[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Selber "Plastik-Schrott-Kühler", mit billig Fans wie schon bei der 3090 Ti.....
Am geilsten wär jetzt noch, das die die Waterforce nur mit WB vorstellen würden.
Bisher hat außer Inno kein Hersteller eine mit WB vorgestellt oder?
Ziemlich dünn leider die Auswahl.
Bisschen enttäuscht muss ich sagen .
Hätten bei so einem Monster ruhig mehr vorstellen können.
Hoffe bekomme eine FE irgendwie und kann zur not den EKWB nehmen , wenn mir das zu lange dauert mit WC.
Man weiß ja wie das ist und man möchte schnell wieder ruhe im System.
Bin mal gespannt wie es mit der Verfügbarkeit ist. Würde auch eine Strix nehmen bzw. ist zweite Wahl .
Ansonsten wenn beides nicht funktioniert werde ich erstmal abwarten müssen :(
Scheiß Spätschicht zu Release....
Das Problem mit der Spätschicht habe ich auch, ich mag die Spätschicht lieber als die Frühschicht. Aber nicht in der Woche....
Und bei mir soll es entweder die FE oder die Inno3d (auch wenn hier davon anscheinend abgeraten wird) werden.
Inno3d hat sich bisher nicht als besonders tollen Hersteller präsentiert.
Dann kannst auch eine FE oder Ref. Karte nehmen für bis 2000 € und nimmst den Block deiner Wahl.
Raten kann man es jedem dennoch die Karte mal on Air erstmal zu verbauen und ausreichend zu testen.
Dann ausbauen und umbauen. EVGA ist ja leider nicht mehr da . So ist zumindest mein Plan.
Mir wäre eine Asus mit WB am liebsten gewesen , weil ist was an einer Asus Karte was , dann schickst die ein und der
Händler leitet es an Asus weiter und man bekommt meistens einfach sein Geld oder eine neue Karte.
Nicht irgendeine Lösung mit Credits oder wenn der WB risse bekommt ist man selber schuld oder man
bekommt gleich eine Karte wie bei der 3090 wo die falschen Pads drauf waren oder welche gefehlt haben.
Ne meiner einschätzung nach ging bei Inno3d bei der letzten Gen. einiges schief und Leute die Turing besaßen,
hatten auch ihren "Spaß" mit Inno3d. Ne da kann ich gleich auf Garantie scheißen und suche zumindest eine Karten mit
guten PCB und verarbeitung und kümmer mich um die Kühlung selber , wenn es halt kein anderer anbieten möchte.
Bei Gigabyte muss man erstmal schauen , wenn dann mal was kommt.
Die haben den WB von der 3000er verkackt .
Hatte selber die von 1080 TI und 2080 TI.
Die von der 1080 TI war wirklich top und 2080 TI ging noch, aber fande den schon schlechter.
Das Custom PCB war bei beiden Karten ziemlich gut , aber die 2080 TI war stark von Spulenfiepen betroffen.
Der von der 3000er war eigentlich kein richtiger Fullcover mehr soweit ich weiß und war froh , dass ich den WC HKV gekauft habe.
Allerdings hat man bei der 3090 Ref. nicht mehr so Spielraum , wenn man bisschen testen will, allerdings kaum probleme mit den Spulen.
iwie scheint mir Gigabyte keine Fortschritte zu machen :(
Qualitativ sehe ich da nie einen großen Sprung. Hatte mich damals bei der 3080 schon gestört. Diese Stromversorgung mit Verlängerung war furchtbar.
Zum Thema DLSS.
Ich finde es keine schlechte Sache per Software mehr FPS herzuzaubern. Allerdings messe ich die Karten immer an der "Rohleistung". DLSS ist für mich teils einfach unschön.
Man muss ja immerhin gute 1000€ jetzt draufzahlen um +/- 50% Mehrleistung ohne DLSS zu bekommen. Verbesserungen in der Software sind natürlich super. Allerdings möchte ich natürlich bei einem Hardwarehersteller auch bei der Hardware Verbesserungen sehen und dafür bezahlen ich ja schließlich. Nicht dass Nvidia iwann auf die Idee kommt die gleiche Karte nur mit besserer Software zu verkaufen^^
Ich bin zwar ordentlich gehyped von der 4090 und "träume" noch weiter von 100% mehr Leistung (ohne DLSS). Aber überlegen werde ich es mir ggf doch nochmal... 2000-2500€ sind doch ordentlich
Das Marketing funktioniert auf jeden Fall gut. Nach der Vorstellung war ich 200% dabei. Jetzt wo das mit DLSS klarer wird noch 90% :-)
Ich denke man sollte die Tests auf jeden Fall abwarten, da immer alles overhyped angepriesen wird. Ich bin mit meinem System auch in keinem Zugzwang und war vom 13900k auch bisher enttäuscht und da es sowohl nen 13900KS Anfang nächsten Jahres und sicher auch eine 4090Ti und eine Titan geben wird, warte ich wirklich dieses Mal ab, was die Tests sagen!
