[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das dürfte schon hinkommen mit dem Render. Erkennt man gut bei dem Bild für die Backplate.
Ist doch ein gerendertes Pic. Wer weiß, ob es diese Löcher überhaupt real geben wird
wobei sich Zotac auch bei Ampere gedacht hat, wir nehmen zwar grundlegend das Ref-Layout, machen die Platine aber 10mm länger.
Und Inno3D hat sich gedacht: Was Zotac kann, können wir schon lange. Wir machen das PCB aber einfach 14mm länger als Ref.
Ich denke, dass der Leistungssprung der RTX 4090 wird insgesamt der größte sein von den letzten Generationen.
Jop, größter Sprung seit Pascal :)
Es gibt einen ganz einfachen Grund, warum es so etwas nie geben wird, bzw. geben sollte:
Mit jedem zusäztlichen Steckkontakt gibt es eine zusätzliche Stelle mit erhöhtem Widerstand (im Vergleich zu einer Leitung ohne Trennstellen).
Auch ist es eine zusätzliche Stelle, die aufgrund von An/Absteck-Vorgängen "ausleiern" kann, was zu einer weiteren Erhöhung des Widerstandes führt.
Und bei einer Karte, die maximal 600W darf, ist so etwas halt relevanter als bei einer Karte, bei der nur 225W zugeführt werden müssen.
Weil das ein Thema ist, gibts halt auch keine Karten wie die Umsetzung von Gigabyte bei Ampere (Verlängerungsleitung vom PCB zum Ende des Kühlers).
Auch gibts Stand jetzt keine Karten, bei denen das PCB insgesamt verlängert worden ist. Auch hier müsste der Strom dann ja noch durchs PCB fließen, was auf dieser Länge weitere Verluste bedeutet.
Bei der Art der Leistungsgebrenzung, wie es nVidia verwendet, würden solche Verluste am Budget von GPU/VRam knappern.
Solange keine luftgekühlte Karte kommt, bei der der Luftkühler mit dem kurzen PCB endet, wirds halt auch keine Karte geben können, bei dem der Stecker nach hinten weg geführt ist.
Hab absolut kein Problem mit dem kurzen PCB . Hat mich bei der 3000er auch nicht gestört . Finde sieht sogar schicker aus , wenn es am ATX Board abschließt.
Für Luftkühler sehe ich auch nur Vorteile.
Es gibt neue Bilder von ASUS für die Strix
4x 8Pin und ein Kartenhalter ist mit dabei. Sogar ein Schraubenzieher :d
Als Vergleich die 3090 STRIX
Was wohl das mit den 3 Löchern ist? Sieht aus, als könnte man es abmachen. Und 2 Lüfter anschließen geht auch. Top
Passt die Strix eigentlich in ein Lian Li O11 Dynamic Razer? Finde leider keine Daten zur maximalen Breite im Gehäuse. Es war aber auch schon eng mit einer evga 3090.
Wenn ich mir die Strix so an sehe, fürchte ich, dass man zwei Leute für den Einbau braucht!?
die 4090 FE bei NBB "Artikelseite" wird vermutlich erst am 12. um 15h zu finden sein gehe ich mal von aus.
weis jemand ob das dann wie bei der RTX 30 über den Link bei Nvidia bekannt wird ?
oder hat jemands bereits eine ID für NBB :fresse2:
Üblicherweise kamen die Seiten meist schon am Vortag online, nur halt ohne öffentliche Verlinkung.
Haben andere Karten auch (auch schon in der Vergangenheit). Da kann man einen Halter anschrauben, der dann in eine entsprechende Aufnahme vom PC-Gehäuse gesteckt wird. Wenn man das so nutzt, hängt dann auch nichts durch.
Ähnliche Themen
