[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habe nur 1 das sich Splittet auf 2. Und jeweils 2 die auf 2 gehen. Der Adapter brauch doch 4 anschlüsse. Oder nicht?
Genau, das eine Kabel steckst bei PCIe1 oben rein, das andere bei PCIe 3 oben. Also die 12 pin Seite.
Wenn du nur 1 Kabel mit 12 Pin hast, fehlen dir irgendwie die richtigen Kabel. -> nachkaufen bzw gleich den 12HVPWR Kabel bestellen
Bekomme alle paar Tage ein Update von CU in der mir mitgeteilt wird, das sich die Lieferung vom be Quiet 12VHPWR verspätet. Einerseits toll informiert zu werden, aber habe im Gefühl das es wohl ewig dauern kann. :/
Wollen halt alle haben das Ding... finde es aber extrem schwach von den PSU Herstellern, dass die darauf nicht vorbereitet waren. Der Release der GPU ist ja nicht erst seit gestern bekannt, man hätte die Produktion schon vor Monaten starten können.
Oder die haben technische Probleme gesehen und wollten erstmal abwarten, ob NV so dumm ist und weiter auf das neue Kabel setzt.
Man weiß es nicht genau ...
Silverstone HELA. Aber war sowieso ein unüberlegter Kauf. ToughPower ist günstiger und Loki auch. Werde wohl was anderes nutzen.
immerhin hat das Silverstone genug PCIe Anschlüsse am Netzteil, wenn man je nachdem der CPU da zwei gibt würden immerhin noch 3 übrig bleiben :d, das ist beim Loki nicht der Fall (falls man ne Karte ohne 12+4 VHPWR nutzen will)
Und theoretisch dürfte das Silverstone auch "nur" 450W über den 12+4 VHPWR Anschluss liefern, wenn es ATX 3.0 Konform ist. Ich warte wohl auf die Seasonic Vertex :<, das Toughpower scheint mir recht "laut" zu sein.
Ach so, falls es wen interessiert: Die GPU-Halterung der Gigabyte Gaming OC passt nicht in das H7 Flow, da die weiße Leiste im Weg ist. Des Weiteren kollidiert die Halterung mit dem USB-C Frontpanel-Anschluss vom Z690 Tomahawk.
eventuell lianli Gb001/gb002 probieren
das machste am board fest und ist praktisch unsichtbar
so ein kleiner ständer von asus wäre auch praktisch :)
Oh, mir ist wieder eingefallen, dass ich den beiliegenden Ständer nicht installiert habe, weil ich ihn erst nach der Installation der GPU bemerkt habe. Wird aber wohl nicht sooo schlimm sein, oder?
viel zu viel für eine M3 Schraube, das sind über 1 kN Vorspannkraft.
Na dann lass knacken wieviel denn? Ich könnte jetzt mal mein Tabellenbuch rausholen ;-) Bin aber mit 0,35NM gut gefahren bislang.
Hab die Annahme jetzt verweigert. Können das Ding morgen zurückschicken. Ich bleibe erstmal auf dem BeQuiet Straight Power 11 Platinum und hole mir einfach das Kabel wenn es das gibt. Bisher ist mit dem Adapter ja alles super.
  • Danke
Reaktionen: hwk
So, eben noch fix bei CableMod nen 3x8-Pin auf 1x12-Pin (oder 1x12+4 Pin/12VHPWR) Kabel bestellt. 15€ Versand für ein 25€ Kabel... lustig, sich bei ner 2000€ Karte darüber aufzuregen, aber ich war trotzdem kurz sauer :d Den Nvidia-Adapter würde ich mir schon aus rein ästhetischen Gründen nicht antun wollen :d
@***** Korrigiert, nur für dich :P
Passt den der Adapter ohne jegliche Einschränkungen für die FE?
Nicht dass ich jetzt OC vor hätte was anscheinend doch nur mit den 4x8 Pin Adaptern gehen sollte.
Aber gibt es denn sonst irgendwelche Nachteile, werden Lasten vielleicht nicht richtig verteilt?
Ich brauche auch sowas für die Optik, hab mich da leider aber noch nicht informiert.
Danke
Also die MSI Liquid ist auf jeden Fall die Karte mit dem besten Kühler. Die Waterforce mit dem 360 Radi war schlechter gewesen in den Temps
Das mag für einen Benchmark lauf passen für Gaming betrieb sicher nicht .... Pumpe ist bei der Gigabyte allerdings auch leiser vielleicht lags daran...
Haupt unterschied ist allerdings das bei der Gigabyte alles mit Wasser gekühlt wird, bei der MSI hast nen sep. Lüfter auf der Karte, oder?
Hätte mal ne Frage. Habe das Bequiet straight Power 11 und wollte mal meine 4090 einbauen.
Bin gerade ein bisschen verwirrt wo ich die jetzt am Netzteil anschließen soll. Habe 1x 12pin auf 2x 6+2 Pin und 2x 8pin auf 8pin Kabel.Anhang anzeigen 811200
PCIe 1 und 3 ...
Ich hab die Halterung ein wenig abgeflext und tataaaa sie passt. Bissl Do it yourself spirit😂
PS jetzt sehe ich das mit der weißen Leiste. So passt sie jedenfalls auf das Strix z690a und ein Define. Lackieren müsste ich sie noch.
Da tolle B-Ware :d
@hithunter
Also so schlimm sind 0,35 denke ich nicht und 0,5 auch noch okay ...
0,6NM wären dann ca. 1,05KN was für ALU Schrauben 5.6 noch okay ist ....
Wie gesagt zwischen 0,35 und 0,5 macht man nicht viel falsch ... erstmal mit 0,35!
Und wie war das ...
Nach ganz fest, kommt ganz ab.
:ROFLMAO:
Besser als jede Schraube von Hand unterschiedlich ...
Ähnliche Themen
Antworten
6K
Aufrufe
381K
