28.8.08 und 1.1 30.10.08, evtl. hattest du schon das neuere Bios drauf kann ja sein :d
Bei mir steht 02/04/2009 also 04. Februar 2009
Heisst das ich habs aktuelle Bios schon drauf?
Hmmm, wenns das J&W bei mir wird, könnte ich mich auch mit nem X4 940 BE anfreunden. Die müsste theoretisch ja laufen, da es noch eine AM2+ CPU ist.
Die bietet ja auch mehr Druck als der X3 720 BE.
Ob ich jetzt die MSI 720 oder J&J 940 Kombi fahre macht ja finanztechnisch keinen großen Unterschied, dafür um einiges mehr Druck auf dem Kessel.
Wenn du willst, kannste mitte des Monats von mir Board, Ram und CPU haben.
Aber ich denke, dann sollten wir alles weitere per PN klären.
Details findeste schonmal im Sysprofil (Signatur)
Rechnungen sind auch alle vorhanden.
Ich glaube das ist mir ehrlichgesagt noch zu früh. Aber du wirst sicherlich bald einen Käufer haben, bei der Qualität.
Weisst du, ob der 940 BE vernünftig läuft? Ich meine jetzt auch mit veränderbarem Multi.
Obwohl ich bei der recht performanten CPU eh erstmal leicht undervolten wollte bei Standardtakt. Derzeit lohnt sich für mich bei der CPU OCn nicht. Aber wenn es dann mal soweit ist, möchte ich nicht entsetzt feststellen: "Scheiße, das Board lockt den Multi..."
Edit: manchmal hats bei mir doch ne Denkblockade. Du fährst den 940 BE, also wird er wohl laufen. ^^
Außerdem habe ich seiten zuvor den 940 BE mit 2x Multis laufen sehen. Deiner läuft offensichtlich auf 15x200, also standardtakt. Also müsste meine Frage damit nun beantwortet sein.
Ich denke meine Entscheidung steht: In ca. einem Monat wirds bei mir ein 940 BE mit 4 GB Ram von Corsair (mit niedrigen Heatspreadern, damit der Mugen 2 drüber geht) auf dem J&W. Damit habe ich sicherlich eine der möglichst schnellen AM2+ Kombis. Und wenn ich später Lust auf noch mehr Power habe, verpasse ich ihm mit neuestem Bios einen 955 BE und verkaufe den alten.
Scheinbar gibts an dem Board ja nichts, das abschrecken könnte. Und bevor ich mir da ein Gigabunt ins Case rödle. nene ^^ Die mögen nicht schlecht sein von der Qualität her, aber das Auge isst nunmal mit.
Ich habe das Board mir jetzt auch zugelegt.Bisher bin ich aber nicht zufrieden.Der Psi-E Slot wird bloß 8x erkannt,ich weiß nicht ob es damit zusammenhängt,im ATI CC kann ich keine Einstellungen vornehmen,karte wird aber richtig erkannt.Beim Start kommte immer 3Beeps,ein lauter und zwei leise hinterher.Ich habe jetzt die Karte rausgenommen,genau das selbe.
Vielleicht kann mir jemmand erklären wie ich das neuste bios draufbekommen,ob im dos/vielleicht gebe ich auch nicht die richtigen befehle/oder unter Window kommt im ein Error.
@Mounti
Wie sind denn deine ganzen Slos belegt?
Eventuell die Jumper auf CF eingestellt?
Bios-Updates findest du im Startpost. Welches du hast, kannste mit CPU-Z gucken.
Bios update hatte ich machen können,nun ist aber der Bildschirm schwarz,so ein mist aber auch.
Habe schon alles versucht,jumper,batterie)
vielleicht habt ihr ja noch eine idee.
Schon auf safebios gejumpert?
Ps: Der Crucial RAM läuft super: 2x BL25664AA80A(ein eizelner Riegel) also insgesamt: 2x 2Gb DDR2 800 CL4 @ 534 Mhz CL5-5-5-18
Ich werde heute noch Vollbesetzung von 8 gb mit einem zusätzlichem G.skill 4 Gb 800er kit testen.
wie stellt ihr eigentlich die Ram mhz ein? im bios kann ich neben 400 nur 533 machen und das macht mein ram nicht mit -.- Würde gern mal was dazwischen testen.
Auch wenn Du Dir jetzt offenbar eine andere CPU zulegen willst:
Der X3 720 wird sofort erkannt, da muss nix am Bios gefrickelt werden. ;)
habe es gefunden,die jumper für den safebios,habe zwar jetzt wieder ein anderes board drin,muß ja nicht gleich wieder alles einbauen.
---------- Beitrag hinzugefügt um 16:06 ---------- Vorheriger Beitrag war um 15:57 ----------
Mist,stand schon auf sfebios,ob es sinn macht auf user bios umzustellen?
Danke. :) Das isn Wort.
Dann wird die entscheidung wohl vom Portemonnaie abhängen, ob ich einen X4 940 BE oder einen X3 720 BE einbaue. Ersterer ist ja locker 30% schneller laut diversen Benchmarks.
Wird wohl hart die Entscheidung. Sollte man bei dem Board eher 1066er oder 800er Ram nehmen? Ich habe da 2 unterschiedliche Dinge gelesen:
1. 800 und 1066 macht fast keinen Unterschied
2. mit 1066er sind fast 5% mehr Gesamtleistung drin
Bei Daniel N scheint ja ein 4 GB Kit DDR 800 von A-Data zu laufen. Das wäre dann schonmal sehr sicher, da er bei mir ja wahrscheinlich auch laufen würde.
Dann habe ich noch von einem G.Skill Set mit DDR 1000 gelesen, das angeblich super gehen soll auf AM2+ Platinen
Schade, dass es keine offizielle Kompatibilitätsliste gibt. Oder habe ich sie einfach bisher nicht gefunden?
Kann mir jemand bitte die SVID Override Funktion erklären? Ich hab schon ne Zeit lang rumprobiert bin aber zu keinem Ergebnis gekommen.
Ps: Wo sind die vrms?
