[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kühlerwechsel ist bei kfa2 immer noch kein Grund für Ablehnung der Garantie. Muss in den Garantiebestimmungen extra aufgeführt sein. Habs kurz überflogen….. alles safe, nur biosflash ist ausgenommen
Und hier nochmal:
Und hier nochmal:
Ich trau der Liste nicht. Letzte Update ist von 2020 in 2 Jahren kann viel passieren.
In dem Moment wo Dein Netzteil abschaltet, machste Dir Gedanken um ein neues.
Nicht immer vorher.
Warum macht ihr das nur?
Interessant aber definitiv nicht meine Philosophie. Wenn eine Schutzschaltung mir den Arsch retten muss dann habe ich entweder vorher bereits etwas falsch gemacht oder Pech gehabt und muss mich dann auf das Glück verlassen, daß sich nicht doch noch eine Spannungsspitze zu meiner Hardware durchkämpft. Das ist nichts für mich.
Ich bin zudem jemand der immer mit Reserven arbeitet, auch beim Netzteil, es gehört für mich zu den wichtigsten Teilen in einem PC. Instabile Stromversorgung und man jagt Fehler die nicht da sind und ärgert sich mit Abstürzen herum. Daher sind meine Netzteile immer möglichst hochwertig, mit langer Garantie und ausreichend Reserve. Und wenn es sich dem Ende der Garantiezeit nähert, schaue ich zumindest schon mal ob es nicht vielleicht etwas moderneres gibt. Nur weil das Netzteil erst mal nichts zur Performance beiträgt, heißt es für mich nicht das es nachrangig wäre. Und je näher an der Maximallast, desto höher die Wahrscheinlichkeit für Ausfälle. Beim OC nehme ich das natürlich in Kauf (wobei ich auch da immer ein wenig von der Maximalgrenze wegbleibe) aber die Energieversorgung muss Reserven haben, damit nicht plötzlich noch Probleme beim OC bekomme weil dem Netzteil die Luft ausgeht.
Aber auch ich habe keine Lust zu jeder Aufrüstung das Netzteil zu tauschen, daher lege ich die Reserve da großzügiger aus damit es länger hält. 7-10 Jahre sind da ein guter wert für mich. Mein aktuelles Netzteil dürfte keine Probleme mit einer 4090 haben.
Denkt ihr ne 4090 FE wird zu bekommen sein?
Kommt darauf an wann Du eine bekommen willst. Am Releasetag bzw. in der Releasewoche? Schwierig. 1-2 Wochen später ? Kann ich mir gut vorstellen. 1-2 Monate später? Sehe ich keine Probleme.
Und wenn der Verkauf am 12.10. um 15 Uhr startet, dann brauchts Du auch keinen Benachrichtigungsbutton eigentlich, ist doch schon klar wann es losgeht. Hat man es eilig, dann wird man so oder so aud den Shoppages rumhängen und die F5 Taste mißhandeln müssen. Ich würde aber so lachen wenn am 12.10. plötzlich unerwartet alles rund läuft und es genug für alle gibt und all die Aufregung umsonst war ;) Nicht daß ich das wirklich glaube, aber ich denke reinsteigern macht auch keinen Sinn.
Naja aber genau dafür ist die Schutzschaltung da. Wenn da irgendwas abrauscht, dann war die Schutzschaltung Schrott.
Ich persönlich werde jetzt, wo gerade ATX 3.0 vor der Tür steht, jedenfalls kein neues ATX 2.x mehr kaufen. Also wird erstmal die Kotzgrenze beim 850W ausgelotet und dann gibt es ein neues, wenn endlich mal Corsair oder sonst ein Qualitätshersteller mit einem digitalen ATX 3.0 PSU um die Ecke kommt.
Was mich dieses Mal etwas stutzig macht ist das es bis heute noch keine leaks gibt gerade der ferne Osten hat sonst immer mal was gezeigt zumal es dort Karten schon zu kaufen gibt.
Gibt schon einen 3DMark leak mit der 4090. Gibt schon einen Geekbench CUDA test Score. Es gibt die realen Performance Leistungen von Digital Foundry mit DLSS3 und auch mit RayTracing. Und es gibt die eigenen Benchmarks von NVIDIA :) was willst du gerne noch haben? 😃
Sehe ich ähnlich, mal schauen wie mit Seasonic 850 Watt noch reicht. Ich bin auch kein Fan Netzteile in Dimensionen großer zu kaufen als man sie benötigt. Alle paar Jahre kommt eh ein neuer Standard, Stecker oder sonst was.
