So hab ein programm gefunden das monitor daten ausliest allerdings kann ich da nichts versprechen
hier die auswertung, firmware 1.49 ob das stimmt keine ahnung !!!
Monitor
Model name............... 29EA93
Manufacturer............. LGE
Plug and Play ID......... GSM5974
Serial number............ n/a
Manufacture date......... 2012, ISO week 27
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 670 x 280 mm (28,6 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Supported
MCCS revison............. 2.0
Display technology....... TFT
Controller............... STMicro 0x0
Firmware revision........ 1.49
Firmware flags........... 0x0000FFFF
Active power on time..... 47 hours
Power consumption........ Not supported
Current frequency........ 66,60kHz, 60,00Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,651 - Ry 0,332
Green chromaticity....... Gx 0,307 - Gy 0,631
Blue chromaticity........ Bx 0,150 - By 0,060
White point (default).... Wx 0,313 - Wy 0,329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-90kHz
Vertical scan range...... 56-75Hz
Video bandwidth.......... 240MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 2560x1080p at 60Hz
Modeline............... "2560x1080" 185,580 2560 2624 2688 2784 1080 1083 1093 1111 -hsync -vsync
Detailed timing #1....... 1920x1080p at 60Hz
Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1152 x 864p at 75Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1600 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #2....... 1920x1080i at 60Hz
Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #3....... 1280x720p at 60Hz
Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #4....... 720x480p at 60Hz
Modeline............... "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
640 x 480p at 60Hz - Default (4:3, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 03.04.2013
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0100
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,1E,6D,74,59,01,01,01,01,1B,16,01,03,80,43,1C,78,EA,CA,95,A6,55,4E,A1,26,
0F,50,54,A5,4B,80,71,4F,81,80,81,C0,A9,C0,B3,00,01,01,01,01,01,01,7E,48,00,E0,A0,38,1F,40,40,40,
3A,00,A5,22,21,00,00,18,02,3A,80,18,71,38,2D,40,58,2C,45,00,A5,22,21,00,00,1E,00,00,00,FC,00,32,
39,45,41,39,33,0A,20,20,20,20,20,20,00,00,00,FD,00,38,4B,1E,5A,18,00,0A,20,20,20,20,20,20,01,30,
02,03,1D,F1,4A,90,04,03,22,14,12,05,1F,01,13,23,09,07,07,83,01,00,00,65,03,0C,00,10,00,02,3A,80,
18,71,38,2D,40,58,2C,45,00,56,51,21,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00,56,51,21,00,00,
9E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,56,51,21,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,56,
51,21,00,00,18,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,78
