[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So, hab auch endlich meine bekommen. Muss leider noch bis Montag warten bis ich sie einbauen darf. :sneaky:
Die 4090 hat übrigens ECC, wobei sich beim Aktivieren die Bandbreite um ca 100 GByte/s reduziert.
Bei nur +45MHz wird wahrscheinlich nichts selektiert. Das schafft die grottigste GPU
Anderes BIOS drauf und fertig - zack 300€ mehr Deppenzuschlag kassiert
jede karte wird zwischen fertigstellung und kartonage getestet. kaputte werden zurückgestellt, gute werden OCs. alle anderen bleiben normal. wüsste nicht wann das geändert haben soll. ich kenne den prozess aus videos, die ich vor jahren mal gesehen habe. da sitzt niemand und flasht irgendwas hin oder her.
tobi
Da ist nur die halbe Wahrheit …
OC Chips sind selektiert. Allerdings gerade bei den Releasemodellen ist das selektieren nicht sehr zuverlässig. Da sind noch wenig Erfahrungen vorhanden da das selektieren nicht nach Einbau erfolgt, sondern bereits davor werden Spannungen und Widerstände gemessen der Chips gemessen.
Diese (Spannungen und Widerstände) werden u.a. Auch ermittelt anhand der Testkarten zu beginn in der Testphase. Manchmal kommt es vor das auf Grund der gesammelten Erfahrungen bei realen Karten diese Werte noch angepasst bzw. Besser selektiert werden kann.
Zumindest war es mal so bzw. habe ich das mal irgendwo gelesen.
bin Zuhause. Kann aber nicht testen. Da ohne Gehäuse die Karte nicht hält. xD
Muss ich doch bis morgen oder nächsten Donnerstag Warten je nachdem wann das Case kommt.
Nein bei mir nicht, oder ich habs noch nie gemerkt? Sieht doch gut aus.
Shared Memory Support nur 12 Stunden. Und den brauche ich für Afterburner und HWINFO Monitor. Ok, dann muss ich jetzt mal updaten.
Falls jemand die blöde LED abschalten kann, bitte melden :ROFLMAO:
Icue klappt bei mir schonmal nicht. GPU Tweak auch nicht.
Du brauchst Amory crate von asus. Setzt dir dafür eine 2te windows instanz auf Sonst müllt du alles zu.
Kann die im AB auch nicht freischalten max liegt laut hw monitor bei 1.050 V ...
Braucht es da noch eine neue AB Version?
4.6.5 Beta 2 ist die neueste Version.
Standard sind 1.050V, wenn ich den Regler (der bekloppterweise eine Prozentgabe hat) ganz nach rechts schiebe, komme ich auf 1.1V, aber das bringt halt nicht sehr viel, das sind nur zwei Taktstufen.
12 Stunden am Stück... is der Rechner dazwischen aus ist doch alles fine
Zumindest hat mein OSD und die Sensoren immer funktioniert... ohne dass ichs jemals von Hand neu gestartet hab, aber ich mach den PC auch aus und hab Fast Startup deaktiviert, er startet also immer richtig.
Unten drunter so wie ich das auf dem Bild farblich markiert habe
Danke . Bilder sagen mehr als tausend worte. Ich hatte nun 2 Jahre das P8 Kabel am PCIe3. Lief allkes. Hatte gerade geguckt und dachte mir, dass das P8 Kabel unten in deine grüne Zone nicht passt. Keine Ahnung was los war. War wohl zu hektisch. Jetzt habe ich 3x Pcie frei und alle 4 Sträönge an der Tuf und die lässt nun ein Powerlimit von 133% zu :-)
Danke
Meiner ist immer nur im Standby. Deshalb laufe ich in das 12 Stunden Limit.
Das P4/P8 KJabel passt ja nur in einen der 3 PCIE Buchsen? Wo soll es sonst hin?
BeQuiet hätte sich etwas mehr Mühe bei der Bedienungsanleitung geben können.
War bis gerade noch der Überzeugung, dass die MB-Stromversorgung zwingend am gekennzeichneten Anschluss erfolgen muss.