@SH 2-4x faster :fresse:
Das stimmt schon. Aber wenn die Erkenntnis "Ok diese Schutzschaltung war leider Schrott" dann halt mit weiterer toter teurer Hardware einhergeht, dann nützt mir diese auch nicht mehr viel. Daher gehe ich eher davon aus, daß sie im Zweifel nicht funktioniert und freu mich dann wenn sie es doch getan hat :) Und ich wollte auch nicht sagen das jeder das so wie ich machen sollte, es gibt gute Gründe das wie HisN oder Du zu sehen. Ich wollte eigentlich nur meine Philisophie vorstellen, weil HisN wissen wollte warum man das macht ;)
Aber ich habe auch ein Corsair AX1600i in meiner Kiste. Ich würde ansonsten auch kein ATX 2.3 Netzteil mehr kaufen, jetzt kurz bevor ATX 3.0 den Mark erreicht. Die Zeit würde ich auch notfalls mit einem älteren Modell noch überbrücken, nur um eine neue Grafikkarte nicht rumliegen lassen oder deren Anschaffung verschieben zu müssen. Ein paar Wochen oder Monate erhöhen das Risiko jetzt ja nicht mal für meine Sichtweise signifikant. Aber OC Versuche würde ich wahrscheinlich dann eher nicht mit dem alten Netzteil machen :d
@Holzmann
20.000 Punkte in Timespy Extreme bzw. DX12 Rohleistung, wäre ein krasser Wert aber wohl auch mit guter Kühlung und 3 Ghz Takt.
Zum Vergleich, meine sehr gut gehende 3080 @ 2Ghz schafft dort nur etwa 9.500. https://www.3dmark.com/3dm/77752200
Was dann wohl im TS non extreme geht 30.000 oder gar viel mehr? 8-)
Für welche 4090 habt ihr euch entschieden?
Ach du sch... ist die Strix lang!!! :oops:
~35,76cm vs 31,85cm (<-3090 Strix OC)
Noch gar nicht. A erstmal Tests abwarten B welche Karte RefDesign hat/BlockKompatibel ist C sich die PT Geschichte geklärt hat
Ich habe mich für eine Founders Edition entschieden….
Allerdings weiß ich nicht, wo ich eine kaufen kann…
Ich dachte an NBB aber diese stehen nicht auf der Liste. Werde wohl über den NV Shop gehen…
Wäre meine erste Founders Edition seit Jahrzehnten 💁🏽
Gibts irgendwo eine aktuelle Übersicht aller Hersteller, die einen Kühlerwechsel erlauben?
Bei CB gabs mal eine. Finde sie aber nicht (noch aktuell?)
Bezüglich Kühlrr Umbau wäre schön wen Hardwareluxx da mal nach hacken könnte und eine aktuelle Liste erstellen würde .
Welcher Hersteller wird Referenz?
ALC verkauft schon Ref-Blöcke. Die müssten ja wissen, welcher Hersteller das ist. Oder gilt da auch noch NDA?
Wäre schon komisch, da es ja Blöcke für ZOTAC gibt...
Oder bei Ali (nur ZOTAC)...
Ich habe die erste Seite mal mit momentanen Leistungen geupdated.
Frage an alle. Was wollt ihr noch gerne für die erste Seite haben?
Wakü Übersicht?
Powerlimit Übersicht jeder Karte?
Etc...
PT wäre sicher nicht schlecht. Blöcke Übersicht könnte man verlinken.
Noch kann ALC nichts sagen. Wohl weil man nicht zu allen Herstellern Beziehungen hat.
Wenn ich das so lese, wird ZOTAC höchstwahrscheinlich Ref. sein
btw:
Seltsam, dass Byksky.de noch keinen 4090-Block aufführt, aber ezmodding.com schon
Wakü Übersicht?
Etc...
Jup Powerlimit REF FE Custom und Wakü wäre Top
  • Danke
Reaktionen: SH
Zotac=Ref 93,7% :-)
Immer schön ins imprint schauen 8-)
btw:
Zotac hat wohl leider kein ref pcb. Bohrungen und die größe des Pcbs passt nicht
Schaut euch genau den Abstand vom 12vhpwr zur Schraube an
12 Oktober, 15 Uhr ist start.
NBB ist die erste Anlaufstelle für die FE, weiß nicht ob NV überhaupt auf der Seite für DE verkauft.
Ähnliche Themen
