[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die MSI Kartons sind offen. Meine Suprim war auch nicht versiegelt, im Gegenteil. Das Adapterkabel war in einer aufgeschnittenen Plastiktüte.
Für mich sind das alles Rückläufer. Warum sollten nur vereinzelte Karten neu bei den Händlern eintreffen?
der Karton ist offen aber die Karte selbst ist in schutzfolie mit einem schwarzen Klebeband zu
zudem sind noch überall schutzfolie auf der karte auch auf den 3 Lüftern
Konnte meine 4090 FE jetzt ordentlich testen, nachdem ich ne Woche nicht Zuhause war. Der Core ist relativ gut, Mem eher solala.
Timespy läuft mit +300 Core und +1000 Mem durch (bei 1250 schmiert bereits der Desktop ab, Core komm ich damit an die 3130mhz). Alles andere ist nur noch bei ca. +280 Core und +750 Mem stabil. Betreibe die jetzt mit Curve UV 2565mhz@0.875V und +750 Mem. Ist damit immer noch grob 80% schneller als meine alte UV 3090 und verbraucht sogar weniger. (3090 war bei 300-330W, die 4090 jetzt bei 250-280W) Alles darüber stürzt in Spielen zwar nicht ab, erzeugt aber hier und da Grafikfehler/Artefakte.
Kann mich aber, trotzt Temps unter 60C bei minimaler Lüfterdrehzahl, nicht von meiner Wakü verabschieden, finde die +-1000 min RPM immer noch deutlich zu laut, bin aber auch 300RPM Lüfter gewöhnt.
Spulenfiepen ist subjektiv deutlich leiser als bei meiner alten 3090 Stix OC, kann aber auch an den lauten Lüftern liegen.
PS: Idle Verbrauch der 4090 ist bei mir niedriger als bei der 3090. 3090 hatte bei 4K240Hz 55-60W verbraucht, die 4090 jetzt 40-45W.
Idle der FE ist hier bei 15-17W. Irgendwie ist das Teil zu hoch bei dir?
Najaaaaa das ist ja sowieso klar... die werden schon die Info haben, dass da was nicht stimmen könnte. Da muss jetzt eh erstmal geprüft werden, bevor da wieder was verschickt wird. Wäre ja Unsinn dir ein weiteres "defektes" Kabel zu schicken.
das ist ja auch so in Ordnung.
WICHTIG: ist einfach zu kontrollieren das das aufgesteckte 12VHPWR kabel sauber in der Buchse sitzt und keine Steckkontakte hinten rausgedrückt werden, das sieht man ja wenn man es kontrolliert.
das ist abhängig von der verwendeten Auflösung und Bildwiederholrate, ich habe auch 25W im Idle.
Ok, sind bei mir 3440x1440 und 144Hz, 10bit.
Klar, wenn ich Browser usw anwerfe, dann steigt die Shice, aber habe dann auch nicht moar als 25-27W.
Schätze mal Userfehler.
Geknickte Kabel in einem PC haben niemals "Userfehler" zu sein. Das ist dann ein absoluter Fail by Design und nichts anderes. Ganz davon ab, dass den Karten auch kein Hinweis beiliegt, dass man das Kabel nahe am Stecker nicht knicken soll.
Es war bekannt, dass man die Kabel nicht zu stark knicken soll und zwar genau aus diesem Grund. Bezüglich des Hinweises gebe ich dir allerdings recht. Der sollte dabei liegen.
Das ist falsch. Kabel sollten gar nicht geknickt werden, das ist ÜBERALL so. Das führt zum Kabelbruch im schlimmsten Falle.
Wenn du ein Kabel um 90° oder 180° biegen willst, solltest du immer einen ausreichend großen Radius haben.
Warum gibt es z.b. bei vielen USB Kabeln eine Gummi-Ummantellung am Stecker? Damit man den nicht zu stark knicken oder rausziehen kann...
