[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
so meine 4090 Founders Edition ist zerlegt und gereinigt ...
Aha, siehe da, habe Geforce Experience runtergeschmissen und nun wagt sich die Gaming OC auch auf über 65c und läuft deutlich ruhiger. Ich denke mal da hing irgendein Temp Target oder eine Lüftereinstellung schief. Einen wirklichen Unterschied zwischen Silent/OC-BIOS höre ich jedoch immer noch nicht. :unsure: Beide Modi nach 15 Min Hitman 3 (für gute CPU und GPU-Last) auf 80% Fan Speed und 70c.
Gerade meine Gigabyte Gaming OC eingebaut und getestet. Wesentlich ruhigere Lüfter als die KFA2, die ich hatte und Spulenfiepen auf identisch leisem Niveau. (Evtl. die Gigabyte sogar noch etwas leiser. Das Rasseln nehme ich hier gar nicht wahr) Was mir jedoch aufgefallen ist, ist, dass sowohl OC- als auch das Silent-BIOS sich scheinbar gleich verhalten. Lüfter gehen auf ca. 1800rpm hoch und halten 65 Grad. Ist der Default das OC-BIOS? Laut Kartenbeschriftung müsste es so sein. Kann jedoch keinen Unterschied zwischen den beiden feststellen. Lässt sich irgendwie herausfinden welches BIOS gerade rennt?
tippst du die auch im anderen Thread ein? Das wäre dann 1:1 bei Rasseln etc.
Gibt´s eigentlich einen Grund wieso NBB die FE nur mit Hermes verschickt? Die bieten ja grundsätzlich auch andere Dienstleister an. Habe schon Bauchschmerzen bei Hermes :ROFLMAO: Mal sehen aus welchem Blumenkübel ich die Grafikkarte dann ziehen kann
....diese Maden ey
Naja, komischerweise geht das nur mit der FE, weil scheinbar immer noch genug Leute unbedingt viel Geld ausgeben wollen für die FE.
Die Gainward ist ab 2000 € NEU gelistet zur Abholung. (Will nur scheinbar keiner)
Und man kann an EKA sehen, wieviel FEs wirklich ungefähr verkauft wurden :ROFLMAO:
Hab heute den ganzen Tag versucht eine Karte der Drops bei Saturn zu holen, aber komme auch nur bis zum Warenkorb, falls überhaupt.
Probiert bei ASUS GeForce RTX 4090 TUF Gaming OC und der MSI SUPRIM X
habe den Ticker die ganze Zeit auf und habe nach 1-2 Sekunden auf den Link geklickt - war scheinbar dennoch immer zu langsam - da wird sicherlich mit Bots gescalpt, oder?
Hab meine letzten Eindrücke schon in den Thread geschrieben. Die Karte ist auf jeden Fall nochmal besser als meine KFA2. Habe einige Spiele jetzt von 90 bis 180 fps laufen gehabt ohne quasi auch nur ein Geräusch zu hören. Ich denke das wird die Varianz sein. Einige haben hier ja auch gesagt, dass sie ihre KFA2 nicht hören. Meine KFA2 lies sich hingegen schon vernehmen. Im Endeffekt sind die wahrscheinlich im Schnitt identisch, meine Gigabyte jedoch besser, deswegen berichte ich das auch so.
Bei mir lag der NBB Karton neben den Mülltonnen, wir sind aber ein Haus mit nur 2 Familien, daher ging das... trotzdem frech nicht mal zu klingeln :fp
Lustig, am Release-Tag war die TUF recht einfach zu bestellen bei MM und Saturn.
EK-Quantum Vector² FE​
Am release Tag konnte man einige Karten ziemlich gut ergattern.
Nur bei der FE hatte ich keine Chance.
Jeder zweite hier im Thread will ja auch eine FE, obwohl schon eine andere 4090 im PC verbaut ist...
So, eben noch fix bei CableMod nen 3x8-Pin auf 1x12-Pin (oder 1x12+4 Pin/12VHPWR) Kabel bestellt. 15€ Versand für ein 25€ Kabel... lustig, sich bei ner 2000€ Karte darüber aufzuregen, aber ich war trotzdem kurz sauer :d Den Nvidia-Adapter würde ich mir schon aus rein ästhetischen Gründen nicht antun wollen :d
@***** Korrigiert, nur für dich :P
Hätte mal ne Frage. Habe das Bequiet straight Power 11 und wollte mal meine 4090 einbauen.
Bin gerade ein bisschen verwirrt wo ich die jetzt am Netzteil anschließen soll. Habe 1x 12pin auf 2x 6+2 Pin und 2x 8pin auf 8pin Kabel.
EK-Quantum Vector² FE 8-)
genauere Daten zu Temperatur usw. sowie OC Test werde ich sobald ich Zeit finde gerne noch liefern.
Ähnliche Themen
