[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Und warum ist der BMW mit auf dem Foto? :d War die Flex im Auto?
Das war das einzige Foto in Nahaufnahme😂 Schwiegervater hielt die Flex und ich zog das Teil drüber. Passt wie ne Maßanfertigung in 2 min.
(Ps natürlich mit Augenschutz wg fliegender Teile)
Passt den der Adapter ohne jegliche Einschränkungen für die FE?
Nicht dass ich jetzt OC vor hätte was anscheinend doch nur mit den 4x8 Pin Adaptern gehen sollte.
Aber gibt es denn sonst irgendwelche Nachteile, werden Lasten vielleicht nicht richtig verteilt?
Ich brauche auch sowas für die Optik, hab mich da leider aber noch nicht informiert.
Danke
Berechtigte Frage.. hab' da jetzt ehrlich gesagt nicht groß recherchiert. Jay (Jays2Cents) hatte die Teile neulich in irgendeinem Video kurz vorgestellt, daher werden die schon passen. Für die 3090Ti gab's die ja glaube ich auch schon, und die Anforderungen an das Kabel sind ja mehr oder weniger identisch bei der 4090 (non-OC).
Ich probier's einfach mal aus. Je nachdem, wann das Kabel ankommt, kann ich ja nochmal berichten (wenn ich nicht dran denken sollte, gerne PN an mich). Da ich nicht vorhabe, die Karte (und die Spulen) mit 600W zu quälen, hab' ich mich für das 3x8-Pin entschieden. Werde die Karte eh undervolten, damit ich Richtung 300 oder 350W komme.
Wird schon schief gehen :)
hier mal ein Time Spy Extreme 100% PT mit dem EKWB EK-Quantum Vector² FE
Mora 500rpm / Pumpe bei 60% Leistung
Water-in: 24.2
Water-out: 27.5
Wenn du jetzt noch die Wassertemp verrätst^^
Versuche meine suprim liquid x zu übertakten, aber bei knapp 2970 MHz ist Schluss (1,1v und 600w/125% pt). Kann mir nicht vorstellen, dass sie keine 3ghz packt.
Hat noch jemand Ideen, woran es liegen kann? Gibt es irgendwo nen Vergleich, was andere hier so geschafft haben, bei welchen settings? (thread habe ich bereits durchsucht, das ist leider nicht so zielführend)
Klingt aber plausibel. Die muss nicht unbedingt 3 ghz schaffen.
Kannst eigl nur spannungsregler, power limit und mhz anheben. und natürlich kühlen, damit sie nicht runtertaktet.
Ok ich hab kein Sichtfenster. Insofern 1 luxusproblem weniger
Water-in: 24.2
Water-out: 27.5
Wenn du gute Laune hast und du daran interessiert ungefiltert Infos an die Leute weiter zu geben wäre einmal Benchmarks durchführen oder besser mal ein anspruchsvolles Game zocken und mal HWINFO im Hintergrund laufen lassen .
Da sieht man Package Power und Temps der GPU und Vram und Spannungen etc.
Dazu gerade noch deine AB Einstellungen dazu posten bzw. mit in den Screenshot packen . Hier scheint eh GPU Z misst anzuzeigen , weil Hot Spot kälter als GPU Temp .
Die einzigste Info sind die 20 Kelvin Delta .
Also etwa das was ALC und Optimus auch haben sollen bei 450 Watt PL .
Water-in: 24.2
Water-out: 27.5
Also ein Delta von ca. 20 Grad zw. Wassertemp und Chip Temp. ist glaube ich relativ hoch, hängt aber auch von den Watt ab, die da durch gehen, bei dir ja mit 5K entsprechend hoch.
Denke das ist in Ordnung aber mal sehen was die Experten sagen ....
Ich denke auch das passt
Gleiches Testscenario wie bei dem Der 8auer (RTX 4090 ICHILL Frostbite) mit MoRa, er hatte 46Grad bei sogar geringerem takt
nee 20K sollen diesmal normal sein, weil der Großteil der Poweraufnahme wohl an den Chip geht als an den heiß laufenden Vram wie noch bei Ampere. Deshalb hatte Ampere so niedrige Deltissimi
20° Delta sind bei 450W+ und 1,1V durchaus normal. Bei 300W sinds noch rund 10-15°.
Ein ähnliches Delta wird auch ne Suprim Liquid auf dem Chip halten, nur steigt dort die Wassertemperatur eben schneller an, womit man dann bei internem Radiator je nach Case und Raumtemp irgendwann eher bei 55-65° landet.
Delta vom Speicher würde mich bei dem Quantum Vector und auch bei der MSI Liquid (hier einfach im Verhältnis zur Chiptemp, Wassersensor wird die ja keinen haben) interessieren. Könntet ihr das mal mit hwinfo bei Gelegenheit checken?
20k Delta is nix, noch nie ne Volta gehabt was? ^^
das sind alles Heizelemente und sonst nix
Dadurch, dass jetzt doch kurzfristig die 4090 ins System wandert und ich die FE ehrlich gesagt zu schön finde um sie auf Wasser umzubauen (und der LuKü bei UV wohl auch mehr als ausreichend dimensioniert ist), musste ich jetzt noch fix nen gescheiten Kühler für den 5900X kaufen... WaKü dann bis auf weiteres erstmal nicht mehr, schätze ich. Außer, mir ist das alles wider Erwarten doch zu laut :d
Wird einiges an Bastelei am WE... Loop leer machen, Radis raus & Lüfter abnehmen, Luftkühler für CPU montieren, Lüfter wieder rein... was ein Stress :d
Dabei war das alles so gar nicht gelpant! :d
War mir zuviel. Ich hatte alles da um auf Luft zu gehen. Aber keine Lust gehabt alles umzubauen. Wobei ich das sicher gemacht hätte wenn ich nicht die Karte mit dem passenden Block direkt bekommen hätte.
Kann ich nachvollziehen. Eigentlich wollte ich erstmal die RDNA3 Präsi morgen abwarten, und dann ggf. die Inno3D mit dem vorinstallierten Block kaufen, sollte abzusehen sein, dass die 4090 für AMD nicht zu knacken ist. Aber die FE find' ich so schön, dass ich die ehrlich gesagt nicht umbauen möchte. Irgendwo bescheuert, schätze ich, aber was solls... immerhin mal wieder ein Grund, das Setup zu überarbeiten :d Auf der einen Seite eigentlich gar kein Lust, das alles anzugehen, auf der anderen Seite macht's halt trotzdem irgendwo Bock... verrückt.
Echt schade das man keine 2 Kurven / je eine pro Controller basteln kann.
Das geht ja doch. Warum sagt mir das hier keiner? Musste ich mir erst ne Schelle von Unwinder himself abholen um die Funktion zu finden :bigok:
Der Typ geht auf keine Kuhhaut. Hat ein gutes Tool entwickelt, aber man man man...
Na dann lass knacken wieviel denn? Ich könnte jetzt mal mein Tabellenbuch rausholen ;-) Bin aber mit 0,35NM gut gefahren bislang.
Ich habe mal bei einem MB die M.2 Schraube beim LÖSEN abgeschert, weil die so fest war UND Loctite dran hatte... habe das Geld zurückbekommen beim RMA :d
@hithunter
Bietet nicht EKWB auch nen 0,6NM Schraubendreher an? :unsure:
Ähnliche Themen