Warum es also sowas nicht beim 12VHPWR gibt? Ka...
Das ist der eigentliche Punkt. Die Adapterkabel sind nicht sauber gemacht, wenn sie dort wo sie nicht geknickt werden dürfen trotzdem geknickt werden können.
wäre ein Schrumpfschlauch oder Sleeve über dem 12VHPWR Stecker, kannst Du nicht mehr erkennen ob einer der Pins nicht sauber eingesteckt ist.
-> es währe mir zumindes dann garnicht aufgefallen das einer der Kontakte nicht sauber gesteckt ist.
ein vergossener USB Stecker ist nunmal nicht mit einem Pin-basierten Stromkabel vergleichbar.
Stimmt schon,wenn sich jedoch der Stecker durch das Eigengewicht auflöst passt etwas nicht.
Lausig konstruiert und im schlimmsten Fall (Wohnungsbrand oder gar Personenschaden) werden sich damit Gutachter befassen...
Wie werden sich diese Stecker auf Zeit verhalten?Bei 40-50°C im Case?Immer leicht unter Zug mit dem Gebimmel?
Na also, wenn du dir den Beitrag von Gamers Nexus zu dem Thema jetzt angeschaut hast, dann kennst du jetzt die möglichen Ursachen
Ah Userfehler? Wirklich? Du meinst der ungebildete 0815 User weiß wie und wo er die Leitung des Adapters knicken darf? Steht es irgendwo auf der Verpackung? Gehst du davon aus dass alle ausgebildete Elektrofachkräfte sind und keinen Hinweis benötigen?
Ich weiß, du weißt es, wir alle wissen es. Für mich ist es als wenn man seit über einen Monat einen Zug gegen eine Wand fahren sieht. Es war von Anfang an vorauszusehen, insbesondere vor dem Hintergrund, wo sich die Buchse auf dem PCB befindet in welche Richtung sie positioniert ist und wie klein so manches Gehäuse auf einmal geworden ist.
Meiner Meinung nach, hätte man sogar noch weiter gehen müssen und die PCI-Sig nvidia und alle Board Partner dazu verdammen müssen, Adapter mit einem gewinkelten Stecker bereitlegen zu müssen.
In gewisser weise schon, ja. Darüber wurde massiv berichtet und es war bekannt, dass der Biegeradius nicht zu klein sein darf und der Stecker für max. 30 Zyklen konzipiert wurde.
Das sind aber keine 0815 User, sondern Posts von Reddit und dort ging die Warnung der PCI-SIG rum.
Der 0815 User meldet sein Problem nicht als erstes auf Reddit.
Ja, das ist natürlich ne Sauerei. Der unwissende 0815 User hat keine Ahnung und knickt es einfach. Man hätte mindestens ein Hinweis auf der Box oder in Form eines Zettels beilegen müssen.
Oder die Steckverbindung so positionieren das diese Probleme nicht existent sind.
Da werden noch einige Leute welche nicht in Foren aktiv sind mächtig Spass haben.
Hab mal das Kabel und Stecker mal angefasst während Bf2042 lief.
Habe das von Corsair und es war wirklich nur lauwarm .
Vielleicht hat sich Corsair auch was bei gedacht dieses Kabel eher als flaches Kabel ohne es zu sleeven anzubieten .
Finde es immer noch seltsam, dass nur ein einziger Hersteller (Thermaltake) es zur Zeit geschissen bekommt ein ATX 3.0 NT anzubieten… dabei gibt’s doch nun wirklich nicht wenige Hersteller da draußen.
Muss ja nicht unbedingt ATX 3.0 sein, den 12HVPWR Anschluss haben auch noch andere Hersteller mit ATX 2.x im Programm.
ATX 3.0 ist halt noch neuer als der Stecker selbst ^^
Welches ATX 2.x Netzteil hat den einen 12HVPWR Anschluss?
Das hier:
Oder das teurere Asus:
Ähnliche Themen