EVGA wird bestimmt wieder kommen. Bei 80% des Jahresumsatz war auf grafikkarten zurückzuführen ist. Bleibt EVGA zwei Möglichkeiten.
1.pleite oder 2.back to nvidia
Hey Leute
Ich hab mir mal die Arbeit gemacht und die momentan bekannten 4090 Modelle mit dem Alphacool Waterblock für das Ref Design verglichen.
Hier mal ne Liste welche Modelle nach visuellem abgleich das Ref Pcb nutzen :
Ref pcb inkl Garantie bei Kühlerwechsel :
-KFA2 GeForce RTX 4090 SG
Ref pcb ohne Garantie bei Kühlerwechsel:
-PNY GeForce RTX® 4090 24GB XLR8 Gaming VERTO
-Inno3D GeForce RTX 4090 ICHILL X3
-Inno3D GeForce RTX 4090 X3
-Palit GeForce RTX 4090 GameRock
Da noch keine Bilder der nackten Platinen verfügbar sind habe ich Bohrungen und position des 12vhpwr zum abgleich verwendet.
Asus, Msi, Gigabyte und co scheinen alle custom pcbs zu nutzen….. auch bei den günstigsteren Modellen. Soweit das verfügbare Bildmaterial auch wirklich dem Endprodukt entspricht
Die Palit Gamerock hat auf der Rückseite einen BIOS Switch, vermutlich eher kein Ref PCB
Kommt drauf an ob der Hersteller noch Kleinigkeiten auf dem pcb ändern kann. Alphacool hat vom pcb zur backplate einen 3mm Abstand. Genug Platz einen switch unterzubringen ohne dass es Probleme mit dem Kühler geben sollte
Ich gehe auch davon aus das die KFA2 GeForce RTX 4090 SG ein Referenz PCB hat. Aussage zur Leistung fand ich ganz interessant. Damit wäre die Frage ja auch geklärt ;)
  1. PSU with native 450W PCIe Gen5 16-pin power connector, or minimum 3x PCIe 8-pin power connectors (use with included adapter)
    *450W PCIe Gen5 16-pin power connector or 3x PCIe 8-pin power connector when running in stock (450W TGP). For overclocked settings beyond 450W TGP, 600W PCIe Gen5 16-pin power connector or 4x PCIe 8-pin power connector will be required.
Auf dem ref pcb wäre auf jeden fall genug Platz fürn Bios Switch
Die Kfa2 ist auf jeden Fall dann das Interessanteste Modell wegen Garantie bei Kühlerwechsel 😅
Denkt ihr ne 4090 FE wird zu bekommen sein? Werdet ihr Mehrfachbestellungen aufgeben (also auch andere Modelle aus diversen Shops versuchen)?
Nach letztem Jahr traue ich Nvidia nicht so recht. Den Benachrichtigungsbutton kann man denk getrost vergessen. Der benachrichtigt vermutlich erst wenn alles verkauft ist^^.
Am 12.10 15 Uhr solls losgehen. Gibt's da schon wieder eine PartAlert Gruppe?
@SH loht es sich ggf schon mal eine Liste der Shops in den 1. Post zu hängen?
Aktuell listen folgende Shops die 4090
- NBB
- Proshop
- Caseking
Bei der Karte Könnte ich Schwache werden. :coffee2:
Lg
Auch wenn die olle 240er AiO drauf bleibt?
Das Bild zeigt, dass nur die GPU gekühlt wird aber die umliegenden Komponenten nicht, anders wie bei MSI z.B.. Ich hatte mal eine Waterforce 2080Ti, welche zwar gut gekühlt hat aber die umliegenden Komponenten sowie die Backplate wurden kochend heiß.
Echt seit wann ist das bei KFA so gibt es da was schriftliches.
Ähnliche Themen
