[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das meine ich gar nicht, aber es ist sinnfrei jetzt solche Stecker zu entwickeln, wenn man die Ursache noch gar nicht kennt.
Natürlich kennen wir die Ursache.
Man kannte schon die Ursache bevor die RTX 4090 überhaupt auf dem Markt kam. Einige Hersteller hatten davor schon gewarnt.
Der Adapter ist einfach minderwertig. Der Anschluss an sich ist nicht das Problem. Wenn man es schafft die Kabel sicher in den Pins zu fixieren, sollte es auch keine Probleme geben. Bei meinem nativen Kabel von Thermaltake sieht das alles sehr viel besser und fester aus
Würdet ihr sagen das kann zum Problem werden? Konnte das einzelne Kabel ca. ~0.5mm reindrücken, fühlte sich jetzt aber nicht locker an. Lieber auf das Adapterkabel ausweichen und zurückschicken?
Reinstecken, bissel wackeln, schauen dass der Stecker schön gerade sitzt und auch das Kabel hintenraus eben erstmal noch gerade raus läuft bevor es geknickt wird, schauen dass kein seitlicher Druck auf den Stecker kommt dann die Karte auf 600W frei lassen und nen Benchmark mal für 30 min laufen lassen. Wenn man unsicher ist ggf auch 1h. Während dem Benchmark prüfen ob der Stecker heiß wird.
Ich denk tendenziell kann jeder Stecker Probleme machen. Da liegen ja nur ein paar Metallkontakte nebeneinander und berühren sich.
Von daher Stecker rein, schauen dass er sitzt, 600W benchmark, Temp messen und wenn alles gut ist nie wieder anfassen! :fresse2:
Mittlerweile habe ich kein Bock mehr auf die neue Generation weil die Händler einfach nichts gegen Botter gemacht haben.
So bleibe ich bei der 3080
Ja ich versuch auch schon seit knapp 2 Wochen an eine 4090 Strix zu kommen aber pustekuchen ... aber je länger das dauert umso einfacher fällt es mir nun zumindest noch auf die AMD Präso zu warten
um zu schauen was diesmal AMD so hat .. is ja nur noch etwas mehr als 1 Woche.
Und AMD scheint wohl bei dem alten Power System zu bleiben damit währe NVIDIA alleine da auch Intel ja auf dem alten Power System geblieben ist :
Also nachdem ich die letzten Tage sehr heiss auf die 4090 war denke ich nun immer mehr nach erstmal noch 1 - 2 Wochen abzuwarten was bei AMD so kommt
und wie sich das mit dem Power Adapter so entwickelt ... in 2 Wochen 3 Fälle mal schauen wie das in weiteren 2 Wochen aussieht.
Weiß einer wofür das BIOS Update für die TUF ist ?
Steht doch extra bei :
Die haben damit noch nie aufgehört.
Wartet doch bis nach dem 3. November ab, dann hat AMD die 7000er Serie angeboten, und alles wird billiger.
Das glaube ich erst wenn ich es sehe, ich vermute das absolute Gegenteil wird eintreffen...
Dazu wird die Karte lediglich vorgestellt am 03.11, zu bestellen ist sie wohl erst ab Dezember:
Ja gut das kann ich ja nicht wissen. Bild aus Rechner hat mich darauf schließen lassen. Sorry.
Ich hatte schon Pins die beim Reindrücken rausgekommen sind. Das waren keine 12VHPWR Stecker. Kann leider immer passieren. Hier wohl besonders leicht. Evtl. sind die zu weich oder Chargenfehler. Wird sich zeigen.
Ja das ist dann aber ein Produktionsfehler die Kontakte waren dann nicht richtig bei der Herstellung eingerastet oder sind evtl. sogar defekt und müßten getauscht werden. Passieren kann das natürlich. Wenn ich Kabel Sleeve gehen mir auch immer ein paar Kontakte kaputt die dann neu gemacht werden müßen. Aber ist halt ein Defekt / Fertigungsfehler und kein Normalzustand oder Anwenderfehler.
Ja super dolle Info .
Spannung im Idle schonmal von 0,875 auf 0,88V erhöht worden.
Konnte vorhin zum Glück vor der Arbeit eine Suprim X bei MF bekommen. Habe auch schon eine Sendungsnummer erhalten. War zwar etwas teuer aber nun habe ich hoffentlich den Stress nicht mehr, da ist mir der Aufpreis dann egal. Wie ist denn die Verpackung bei MF? Hatte von Amazon mal eine Karte, da wurde das Etikett nur auf den Produkt Karton geklebt. Da ich sonst nur bei Alternate zur Abholung bestelle, weiß ich daher leider nicht, wie MF alles so handhabt.
Edit: Ich schaue nach der Arbeit mal meine BeQuiet Kabel an, konnte aber so etwas bei meinen Kabeln auf den ersten Blick nicht erkennen.
Das VBIOS Update der 4090 TUF / Strix verbessert halt die Compatiblität mit anderen Geräten .. steht doch da auch mit bei
wir wissen doch zb das es Probs mit den neuen AMD Boards gibt wo manche ein Bios Update brauchen
ich glaub in diese Richtung geht das VBIOS Update der TUF / Strix auch so interpretiere icch zumindest das was ASUS da selbst schreibt ; "Update VBIOS to improve compatibility"
Daher ja "super dolle info"
Nichts versiegelt, nichts eingeschweisst.
Könntest Du das bitte etwas konkretisieren? Mir ging es nur um die Umverpackung. Da heute auch Liquid X verfügbar waren, denke ich, die haben eine neue Charge bekommen. Sollten also keine Rückläufer sein. Waren ja auch echt viele Karten verfügbar.
Die MSI Kartons sind offen. Meine Suprim war auch nicht versiegelt, im Gegenteil. Das Adapterkabel war in einer aufgeschnittenen Plastiktüte.
Für mich sind das alles Rückläufer. Warum sollten nur vereinzelte Karten neu bei den Händlern eintreffen?
Entweder schreien die zuviel oder Scalper konnten die nicht verkaufen...
Alle 2 Wochen gibt es neue Rückläufer von Scalper... da der 12.10 Release war, sind die ersten 2 Wochen so langsam um.
Proshop verkauft jetzt "DEMO" Grafikkarten. Da würde ich persönlich Rückläufer erwarten...
Zwei Wochen nach Release würde ich jedenfalls nicht kaufen. Aber ich bin auch paranoid.
Karte kommt gut verpackt an. Da brauchst Du Dir keine Gedanken zu machen.
Als wenn die auf dem Originalkarton einfach so ein Sendungslabel drauf hauen und verschicken würden? :rolleyes2:
Dann hoffen wir mal, dass mit der Suprim alles in Ordnung ist und sich der Zuschlag von 230 Euro (für nichts) gegenüber meinem Kauf am 13.10. gelohnt hat.
Immerhin deklarieren sie diese als solche mit einem Preisnachlass. Bei anderen bekommt man solche Karten zum Normalpreis.
zur Reklamation des 12VHPWR Kabels habe ich folgende Information von bequiet! erhalten
Die 4090 hat das Problem mit dem Heizen im Winter einfach gelöst
Thja dann hast du wohl nicht alles mitbekommen
Ähnliche Themen
