[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Sooo, Board und Kühler sind da, Bilder und Infos kommen gleich ;)
Bilder:
Northbridge - Spannungswandler - CPU
Für die Southbridge hat er keinen hin bekommen, der Platz ist zu eng. Ich als Laie bin der Meinung, das man mit etwas fummeln auch darauf einen bekommen könnte, Dieser wär dann aber auch der 2. GraKa für ein CF-System im Weg (Zumindest laut meinem Augenmaß ;))
Northbridge hat 1/4"-Gewinde, Spannungswandler 1/8"-Zoll.
Die Kühler werden pro Stück 32,90 kosten, sind aber noch nicht in seinem Shop gelistet.
Testen kann ich sie noch nicht, Bis mein PC inkl. WaKü komplett ist, dauerts noch etwas.
Und hier noch ein paar Impressionen wie es aussieht, wenn Daniel auf die glorreiche Idee kommt 2 PC´s komplett neu zu verkabeln:
1. Ich musste eine Person schwärzen.
2. Ich weiss... hässliche Wohnung :fresse:
MfG
Daniel
Räum mal deine Hütte auf :fresse:
Kühler sehen gut aus, auch wenn sie imho ein wenig das gute Design des Boards zerstören... weißer POM statt Plexideckel wär halt doch ne Nummer schöner... und beim CPU-Kühler würde ich lieber auf Altbewährtes setzen, die Phenoms werden zu heiß für Experimente...
Aufräumen ist morgen angesagt, immerhin is der ganze Kabelsalat verschwunden.. inkl. Ikea-Syndrom. Eine USB-Verlängerung ist übrig und ich weiss nicht wo sie war :fresse:
Ich wollte ursprünglich die Kühler beleuchten, deswegen Plexi, hab mich nun aber dazu entschieden sie bei Gelegenheit schwarz vernickeln zu lassen. Zusammen mit rotem Wasser.. Mal gucken wie es aussieht ;)
@Mr.Wifi
da hast du recht , ich hab vista64 drauf aber in einpaar tagen teste ich den oc nochmal unter xp32 und werd dann nochmal berichten, thx für den Hinweis.
@4th Floor
lieber schwarzer pom
@allgemein
habt ihr so schlechte temps das ihr das Board unter wasser setzten müsst oder macht ihr das wegen der optik?
Ich hatte noch n anderes am2+ board mit nem 790fx chipsatz hier und da waren die temps gigantisch im vergleich zu dem hier.
Ich machs aus optischen und silent gründen.. Naja ok, meine geplanten Kreisläufe werden nicht sooo leise sein, aber mal gucken ;)
Hauptgrund ist aber die Optik.
Na wo ist denn das Silent cool Schild auf den neuen Boards abgeblieben ? :d
Farblich gefallen mir die "neuen" Boards nicht wirklich, das Fusion scheint ein Extreme zu sein mit DDR3 Unterstützung, naja wers brauch...
Ich freu mich schon auf die Temps. Das negative sind die 1/8" Anschlüsse :(. Was haben die SB- und SpaWa-Kühler gekostet?
NB und Spawa, nicht SB und Spawa.
Die Kosten möchtest du nicht erfahren, da es ne Neuentwicklung war ;)
Werden aber jeweils 32,90 im Shop kosten, wenn verfügbar.
Wegen der 1/8 Anschlüße hab ich schon ne Idee... wird aber nicht verraten ;)
Spart 50cent in der Produktion und bringt uns 2°C weniger auf dem Board :d
Also mein Fall sind die neuen Bretter auch nicht, die SATA Anschlüsse sind mal richtig Banane...
naja wers brauch...
Eben :fresse:
Immer noch besser als die grauenvolle Leiste mit zwei Anschlüssen übereinander, wo kein Stecker richtig einrastet :-[
Eigentlich ganz nett die Idee, DDR3 auch mit älteren AM2+ CPUs nutzen zu können...
Schade, bei mir sitzt alles gut...
Die Idee ist in der Tat gut aber nicht neu und die Umsetzung also das Layout ist halt Geschmackssache.
Nach wie vor liebe ich mein 790GX-XTRM :d
Irgendwie kotzt es mich grad voll an das das Board nur 2x8Lanes hat -.-'
Aber es ist auch das einizg gute Board das gut aussieht... Scheissedreck ey :/
Sachtma bin ich zu doof zum suchen und lesen?
gibts irgendwo ne Anleitung welche Werte und Spannung man bei der CPU und Nb einstellen sollte zum verlässlichen Übertakten? Also nicht die Hex-Tabelle, sondern Beispiele die nicht gleich bei 4GHZ liegen?
Hab mein User Bios zerschossen:mad:, da tut sich nix außer, dass das DVD Laufwerk ständig nen Geräusch von sich gibt, Bildschirm dunkel. Mitm Safe Bios ist alles ok und Rechner bootet ganz normal, leider funktioniert diese Dual Bios Recovery nicht bei mir, es tut sich nix Bildschirm ebenfalls dunkel, nur Laufwerksgeräusche. Hat wer ne Idee, wie ich das wieder hinkrieg?
Bios Baustein umstecken und Hot Flash im Windows?
Ich versuchs mal
e: hat nicht geklappt, immer wenn ich den jumper umstecke startet der rechner neu, kann aber logischerweise nicht hochfahren da das user bios zerschossen is :(
Sehr schlecht :/
Entweder bei ebay neues Bios ordern oder beim Support anfragen ob Sie das so tauschen ohne gleich das ganze Board einschicken zu müssen.
Hmm dann lebe ich halt damit nur noch ein "einfaches" Bios zu haben und kein Dual Bios mehr und spiel nich mehr herum.
Wie hast das überhaupt kaputt bekommen?
Beim Flashen ist der Rechner gefreezt. Mich wundert nur, dass dieses Dual Bios recovery Zeugs da nicht funzt.
Na son Mist.. hatte das Problem noch nicht fällt mir grad auch nichts zu ein wie das gehen könnte.
hast ihn übertaktet geflasht?
Nee da war alles @stock, nur Ram Timings, Takt und Spannung richtig eingestellt gehabt. Hab mich mittlerweile damit abgefunden, is zwar ärgerlich, hätte aber schlimmer kommen können.
Je nach Bios Version auf Dual Channel umstellen, ist wie beim Flashen. Da musst du auch erst im Bios die Write Protection Disablen.....
Einer ne Idee, warum ich nicht vom USB Stick booten kann? Ging bisher an jedem Rechner :-/
Aus'm Kopf kann ich es dir nicht sagen aber beim Asus musste ich dafür auch eine Funktion im Bios Enablen...
Es macht 2x 2x Peep, Eiert ewig bei Detecting USB Mass Storage rum und macht dann trotzdem nix. Nach 2 Minuten gehts dann weiter... (POST 78)
Das Board wirds doch wohl schaffen von USB zu booten.
Hmm wenn der Stick bootfähig ist (angeblich läufts an anderen Rechnern ja) dann müsste man den im Bios nur noch als Bootlaufwerk auswählen und es sollte gehen.