Danke
Gerne, nichts zu danken :-)
Die Suprim ist angekommen, erste Eindruck, tolle Leistung wie erwartet.
Aber was mich stört, die Verarbeitungsqualität und zwar sind ein paar Kühlfinnen nicht so sauber gefräßt, ist jetzt kein krasser Makel, aber für 2250 Euro erwarte ich perfekte Qualität
Außerdem ist es ja das Top-Modell von MSI
Hab die Gamerock von Palit als vergleich dagehabt, hab diese heute wegen einem Freund der Sie haben wollte aus der Packung genommen, und die Qualität vom Kühler ist wirklich 1A.
Aber was mir jetzt schon auf den Zeiger geht ist das Spulen-Rasseln.
Da Hilft auch das Silent Bios nichts, was bringt es mir wenn ich bei jedem Spiel ein rasseln höre anstelle des Lüfters (Welche ja schon gut sind) :fresse:
Meine 3090 TUF OC war dagegen Ultra leise und kaum hörbar.
Wie ist es bei euch?
Hat jemand von euch mit der Suprim X schon die RGB Steuerung hinbekommen? Dieses MSI Center will, wenn ich dort Mystic Light installiert, habe meine GPU anscheinend nicht erkennen. Ich bin mir nicht mal sicher ob Mystic Light richtig installiert ist. Total blöd das man da extra dieses Center für braucht. Eine separate RGB Steuerung wäre besser gewesen.
Hab ich auch heute versucht. Die MSI Software ist ja die absolute "Pest". Hab auch nur Mystic Light installiert und wenn ich's startete kam nur live update bla??? Irgendwann ist es aber auch "red" umgesprungen, keine Ahnung. Passt zum Rest. Hab die Software dann direkt wieder runtergeschmissen......iiiiiibääääää. Standalone Mystic Light funzt ja leider nicht mehr.😕
Wäre halt sinnbefreit das Mainboards Powerkabel nicht an den dafür vorgesehenen Buchsen einzustecken ,weil sonst die 12V2 Schiene gar nicht belegt ist und man unnötig die PCIe Schienen mit belastet
Ich hab damit scheinbar auch nie Glück die TUF non-OC singt in Benches ordentlich, in Games ist es leiser, praktisch wie die 6800XT davor auch, hab beim spielen aber immer Kopfhörer auf dem Schädel.
Hab ich auch heute versucht. Die MSI Software ist ja absolute "Pest". Hab auch nur Mystic Light installiert und wenn ich's starte kam nur live update bla. Irgendwann ist es aber auch "red" umgesprungen, keine Ahnung. Passt zum Rest. Hab die Software direkt wieder runtergeschmisse......iiiiiibääääää. Standalone Mystic Light funzt ja leider nicht mehr.😕
Wie ist es bei dir mit dem Spulen-Rasseln/Fiepen?
Also lt MSI Marketing soll ja was verbessert worden sein, ich merk davon nix XD
Ja schrecklich … sehe ich auch!
Vielleicht zur 3090TI weil die hatte bei mir rasseln die 3090 war super!
Die sind morgen Abend wahrscheinlich schon wieder zurück. Die Marktsitation lässt es zu, dass man kostenlos selektieren kann. Und andere freuen sich, dass sie die Karten zum EK bekommen. Win Win :)
Jo, wie gesagt hätte ich die Zeit würde das bei mir auch so laufen :-)
Weiß jemand ob man Softwareseitig prüfen kann, ob Silent oder Performance Bios ausgewählt ist?
Hab gerade mal bei der Gainward geswitched und wollte einfach mal checken ob das übernommen wurde.
Die Aorus Master scheint wohl keiner bekommen zu haben?
Hier im Forum sehe ich auf Anhieb nix und auch auf YT testet die bis auf der Bauer kaum wer.
Gabs die nirgends in DE?
Ist nicht meine Wunschkarte, aber zumindest einmal würde ich gerne diesen "Berg" von Karte (4,3 Liter Volumen) in den Händen halten :-)
Ähnliche Themen
Antworten
5K
Aufrufe
308K
