[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wie schneiden die Gigabyte Modelle ab mit Spulenfiepen? Erfahrungen?
Meine Liegt neben mir und ich will sie testen aber sonst bricht mir der PCI-E Sockel vom Board ab .D
4.6.5 Beta 2 ist die neueste Version.
Mit der geht es, die leichte Erhöhung der Spannung per AB :-)
Noch eine blöde Frage:
Ist 108% PT Erhöhung via AB für die Supreme X das normale Max ??
mein ich hätte mit dem Silent Bios 113% gehabt bin dann mal auf das Gaming Bios gegangen = 108% Max ...
Läuft seit Ewigkeiten ohne Probleme.
Ich glaube ich stecke das Kabel morgen mal um.
Ich muss leider meine Aussage bezüglich Spulenfiepen der Suprim X korrigieren.
Mir ist im Benchmark aufgefallen, dass die Leistung nicht passt...Grund war, 2 der Powerconnectoren saßen nicht richtig.
Jetzt passt alles und die Karte ist leider was Spulenfiepen angeht extrem unangenehm.
Selbst bei 70% Powertarget dreht die in 3DMark ab 140FPS regelrecht durch. Bei über 200FPS wird es mega ekelhaft.
Schade. Jetzt fängt wie bei der 30er Serie wieder das Selektieren an. Zum Kotzen. o_O
So, endlich zuhause. :d
Habe mit der FE etwas experimentiert.
Untervolting: 975Mv bei 2835mhz und +538MHZ Speichertakt
Bin mit den Punkten Speedway von 9800 auf 9939 und ungefähr 60 Watt weniger verbrauch.
Meine Suprim X kam heute auch an, kann erst morgen mit dem Umbau beginnen, da kein Platz mit der aktuellen Pumpen-Kombi :rofl:
Die EK-Quantum Kinetic TBE 120 DDC kommt leider erst morgen mit DHL....
Falls jemand die blöde LED abschalten kann, bitte melden :ROFLMAO:
Icue klappt bei mir schonmal nicht. GPU Tweak auch nicht.
dann ist bei dir sicher etwas mit der software kaputt. alles von asus deinstallieren (afair gabs sogar im netz dafür einen uninstaller) und dann die armoury crate software neu installieren. das selbe machst du mit icue und dann müsstest du auf dem selben stand sein wie ich. hier wird die graka ganz normal von icue erkannt und kann gesteuert werden.
Asus RTX 4090 TUF Gaming OC, Win11, iCue und Armoury Crate installiert (aktuelle Version)
tobi
Der Asusshop hat meine jetzt gerade rausgeschickt. Kam die bei euch amnächsten Tag an? 20Uhr is ja schon etwas spät, wär aber sehr sexy wenn sie morgen schon ankommt. 🤔 (Standard DHL)
Habe seit heute die Gaming OC verbaut. Sie singt ein wenig, aber hält sich noch in Grenzen bei geschlossenem Case.
Die Leistung ist einfach brachial, ich bin immernoch hin und weg.
+200/+500 ohne Probleme, erreicht damit die 3ghz und war bisher stable in ~3 Stunden Cyberpunk. (Wo bleibt das Cyberpunk update für DLSS 3.0 und RT Overdrive?!)
Werde allerdings definitiv undervolten für 24/7, die Effizienz ist einfach nur abartig!
Habe seit heute die Gaming OC verbaut. Sie sing ein wenig, aber hält sich noch in Grenzen bei geschlossenem Case.
Gaming OC ist zur Windforce viel Unterschied? Ich wollte meine mit 70% laufen lassen. Mich ärgert es so das ich alles zusammen bestellt und wurde angeblich zusammen verschickt. Das Gehäuse soll jetzt 2 Tage länger dauern. Und dann bin ich eine Woche weg :( hab sie aber trotzdem schon ausgepackt. Jetzt ist sie nicht mehr neu :x
Oh jeh, das macht mich etwas stutzig! Wollte eigentlich auf die Suprim warten, da die 3090Ti Version echt super ist, aber wenn ich das höre! Irgendwie bin ich gerade total unsicher, welche man kaufen "kann/sollte"!
Hat einer mal eine Zotec geholt?
Wie verhalten die sich so vom Lüfter her und fiepen usw.🤔
Das kommt darauf an ob DHL dich mag oder nicht. Mich mag DHL nicht. Meine Karte ist heute Nacht um 1 Uhr hier bei mir um die Ecke gelandet und das letzte Update war um 6 Uhr das die Verladung ins Zustellfahrzeug ist. Passiert ist nichts. Karte nicht verladen, wird morgen erst klappen.
Ist aber auch nicht wild da ich sowieso arbeiten war und selbst annehmen will statt ablegen und zusätzlich eine Inno3d X3 OC inklusive Wasserblock bestellt habe. Ich glaube nur das ich nicht warten kann bis Montag :d
Brauchst du tatsächlich 200pfs zum Zocken?
Hast du die Möglichkeit das NT zu tauschen (zum Test kurz ein Anderes anschliessen)
Meine 4090 FE ist angekommen und ich kann die Frage beantworten, wie viele Karten NBB hatte: 200.
Steht außen auf der Verpackung (Package count: XXX of 200), Total Delivery Quantity: 200.
Äußert interessante Info aber ich kann mir das einfach nicht voorstellen. Vielleicht 200 für den gesamten europäischen Markt (und NBB hat den Teiol bekommen auf dem noch der Zettel klebte) oder es war die Gesamtzahl aller 4090 incl Customs die NBB da hatte. 200 FEs für Deustchland alleine, das hätte doch länger als knapp 2 Minuten gereicht.
Danke für den Bericht, gut zu wissen, werde mal drauf achten. Bin ich zwar nicht empfindlich für, aber für ein paar Benchläufe würde mich das so oder so nicht stören. Im Praxisbetrieb regel ich meine Karten knapp unter 120FPS ab, mehr kann mein OLED nicht und mehr brauche ich auch nicht, überschüssige Leistung wird in Bildqualität investiert oder spart Energie.
Mit Glück kommt das noch dieses Jahr zu Weihnachten schätze ich mal. Mit ganz viel Glück zusammen mit dem 4080er Release, Die wollen eine ganze Reihe neuer Beleuchtungseffekte zusammen mit DLSS3 bringen, sowas baut man in diese Engine nicht mal eben schnell ein. Das dauert.
Und weiter gehts mit selektieren :)
Morgen kommt noch eine und dann reicht das erstmal. Ich darf das Kabel ja nur maximal 30x rein und raus stecken 😂
Und auch noch stolz darauf,... man könnt im Viereck kotzen. ;-)
Ja gut was heißt high fps ?
Timespy, 200+
Grad bisschen Forza gezockt da hängt sie zwischen 120 und 160 fps da gehts einigermaßen, Case ist noch offen.. Am Ende nehmen sich alle 4090 nicht viel, die fiepen alle.
Suprim X incoming... :-)
Fr, 14.10.2022, 16:35,
Die Sendung ist in der Region des Empfängers angekommen und wird im nächsten Schritt zur Zustellbasis transportiert.
Hatte mal jmd eine 3000er-Suprim?
Konnte man da ein markenfremdes BIOS flashen?
Ähnliche Themen
