[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Sogar noch lustiger: Wenn ich nen anderen nicht bootfähigen USB Stick dranhänge hab ich denselben Hänger mit 4min Verzögerung.
Wenn ich den bootfähigen dranhäng und F11, ergo Boot Selection mache, kann ich auch nicht den USB Stick als Device auswählen.
Also Booten von USB geht, hab Windows7 von externer HDD installiert...
Du musst im BIOS bei Boot / HardDrives das angeschlossene USB-Laufwerk ganz nach oben schieben.
Achja, und der Stick muss natürlich FAT32 (max 32GB) und die Partition als aktiv gesetzt worden sein. Geht alles über die Datenträgerverwaltung von Windoof.
@ToPPi
Mein Beileid, dass dein BIOS zerschossen ist, aber wenigstens hat es überhaupt ein zweites... Dass das mit der DualBIOS Funktion nicht so reibungslos funktioniert wie z.B. bei Gigabyte, konnte ich mir bei DEM Hersteller aber schon irgendwie denken...(ich warte schon auf Chubaka's Aufschrei)
Habs gebacken gekriegt. Er kann nicht über nen USB Hub booten. Direkt am USB Port gehts.
Kann man eigentlich nem anderen PCIe Slot 16 Lanes geben? Am Besten wär der inner Mitte, weil mein Netzteil unten ist. Die Graka ist im oberen bisschen schlecht platziert weil der mugen 2 Lüfter kaum Abstand hat. Zur Ram Seite ausrichten geht net, Lüfter zu fett^^ Im Handbuch steht wenn man das Zeugs da umjumpert, dass dann der 1. und 3. Slot 8 lanes haben, steht aber nix über den 2.
Und wie ist dann der 1x Slot angebunden? Da würde ja quasi ne Lane fehlen :hmm:
Ääääh stimmt, gute Frage, mom ich recherchier mal und überleg n bissel ;)
Anleitung, Seite 10:
Slot 1: 8x
Slot 2: 1x
Slot 3: 8x
Slot 4: 4x
Zumindest bei Vollbestückung, sonst hat Slot 1 16x und Slot 3 0x
Denke ich zumindest mal ^^
So denk ich auch. Hast ja 16 Lanes für 1 oder 2 Karten und dann nochmal 6 Lanes zur freien Verwendung. Also is der dritte 16x nur mit 4x angebunden. Wär noch eine Lane frei, wo vermutlich der Netzwerkchip dran hängt.
Muss ich wohl mit 8x die Graka betreiben, meinte übrigens den 3. Slot hab den kleinen übersehen^^
Ist im Moment nen bisschen eng, denke der Mugenlüfter braicht nen bisschen mehr Platz. Killt mich aber nich wegen den ganzen Leitungen die werden noch richtig verlegt.
Warum baust den Lüfter nicht an die Seite über die Rams?
Weils net passt die HS von den Domis sind viel zu hoch, vllt evtl mit Kabelbindern, bin da ab er net so der Fan von.
Also die kleinen Chinesen, die das Englisch verbrochen haben:
Code:
1. The BIOS is for reference only, can't ensure successful completely;
2. Can't ensure unstable completely;
3. Maybe bring some risk to your CPU, please take care;
4. Can't ensure OC on all of CPU;
Seems get some information only the fourth week in 2009 of CPU supports;
5. Due to the latest version CPU microcode can't support, so can't ensure recognize the correct CPU name;
Decode method:
1. This method is apply RS780D+SB750 board which was built in JHDP jumper;
2. JHDT jumper sets over_driver status after flash bios;
3. Sets advanced clock calibration to enable option in the BIOS setup;
Seufz. Aber um meinen 550er X2 freizuschalten benötige ich das unlock Bios oder? Fahre momentan mit dem 1.02er und weißt nicht, ob ein Update lohnt. Was genau bringt das Decimal Bios?
Also ich dachte immer ich bin gut in Englisch, aber entweder die sind grottenschlecht oder ich zu doof um es zu raffen :fresse::lol:
Also JHDT Jumper auf over_drive stellen und dann im Bios "advanced clock calibration" anschalten. Wofür auch immer das jetzt gut sein soll :hmm:
Das aktiviert anscheinend den Decode-Mode... fragt sich nur was und wofür der/das ist *?*
Oder Temperatur? Das J&W zeigt doch prinzipiell irgendwie keine echten Temps an, oder?
Also AOD liest irgendwie gar nix aus das einzige das vernünftige werte bis auf die cpu (X2 Brisbane)anzeigt ist Speedfan.
Temps von der Cpus mit Coretemp oder halt AOD. Den Rest: Finger dranhalten, wenns zu warm ist merkt man das :fresse:
Spannungen mess ich grundsätzlich nur mitm Multimeter.
Super Idee und morgen haben wir 20 Bilder von Leuten mit verbunden Händen :lol:
Wobei mein Ram im offen Aufbau aufm Schreibtisch vllt 40° maximal hat. Etwas wärmer als meine Finger :)
Und noch ne Sache: Im Bios hab ich den Takt manuell auf 4-4-4-12 gestellt, nach nem Neustart wird mir aber für den 2. Ram 4-4-4-10 angezeigt Oo
Der erste wird mit 4-4-4-12 angezeigt. CPU-Z gibt mir aber 4-4-4-12 an. Auslesefehler vom Bios? :confused:
MfG
Daniel
Kann das Board mehr als 1,55V Vcore?
Mit meinem 3800er ist schon bei 2.7 (1.55 V eingestellt) schluss auf dem alten Gigabyte waren 2.85 drin auch bei 1.55 aber ich glaube es liegt daran dass das GB stark übervoltet hat mit teilweise 1.60 V statt 1.55 V
Da sollte auch mehr als 1,55V gehen. Aber nicht bei cpu vid... da muss man wohl noch an paar anderen Einstellungen spielen ;)
Machs nich so spannend :d
Und wie hängt das genauer zusammen? Kommt schon Jungs, will das Board heut abend unter LN2 setzen auf der Benchsession :)
Multimeter an die VRMS dran und dann im Bios halt vid und svid override oder die anderen durchprobieren ;) und vielleicht vorher mal bischen rechnen nicht das es auf einmal 2V sind :fresse:
Kann es dir leider auch nicht so genau sagen an welcher VID Override du "Spielen" musst, da ich es selber nicht gebraucht habe...
Viel Erfolg bei deiner Session ;)
Chubaka
Servus,
Es klappt einfach nicht. Egal welche Verhältnisse oder was ich ändere (VID/SVID) ich komme einfach nicht über 1,55V! Kann das bitte mal wer nachstellen? Der SVID overide wird enfach ignoriert :(
